Thread: 1986 Original Paint
    May 2017
    Ohio
    Default 1986 Original Paint
    Was factory paint on a 86 Cutlass single stage or base/clear?
    May 2017
    Ohio
    Found an older post and it seems 86 and older was single stage. If anyone can confirm that would be awesome. Thanks
    May 2017
    Saskatchewan, Canada
    My unrestored, low km 1987 442 is single stage so that should help you out!
    My '87 442 was base/clear, GM changed in '87 I believe, I've seen many '87 442's with the clear coat peeling off...
