For those who are familiar with factory power antennas know that even with NOS units and NOS replacement nylon cables that the nylon cable is still a ticking time bomb for drying out and cracking and shattering resulting in the motor constantly running.
I have special ordered a limited quantity of the correct diameter smooth flexible steel armor wrapped push-pull style cable to obtain a tight bend radius without kinking to replace the nylon cable and is better than the plastic coated steel braided cables that will still dry rot or expand as braided cable does over numerous push-pull cycles.
I will replace the cable in your antenna for $100 plus return shipping
Antennas will also be correctly riveted back together with brass eyelets as done in the factory.
