85-87 442
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: 78-88 Cutlass Interior Color RPO Code Index
    1,246
    Default 78-88 Cutlass Interior Color RPO Code Index
    Here is a quick list of 78-81 A body and 82-88 G body Oldsmobile Cutlass interior colors followed by the RPO code and the paint code for ordering purposes for those wanting to interchange or restore parts from other years to restore their interior, paint chips are here:
    http://www.78-88olds.com/forum/showthread.php?t=547
    There were only a few pieces that GM used these codes for:
    Dash, column, rear package tray, console plastic, console arm rest, dash lower column trim and speaker covers.
    Everything else was color molded.
    The semi gloss was used on the console plastic parts and arm rest, the top pad of the console body was color molded.
    Believe it or not the flat stuff was used on the dash and column I believe.
    I have seen low mile dashes and they are not shinny nor is the NOS Sage green one I have and just look at the lower column trim and speaker covers compared to the console plastic parts.
    It's a little misconception since everyone coats them in armor all...
    Rear package tray is flat.
    1978:
    ***Dark Carmine 74 (78-79) -2 years
    Ditzler #: S.G.: 72273, L.G.: 72291
    Dupont #: S.G.:45224, L.G.: 45243
    ***Dark Sage Green 44 (78-80) *Buckets/Console not offered in this color this year
    Ditzler #: S.G. 45245, Flat 45362
    ***Light Blue 24 (78-79) -2 years
    Ditzler #: S.G. 14782
    ***DarK Camel Tan 62 (78-80)
    Ditzler #: S.G. 24542, Flat 24530
    Dupont #: S.G.:45222
    ***White 11 (78) - 1 year only
    Ditzler #: S.G. 8855
    ***Black 19 (78-80)
    Ditzler #: S.G. 9387
    Dupont #: S.G.: 4428
    1979:
    ***Dark Willow Green 44 (78-80)
    Ditzler #: S.G. 45448, L.G. 45444
    Dupont #: S.G.:45863, L.G.: 45877
    ***Oyster 12 (79-80) -2 years
    Ditzler #: S.G. 90101
    Dupont #: S.G.:45220
    ***Black 19 (78-80)
    Ditzler #: S.G.: 9387
    1980:
    ***Dark Claret 79 (80, 85-88)
    Ditzler #: S.G.: 50994 L.G.: 50996
    Dupont #: S.G.: 44265 L.G.: C8019
    ***Dark Blue 26 (80-82) - 3 years
    Ditzler #: S.G. 15344, L.G. 15345
    Dupont #: S.G.:C8005, L.G.: C8014
    ***Black 19 (78-80)
    1981:
    ***Dark Maple 77 (81-84)
    Ditzler #: S.G.: 72415 L.G.: 72435
    Dupont #: S.G.: C8115 L.G.: C8129
    ***Medium Waxberry 45 (81) - 1 year only
    Ditzler #: S.G.: 82473 L.G.: 82497
    Dupont #: S.G.: C8108
    ***Medium Jadestone 47 (81-82) -2 years
    Ditzler #: S.G. 45589
    Dupont #: S.G.:C8112
    ***Light Sandstone 63 (81-82) -2 years, vinyl interior available in '81
    Ditzler #: S.G. 24899
    Dupont #: S.G.:C8105
    ***Medium Doeskin 64 (81-82) -2 years
    Ditzler #: S.G.: 24867 L.G.: 24980
    Dupont #: S.G.: C8110
    1982:
    ***Dark Redwood (Maple)77 (81-84)
    ***Dark Blue 26 (80-82) -3 years
    ***Light Slate Gray 13 (82) - 1 year only
    1983 -1984:
    Dupont #: S.G.: D8391 or Dupont #: S.G.: C8115 L.G.: C8129
    W12A7298 S.G. W5A7298 flat
    Medium MapleDitzler #: S.G.: 72568
    Very Dark Maple
    W12A8284 S.G. W5A8284 flat
    ***Dark Royal Blue 22 (83-84) -2 years
    Ditzler #: S.G.: 15632 Flat: 15682
    Dupont #: S.G.: C8385
    ***Light Sand Gray 60 (83-84) -2 years
    GM: WA7690
    Ditzler #: S.G.: 33567 Flat: 33617
    Dupont #: S.G.: C8384 Flat: C8384
    Medium Sand Gray (Console?) (83-84) -2 years
    Ditzler #: S.G.: 33568 Flat: 33618
    Dupont #: S.G.: C8329
    ***Dark Charcoal 18 (dash) (83-84) -2 years
    Ditzler #: S.G.: 33570 Rinshed Mason Semi: 13257
    W12A7350 S.G. W5A7350 flat
    Medium Charcoal (column?)
    Ditzler #: S.G.: 33569 Rinshed Mason Flat: 13195
    ***Medium Gray Fern 42 (83-84) -2 years
    Ditzler #: S.G.: 33586 Flat: 33619
    Dupont #: S.G.: C8327
    ***Dark Briar Brown 67 (83-84) -2 years
    Ditzler #: S.G.: 25306 Flat: 25229
    1985 -1988
    W12A4887 S.G. W5A4887 flat
    ***Dark Blue 27 (85-88)
    W12A8576 S.G. W5A876 flat
    Headliner: 1665 (shade too dark)
    ***Medium Sage 43 (85-87) *1985 was the only year for buckets/console in this color
    Medium Sage: W12A8583 S.G.
