Thread: 1984 Project Car for sale
    Jul 2015
    Philadelphia
    Default 1984 Project Car for sale
    Hi all,
    I have a 1984 Monte Carlo SS for sale. The car was completely stripped down, the frame was then powder coated black. All new body mounts were installed. All new suspension parts were also installed, minus the front upper and lower A-arms. Rear lower control arms are box style, while the rear uppers are tubular. This also includes all the front linkage components. All new bushings and ball joints were installed. All the suspension parts come from Spohn Performance, powder coated red. Front and rear sway bars are 1-3/8 inch and 1 inch respectively.
    The front and rear springs are Hotchkis one-inch drop springs, and the shocks are Bilstein. It has new front brakes, including the calipers. New booster and master cylinder as well. New rear brakes are still in box. Also all new brake lines including the flex hoses are still in box also. She currently has a 350 and a th-700r4 trans, which needs a new input shaft. Also has 3.73 gears in the rear. All bolts and remaining parts are labeled and cared for. The car also has camaro rally rims with authentic center caps.
    The simple fact is that I need to sell her because my situation has changed and I can no longer afford to continue the build. I'm looking for $1800 but that is flexible. Email me and I can send you some pics if you would like. I can certainly answer any questions you may have. I have extra parts as well that will go with the buyer, no extra charge. I have a carb that can go with the car, but that will have to be added to the price. I have the headers for the motor, they go with it also. I kept all the receipts so should there be a problem with anything you have the record. Serious inquires only please.
    NE
    4
    Still for sale?
