Thread: Decoding RPO Codes
    Cheektowaga, NY
    15
    Default Decoding RPO Codes
    Member Furtrader's Avatar
    Feb 2009
    Ottawa Ontario Canada
    60
    This link has:
    • Olds G-Body Registry
    • Olds G-Body Parts Database
    • RPO Code Lookup
    • VIN Decoder (1981-1988) [Oldsmobile & Chevrolet]
    http://apps.oldsgmail.com/
    DON'T pimp my ride!!!
    http://www.cardomain.com/ride/723196
    A Proud Canadian
    Jeff
    1,250
    AA4 WINDOW, SPECIAL GLAZING, DOMESTIC
    AA7 WINDOW, POWER OPERATED, QUICK OPENING
    AA8 WINDOW, R/CMPT LIFT
    AA9 WINDOW, REAR, BLACKOUT BANDED EDGE
    AB1 WINDOW, RR QUARTER, ORNAMENTAL
    AB2 WINDOW SIDE BODY, STA LEFT SIDE
    AB3 SEATING ARRANGEMENT, SIX PASS
    AB4 SEATING ARRANGEMENT, FIVE PASS WITH BUCKET SEATS
    AB5 LOCK CONTROL, SIDE DR, ELECT, KEY ACTIVATED
    AB6 WINDOW, RR INSERT
    AB7 WINDOW, T/GATE,HINGED
    AC1 ADJUSTER, PASS ST, POWER, 6 WAY, BKT
    AC2 WINDOW, SLIDING RIGHT FRT DR
    AC3 ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
    AD2 WINDOW, RR DR ------ DELETE
    AD3 WINDOW, HINGED, ROOF
    AD5 WINDOW, SIDE RR SLIDING
    AD8 DOOR CHECK, RR
    AD9 ADJUSTER, SEAT, POWER 2 WAY DRIVER
    AE1 SEAT, FRT BKT, PASS, HIGH BACK, AIR SUSP
    AE2 SEAT, DRIVER
    AE7 SEAT, FRT SPLIT DRIVER PASS EASY ENTRY
    AF0 ADJUSTER, SEAT EASY ENTRY, DRIVER
    AF1 ADJUSTER, SEAT MANUAL----DELETE
    AF2 WINDOW, STA SIDE, LH, UTILITY BODY
    AF3 WINDOW, STA SIDE, RH UTILITY BODY
    AF4 ADJUSTER, SEAT, MANUAL, 6 WAY DRIVER, PASS
    AF5 ADJUSTER, SEAT, EASY ENTRY, PASS
    AF6 SEAT, FRT BENCH, 2 PASS
    AF7 SEAT, FRT BENCH SPLIT BACK, CTR ARM REST, 2 PASS
    AF9 SEAT, FRT BKT, PASS DRIVER, RECL, OUTSIDE VENDOR
    AG1 ADJUSTER, FRT ST, POWER, 6 WAY DRIVER, SPLIT BENCH
    AG2 ADJUSTER, PASS ST POWER, 6 WAY, SPLIT BENCH
    AG3 ADJUSTER, FRT ST, POWER, 6 WAY, 2 POSITION MEMORY
    AG4 ADJUSTER, SEAT, MANUAL, 2 WAY, VERT, DRIVER
    AG7 ADJUSTER, SEAT, POWER, 6 WAY, 2 POSITION MEMORY
    AG9 ADJUSTER, SEAT, POWER, 6 WAY
    AH6 WINDOW, BACK DR, UTILITY BODY
    AH8 WINDOW, SIDE ACCESS DR, LH, UTILITY BODY
    AH9 WINDOW, SIDE ACCESS DR, RH, UTILITY BODY
    AJ1 WINDOW TINTED,DEEP, ALL EXCEPT W/S AND DRS
    AJ2 SEAT RR, FLDG, SIDEWAYS JUMPSEAT
    AJ3 RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
    AJ4 RESTRAINT SYSTEM, HEAD MOUNTED GUIDE LOOP
    AJ6 TRAVEL BED, RR SEAT
    AJ9 TRAVEL BED, RR SEAT RR
    AK1 RESTRAINT SYSTEM, FRT, CTR, RR SEAT, FRT SHLDR,
    AK5 RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
    AK8 RESTRAINT SYSTEM, FRT SEAT, SHLDR, 3 POINT
    AK9 RESTRAINT SYSTEM, RR SEAT, SHLDR, RETR, 3 POINT
    AL4 SEAT RR, BKT
    AL7 SEAT, FRT SPLIT, PASS/DRIVER, 8 WAY ADJ, 2 WAY
    AM3 SEAT, FRT BENCH, 2 PASS, CTR ARM REST
    AM4 SEAT, FRT BENCH, N/BACK, 2 PASS
    AM5 SEAT, FRT SPLIT, 3 PASS, 6 WAY ADJ, 2 WAY LUMBAR
    AM6 SEAT, FRT SPLIT, 3 PASS, CTR ARM REST
    AM7 SEAT, RR, FLDG
    AMB SEAT, FRT SPLIT, 2 PASS INTEGRAL CONSOLE
    AM9 SEAT, RR, SPLIT, BACK, FLDG
    ANL SALES PACKAGE, AIR DEFL . AND FOG LP
    AN1 SEAT, RR, BENCH
    AN3 SEAT, FRT BKT, DRIV, PASS, ELEC BODY SUPT CONT
    AN4 RESTRAINT, PROVISION CHILD
    AN5 SEAT RR, BUCKET, W/INTEGRAL CHILD SEAT
    AN6 ADJUSTER SEAT BACK DRIVER
    AP1 RESTRAINT, CARGO PROVISIONS
    AP7 PARTITION SLIDING, PLYWOOD
    AP9 NET, CONVENIENCE
    AQ3 SEAT RR, CTR
    AQ7 SEAT, FRT SPLIT, 3 PASS, 6 WAY ADJ, RECL
    AQ9 SEAT, FRT BKT PASS DRIVER RECL
    AR3 RESTRAINT SYSTEM, HEAD, RR SEAT, CLOTH COVERED,
    AR4 RESTRAINT SYSTEM, FRT SEAT, AUTO, PASSIVE
    AR5 RESTRAINT SYSTEM, HEAD, RR SEAT, LEATHER COVERED,
    AR6 RESTRAINT SYSTEM, SEAT BELT, SHLDR HARN, MAN
    AR7 SEAT, FRT BKT, STANDARD
    AR9 SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
    AS1 SEAT, FRT BKT, HIGH BACK, DRIVER
    AS2 SEAT, PASSENGER, FRT BKT, HIGH BACK
    AS3 SEAT, RR, SUBURBAN
    AS5 SEAT, FRT BKT, DELUXE
    AS7 SEAT, FRT SPLIT
    AS8 RESTRAINT SYSTEM, FRT SEAT, MANUAL, ACTIVE
    AT2 SEAT RR, DELETE
    AT5 SEAT RR, CTR, FLDG
    AT6 ADJUSTER PASS ST BK, MANUAL, RECL
    AU0 LOCK CONTROL, REM0TE ENTRY
    AU1 LOCK CONTROL, SIDE DR, FUEL FILLER DR, ELEC
    AU2 LOCK CONTROL, CARGO DR
    AU3 LOCK CONTROL, SIDE DR, ELEC
    AU4 LOCK CONTROL, SIDE DR, ELEC, AUT0MATIC
    AU6 LOCK CONTROL, END GATE WINDOW, REM CONT ELEC
    AV3 HOOK, CARGO TIE DOWN
    AV5 SEAT, FRT BKT, HIGH BACK
    AV7 SEAT FRT SPLIT, SD/SO
    AW2 ADJUSTER, SEAT, MANUAL, 6 WAY, DRIVER
    AW3 ADJUSTER SEAT MANUAL, 6 WAY, PASS
    AW4 DOOR, SLIDING SIDE EXTENSION
    AW9 LOCK CONTROL, QUARTER STOW L L/CPMT
    AX3 LOCK CONTROL, KEYLESS ENTRY SYSTEM
    AX4 RESTRAINT, CONVERSION SEAT, MAN, EUROPEAN
    AX5 PARTITION, EXPANDED METAL, LEFT SIDE
    AX6 PARTITION, EXPANDED METAL, WITH RH SLIDING DR
    AX7 PARTITION, EXPANDED METAL, WITH CTR SLIDING DR
    AX8 SEAT, FRT BKT, PEDESTAL, DRIVER, BELTS
    AX9 ATCH RR CARGO DR
    AY4 RESTRAINT CONVERSION, HEAD FRT SEAT, LEATHER
    AY9 ADJUSTER,SEAT, POWER 6 WAY SPLIT SEAT
    A01 WINDOW, TINTED, ALL SHADED, W/S
    A02 WINDOW, TINTED, SHADED UPPER
    A04 WINDOW, TINTED, RR SIDE, RR
    A07 WINDOW, BODY
    A08 WINDOW, BODY, RIGHT SIDE
    A11 WINDOW, TINTED, ALL
    A12 WINDOW, RR, STA BACK DR
    A13 WINDOW, SIDE DR, STA, RR
    A17 WINDOW, SIDE BODY, LEFT SIDE, SWING OUT
    A18 WINDOW, RR, DR, SWING OUT
    A19 WINDOW, SIDE DR, RR, SWING OUT
    A2Q PACKAGE,'GSI'
    A20 WINDOW, RR QUARTER VENT SWING OUT
    A21 WINDSHIELD, ADDITIONAL LAMINATE
    A23 WINDSHIELD, HEAT REFLECTIVE
    A26 WINDOW, EUROPEAN GLAZING, ALL
    A28 WINDOW, RR, FULL WIDTH, SLIDING
    A31 WINDOW, POWER OPERATED, SIDE
    A32 WINDOW, POWER OPERATED, FRT DR
    A33 WINDOW, POWER OPERATED, T/GATE OR BACK DR
    A37 RESTRAINT SYSTEM, FRT SEAT, DELUXE TYPE
    A40 WINDOW POWER OPERATED, RR VENT
    A42 ADJUSTER SEAT, POWER, 6 WAY, BENCH
    A43 MEMORY SEAT ADJUSTER, MIRROR, POWER, DRIVER
    A44 ADJUSTER PASS ST, MANUAL, 4 WAY
    A50 SEAT, FRT BKT
    A51 SEAT, FRT BKT PASS, DRIVER
    A52 SEAT, FRT BENCH
    A57 SEAT PASSENGER AUXILIARY, ONE, FLDG
    A59 LOCK CONTROL, RR COMPT LID, REM CONT, MANUAL
    A65 SEAT, FRT BENCH, SPLIT BACK, CTR ARM REST
    A70 WINDOW, RR QUARTER, REM0TE CONTROLLED
    A75 SEAT CUSHION, BACK FRT, HD
    A78 ADJUSTER FRT, ST BK, MANUAL, PASS & DRIVER, RECLINING
    A79 ADJUSTER FRT, ST BK, MANUAL, DRIVER, RECLINING
    A80 ADJUSTER FRT, ST BK, POWER DRIVER, RECLINING
    A81 ADJUSTER PASS, ST BK, POWER, RECLINING
    A82 RESTRAINT, HEAD
    A83 ADJUSTER, SEAT BACK, RECLINING
    A90 LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE AAAAA
    A91 PULL DOWN, RR COMPT LID
    A93 LOCK CONTPOL, QUARTER STOWAGE COMPT
    A94 LOCK CONTROL, DR
    A95 SEAT, FRT BUCKET, HIGH BACK, PASS & DRIVER RECL
    A96 LOCK CONTROL, LUGG COMPT
    A99 LOCK CONTROL, I/P COMPT
