Results 1 to 8 of 8
Thread: frame mounts ,where do they go?
    Mar 2011
    trenton ,ohio
    Default frame mounts ,where do they go?
    putting in a 455 in a 1979 olds cutlass ,not sure where to mount the frame mounts ,dont want to have to bolt engine and trans together ,put in the hole and install drive shaft just to see where the mounts go ,,,, so many holes to choose from !! can anyone with the experiance please help !! and on the block there are 2 positions ,{up front and in the middle of the block} i was guesssing when i put these mounts here in pic
    Feb 2011
    Dardanelle, Arkansas
    If the car had a sbo stock leave the mounts in stock location and use the sbo motor mounts. That is how I did the 455 swap in my 1980 Calais many moons ago.
    Mar 2011
    trenton ,ohio
    no it was a v6 and the mounts were gone , i had to buy bot mounts a engine mounts ,just need a pic of were they go or a diagram
    Feb 2011
    I pulled the engine out of the 84 this past weekend I will try to take some decent pics and post them here.
    Mar 2011
    trenton ,ohio
    Quote Originally Posted by oldsfromyell View Post
    thats awsome i cant wait !thank you !!!
    Feb 2011
    Ok here are some pics of the frame mounts in my 84HO sorry it is so dirty just got the engine out and have not had time to start the clean up. And to answer your other question the engine mounts attach in the rear set of mount holes in the side of the block. My car had a 307 in it but the 455 will mount exactly the same. HTH, David
    Mar 2011
    trenton ,ohio
    thanks so much david !!! i'll be putting this info to good use tomorrow !!!well today its 1:26 am here lol tony:icon14:
    Mar 2011
    trenton ,ohio
    Quote Originally Posted by augydoggy455 View Post
    still have to drill a few holes ,my mounts have 2 holes at the top of them got them in today !!thanks so much oldsfromyell !!
