Thread: Replacing Power Antenna on 84 H/O
    Jun 2016
    Rockford
    Default Replacing Power Antenna on 84 H/O
    Need some help replacing the power antenna on my 84 H/O like parts numbers, vendor, and procedure. Antenna powered down except for the last 6". Had to unhook battery as antenna motor continued to run even when key was in off position. Any help would be appreciated-
    Quote Originally Posted by Jbender View Post
    Nylon cable snapped, replacing it with another nylon cable is just going to be a temporary fix.
    I can permanantly fix the antenna for you if you like if you remove it and ship it to me, more info:
    http://www.gbodyolds.com/forum/showt...=4177#post4177