    BA0 ORNAMENTATION, EXTR, DOOR, NAMEPLATE
    BA1 ORNAMENTATION, EXTR HOOD
    BA5 ORNAMENTATION, EXTR CUSTOM
    BA6 COMPARTMENT, RR, PACKAGE SHELF, STOWAGE
    BA8 COMPARTMENT, FRT SEAT STOWAGE, PASS
    BA9 COMPARTMENT, FRT SEAT STOWAGE, DRIVER
    BB2 TRIM, LUGG COMPT LINING ---- DELETE
    BB3 ORNAMENTATION, INTR, DR POCKET, INNER LINING,
    BB4 ORNAMENTATION, INTR, DR POCKET, INNER LINING, LEFT
    BB5 ORNAMENTATION, INTR, HEADLINER
    BC1 ORNAMENTATION, INTR, I/P
    BC2 ORNAMENTATION, INTR, I/P, WOOD GRAIN
    BC3 ORNAMENTATION, INTR, I/P, DELUXE
    BC4 ORNAMENTATION, INTR, COAT HOOK RETRACTABLE
    BC5 ORNAMENTATION, INTR, LOAD COMPT CARPET PANELS
    BC8 ORNAMENTATION, INTR, DR MAP POCKETS
    BC9 ORNAMENTATION, EXTR HOOD ---- DELETE
    BD1 ORNAMENTATION, EXTR MLDG, ROCKER PNL ---- DELETE
    BD2 ORNAMENTATION, EXTR ---- DELETE
    BD3 ORNAMENTATION, INTR ACCEL/BRAKE PEDAL
    BF1 COVERING REAR FLOOR MATS----DELETE
    BF2 COVERING, FLOOR CARPET, DELUXE
    BF3 COVERING, STEP WELL MAT
    BF4 COVERING, FLOOR CARPET, CUSTOM
    BF9 COVERING FRT, FLOOR MAT----DELETE
    BG4 TRIM OVERRIDE ,INTERIOR, BIG FOUR
    BG9 COVERING FLOOR, RUBBER
    BS1 INSULATION, ACOUSTICAL PKG
    BS2 INSULATION, ACOUSTICAL PKG, ADDED MATERIAL
    BS4 INSULATION, BACK PNL
    BS6 SEAL, DR
    BV1 FLEET INCENTIVE, LAND O'LAKES (J/L/W-TRK CKMST)
    BV2 ORNAMENTATION, EXTR RR C0MPT LID
    BV3 ORNAMENTATION, INTR, I/P, BLACK
    BV6 ORNAMENTATION, EXTR LOCK CYLINDER, PAINTED
    BV7 ORNAMENTATION, EXTR PLR APLQ ---- DELETE
    BV8 ORNAMENTATION, EXTR DR HANDLE, LOCK CYLINDER,
    BV9 ORNAMENTATION, EXTR MLDG, BODY SIDE, WOOD GRAIN
    BW1 ORNAMENTATION, EXTR RR END
    BW2 MOLDING B/S, DELUXE
    BW3 ORNAMENTATION, EXTR ROOF WINDOW TRIM, PAINTED
    BW6 ORNAMENTATION, EXTR PLR APLQ, COLORED
    BW7 ORNAMENTATION, EXTR PLR APLQ
    BW8 ORNAMENTATION, EXTR, EMBLEM, BODY, RR
    BX1 ORNAMENTATION, EXTR FRT END, SPECIAL
    BX2 MOLDING B/S, L0WER, EXTRA WIDE
    BX3 ORNAMENTATION, EXTR WOOD GRAIN SIDE PNL
    BX4 ORNAMENTATION, EXTR MLDG, BODY SIDE, BRIGHT
    BX5 ORNAMENTATION, EXTR MLDG, ROOF DRIP, PAINTED
    BX6 ORNAMENTATION, EXTR MLDG, APLQ, CAB BACK PNL
    BX8 ORNAMENTATION, EXTR MLDG, RR WINDOW REVEAL ----
    BX9 ORNAMENTATION, EXTR FRT END PNL
    BYP SALES, SPORT EQUIPMENT PKG
    BY1 ORNAMENTATION, EXTR EMBLEM, BODY, VAR 3
    BY4 ORNAMENTATION, INTR, INST PANEL, NAME PLATE
    BY8 ORNAMENTATION, EXTR FRT DECOR PLATE
    B05 BODY EQUIPMENT ARMORED
    B1A PORT OF ENTRY CAMI
    B1B MODIFICATION FOUR SEATER
    B1J LINER FENDER
    B1N TIRE ALL, P165/65R13 BL R/PE ST TL AL3
    B1R TIRE ALL, P185/60VR14/N BL R/PE ST TL AL3
    B1Y MERCHANDISED PKG, SPECIAL COMPONENTS
    B18 ORNAMENTATION, INTR, DELUX
    B19 ORNAMENTATION, INTR, CUSTOM
    B2E SALES, SPRING SPECIAL PACKAGE
    B2L PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7L PFI
    B2Q PANEL, RR ROOF, BLACK ---DELETE
    B2S SPRING , REAR LEAF TRANSVERSE (LH)
    B2U SPRING, REAR LEAF TRANSVERSE (RH)
    B2W TIRE ALL, P205/75R15/N R/PE 0WL TL 00R (TRACKER)
    B2Z MERCHANDISED PKG, DELUXE VAN
    B20 ORNAMENTATION, INTR, LUXURY
    B22 ORNAMENTATION, INTR, EMBLEM, DR INNER PANEL
    B23 ORNAMENTATION, EXTR WHEEL OPG SPOILER
    B24 ORNAMENTATION, EXTR MLDG, SIDE WINDOW REVEALs
    B25 TRIM EQUIPMENT LUGG COMPT, DELUXE
    B26 ORNAMENTATION, INTR, DR PULL HANDLES, FRT
    B29 ORNAMENTATION, INTR, DR PULL HANDLES, RR
    B3D EQUIPMENT, SCHOOL BUS
    B3H COVERING, FLOOR CARPET LOAD FLOOR ---DELETE
    B3J EQUIPMENT DIESEL
    B3K TIRE ALL, P145/BOR12/N BL R/PE ST TL ALS
    B3M EQUIPMENT, SCHOOL BUS, DELUXE
    B3S TIRE ALL, P205/50R15/N BL R/PE ST TL HW4
    B30 COVERING, FLOOR CARPET
    B32 COVERING, FRT FLOOR MATS AUX
    B33 COVERING, REAR FLOOR MATS AUX
    B34 COVERING, FRT FLOOR MATS CARPETED INSERT
    B35 COVERING, REAR, FLOOR MATS CARPETED INSERT
    B36 COVERING, FLOOR MAT, LUGG COMPT
    B37 COVERING, FLOOR MATS, FRT & RR AUX
    B39 COVERING, FLOOR CARPET, LOAD FLOOR
    B4A PANEL ROOF, BLACK --- DELETE
    B4C SALES, SPECIAL SERVICE PKG
    B4F PACKAGE, SECURITY LIGHTING
    B4H MODIFICATION, NOISE CONTROL , EXPORT
    B4K HANDLING CHARGE, TARRYTOWN T0 MIDWAY COACH
    B4M VEHICLE, CUSTOM FEATURE PACKAGE
    B4N HANDLING CHARGE, TARRYTOWN T0 ESSEX MD T0 T & B IN
    B4U PERFORMANCE PACKAGE, SPORT
    B4V PERFORMANCE PACKAGE, SUPER SPORT
    B42 COVERING, FLOOR MAT, LUGGAGE COMPARTMENT FITTED
    B43 COVERING, LOAD FLOOR, TEXTURED SURFACE
    B44 COVERING, LOAD FLOOR, LOOSE
    B46 TRIM EQUIPMENT, SPECIAL ORDER
    B48 TRIM EQUIPMENT, LUGGAGE COMPARTMENT
    B5A PACKAGE, INDY CONVERTIBLE
    B5I PACKAGE, INDY "GT"
    B5S FLEET INCENTIVE, D & K FINANCIAL
    B5Z SALES, EXTR APPEARANCE
    B51 MOLDING, ROCKER, EXTRA WIDE
    B53 COVERING FRT, FLOOR MATS, CARPETED INSERT DELUXE
    B54 COVERING REAR, FLOOR MATS, CARPETED INSERT DELUXE
    B56 MOLDING ROCKER,COLORED
    B57 ORNAMENTATION P EXTR DELUXE
    B58 COVERING, FLOOR MATS FRT & RR, CARPETED INSERT
    B60 DECAL PACKAGE, 01
    B6Q DECAL PACKAGE, 02
    B6R DECAL PACKAGE, 03
    B6S TRAVEL BED PACKAGE
    B65 COVERING, FLOOR SIDEWALL TRUNK
    B67 CONTAINER, RADI0 CASSETTE TAPES
    B69 CONTAINER, COMPACT DISCS
    B7N BODY EQUIPMENT, PICKUP BOX PANELS (NON-PRIME)
    B7P BODY EQUIPMENT, PICKUP BOX PANELS (PRIME)
    B71 MOLDING WHL OPENING, COLORED
    B72 ORNAMENTATION, EXTR MLDG BELT REVEAL' COLORED
    B74 MOLDING WHL OPENING, EXTRA WIDE
    B75 TRIM EQUIPMENT, LUGG COMPT LINING
    B77 ORNAMENTATION, EXTR MLDG W/S REVEAL, COLORED
    B79 ORNAMENTATION, EXTR RR END
    B80 ORNAMENTATION, EXTR MLDG ROOF DRIP
    B81 MOLDING B/S ---- DELETE
    B82 ORNAMENTATION, EXTR EMBLEM ---- DELETE
    B83 MOLDING ROCKER, NARROW
    B84 ORNAMENTATION, EXTR MLDG, B0DY SIDE
    B85 RNAMENTATION, EXTR MLDG BELT REVEAL
    B87 ORNAMENTATION, EXTR EMBLEM FENDER---DELETE
    B88 MOLDING B/S CUSTOM
    B89 ORNAMENTATION, EXTR MLDG, RR WINDOW REVEAL,
    B9Q MODEL CONVERSION, HEARSE
    B90 ORNAMENTATION, EXTR MLDG, SIDE WINDOW REVEAL
    B91 ORNAMENTATION, EXTR MLDG DR EDGE GUARD, COLORED
    B92 ORNAMENTATION, EXTR FRT FENDER NAME
    B93 ORNAMENTATION, EXTR MLDG, DR EDGE GUARD
    B94 ORNAMENTATION, EXTR EMBLEM, BODY, VAR I
    B96 MOLDING WHL OPENING
    B97 ORNAMENTATION, EXTR MLDG, LOWER ACCENT
    B98 STRIP B0DY SIDE, DELETE
    B99 MOLDING WHL OPENING,---- DELETE
    CA1 ROOF, SUN, STEEL SLIDING, ELEC
    CA2 ROOF COVERING, VINYL ---- DELETE
    CA3 ROOF COVERING, STAINLESS STEEL
    CA5 ROOF COVERING, VINYL, HEAVY PAD, HALO TYPE
    CA9 ROOF COVERING, VINYL, PADDED, HALO TYPE
    CB4 ROOF COVERING, VINYL, PADDED, RR INTEGRAL PAD
    CB5 ROOF COVERING, VINYL, PADDED, FULL
    CB7 ROOF COVERING, VINYL, PADDED, FRT INTEGRAL PAD
    CC1 ROOF HATCH, REMOVABLE PANELS, GLASS
    CC2 ROOF AUXILIARY
    CC3 ROOF, HATCH, REMOVABLE PANELS. PLASTIC
