Thread: 307 rattles when cutting off!!!!!! Help!!!!!
    Dec 2009
    North Carolina
    Default 307 rattles when cutting off!!!!!! Help!!!!!
    I have a 87 Cutlass Supreme 105,000 miles original motor. what does it mean when your engine rattles like it's struggling to cut off?
    It's called dieseling which means excess fuel is draining into the cylinders due to the carb leaking fuel (needs a rebuild) and then being ignited by the excess cylinder heat due to running way to hot. I believe it can also be caused by poor cylinder pressure.
