Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
Thread: Project 87 442
  1. #21
    Member 2002duramax's Avatar
    Oct 2011
    Grunthal, Manitoba,Canada
    46
    so, my boxing day shopping consisted of buying parts for my car, i got me, full weather strip set, decal kit, nos front brake backing plates, whole pile of nos interior and exterior parts, including new shifter handle, and my favorite part a set of nos gm door sills still in there package, car body on stands is going into body shop next week, hoping to have her rolling by summer time
  2. #22
    Very cool, sounds like its comin along very nicely!
    Oct 2011
    46
    body went to the body shop lest weds, i stopped in on friday to see if they had a chance to check to see if body was tweeked or not, and its pretty much done, i couldnt believe it, it looks great. pictures to come shortly
  4. #24
    Sep 2011
    IL
    Default 86 Grey 442
    Should look like this:icon14:
  5. #25
    Oct 2011
    46
    oh yes it will and i cant wait lol
  6. #26
    Oct 2011
    46
    current pictures of the project
  7. #27
    Oct 2011
    46
    apperently they wont upload, darn
  8. #28
    I was wondeing how your 87 was coming along....
  9. #29
    Oct 2011
    46
    well, body is all done, picked it up, now shes back home on the stands, frame got sandblasted, and painted, all the control arms are sandblasted and painted, energy suspension bushings installed, and all new ball joints, i decided to buy the rear portion of the frame from arizona aswell to make sure she is completly rust free, also ordered my cam, and engine build begins
  10. #30
    Very cool....I would love to do a frame off restoration in the future....when time, money, & space allow me to.... what re your plans for the engine build?
  11. #31
    Very nice, pics would be great! I too am having issues loading them.... Good luck on your project.
  12. #32
    Oct 2011
    46
    finally got the pics to work
  13. #33
    Oct 2011
    46
    doors and trunk
  14. #34
    Very nice! Before joining these forums, I didn't realize anyone in Canada had the g.body bug like I do! My own ignorance... I suppose some people see Nebraska In my info & assume that I'm knocking down rows of corn to park my Cutlass! HaHa
  16. #36
    Oct 2011
    46
    Default engine build
    for the engine build, im not going to extream, im kinda in search of a 455 to stick all my money into, so i figured id give the 350 rocket some love and dress it up nice, so im doing new bearings, hone it out, new rings, comp cam set, valve springs, set of headers, edelbrock intake, holley 650 double pumper, msd distributor,
    cam i bought
    BrandCOMP CamsManufacturer's Part NumberK42-225-4Part TypeCamshaft and Lifter KitsProduct LineCOMP Cams Xtreme Energy Cam and Lifter KitsSummit Racing Part NumberCCA-K42-225-4UPC036584067924Cam StyleHydraulic flat tappetBasic Operating RPM Range2,300-6,500Intake Duration at 050 inch Lift240Exhaust Duration at 050 inch Lift246Duration at 050 inch Lift240 int./246 exh.Advertised Intake Duration284Advertised Exhaust Duration296Advertised Duration284 int./296 exh.Intake Valve Lift with Factory Rocker Arm Ratio0.541 in.Exhaust Valve Lift with Factory Rocker Arm Ratio0.544 in.Valve Lift with Factory Rocker Arm Ratio0.541 int./0.544 exh.Lobe Separation (degrees)110Grind NumberOL XE284H-10Computer-Controlled CompatibleNoLifters IncludedYesLifter StyleHydraulic flat tappetValve Springs IncludedYesOutside Diameter of Outer spring
    1.437 in.
  17. #37
    Oct 2011
    46
    some newer update photos
  18. #38
    VERY NICE!
    Those are some heafty plug wires
    Looks like things are coming along nicely.
    Oct 2011
    46
    Slow and steady, in January I'm back to school for 2.5
    Months so il be home ever night to work on it
  20. #40
    I wish I caught this before you bought that cam! That thing is going to be a dog. What year 350 do you have? 2 or 4 bbl?
    If it is a low compression engine you are going to absolutely kill the bottom end torque. Since you said you were honing the cylinders I assume you have the engine apart. The older 350's has .017" thick shim gaskets. If you replace it with a composite gasket you will lower the compression even more. Usually the advertised compression is a 1/2 point lower in reality. So if it is advertised 8.5:1 it will more than likely be 8:1. Composite gasket can lower it to 7.5:1 before it's all over.
    The cam you picked should be used with at least 10:1 compression. You won't beable to use any power accessories with that cam as well.
    Other areas your going to run into problems is with the retainer hitting the valve guide boss because of the lift,unless you cut it down. You will need to change to an adjustable valvetrain as well.
    If I were you I would use the stock cam, get a shim gasket from M&J Proformance, mill the heads .030" for 64 cc chambers (depending on the exact engine you have) and degree the cam to get the intake valve to close at 51 ABDC or sooner using seat timing.
    This will save you money and give you the most bang for your buck. Save the cam for the big block.
    I could go on, but I think I have made my point. Already made these mistakes myself. Just trying to help.
    http://carphotos.cardomain.com/ride_images/3/2463/449/31155224025_medium.jpg
    1974 Olds Omega 468 BBO 11.85 @ 112 MPH on 87 octane 1.62 60 ft.
    1987 442 Bone stock 250,000 miles
