Thread: VIN 9 Trans Identification
    Default VIN 9 Trans Identification
    1983 - OZ, blue tag
    1984 - OZ, yellow tag
    1985 - OZ, pink tag
    1986 - KZF, blue tag
    1987 - KZF, yellow tag
    VIN 9 cars use a 4 speed overdrive TH-2004r with different shift points due to different governors and also have a higher 2400RPM stall D5 converter (GM# 8653400 with CBBF on the paper tag, 2050RPM stall with 14 blade stator) than the stock VIN Y TH-2004r transmission.
    D5 Torque converter PN's
    '83-'85 OZ & BQ: 8634993
    '86-87 KZF: 8642965 (BRF 8656903)
    There were two different Transmissions offerered for VIN 9 vehicles
    1983-85 has code OZ on the trans tag while '86-'87 reads KZF. These transmissions have a wide open throttle shift point (WOT) of 4800rpm than the VIN Y TH2004R which has a WOT shift point of 3000rpm.
    The gear ratios: 1st: 2.74, 2nd: 1.57, 3rd: 1.00 and 4th (OD): 0.67
    Governor:
    BRF, BQ and CZF GN/Monte SS TH2004Rs have WOT 1st gear 5200 rpm upshift governor, part#8655976, WOT 1st gear upshift on OZ and KZF Hurst/442 is 4800 rpm part# 8634982 vs. 3000 rpm stock.
    Shift points:
    BRF, BQ and CZF:
    1-2: 5200 rpm
    2-3: 4900 rpm
    3-4: 4400 rpm
    OZ and KZF:
    1-2: 4800 rpm
    2-3: 4500 rpm
    3-4: 4000 rpm
    Valve Body:
    1983 OZ: GM# 8639918
    1984 OZ: GM# 8639131
    1985 OZ: GM# 8639493
    1986 & 87 KZF: GM# 8657286
    I am attempting to identify which transmission I have but do not understand this post...
    Tag at the back of the trans on the passengers side by the tail shaft has this information.
    Unless you have a 442 or Hurst these do not apply.
    VIN Y cars had OG, OM or KCF.
    BQ (86-87 GN), OZ (83-85 VIN9), CZF (Monte SS), KZF (86-87 VIN9) and BRF(84-85 GN) are the good ones.
