GbodyOlds.com
Results 1 to 4 of 4
Thread: 1986 Original Paint
    May 2017
    Ohio
    2
    Default 1986 Original Paint
    Was factory paint on a 86 Cutlass single stage or base/clear?
    May 2017
    Ohio
    2
    Found an older post and it seems 86 and older was single stage. If anyone can confirm that would be awesome. Thanks
    May 2017
    Saskatchewan, Canada
    1
    My unrestored, low km 1987 442 is single stage so that should help you out!
    1,260
    My '87 442 was base/clear, GM changed in '87 I believe, I've seen many '87 442's with the clear coat peeling off...