    Dark Sage: W12A8583 S.G. W5A8583 flat
    ***Medium Dark Gray 82 (85-88)
    W12A8247 S.G. W5A8247 flat
    Dark Gray: W12A8595 S.G. W5A8595 flat
    Headliner: 1810
    ***Light Saddle 62 (85-88)
    W12A7769 S.G. W5A7769 flat
    Med. Lt Saddle: W12A8806 S.G.
    Dark Saddle: W12A8257 S.G. W5A8257 flat
    Very DK Saddle: W12A8285
    Senior Member Fader's Avatar
    May 2011
    Omaha Nebraska
    141
    9
    Sweet....this a perfect resourceā€¦im gonna double check my rpo codes on mine & my buddys 442...also the interchange info is appreciatedā€¦thanks
    Junior Member DIGIMURDA's Avatar
    Sep 2011
    RHODE ISLAND
    3
    do i need to prime a center console before i paint it?
    1,246
    No but you should use adhesion promoter and clean the hell out of it.
    Mar 2012
    colorado
    3
    Would like to know if any of you are familiar with the color code L/camel 63? I found a donor pair of rear seats from a junked 1980 Cutty supreme and found the original build sheet on the rear seat frame. I really like this color and plan on doing my rebuild with this along with year code matching white for some trim. Thanks for any input.
    Attached Files Attached Files
  6. #6
    1,246
    Thats an exterior color code, the build sheet states the interior was a 62D trim package which is camel tan.
    If you want a paint sample your local body shop could perhaps mix it up.
    1,246
    Rare Sandstone Vinyl Interior '81 Supreme:
    Quote Originally Posted by 88hurstolds View Post
    Nice... I'm looking for me a set of buckets and a rear seat but I'm debating if I want to stick with the color I have now (which I don't know the exact name ) or go with a Midnight Blue interior ...
    Attached Images Attached Images
  9. #9
    1985 cutlass supreme
    Jan 2009
    springville ,IN
    39
    9
    That's pretty, I've always liked the vinyl as well..pretty hard to find tho, especially in good condition....hey, 88 are u still interested in 83-84 maple seats? The weather has been crazy here & I haven't been able to pick them up yet.
    1985 Cutlass : Gbody Hurst/Olds Tribute Car: 350 SBO, TH-350, 84-87 Dual Snorkel air cleaner, '79 H/O dual gate set up, 84 H/O wheels...84 H/O hood, spoiler, & badges: COMING SOON
  10. #10
    Jan 2009
    springville ,IN
    39
    9
    Quote Originally Posted by InTheCutt View Post
    Looks like you have the 78-80 camel tan color...I picked up a set of dark blue buckets & rear seat out of a 57k mile '82 Calais, they have the velour like material similar to what the 85-88's used..I have never seen a 82 with this material before..maybe it was an option???
  11. #11
    Quote Originally Posted by Evan View Post
    It's a 78 I was just confused on the name of the color..
  12. #12
    Jan 2009
    springville ,IN
    39
    9
    Yep. You have the dark camel tan. Used in 78-80 models. I've never ran across a nice set in that color around here.
  13. #13
    Do you know what gbody vehicles that had Midnight blue buckets and rear seat as an options..?
  14. #14
    Jan 2009
    springville ,IN
    39
    9
    The closest thing to "midnight blue" would be the dark blue used in 1980-82. Like the set I was taking about in the earlier post.
  15. #15
    Jul 2017
    Bowling Green Ky.
    2
    I see this an old thread but I am hoping someone can help me decide which interior color
    is correct for my 1987 442---Medium dark gray or dark gray. I see there are 2 grays--have just come from automotive paint store with a glove box cover. The man had both samples but they were identical in my eyes. How can I be sure? VIN # --does it contain the interior code? Thanks Lee
  16. #16
    Jul 2017
    Bowling Green Ky.
    2
    I don't see anything in the RPO codes that tells me interior color. HELP!!!---Lee
  17. #17
    1,246
    The dark gray was typically used as vinyl dye code for the seats I believe.
    Medium Dark Gray was used on the dash, console and columns.
    Nov 2011
    Delaware
    9
    I picked up some W12A8247 code spray to dye some upper sail panels and possibly other interior parts. Paint store only had this code in the system to mix. Is this Med Gray color the same as the factory gray on the sail panels?
  19. #19
    1,246
    Quote Originally Posted by QS442 View Post
    Yes, it's listed above.
  20. #20
    Sep 2017
    Wisconsin
    1
    Greetings! New to the forum, and maybe this is a stretch since this is an older thread. But I am curious about the rare sandstone vinyl interior on the 1981 comment. Is that something that's well known?
    I have been searching for my first car - a 1981 Cutlass with bucket seats in the exact color combo (interior and exterior) as you have shown. Hence my curiosity any info would be greatly appreciated.
    Thanks.
    Stu