    CD2 INDICATOR, WSWA JAR FLUID
    CD4 WIPER SYSTEM WINDSHIELD, PULSE
    CD7 WIPER SYSTEM WINDSHIELD, PULSE, WET ARM
    CE4 WASHER, HEADLAMP, HIGH PRESSURE
    CF3 ROOF, SUN, REMOVABLE, TRANSPARENT
    CF4 ROOF, SUN, GLASS SLIDING, MANUAL
    CF5 ROOF, SUN, GLASS SLIDING, ELEC
    CF7 ROOF, SUN REMOVABLE NON-TRANSPARENT
    CF8 ROOF, COVERING, SIMULATED CONVERTIBLE
    CG1 FLEET INCENTIVE, AMERICAN INTERNATIONAL REALTY
    CH1 FLEET INCENTIVE, HALLMARK CARD
    CH2 FLEET INCENTIVE, AMSCO
    CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT
    CJ3 HVAC SYSTEM AIR CONDITIONER FRT, MAN TEMP CONT,
    CR0 LAMP, INTR ENG COMPT COURTESY ---DELETE
    CR1 LAMP, INTR FRT DR WARNING
    CR3 LAMP, INTR I/P READING
    CR5 COUNTRY, YUGOSLAVIA
    CR6 COUNTRY, POLAND
    CR7 COUNTRY, HUNGARY
    CTF SALES PACKAGE, INTERIM CONTROL
    CT1 COUNTRY, BELGIUM
    CT2 COUNTRY, AUSTRIA
    CT3 COUNTRY, GERMANY
    CT4 COUNTRY, LUXEMBOURG
    CT5 COUNTRY, NETHERLANDS
    CT6 COUNTRY, ITALY
    CT7 COUNTRY, DENMARK
    CT8 COUNTRY, PORTUGAL
    CT9 COUNTRY, SPAIN
    CU1 COUNTRY, NORWAY
    CU2 COUNTRY, FINLAND
    CU3 COUNTRY, FRANCE
    CU4 COUNTRY, SWEDEN
    CU5 COUNTRY, SWITZERLAND
    CU6 COUNTRY, TAIWAN
    CU7 COUNTRY, KUWAIT
    CU8 COUNTRY, SAUDI ARABIA
    CU9 COUNTRY, UNITED KINGDOM
    CV1 COUNTRY, ICELAND
    CV3 COUNTRY, MEXICO
    CV4 COUNTRY, ISRAEL
    CV7 COUNTRY, ENGLAND
    CV8 COUNTRY, IRAQ
    CV9 COUNTRV, TURKEY
    CW1 COUNTRY, KOREA
    C01 ORNAMENTATION, EXTR EMBLEM, BODY, VAR 2
    C04 ROOF COVERING VINYL PADDED, RR
    C05 ROOF, CONVERTIBLE FOLDING
    C09 ROOF COVERING, VINYL PADDED, FULL,INTEGRAL PAD
    C1B LAMP GROUP, COMPONENTS 2
    C1F PACKAGE, ACCENT
    C18 ARM & BLADE, WSW
    C2L ROOF, PACKAGE DUAL REMOVABLE
    C2X MODEL CONVERSION, VALUE LEADER
    C25 WIPER SYSTEM, RR WINDOW
    C27 ROOF COVERING, SOFT TRIM
    C3A PAYLOAD, 1500 LBS
    C3B PAYLOAD, 1000 LBS
    C3C PAYLOAD, 1625 LBS
    C34 HVAC SYSTEM, AIR CONDITIONER HEATER COMBINATION
    C35 HEATER, RR COUPT, PROVISIONS FOR
    C36 HEATER, AUXILIARY
    C4G GVW RATING, 4935 LBS
    C4H GVW RATING, 5050 LBS
    C40 HVAC SYSTEM, HEATER OUTSIDE AIR, WITH FAN, ELECTRONIC
    C41 HVAC SYSTEM, HEATER OUTSIDE AIR, WITH FAN
    C42 HVAC SYSTEM, HEATER DELUXE OUTSIDE AIR
    C44 TAILGATE, PLASTIC
    C46 HEATER, HIGH CAPACITY
    C47 DEFOGGER, RR WINDOW ---- DELETE
    C49 DEFOGGER, RR WINDOW, ELECTRIC
    C5A GVW RATING, 4900 LBS
    C5B GVW RATING, 15,000 LBS
    C5C GVW RATING, 5000 LBS
    C5D GVW RATING, 4600 LBS
    C5E GVW RATING, 5400 LBS
    C5F GVW RATING, 4100 LBS
    C5G GVW RATING, 5600 LBS
    C5H GVW RATING, 5350 LBS
    C5J GVW RATING, 6000 LBS
    C5K GVW RATING, 5175 LBS
    C5L GVW RATING, 5370 LBS
    C5U GVW RATING, 6100 LBS
    C5P GVW RATING, 6250 LBS
    C5Q GVW RATING, 6400 LBS
    C5R GVW RATING, 5800 LBS
    C5S GVW RATING, 6600 LBS
    C5T GVW RATING, 4200 LBS
    C5U GVW RATING, 6800 LBS
    C5V GVW RATING, 6850 LBS
    C5W GVW RATING, 7000 LBS
    C5X GVW RATING, 4650 LBS
    C5Y GVW RATING, 7100 LBS
    C5Z GVW RATING, 7200 LBS
    C50 DEFROSTER, HEATED WINDSHIELD
    C51 DEFLECTOR, RR WINDOW, AIR
    C55 VENT, ROOF
    C56 VENT, FORCED AIR, RIGHT SIDE
    C57 VENT, FORCED AIR
    C6A GVW RATING, 7300 LBS
    C6B GVW RATING, 4785 LBS
    C6C GVW RATING, 7400 LBS
    C6D GVW RATING, 10100 LBS
    C6E GVW RATING, 7500 LBS
    C6F GVW RATING, 5150 LBS
    C6G GVW RATING, 7600 LBS
    C6H GVW RATING, 4350 LBS
    C6I GVW RATING, 4850 LBS
    C6J GVW RATING, 5100 LBS
    C6K GVW RATING, 20000 LBS
    C6L GVW RATING, 8000 LBS
    C6U GVW RATING, 5950 LBS
    C6N GVW RATING, 8200 L85
    C6P GVW RATING, B600 LBS
    C6Q GVW RATING, 6875 LBS
    C6S GVW RATING, 8900 LBS
    C6U GVW RATING, 9000 LBS
    C6W GVW RATING, 9200 LBS
    C6X GVW RATING, 4810 LBS
    C6Y GVW RATING, 9600 LBS
    C60 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
    C61 HVAC SYSTEM, AIR CONDITIONER FRT AUTO CONTROLS
    C65 HVAC SYSTEM, AIR CONDITIONER FRT SEMI-AUTO CONTROLS
    C66 HVAC SYSTEM, AIR CONDITIONER PROVISIONS FOR DEALER
    C67 HVAC SYSTEM, AIR CONDITIONER FRT ELECTRONIC CONTROLS
    C68 HVAC SYSTEM, AIR CONDITIONER FRT AUTO, ELECTRONIC
    C69 HVAC SYSTEM, RR, AIR CONDITIONER
    C7A GVW RATING, 10000 LBS
    C7C GVW RATING, 10500 LBS
    C7E GVW RATING, 11000 LBS
    C7G GVW RATING, 11500 LBS
    C7J GVW RATING, ll800 LBS
    C7L GVW RATING, 12000 LBS
    C7M GVW RATING, 14100 LBS
    C7N GVW RATING, 12300 LBS
    C7P GVW RATING, 16000 LBS
    C7Q GVW RATING, 10200 LBS
    C7S GVW RATING, 14600 LBS
    C7U GVW RATING, 5200 LBS
    C7V GVW RATING, 26500 LBS
    C7X GVW RATING, 5850 LBS
    C7Y GVW RATING, 4700 LBS
    C7Z GVW RATING, 4537 LBS
    C71 LAMP, INTR, FRT DR, COURTESY
    C72 LAMP, INTR, RR DR COURTESY
    C75 LAMP, INTR, FRT HEADER, COURTESY AND DUAL READING
    C77 LAMP, INTR, FRT HEADER COURTESY
    C78 LAMP, INTR, ROOF, COURTESY AND SINGLE READING
    C8B PAINT SPECIAL, (SILVER MET)
    C8K PAINT SPECIAL, (MED GRAY MET )
    C8T PAINT SPECIAL, (DK MAPLE RED MET)
    C80 SWITCH, JAMB, FPT DR
    C81 SWITCH, JAMB, RR DR
    C87 LAMP, INTR, QTR COURTESY
    C88 LAMP, INTR, RR HEADER, COURTESY
    C89 LAMP, INTR, QTR, SINGLE READING
    C9A PAINT SPECIAL, (WHITE)
    C9C PAINT SPECIAL, (BLACK)
    C9D PAINT SPECIAL, (DK BLUE MET. )
    C9E PAINT SPECIAL, (LT BLUE MET. )
    C9F PAINT SPECIAL, (DK RED MET)
    C9Q PAINT SPECIAL, (DK CHESTNUT MET. )
    C9R PAINT SPECIAL, (CARMINE)
    C9X PAINT SPECIAL, (LT CAMEL MET)
    C90 LAMP, INTR, FRT AND RR DRS, COURTESY
    C91 LAMP, INTR, ROOF, COURTESY
    C93 LAMP, OPERA
    C94 LAMP, D0ME, DELAYED
    C95 LAMP, INTR, ROOF, COURTESY AND DUAL READING
    C96 LAMP, INTR, QTR, COURTESY AND SINGLE READING
    C97 ILLUMINATED ENTRY,
    DA0 ARM REST, FRT SEAT, STORAGE
    DA1 ARM REST, RR SEAT, STORAGE
    DA2 GVW RATING, 5070 LBS
    DA3 GVW RATING, 5700 LBS
    DA4 GVW RATING,12 500 LBS
    DB3 SUNSHADE, WINDSHIELD, WITH EXTENSION
    DB4 SUNSHADE, WINDSHIELD, WITH POCKETS
    DC4 MIRROR I/S, R/V, TILT, DUAL READING LAMPS
    DC5 MIRROR I/S, RR HEADLINING, ILLUM
    DC6 MIRROR O/S, LH & RH, REM CONT, ELEC, LH & RH DEFOG,
    DC7 MIRROR O/S, LH & RH, REM CONT, ELEC, BREAKAWAY,
    DC8 MIRROR O/S, LH & RH, REM CONT, ELEC, BREAKAWAY,
    DD0 MIRROR O/S, LH & RH, REM CONT, ELEC, DEFOG, LT
    DD1 MIRROR I/S, R/V TILT, DUAL READING LAMPS, COMPASS
    DD2 MIRROR I/S, SUNSHADE, COVERED
    DD3 MIRROR O/S, LH & RH, REM CONT 8REAKAWAY, PAINTED
    DD4 MIRROR O/S, RH, REM CONT, ELEC, CHROME
    DD5 MIRROR 0/S, LH, REM CONT, ELEC, CHROME
    DD7 MIRROR I/S, R/V, LT SENSITIVE, C0MPASS
    DD8 MIRROR I/S, R/V, LT SENSITIVE
    DD9 MIRROR O/S, LH & RH, RE4 CONT, ELEC, 8REAKAWAY,
    DE1 SUNSHADE, BACK WINDOW
    DE4 SUNSHADE, REMOVEABLE HATCH ROOF
    DE7 MIRROR O/S, LH & RH, REM CONT, BREAKAWAY, CHROME
