Thread: Need Paint Codes
    Orlando, Fl.
    Default Need Paint Codes
    My 1986 Black over Silver 442 the rear bumper paint (silver) is peeling and flaking off.
    The door stickers are for vehicle weight and the other is for tire info.
    I do have the sticker inside the trunk on the under side of the trunk lid, thats about 4"X6" with several rows of letters and numbers. Starting with A-Z with a couple numbers after each letter. None seem to be any kind of match at all or even a partial match.
    In another thread here I found the codes : 12/WA 8535 poly silver 1985-86
    and 13/13S/WA 9021 also poly silver 1985-86, the last one starting with 13 appears to be the closest (its the lighter one), but with fading and all its really hard to judge.
    Also where to buy paint, I have Advance, Auto Zone, Pep Boys, and maybe a NAPA, local.
    I'm a little nervous about buying on line unless I'm sure I have the correct color.
    Any help is greatly appreciated...........
    1,265
    Go to a paint store and get a pint or spray can mixed up.
    The WA paint code is on your trunk RPO tag.
    Also your body tag will have the GM paint code on it. Should be 13 IIRC.
    Orlando, Fl.
    Thanks for the help.
    Found all the info on the metal cowl tag screwed to the cowl on the drivers side, Blues Pwr........
