Thread: High Beam Stuck On
    Default High Beam Stuck On
    When we took off the steering wheel to tighten the tilt steering bolts the high beam plastic part that it slides on and off of broke. Now, months down the road and the high beams being off, the highbeams randomly are on and I cannot turn them off. Does anybody know a quick fix to this problem other than taking off the steering wheel again?
    13
    The dimmer switch is located about 18 inches down the column on the left side. You can actuate the switch by hand if it isn't broken. You can also bypass the switch with a short wire with 1/4 inch spade terminals. I have mine bypassed currently until I get a replacement.