    DE9 CONSOLE, FRT COMPT, NONSHIFTING
    DF1 MIRROR O/S, CAMPER TYPE, PAINTED
    DF2 MIRROR O/S, CAMPER TYPE, SST
    DF3 MIRROR O/S, RH, REM CONT, CHROYE
    DF4 MIRROR O/S, LH REM CONT, RH DIRECT CONT, BREAKAWAY,
    DF7 MIRROR O/S, LH & RH, REM CONT, ELEC, DEFOG, CHROME
    DF8 MIRROR O/S, LH & RH, REM CONT, ELEC, BREAKAWAY,
    DG0 MIRROR O/S, LH & RH, REM CONT, ELEC, DEFOG, TINTED
    DG1 MIRROR O/S, LH, DR MTD
    DG2 MIRROR O/S, LH & RH, REM CONT, ELEC, CHROYE
    DG5 MIRROR O/S, LH & RH, WEST COAST TYPE, LARGE
    DG6 MIRROR O/S, LH & RH, REM CONT, ELEC, DEFOG, TINTED
    DG7 MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
    DG8 MIRROR 0/S, LH REM CONT, RH DIRECT CONT, BREAKAWAY,
    DG9 MIRROR O/S, LH & RH, REM CONT, ELEC, SST
    DH6 MIRROR I/S, SUNSHADE, ILLUM, LH & RH
    DK1 CONSOLE, RR COMPT FLOOR
    DK2 MIRROR O/S, LH & RH, REM CONT, ELEC, DEFOG, PAINTED
    DK4 CONSOLE, FRT COMPT FLOOR, MINI OPERATING
    DK6 CONSOLE ROOF, INTERIOR
    DL2 DECAL, WINDOW
    DL4 DECAL, PAINT SCHEME TRITONE, MEDIUM LINE STRIPE
    DL5 DECAL, ROADSIDE SERVICE INFORMATION
    DL8 MIRROR, O/S LH & RH REM CONT, ELEC, DEFOG
    DL9 DECAL, FRT FENDER, RR QUARTER, BLACKOUT
    DM1 DECAL, DR
    DR1 MIRROR O/S, LH & RH, MAN CONT PAINTED
    DR2 MIRROR O/S, LH, MAN CONT, CHROME
    DR3 MIRROR O/S, LH & RH, MAN CONT, CHROME
    DR4 MIRROR O/S, LH & RH, REM CONT, CHROME
    DR5 MIRROR O/S, LH REM CONT, RH MAN CONT, CHROME
    DT4 TRAY, ASH, CIGARETTE LIGHTER
    DV1 SUNSHADE, WINDOW, ROOF
    DW1 STRIPE, BODY SIDE, MIDDLE
    DX1 STRIPE, FRT END, HWD
    DX3 STRIPE, DELETE
    DX4 STRIPE, 2 SIDE
    DX5 STRIPE, 3 SIDE
    DY1 STRIPE, 3 SIDE, VAR. 2
    DY2 STRIPE, 3 SIDE, VAR. 3
    DY5 STRIPE, DECK LID
    D02 PAINT, ENAMEL MASTER
    D03 PAINT, PROCESS, WATER BASE
    D04 PAINT, LOW GLOSS FINISH
    D06 CONSOLE, FRT COMPT FLOOR, ARM REST
    D07 CONSOLE, FRT COMPARTMENT FLOOR, CUSTOM
    D08 PAINT, HIGH GLOSS FINISH
    D09 ARM REST, FRT SEAT
    D1B GEAR, SPEEDO DRIVEN (D1B)
    D1D GEAR, SPEEDO DRIVEN (D1D)
    D1E GEAR, SPEEDO DRIVEN (D1E)
    D1F GEAR, SPEEDO DRIVEN (D1F)
    D1G GEAR, SPEEDO DRIVEN (D1G)
    D1H GEAR, SPEEDO DRIVEN (D1H)
    D1R GEAR, SPEEDO DRIVEN (D1R}
    D1S GEAR, SPEEDO DRIVEN (D1S)
    D1T GEAR, SPEEDO DRIVEN (D1T)
    D1U GEAR, SPEEDO DRIVEN (D1U)
    D1V GEAR, SPEEDO DRIVEN (D1V)
    D1W GEAR, SPEEDO DRIVEN (D1W)
    D1X GEAR, SPEEDO DRIVEN (D1X)
    D1Y GEAR, SPEEDO DRIVEN (D1Y)
    D1Z GEAR, SPEEDO DRIVEN (D1Z)
    D12 PANEL, REAR SEAT, BACK PKG SHELF
    D14 ARM REST, FRT DR, RH & LH
    D2A GEAR, SPEEDO DRIVEN (D2A)
    D2B GEAR, SPEEDO DRIVEN (D2B)
    D2C GEAR, SPEEDO DRIVEN (D2C)
    D2D GEAR, SPEEDO DRIVEN (D2D)
    D2E GEAR, SPEEDO DRIVEN (D2E)
    D2F GEAR, SPEEDO DRIVEN (D2F)
    D2L GEAR, SPEEDO DRIVEN (D2L)
    D2M GEAR, SPEEDO DRIVEN (D2M)
    D2N GEAR, SPEEDO DRIVEN (D2N)
    D2Q GEAR, SPEEDO DRIVEN (D20)
    D20 SUNSHADE, WINDSHIELD, PASS SIDE
    D21 SUNSHADE, WINDSHIELD
    D22 MIRROR O/S, RH BELOW EYELINE, 6 S X 9, AERODYN
    D24 CONTAINER, LITTER
    D25 MIRROR O/S, RH BELOW EYELINE, 6.5 X 9, AERODYN,
    D27 COVER, RR COMPT, TRUNK STOW
    D28 MIRROR O/S ---- DELETE
    D3A GEAR, SPEEDO DRIVEN (D3A)
    D3B GEAR, SPEEDO DRIVEN (D3B)
    D3E GEAR, SPEEDO DRIVEN (D3E)
    D3H GEAR, SPEEDO DRIVEN (D3H)
    D3P GEAR, SPEEDO DRIVEN (D3P)
    D3Q GEAR, SPEEDO DRIVEN (D3Q)
    D3R GEAR, SPEEDO DRIVEN (D3R)
    D3S GEAR, SPEEDO DRIVEN (D35)
    D3T GEAR, SPEEDO DRIVEN (D3T)
    D3U GEAR, SPEEDO DRIVEN (D3U)
    D3V GEAR, SPEEDO DRIVEN (D3V)
    D3W GEAR, SPEEDO DRIVEN (D3W)
    D3X GEAR, SPEEDO DRIVEN (D3X)
    D3Y GEAR, SPEEDO DRIVEN (D3Y)
    D31 MIRROR I/S, R/V,TILT
    D33 MIRROR O/S, LH, REM CONT, PAINTED
    D34 MIRROR I/S, SUNSHADE
    D35 MIRROR O/S, LH REM CONT, RH DIRECT CONT, PAINTED
    D36 MIRROR I/S, R/V, TILT
    D4A GEAR, SPEEDO DRIVEN (D4A)
    D4D GEAR, SPEEDO DRIVEN (D4D)
    D4H GEAR, SPEEDO DRIVEN (D4H)
    D4K GEAR, SPEEDO DRIVEN (D4K)
    D4L GEAR, SPEEDO DRIVEN (D4L)
    D4P GEAR, SPEEDO DRIVEN (D4P)
    D4Q GEAR, SPEEDO DRIVEN (D4Q)
    D4R GEAR, SPEEDO DRIVEN (D4R)
    D4S GEAR, SPEEDO DRIVEN (D45)
    D4U GEAR, SPEED0 DRIVEN (D4U)
    D41 TRAY ASH, RR QUARTER
    D42 SHADE, RR COMPT SECURITY
    D43 MIRROR I/S, R/V, TILT, AUTOMATIC, INCREASED VISIBILITY
    D44 MIRROR O/S, PAINTED
    D45 MIRROR O/S, SST
    D46 MIRROR O/S, WEST COAST TYPE, CLEARANCE LIGHTS
    D47 CONSOLE FRT COMPT FLOOR
    D48 MIRROR O/S, REM CONT, ELEC PAINTED
    D49 MIRROR O/S, LH & RH, CHROME
    D5S GEAR, SPEEDO DRIVEN (D5S)
    D5T GEAR, SPEEDO DRIVEN (D5T)
    D5V GEAR, SPEEDO DRIVEN (D5V)
    D5W GEAR, SPEEDO DRIVEN (D5W)
    D5X GEAR, SPEEDO DRIVEN (D5X)
    D51 MIRROR O/S, LH, DIRECT CONT, PAINTED
    D52 SPOILER, RR END, SPORT
    D53 ORNAMENTATION, EXTR HWD APPLIOUE
    D55 CONSOLE, FRT COMPT, FLOOR
    D58 SPOILER, REAR---DELETE
    D6D GEAR, SPEEDO DRIVEN (D6D)
    D6E GEAR, SPEEDO DRIVEN (D6E)
    D6G GEAR, SPEEDO DRIVEN (D6G)
    D6H GEAR, SPEEDO DRIVEN (D6H)
    D6L GEAR, SPEEDO DRIVEN (D6L)
    D6M GEAR, SPEEDO DRIVEN (D6M)
    D64 MIRROR I/S, RH, SUNSHADE, ILLUM
    D68 MIRROR O/S, LH & RH, REM CONT, PAINTED
    D69 MIRROR O/S, LH, REM CONT, CHROME
    D7A GEAR, SPEEDO DRIVEN (D7A)
    D7B GEAR, SPEEDO DRIVEN (D78)
    D7C GEAR, SPEEDO DRIVEN (D7C)
    D7H GEAR, SPEEDO DRIVEN (D7H)
    D7I GEAR, SPEEDO DRIVEN (D7I)
    D7J GEAR, SPEEDO DRIVEN (D7J)
    D7L GEAR, SPEEDO DRIVEN (D7L)
    D7S GEAR, SPEEDO DRIVEN (D75)
    D7T GEAR, SPEEDO DRIVEN (D7T)
    D7U GEAR, SPEEDO DRIVEN (D7U)
    D7V GEAR, SPEEDO DRIVEN (D7V)
    D7W GEAR, SPEEDO DRIVEN (D7W)
    D7Z GEAR, SPEEDO DRIVEN (D7Z)
    D73 RAIL, HAND, PICK-UP BOX
    D74 MIRROR, I/S, LH SUNSHADE, ILLUM
    D75 HANDLE, O/S, DR
    D77 MIRROR, O/S, WIDE ANGLE, DUAL SYS, SST
    D8A SENSOR, VEH SPD (D8A)
    D8B SENSOR, VEH SPD (D8B)
    D8C SENSOR, VEH SPD (D8C)
    D8D SENSOR, VEH SPD (D8D)
    D8E SENSOR, VEH SPD (D8E)
    D8F SENSOR, VEH SPD (D8F)
    D8G SENSOR, VEH SPD (D8G)
    D8H SENSOR, VEH SPD (D8H )
    D8I SENSOR, VEH SPD (D8I)
    D8K SENSOR, VEH SPD (D8K)
    D8L SENSOR, VEH SPD (D8L)
    D8M SENSOR, VEH SPD (D8M)
    D8N SENSOR, VEH SPD (D8N)
    D80 SPOILER, RR END PNL
    D81 SPOILER, RR, AERO WING
    D83 PAINT, MONOTONE
    D84 PAINT, CUSTOM TWO-TONE
    D85 STRIPE, B0DY SIDE LOWER ACCENT
    D86 PAINT, TWO-TONE, DELUXE
    D88 DECAL, STRIPE, SPORT
    D89 PAINT, SPECIAL DECOR
    D9A SENSOR, VEH SPD (D9A)
    D9B SENSOR, VEH SPD (D9B)
    D9C SENSOR, VEH SPD (D9C)
    D9D SENSOR, VEH SPD (D9D)
    D9E SENSOR, VEH SPD (D9E)
    D9Z GEAR, SPEEDO DRIVEN, SELECTION NOT REQUIRED
    D90 STRIPE, FRT END, B0DY SIDE
    D91 PAINT, TWO-TONE WITH RR QUARTER, UPPER PAINT BREAK
    D92 STRIPE, EXTR DR HANDLE
    D96 STRIPE, B0DY SIDE UPPER
    D98 STRIPE, ACCENT
    D99 PAINT, SPECIAL TWO-TONE, BODY PROVISIONS FOR
    EJ8 EQUIPMENT, FLEETWOOD BODY CO.
