Thread: Brake Proportioning Valve
    Oct 2009
    Central Fl.
    27
    Default Brake Proportioning Valve
    Gentlemen,
    How can you tell if your brake proportioning valve is out of whack?
    I will get right to it.
    Before; rear tires would lock up under hard braking.
    After; no rear tire lock up. Car brakes like a anti-lock system but without the pulsing pedal feel.
    Regular driving is unaffected, until, I have to avoid running a stoplight. Then the brakes kind of fade but the car stops. The master cylinder and booster are in good shape.
    Thoughts?
    I have been driving this way for awhile. I just try to avoid the heavy,high speed braking.
    78 Cutlass Supreme
    Drive it everyday!
    Could also be a kink but in your case it's probably unlikely.
    Sounds like your Prop. valve is out of whack, the valve could be jumping around causing this.
    A new Proportioning Valve isn't much, you could grab one from the bone yard but I wouldn't take chances on one...
    Oct 2009
    Central Fl.
    27
    Is this an item that should be bought from GM or are the aftermarket ones durable?
    Thanks,
    78 Cutlass Supreme
    Drive it everyday!
    Cannot be purchased from GM anymore, at least the original stock type can't. They may have a replacement though...
    I've seen some decent aftermarkets on eBay.
