Thread: Swapping a TH-350 for a TH-2004R
    Oshawa, ON
    Default Swapping a TH-350 for a TH-2004R
    I'm looking to go 4-speed with my 442 and ditch the TH-350.
    I'm running a stock Olds 350.anyone have any suggestions as to which TH-2004R is the best for my application?
    i.e. shift points, converter, required cross-member modification, etc...
    The BR or BQ from a turbo regal or GN is best from a stock point of view. The CZ or CQ from the MCSS and the KZ or OZ from the 442 are also very good for a starting point. Also the AA from a Cadillac is a good starting point.
    As for the shift points and TC stall of these trans' they vary, someone might be able to chime in on that but you can swap out the governors on them to get it to where you want it, Summit has kits for these and the stock OZ and KZ trans' have a 2400 stall converter.
    You will also need a new crossmember I believe.
    You will be able to keep your driveshaft but need a different crossmember and a frame extension, check out "Iceman's" products:
    http://www.maliburacing.com/iceman/
    Aug 2009
    HOUSTON TEXAS
    Go to 200raptor.com. They have a great deal on 200r4 transmisions & parts. They can build one to take 800+ hp. They are in booier city, louisiana. They one of best in the south. Give them try call. Hope it helps you
    texas oldsmorat
    1988 OLDS CUTLASS SUPREME CLASSIC
    496 BBC. KINSLER FUEL INJECTED ALCOHOL
    NO NOS. 14PT. CAGE,9"FAB REAR,4LINK,CLUTCH TURBO400. ALL STEEL BODY,EXCEPT HOODTUBBED,STILL FULL INTERIOR. NO TRAILER QUEEN HERE STREET LEGAL. 3,450LB.
    BEST 60FT. 1.20
    BEST ET. 8.82
    BEST MPH. 166.25
    TEXAS OLDSMORAT