    ENV HVAC PROVISIONS, ENGINE DRESS, COMPRESSOR & CONDENSER
    EN2 HVAC PROVISIONS, DELETE
    E1G ADAPTER, SPEEDO (EIG)
    E20 HANDLE, CONVERTIBLE RELEASE
    E24 WWR SIDE, CARGO, HINGED
    E26 PUMP, TILT CAB ASSIST
    E28 HANDLE ASSIST
    E30 B0DY EQUIPMENT, ALUMINUM 14 FT X 96 IN
    E31 BDDY EQUIPMENT, STEEL 10 FT INCR WIDTH
    E32 BODY EQUIPMENT, FORWARD CONTROL VAR 3
    E33 BODY EQUIPMENT, FORWARD CONTROL VAR 4
    E34 BODY EQUIPMENT, STEEL 10 FT STD WIDTH
    E35 BODY EQUIPMENT, FLEETSIDE LESS TAILGATE, PUBX
    E36 BODY EQUIPMENT, ALUUINUM io FT
    E37 BODY EQUIPMENT, UTILITY
    E38 BODY EQUIPMENT, STEEL 12 FT X 96 INCH
    E39 BODY EQUIPMENT, ALUMINUM 12 FT X 96 INCH
    E46 DOOR, RR, 66 INCH, OVERHEAD SLIDING WITH WINDOW
    E48 COVER BODY SIDE, PROTECTIVE
    E50 ROLL BAR
    E52 DOOR RR, 83 INCH, WRAP AROUND
    E53 DOOR RR, 87 INCH, WRAP AROUND
    E54 BODY EQUIPMENT, RR DOOR, W/END GATE WINDOW
    E55 BODY EQUIPMENT, END GATE
    E56 BODY EQUIPMENT, PLATFORM
    E62 BODY EQUIPMENT, STEPSIDE, PUBX
    E63 BODY EQUIPMENT, FLEETSIDE, PUBX
    E65 BODY HEIGHT, INCR INTR TO 80 INCH
    E67 BODY LENGTH, INCR 12 INCH
    E70 WHEEL HOUSINGS, RR DUAL WHEELS
    E71 FLOOR, CARGO, STEEL
    E72 BODY LENGTH, INCR I8 INCH
    E73 BODY WIDTH, INCR INTR TO 86.4 INCH
    E74 BODY WIDTH, INCR INTR TO 90.5 INCH
    E75 BODY EQUIPMENT, FORWARD CONTROL VAR 5
    E76 DOOR, RR, 60 INCH
    E79 DOOR, RR, 74 INCH STRAP HINGES
    E80 LID, RR C0MPT DELETE
    E81 FLOOR, CARGO, WWD
    E88 POCKET, STOWAGE
    E89 PANEL, CAB, DRIVER DR OPENING FILLER WITH WINDOW
    E94 CONVENIENCE PKG, BEAUVILLE
    FE0 SUSPENSION SYSTEM, FRT & RR, ACTIVE
    FE1 SUSPENSION SYSTEM, S0FT RIDE
    FE2 SUSPENSION SYSTEM, RIDE HANDLING
    FE3 SUSPENSION SYSTEM, SPORT
    FE5 SUSPENSION SYSTEM, RIDE l HANDLING ---- DELETE
    FE7 SUSPENSION SYSTEM, FRT & RR HD, VAR 3
    FF4 ARM, TORS BAR SPRING ADJ (C)
    FF5 ARM, TORS BAR SPRING ADJ (D)
    FF6 ARM, TORS BAR SPRING ADJ (E)
    FF7 ARM, TORS BAR SPRING ADJ (F)
    FG2 SHOCK ABSORBERS, FRT & RR, FIRM RIDE
    FG3 SHOCK ABSORBERS, FRT & RR, GAS PRELOADED
    FK2 ARM, TORS BAR SPRING ADJ (A)
    FK3 ARM, TORS BAR SPRING ADJ (B)
    FNT FENDERS DELETION
    FP2 RATIO, TRANSAXLE FINAL DRIVE 3.58
    FP3 RATIO, TRANSAXLE FINAL DRIVE 2.73
    FP5 RATIO, TRANSAXLE FINAL DRIVE 2.95
    FP7 RATIO, TRANSAXLE FINAL DRIVE 3.73
    FQ1 AXLE FRONT, STD RATIO
    FQ2 RATIO, TRANSAXLE FINAL DRIVE 3.48
    FQ6 RATIO, TRANSAXLE FINAL DRIVE 4.12
    FQ8 RATIO, TRANSAXLE FINAL DRIVE 2.96
    FQ9RATIO, TRANSAXLE FINAL DRIVE 3.21
    FS3 SUSPENSION SYSTEM,I-BEAM CONSTRUCTION
    FVM AXLE FRONT, F050, 5000 LBS CAPACITY, HYD
    FVO RATIO, TRANSAXLE FINAL DRIVE 3.67
    FV1 RATIO, TRANSAXLE FINAL DRIVE 3.72
    FV3 RATIO, TRANSAXLE FINAL DRIVE 3.11
    FV4 RATIO, TRANSAXLE FINAL DRIVE 3.71
    FWX SPRING FRONT,5OOO LBS CAPACITY
    FW1 RIDE AND HANDLING, MANUAL ELECTRONIC CONTROLLED
    FW2 RATIO, TRANSAXLE FINAL DRIVE 3.06
    FWS RATIO, TRANSAXLE FINAL DRIVE 4.10
    FW7 RATIO, TRANSAXLE FINAL DRIVE 3.83
    FW9 RATIO, TRANSAXLE FINAL DRIVE 3.43
    FX1 RATIO, TRANSAXLE FINAL DRIVE 3.94
    FX2 RATIO, TRANSAXLE FINAL DRIVE 2.66
    FX3 RIDE AND HANDLING, AUTOMATIC ELECTRONIC CONTROLLED AAA
    FX4 RATIO, TRANSAXLE FINAL DRIVE 3.35
    FX8 RATIO, TRANSAXLE FINAL DRIVE 3.61
    FY1 RATIO, TRANSAXLE FINAL DRIVE 2.36
    FY3 RATIO, TRANSAXLE FINAL DRIVE 3.79
    FY5 RATIO, TRANSAXLE FINAL DRIVE 3 52
    F01 FRAME, HEAVY DUTY
    F16 RATIO, TRANSAXLE FINAL DRIVE 2.53
    F17 RATIO, TRANSAXLE FINAL DRIVE 2.84
    F25 RATIO, TRANSAXLE FINAL DRIVE 3.32
    F40 SUSPENSION SYSTEM, FRT, RR, HD, VAR I
    F41 SUSPENSION SYSTEM, FRT, RR, FIRM RIDE, HANDLING
    F42 SUSPENSION SYSTEM, FRT, HD
    F44 CHASSIS, HEAVY DUTY
    F47 AXLE FRONT, 2 73 RATIO
    F51 SHOCK ABSORBERS, FRT & RR, HD
    F58 STASILIZER SHAFT FR, HD
    F59 STABILIZER SHAFT FR,
    F60 SPRING FRONT, HEAVY OUTY
    F61 STABILIZER SHAFT,RR
    F62 RATIO TRANSAXLE FINAL DRIVE 2.39
    F66 SUSPENSION SYSTEM, FRT, AIR BAG & SEATS, HD
    F67 RATIO, TRANSAXLE FINAL DRIVE 3.19
    F68 RATIO, TRANSAXLE FINAL DRIVE 3.45
    F72 SPRING HEAVY DUTY, VAR 2
    F73 DRIVE, ALL WHEEL
    F75 RATIO, TRANSAXLE FINAL DRIVE 3.18
    F77 RATIO, TRANSAXLE FINAL DRIVE 3.737
    F79 RATIO, TRANSAXLE FINAL DRIVE 2.97
    F93 SPRING FRONT,6000 LB, MULTILEAF
    GH0 AXLE REAR, 3.54 RATIO
    GH2 AXLE REAR, 2.29 RATIO
    GH3 AXLE REAR, 2.77 RATIO
    GH4 AXLE REAR, 2.92 RATIO
    GK9 AXLE REAR, 4.63 RATIO
    GL3 AXLE REAR, 6.17 RATIO
    GM1 AXLE REAR, 2.59 RATIO
    GM3 AXLE REAR, 3.45 RATIO
    GM8 AXLE REAR, 2.56 RATIO
    GQ1 AXLE, STD RATIO
    GS4 AXLE REAR, 3.70 RATIO
    GTY AXLE, WIDE TRACK
    GT4 AXLE REAR, 3.73 RATIO
    GT5 AXLE REAR, 4.10 RATIO
    GT7 AXLE REAR, 3.33 RATIO
    GT8 AXLE REAR, 4.10 RATIO
    GU1 AXLE REAR, 2.41 RATIO
    GU2 AXLE REAR, 2.73 RATIO
    GU4 AXLE REAR, 3.08 RATIO
    GU5 AXLE REAR, 3.23 RATIO
    GU6 AXLE REAR, 3.42 RATIO
    GV2 AXLE REAR, 5.83 RATIO
    GV4 AXLE REAR, 3.36 RATIO
    GV8 AXLE REAR, 2.72 RATIO
    GW4 AXLE REAR, 3.31 RATIO
    GW6 AXLE REAR, 3.27 RATIO
    GW9 AXLE REAR, 2.93 RATIO
    GX3 RATIO,TRANSAXLE FINAL DRIVE 3.33
    GYS RATIO TRANSAXLE FINAL DRIVE 3.65
    G44 AXLE REAR 3.07 RATIO
    G5O SPRING REAR, HEAVY DUTY, VAR 1
    G51 SPRING REAR, HEAVY DUTY, VAR 2
    G52 SPRING, RR, 15000 LBS
    G60 SPRING REAR, AUXILIARY
    G66 LEVEL CONTROL, MAN, AIR
    G67 LEVEL CONTROL, AUTO, AIR
    G69 LEVEL CONTROL, AUTO, AIR, HD
    G72 AXLE REAR, 2.14 RATIO
    G75 AXLE REAR, 3.62 RATIO
    G80 AXLE POSITRACTION, LIMITED SLIP
    G87 RING GEAR, 8.50 INCH
    G89 RING GEAR, 7.50 INCH
    G92 AXLE REAR RATIO, PERFORMANCE
    G9S AXLE REAR RATIO, ECONOMY
    HA3 AXLE REAR, 5.29 RATIO, SINGLE SPEED
    HC4 AXLE REAR, 4.56 RATIO
    HC7 AXLE REAR, 5.13 RATIO, 7500 LBS, SINGLE SPEED
    HC8 AXLE REAR, 3.21 RATIO, SINGLE SPEED, TRUCK
    HE3 AXLE REAR, 3.07 RATIO, 3500 LBS, SINGLE SPEED,
    HF7 AXLE REAR, 4.56 RATIO, IOOOO LBS, DANA 70, SINGLE
    HF8 AXLE REAR, 4.88 RATIO
    HK1 AXLE REAR, 2.87 RATIO
    HK9 AXLE REAR, 5.86 RATIO 10000 LBS, SINGLE SPEED
    HPR HEADLAMPS, DUAL, RECTANGULAR
    H04 AXLE REAR, 4.11 RATIO, SINGLE SPEED
    IFD TRIM, INTERIOR DESIGN (FD)
    IF3 TRIM, INTERIOR DESIGN (F3)
    ILD TRIM, INTERIOR DESIGN (LD)
    IL3 TRIM INTERIOR DESIGN (L3)
    JAF BRAKE, PROVISIONS EUROPE
    JA1 BRAKE, LIGHT WEIGHT DISC DRUM
    JA2 BRAKE, HEAVY WEIGHT DISC DRUM
    JA3 BRAKE, SYSTEM, WAGON DISC DRUM
    JA4 BRAKE, SYSTEM, PWR FRT DISC, RR DRUM, CAST IRON
    JA5 BRAKE, SYSTEM, SPORT COUPE DISC DRUM
    JA6 BRAKE, EXTRA LIGHT WEIGHT DISC DRUM
    JA7 HANDLE, PARK BRAKE RELEASE, LEATHER
    JA8 BRAKE, MEDIUM WEIGHT DISC DRUM
    JB1 BRAKE, MANUAL, DISC/DRUM, 4300 LBS
    JB3 BRAKE, POWER, DISC/DRUM, 4600 LBS
    JB5 BRAKE, POWER, DISC/DRUM, 6400 LBS
    JB6 BRAKE, POWER, DISC, DRUM 7200 LBS
    JB7 BRAKE, POWER, DISC, DRUM 8400 L85
    JB8 8RAKE, POWER, DISC, DRUM 10000 LBS
    JC4 BRAKE, POWER, DISC, DRUM 5600 LBS
    JC7 BRAKE, POWER, DISC/DRUM, 12000 LBS
    JCB BRAKE, POWER, DISC/DISC, 20000 LBS
    JD3 BRAKE, HYD POWER, DISC/DRUM
    JD5 BRAKE, DUAL POWER, DISC/DRUM, 6400 LBS
    JD6 BRAKE, HYD POWER, DISC/DRUM, 7200 LBS
    JD7 BRAKE, HYD POWER, DISC/DRUM, 8400 LBS
    JE1 BRAKE, SYSTEM, EUROPE
    JF9 BRAKE, HYD POWER, 4 WHEEL DISC
    JG1 SHAFT, PROP, ALUMINUM
    JL2 BRAKE, FRT DISC, SINGLE PISTON
    JL6 BRAKE, SYSTEM, MAN, FRT DISC, RR DRUM, CAST IRON
    JL9 BRAKE, SYSTEM, PWR, FRT a RR OISC, ANTILOCK, FRT W
    JM3 BOOSTER, BRAKE, 240MM TANDEM, HIGH FLOW
    JM4 BRAKE, SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON,
    JM5 BOOSTER, BRAKE, 200MM TANDEM, HIGH FLOW
    JM7 BOOSTER, BRAKE HYD HI PERF, DELCO-MORAINE
    JM8 BRAKE SYSTEM PWR, FRT DISC RR DRUM, ALUMINUM,
    JIF BRAKE PROVISION SPECIAL TO SUIT FOREIGN REGULATION
    J41 BRAKE SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON
    J42 BRAKE SYSTEM, PWR. FRT DISC, RR DRUM, ALUMINUM
    J50 BRAKE SYSTEM, POWER
    J55 BRAKE SYSTEM, HEAVY DUTY
    J85 BRAKE SYSTEM, PWR, FRT & RR DISC
    KA1 HEATER SEAT
    KB2 HEADS ENGINE CAST IRON
    KB9 CONTROL, ELECTRONIC, TRANS SHIFT
    KC4 COOLING SYSTEM, ENG OIL
    KD1 COOLING SYSTEM, TRANS OIL
    KG0 GENERATOR, 74 AMP
    KG6 GENERATOR, 96 AMP
    KG9 GENERATOR, 140 AMP
    KL5 CONVERSION, NATURAL GAS
    KL7 CONVERSION, LP GAS
    KM9 MANIFOLD, INLET, ALUMINUM
    KP2 TIMER, RETAINED ACCESSORY POWER
    K42 GENERATOR,124 AMP
    K01 FAN, CLUTCH DRIVE, ON/OFF
    K05 HEATER ENG, BLOCK
    K06 FAN, ENG COOLING
    K07 HEATER, FUEL
    K09 GENERATOR, 120 AUP
    K10 CORD, ENG BLOCK HTR ----- DELETE
    K15 LINES, FUEL VAPOR RETURN
    K19 REACTOR SYSTEM, AIR INJECTION
    K20 MODULE, ELECTRONIC COHTROL
    K22 GENERATOR, 94 AMP
    K30 CRUISE CONTROL, AUTOMATIC
    K34 CRUISE CONTROL, AUT0MATIC, ELECTRONIC
    K35 CRUISE CONTROL, VACUUM RESUME
    K45 AIR CLEANER, HEAVY DUTY
    K46 AIR CLEANER, HEAVY OUTY, PRE-CLEANER
    K60 GENERATOR, 100 AMP
    K61 GENERATOR, 97 AMP
    K64 GENERATOR, 78 AMP
    K65 GENERATOR, 9S AMP
    K68 GENERATOR,105 AMP
    K69 KEY ADDITIONAL IGNITION
    K70 PULSAIR, AIR INJECTION, ENGINE
    K73 GENERATOR, 70 AMP
    K77 GENERATOR, 56 AMP
    K79 GENERATOR, 42 AMP
    K8I GENERATOR, 66 AMP
    K82 GENERATOR, 75 AMP
    K85 GENERATOR, 37 AMP
    K90 GENERATOR,108 AMP
    K91 GENERATOR, 65 AMP
    K96 GENERATOR, 55 AMP, BUILT-IN REGULATOR
    K97 GENERATOR, 80 AMP, BUILT-IN REGULATOR
    K99 GENERATOR, 85 AMP
    LA5 ENGINE, GAS, 4 CYL, 1.8L, MFI, OHC, TUR80
    LA7 ENGINE, DIESEL, 4 CYL, 1.5L, ISUZU
    LB1 ENGINE, GAS, 6 CYL, 4.3L, 4BBL, V6, 90 DEG
    LB4 ENGINE, GAS, 6 CYL, 4.3L, TBI, V6, 90 DEG
    LB6 ENGINE, GAS, 6 CYL, 2.8L, UFI, V6, TRANSVERSE
    LB8 ENGINE, GAS, 6 CYL, 2.8L, MFI, V6, LONGITUDINAL
    LB9 ENGINE, GAS, 8 CYL, 5.0L, MFI, HO
    LC0 ENGINE, GAS, 4 CYL, 1.8L, UFI, TUR80
    LC1 ENGINE, GAS, 6 CYL, 2.8L, 2B8L, V6, LONGITUDINAL
    LC2 ENGINE, GAS, 6 CYL, 3.8L, 4FI, V6, TURBO, HO
    LC3 ENGINE, GAS, 6 CYL, 3.8L, 2B8L, V6, 90 DEG
    LC5 ENGINE, GAS, 4 CYL, 1.5L, 2B8L
    LC6 ENGINE, GAS, 6 CYL, 2 0L, MFI, OHC
    LC7 ENGINE, GAS, 8 CYL, 4 IL, MFI
    LC9 ENGINE, GAS, 4 CYL, 1.6L, 2BBL, TOYOTA
    L02 ENGINE, GAS, 4 CYL, 2.3L, MFI, DOHC
    LD4 ENGINE, GAS, 6 CYL, 4.1L, 4FI
    LD5 ENGINE, GAS, 6 CYL, 3.8L, 2B8L, V6
    LE2 ENGINE, GAS, 6 CYL, 2.8L, 2BBL, V6, TRANSVERSE
    LE3 ENGINE, GAS, 6 CYL, 4.1L, 2BBL, VARAJET STANDARD
    LE4 ENGINE, GAS, 4 CYL, 2.0L, MFI, OHC
    LE8 ENGINE, GAS, 8 CYL, 7.4L, 4BBL, HO
    LE9 ENGINE, GAS, 8 CYL, 5.0L, 4BBL, HI COMP
    LF3 ENGINE, GAS, 8 CYL, 5.0L, TRUCK
    LF5 ENGINE, GAS, 8 CYL, 5.7L, 2BBL, HO
    LF7 ENGINE, DIESEL, 4 CYL, 3.6L
    LF8 ENGINE, GAS 6 CYL 3.0L, MFI, V6, REGULAR FUEL
    LF9 ENGINE, DIESEL, 8 CYL, 5.7L
    LG0 ENGINE, GAS, 4 CYL, 2.3L, MFI, DOHC, HO
    LG2 ENGINE, GAS, 6 CYL, 3.8L, SFI, V6
    LG3 ENGINE, GAS, 6 CYL, 3.8L, MFI V6, HO
    LG4 ENGINE, GAS, 8 CYL, 5.0L, 4BBL
    LGS ENGINE, GAS, 6 CYL, 3.1L, 4FI, V6, TURBO
    LG6 ENGINE, GAS, 6 CYL, 3.1L, TBI, V6,
    LG7 ENGINE, GAS, 6 CYL, 3.3L, MFI, V6
    LGB ENGINE, GAS, 8 CYL, 5.OL, 4BBL, HO
    LG9 ENGINE, GAS, 6 CYL, 2.8L, MFI, V6, TURBO
    LH0 ENGINE, GAS, 6 CYL, 3.1L, MFI, V6
    LH6 ENGINE, DIESEL, 8 CYL, 6.2L
    LH7 ENGINE, GAS, 6 CYL, 2.8L, 2BBL, 60 DEG, TRANSVERSE
    LH8 ENGINE, GAS 4 CYL, 1.8L, 1 TBI, OHC
    LJ5 ENGINE, DIESEL, 4 CYL, 1.8L
    LK9 ENGINE, GAS, 6 CYL, 3.OL, 2BEL, V6
    LL2 ENGINE, GAS, 6 CYL, 2.8L, 1 TBI V6 60 DEG, HO
    LL4 ENGINE, DIESEL, 8 CYL, 6.2L, HEAVY DUTY
    LL8 ENGINE, GAS, 4 CYL, 2.OL, 1 TBI, HO
    LM1 ENGINE, GAS, 8 CYL, 5.7L, 4BBL
    LM3 ENGINE, GAS, 4 CYL, 2.2L, 1 TBI
    LM9 ENGINE, GAS, 6 CYL, 3.8L, MFI, V6, TUR8D
    LN2 ENGINE, GAS, 4 CYL, 2.2L, MFI
    LN3 ENGINE, GAS, 6 CYL, 3.8L, MFI, V6 (3800 SERIES)
    LN7 ENGINE, GAS, 6 CYL, 3.0L, MFI V6 HO
    LN8 ENGINE, GAS, 4 CYL, 2.5L 1 TBI LONGITUDINAL
    LP2 ENGINE, GAS, 3 CYL, 1.OL TBI, OHC, SUZUKI
    LPS ENGINE, GAS, 8 CYL, 5.7L 2BBL, HO
    L01 ENGINE, GAS, 6 CYL, 3.4L, MFI, OHC, V6, HO
    L02 ENGINE, GAS, 4 CYL, 2.OL, MFI
    L05 ENGINE, GAS, 4 CYL, 2.OL, 1 TBI
    L06 ENGINE, GAS, 8 CYL, 4.5L, MFI, HO
    LQ7 ENGINE, DIESEL, 4 CYL, 2.2L, ISUZU
    LQ9 ENGINE, GAS, 4 CYL, 2.5L, 1 TBI, LONGITUDINAL
    LR1 ENGINE, GAS, 4 CYL, 1.95L, 2BBL
    LR2 ENGINE, GAS, 6 CYL, 2.8L, 2BBL, V6, 60 DEG, TRUCK
    LR6 ENGINE, GAS, 8 CYL, 4.5L, 2TBI
    LR8 ENGINE, GAS, 4 CYL, 2 .8L, 1 TBI,
    LR9 ENGINE, GAS, 4 CYL, 2.0L, 2BBL
    LSA ENGINE, DRESS KIT, 4.3L, UPS RETROFIT
    LST ENGINE, DIESEL, 4 CYL, 3.9L, CUMMINS MBT
    LS3 ENGINE, GAS, 3 CYL, 1.OL, MFI, OHC, TURBO, SUZUKI
    LS5 ENGINE, GAS, 4 CYL, 1.6L. I TBI, OHC, ALUMINUM,
    LS9 ENGINE, GAS, 8 CYL, 5.7L, 4BBL
    LT1 ENGINE, GAS, 8 CYL, 5.7L, MFI, HO
    LT2 ENGINE, GAS, 4 CYL, 2.OL, TBI, OHC
    LT3 ENGINE, GAS, 4 CYL, 2.OL, MFI, OHC, TURB0
    LT5 ENGINE, GAS, 8 CYL, 5.7L, MFI, OHC
    LT6 ENGINE, DIESEL, 6 CYL, 4.3L, V6, LONGITUDINAL
    LT7 ENGINE, DIESEL, 6 CYL, 4.3L V6, TRANSVERSE
    LT8 ENGINE, GAS, 8 CYL, 4.1L, 2T8I
    LT9 ENGINE, GAS, 8 CYL, 5.7L, 488L, HD
    LU2 ENGINE, GAS, 6 CYL, 4.3L, TBI V6, 90 DEG, HO
    LV2 ENGINE, GAS, 8 CYL, 5.OL, 4BBL
    LV4 ENGINE, GAS, 4 CYL, 1.6L, OHC, TURB0, PREMIUM FUEL
    LV6 ENGINE, GAS, 4 CYL, 1.8L, MFI
    LW0 ENGINE, GAS, 4 CYL, 1.6L, MFI, OHC, HO
    LA2 ENGINE, GAS, 8 CYL, 4.5L, MFI
    LAS ENGINE, GAS, 6 CYL, 3.0L, TURB0
    LX8 ENGINE, DIESEL, 4 CYL, 2.OL TURBO
    LY5 ENGINE, GAS, 4 CYL 1.6L 2BBL REGULAR FUEL
    LY9 ENGINE, GAS, 3 CYL 1.OL 2BBL OHC, SUZUKI
    L01 ENGINE, GAS, 4 CYL 1.6L MFI, OHC
    L03 ENGINE, GAS, 8 CYL 5.OL TBI
    L04 ENGINE, DIESEL, 4 CYL, 3.0L
    L05 ENGINE, GAS, B CYL, 5.7L, 1 TBI, V8
    L11 ENGINE, GAS, 4 CYL, 1.9L, PREMIUM FUEL
    L17 ENGINE, GAS, 4 CYL, I.6L, 2BBL
    L19 ENGINE, GAS, 8 CYL, 7.4L, 1TBI, VB
    L22 ENGINE, GAS, 6 CYL, 4.1L, 1BBL
    L25 ENGINE, GAS, 6 CYL, 4.BL, 1BBL
    L26 ENGINE, GAS, 8 CYL, 4.9L, MFI, V8
    L27 ENGINE, GAS, 6 CYL, 3.8L, MFI, V6, HO (3800 SERIES)
    L32 ENGINE, GAS, 6 CYL, 3.4L, MFI, V6
    L34 ENGINE, GAS, 4 CYL, 2 OL, MFI, DOHC
    L35 ENGINE, GAS, 6 CYL, 4 3L, CPI, V6, 90 DEG
    L37 ENGINE, GAS, 8 CYL, 4.6L, V8 OHC
    L38 ENGINE, GAS, 4 CYL, 2.SL, 1 TBI, HO
    L40 ENGINE, GAS, 4 CYL, 2.3L, MFI SOHC
    L44 ENGINE, GAS, 6 CYL, 2.8L, MFI V6, HO
    L48 ENGINE, GAS, 4 CYL, 1.4L, MFI, PREMIUM FUEL
    L49 ENGINE, DIESEL, 8 CYL, 6. SL
    L54 ENGINE, GAS, 4 CYL, 1.8L, MFI, REG FUEL
    L65 ENGINE, DIESEL, 8 CYL, 6.5L. TURB0, HO
    L67 ENGINE, GAS, 6 CYL, 3.8L, YFI, V6, SUPERCHARGED
    L68 ENGINE, GAS, 4 CYL, 2.5L, 1 TBI, SHORTER LENGTH
    L69 ENGINE, GAS, 8 CYL, 5.OL, 4BBL, HO
    L73 ENGINE, GAS, 4 CYL, I 6L, T8I, REGULAR FUEL
    L78 ENGINE, ALCOHOL, 4 CYL, 2.0L, MFI, OHC
    L80 ENGINE, GAS, 6 CYL, 2.5L, MFI, HO
    L82 EN6INE, GAS, 6 CYL, 3.lL, MFI, V6, HO
    L91 ENGINE, GAS, 4 CYL, I.6 L, UFI, WHC
    L92 ENGINE, DIESEL, 4 CYL, 1.9 L, TURBO
    L93 ENGINE, DIESEL, 6 CYL, 2.5L, TURB0
    L96 ENGINE, GAS, 8 CYL, 5.7L, MFI
    MAE MARKETING AREA, EUROPE
    MAG MARKETING AREA, GULF STATES
    MAI MARKETING AREA, ISRAEL
    MAJ MARKETING AREA, JAPAN
    MAK MARKETING AREA, ENGLAND UNITED KINGDOM)
    MAQ MARKETING AREA, IRAQ
    MAS MARKETING AREA, SAUDI ARABIA
    MAU MARKETING AREA, UNREGULATED
    MB1 TRANSMISSION, MAN 5 SPD, BORG WARNER, 76MM, 4.03
    MB4 TRANSMISSION, MAN 5 SPD, BORG WARNER, 77MM, 3.76
    MB6 TRANSMISSION, MAN 5 SPD, BORG WARNER, 76MM, 4.03
    MC0 TRANSMISSION, MAN 4 SPD, GETRAG, 64MM, 1ST, 4.00
    MC4 TRANSMISSION, MAN 5 SPD, BORG WARNER, 77MM, 3.35
    MC5 TRANSMISSION, MAN 5 SPD, B0RG WARNER, 774M, 2.55
    MC9 TRANSMISSION, MAN 4 SPD, B0RG WARNER, 77MM, 4.03
    MD2 TRANSMISSION, AUTO 3 SPD, STRASBOURG, THM 180C,
    MD3 TRANSMISSION, AUTO 3 SPD, STRASBOURG, THM 180, OPEN
    MD5 TRANSMISSION, MAN 5 SPD, GETRAG, 76MM, 3.92 IST,
    MD8 TRANSMISSION, AUTO 4 SPD, THM 700 R4
    MD9 TRANSMISSION, AUTO 3 SPD, THU 125 CLUTCH
    ME2 TRANSMISSION, MAN 5 SPD, NEW PROCESS 55OO, 6.29
    ME9 TRANSMISSION, AUTO 4 SPD, THM 440 T4
    MF2 TRANSMISSION, MAN 4 SPD, B0RG WARNER, 774M, 3.76
    MF4 TRANSFER CASE, NP205, 1.96 LO RANGE
    MG1 TRANSMISSION, MAN 5 SPD, MUNCIE, 76MM 3.50 1ST,
    MG2 TRANSMISSION, MAN 5 SPD, GETRAG, 76MM 3.50 1ST,
    MG3 TRANSMISSION, MAN 5 SPD, MUNCIE, 76MM, 3.92 1ST,
    MG4 TRANSMISSION, MAN 5 SPD, ISUZU, 72MM, 3.41 1ST,
    MGS TRANSMISSION, MAN 5 SPD, GETRAG, 84MM, 4.00 1ST,
    MH1 TRANSMISSION, AUTO 4 SPD, THM F-4, ELECTRONIC CONV
    MH2 TRANSMISSION, MAN 5 SPD, BORG WARNER, 77MM, 3.50
    MH3 TRANSMISSION, MAN 5 SPD, BORG WARNER, 77MM, 3.50
    MH5 TRANSMISSION, MAN 4 SPD, DOUG NASH CO, 83MM, 2.88
    MK2 TRANSMISSION, MAN 4 SPD, DOUG NASH CO, 83MM, 2.88
    MK4 TRANSMISSION, MAN 5 SPD, B0RG WARNER, 77MM, 3.76
    MK5 TRANSMISSION, MAN 5 SPD, B0RG WARNER, 77MM, 3.50
    MK6 TRANSMISSION, MAN 5 SPD, B0RG WARNER, 2.95 1ST, O/D
    MK7 TRANSMISSION, MAN 5 SPD, ISUZU, 3.91 IST, 1.45 3RD,
    ML2 TRANSMISSION, MAN 5 SPD, B0RG WARNER, 77MM, 4.03
    ML3 TRANSMISSION, MAN 5 SPD, B0RG WARNER, 77MM, 3.76
    ML8 TRANSMISSION, MAN S SPD, BORG WARNER, 77MM , 3 SO
    ML9 TRANSMISSION, MAN 6 SPD, ZF, 90UM, 2.66 IST, O/D
    MM3 MERCHANDISED TRANS, MAN 3 SPD PROVISIONS
    MM4 MERCHANDISED TRANS, MAN 4 SPD PROVISIONS
    MM5 MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
    MPW TRANSMISSION, MAN 4 SPD, B0RG KARNER, IO9MM, 4.02
    MR2 TRANSMISSION, MAN 4 SPD, MUNCIE, 76MM, 3.50 1ST,
    MR3 TRANSMISSION, MAN S SPD, ISUZU, 76MM, 3.73 1ST,
    MR8 TRANSMISSION, MAN 5 SPD, ISUZU, 76MM, 3.73 1ST,
    MS7 TRANSMISSION, AUTO 4 SPD, TOYOTA, ELECTRONIC CONV
    MT1 TRANSMISSION, AUTO, 4 SPD, THM R2
    MT2 TRANSMISSION, MAN 5 SPD, ISUZU 76MM, 3.72 1ST, .74
    MT8 TRANSMISSION, MAN 5 SPD, NEW PROCESS, 1O9MM, 6.34
    MU1 TRANSMISSION, MAN 5 SPD, HMD, 76MM, 3 77 1ST, 1.03
    MV2 TRANSMISSION, MAN 5 SPD, 3.42 1ST
    MV4 TRANSMISSION, AUTO THM 350, CONV CLUTCH
    MV5 TRANSMISSION, MAN 5 SPD, HMD, 76MM, 3. SO 1ST, 1.03
    MV9 TRANSMISSION, AUTO 3 SPD, THM 200, CONV CLUTCH
    MW1 TRANSMISSION, MAN 5 SPD, 80RG WARNER, 77MM, 4.03
    MW4 TRANSMISSION, MAN 5 SPD, GETRAG, 84MM, 1ST 3.54,
    MW9 TRANSMISSION, AUTO 4 SPD, THM 200, CONV CLUTCH
    MXO MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
    MX1 MERCHANDISED, TRANS, AUTO PROVISIONS
    MX2 TRANSMISSION, AUTO 3 SPD, THM 350, CONV CLUTCH 3
    MX6 TRANSMISSION, MAN 4 SPD, MUNCIE, 76MM, 3.31 1ST,
    MY1 TRANSMISSION, MAN 4 SPD, BRASIL, 70MM, 3.75 1ST
    MY2 TRANSUISSION, MAN S SPD, HMD, 85MM, 4.D2 1T, O/D
    MY5 TRANSMISSION, MAN 5 SPD, HMD, 3.50 1ST, 1.03
    MY6 TRANSMISSION, MAN 4 SPD, NEW PROCESS, 89MM, 3.09
    MY7 TRANSMISSION, MAN S SPD, ISUZU, 3.92 1ST, 1.33 3RD,
    MY8 TRANSMISSION, MAN 4 SPD, MUNCIE, 75MM, 3.53 1ST,
    MZU TRANSMISSION, MAN 4 SPD, NEW PROCESS, 435
    M08 TRANSMISSION, MAN 4 SPD, BORG ARNER, 77MM, 3.50
    M10 TRANSMISSION, AUTO 4 SPD, IZUZU, ELECTRONIC CONV
    M13 TRANSMISSION, AUTO 4 SPD, HMD F31
    M17 TRANSMISSION, MAN 4 SPD, MUNCIE, 76MM, 3.31 1ST,
    Ml9 TRANSMISSION, MAN 4 SPD, MUNCIE, 76MM, 3.53 1ST,
    M20 TRANSMISSION, MAN 4 SPD, 117MM, 6.55 1ST
    M21 TRANSMISSION, MAN 4 SPD, 82MM, 2.43 1ST
    M26 TRANSMISSION, MAN 4 SPD, MUNCIE, 76MM, 3.50 1ST,
    M27 TRANSMISSION, MAN S SPD, GETRAG, 84MM, 2.46 1ST,
    M29 TRANSMISSION, MAN 6 SPD, BORG WARNER 85MM, 2.97
    M31 TRANSMISSION, AUTO THM 250 CONV CLUTCH
    M32 TRANSMISSION, MAN 5 SPD ISUZU 76MM 3.72 1ST, .70
    M33 TRANSMISSION, AUTO 3 SPD, TORQUE CONV
    M34 TRANSMISSION, AUTO 3 SPD, THM 125
    M39 TRANSMISSION, MAN 5 SPD B0RG WARNER, 77MM, 2.95
    M40 TRANSMISSION, AUTO 3 SPD, TORQUE CONV VAR 1
    M62 TRANSMISSION, MAN 3 SPD, 76MM, 2.85 RATIO
    M64 TRANSMISSION, MAN 3 SPD, 76MM, 3.5O RATIO
    M73 TRANSMISSION, MAN 4 SPD, ISUZU, 77.5MM, 4.09 RATIO
    M75 TRANSMISSION, MAN 5 SPD, 77MM, 3.40 IST
    M77 TRANSMISSION, MAN 4 SPD, BORG WARNER, 77MM, 4.07
    M79 TRANSMISSION, MAN 5 SPD, ISUZU, 72MM, 3.41 IST,
    NA1 EMISSION SYSTEM GVW, LESS THAN 85OO LB
    NA2 EMISSION SYSTEM, GERMANY
    NA4 EMISSION SYSTEM, GVW,AB0VE 8500 LB
    NA5 EMISSION SYSTEM, FEDERAL, TIER O
    NA6 EMISSION SYSTEM, HIGH ALTITUDE REQUIREMENTS
    NA9 EVAPORATIVE SYSTEM, EMISSION
    NB1 EMISSION SYSTEM, CLOSED LOOP
    NB2 EMISSION SYSTEM , CALIFORNIA , TIER O
    NB3 EMISSION SYSTEM, ABOVE IOO0O LB GVW
    NB5 EXHAUST SYSTEM, SINGLE
    NC3 TAILPIPE, MODIFICATIONS
    NC5 EXHAUST SYSTEM, OVAL VERTICAL TAILPIPES, CHROME
    NC6 EXHAUST SYSTEM, SPORTY
    NC7 EMISSION OVERRIDE, FEDERAL SYSTEM
    NC6 EMISSION SYSTEM, CALIFORNIA, ULEV
    ND3 LABEL EMISSION, CONTROL
    NE2 FUEL TANK, 151L, 40 GAL
    NF2 EMISSION SYSTEM, FEDERAL, TIER 1
    NH2 FUEL TANK, 113L, 30 GAL
    NJ8 FUEL TANK, 129L, 34 GAL
    NJ9 FUEL TANK 80 GAL LH OR RH FILL
    NK3 STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER
    NK4 STEERING WHEEL, SPORT LEATHER
    NK5 STEERING WHEEL, STANDARD
    NK7 FUEL TANK, 117L, 31 GAL
    NL2 FUEL TANK, AUXILIARY
    NL4 FUEL TANK, 303L, 80 GAL
    NL6 FUEL TANK, 13 GAL, SINGLE
    NL7 FUEL TANK,I25L, 33 GAL
    NL8 FUEL TANK,I32L, 35 GAL, LH, RECT, STEEL
    NL9 FUEL TANK,IO2L, 27 GAL
    NM1 EMISSION SYSTEM, SWITZERLAND, SWEDEN
    NM5 EMISSION SYSTEM, CANADIAN REOUIREMENTS
    NM6 EMISSION SYSTEM, RECALIBRATED
    NM8 LEADED FUEL SYSTEM,
    NN1 EMISSION SYSTEM, DUAL BED MONOLITH CONV
    NN4 FUEL TANK, 227L, 60 GAL
    NN5 EMISSION OVERRIDE, CALIFORNIA SYSTEM, FEDERAL
    NN7 LOCK, FUEL FILLER DR ---- DELETE
    NN8 EMISSION OVERRIDE, UNLEADED FUEL, EXPORT
    NN9 EMISSION SYSTEM, LEADED FUEL, EXPORT
    NPG SHIELD, NOISE ABATEMENT
    NP1 TRANSFER CASE, ELECTRONIC SHIFT CONT, TWO SPEED
    NP5 STEERING WHEEL, LEATHER WRAPPED
    NP7 STEERING COLUMN, EEC APPROVED
    NQE FUEL TANK,20 GAL, SINGLE
    NQ5 CAP, STRG WHL HORN, DELUXE
    NV5 SHIELD, DIFFERENTIAL CARRIER
    NV7 STEERING, POWER, VARIABLE EFFORT
    NWO WHEEL, 16 X 6.5, CAST ALUMINUM
    NW9 TRACTION CONTROL, ELECTRONIC
    NXX EVAPORATIVE SYSTEM, FEDERAL
    NX1 WHEEL, I3 X 5.5, LIGHT METAL ALLOY
    NXB WHEEL, 14 X 6, LIGHT 4ETAL ALLOY
    NY1 SHIELD, FUEL TANK
    NY7 SHIELD, TRANSFER CASE
    NZZ SALES PACKAGE, SKID PLATE OFF ROAD SPOT
    N04 LOCK CONTROL, FUEL FILLER CAP, REM CONT
    N05 LQCK CONTROL, FUEL FILLER CAP
    N08 LQCK CONTROL, FUEL FILLER DR REM CONT
    N09 LOCK CONTROL, FUEL FILLER DR
    N10 EXHAUST SYSTEM DUAL
    N14 CONVERSION METHANOL FUEL
    N18 COVER SIMULATED WIRE WHEEL, LOCKING PACKAGE
    N23 FUEL TANK, 83L, 22 GAL
    N24 WHEEL I5 X 7 ALUMINUM CAST, 5 INCH BOLT CIRCLE
    N25 EXHAUST, EXTENSION
    N27 STEERING WHEEL, 2 SPOKES STD
    N31 STEERING WHEEL, CUSTOM
    N33 STEERING COLUMN, TILT TYPE
    N34 STEERING WHEEL, WOOD GRAINED PLASTIC
    N36 STEERING WHEEL, 4 SPOKES, SPORT
    N37 STEERING COLUMN, TILT, TELESCOPING
    N40 STEERING, POWER, NON-VARIABLE RATIO
    N41 STEERING, POWER, VARIABLE RATIO
    N45 STEERING WHEEL, 3 SPOKES
    N46 STEERING WHEEL, FOUR SPOKES
    N51 STEERING, MANUAL
    N54 STEERING WHEEL, 3 SPOKE, SPORT
    N60 WHEEL, ALUMINUM, PAINTED
    N64 WHEEL & TIRE,SPARE, SPACE SAVER, ALUMINUM
    N65 WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
    N66 WHEEL, RALLY TYPE , VARI
    N67 WHEEL, RALLY TYPE , VAR2
    N68 WHEEL, I5 X 5.5, CHROME
    N70 WHEEL, I3 X 5.5
    N72 WHEEL, CUSTOMER PROPERTY
    N73 WHEEL, CUSTOM SPORT, VAR 4
    N77 WHEEL, 16 X 7, STEEL STYLED
    N78 WHEEL, I4 X 6, ALUMINUM, HUB CAP, WHEEL NUTS
    N81 TIRES, SPARE FULLSIZE
    N83 WHEEL, I5 X 7, CHROME STYLED
    N84 TIRES, SPARE ---- DELETE
    N85 WHEEL, 14 X 6 HD
    N89 WHEEL, TURBO ALUMINUM
    N90 WHEEL, 15 X 7,ALUMINUM CAST,4.75 INCH BOLT CIRCLE
    N91 COVER, SIMULATED WIRE WHEEL, LOCK
    N95 COVER, SIMULATED WIRE WHEEL
    N96 WHEEL, I6 X 8, CAST ALUMINUM
    N97 WHEEL, 15, HD
    N98 WHEEL, CHROME, VAR 2
    N99 WHEEL, HEAVY DUTY
    PA1 COVER, WHEEL, VAR 5
    PA3 WHEEL, 15 X 7, ALUMINUM, STYLED
    PA4 COVER, WHEEL, PAINTED
    PA5 HUBCAPS, WHEEL
    PA6 WHEEL, STYLED, PAINTED
    PB1 COVER, WHEEL 15 INCH
    PB2 COVER, WHEEL TRIM ABS, PLASTIC
    PB3 HUBCAPS, COVERS & RETAINERS
    PB4 LOCK CONTROL, WHEEL
    PB5 WHEEL, 13 X 5.5, MILD STEEL
    PB6 WHEEL, INCREASED SIZE
    PB7 WHEEL, 14 X 6, PAINTED
    PB9 WHEEL, 14 X 5.5, STEEL
    PC1 WHEEL, 14 X 6, STEEL
    PC2 WHEEL, 14 X 7, STEEL, STYLED
    PC3 WHEEL, 14 X 7, STEEL
    PC4 WHEEL, 14 X 6, STEEL, STYLED
    PC5 WHEEL, 15 X 7, STEEL, STYLED
    PC6 WHEEL, 14 X 5.5, LIGHT METAL ALLOY
    PC7 WHEEL, 14 X 5.5, STYLED, STEEL
    PC8 WHEEL, 13 X 5.5, STEEL STYLED PAINTED
    PD4 WHEEL, 15 X 7, LIGHT METAL ALLOY, 5 SPOKES
    PD7 WHEEL, 14 X 6.5, CAST ALUMINUM
    PD8 WHEEL, 14 X 6, ALUMINUM STYLED
    PD9 WHEEL, 13 X 5, MILD STEEL
    PE0 WHEEL, 16 X 8, ALUMINUM, LIGHT WEIGHT, STYLED
    PE1 WHEEL, 14 X 7, ALUMINUM STYLED
    PE7 WHEEL, 13 X 5.5, TRIANGULAR HOLES
    PF1 WHEEL, 15 X 6, STEEL STYLED
    PF2 WHEEL, 15 X 7, ALUMINUM
    PF3 WHEEL, 15 X 6.5, ALUMINUM
    PF4 WHEEL, 16 X 7, ALUMINUM
    PF5 WHEEL, 16 X 7, LIGHT METAL ALLOY
    PF6 WHEEL, 15 X 6.5, ALUMINUM, STYLED
    PF7 WHEEL, 15 X 6, ALUMINUM CAST, STYLED
    PF8 WHEEL, I4 X 6, STEEL, STYLED, 4 SPOKE
    PG0 WHEEL, 16 X 6, ALUMINUM, STYLED
    PG1 WHEEL, 15 X 6, STEEL
    PG2 WHEEL, 15 X 5.5, STEEL
    PG4 WHEEL, 14 X 5.5, ALUMINUM
    PG5 WHEEL, 15 X 6, ALUMINUM CAST
    PG9 WHEEL, 15 X 6, LIGHT METAL ALLOY
    PH0 WHEEL, 15 X 6 FRT, X 7 RR, ALUMINUM
    PH1 WHEEL, 15 X 7, STEEL
    PH3 WHEEL, 15 X 6, ALUMINUM CAST, 115MM BOLT CIRCLE
    PH4 WHEEL, 14 X 5, LIGHT METAL ALLOY
    PH5 WHEEL, 14 X 6, ALUMINUM
    PH6 WHEEL, 15 X 6, ALUMINUM
    PH8 WHEEL, 15, WIRE SPOKE
    PNV CARRIER, OUTSIDE SPARE TIRE MOUNT NOT DESIRED
    PRA SALES PROCESSING OP, POSTAL SERVICE, COMPANION, AAA
    PW7 WHEEL, 16 X 8, ALUMINUM, STYLED
    PW8 WHEEL, 15 X 6, ALUMINUM, STYLED
    PW9 WHEEL, 16 X 9.5, CAST ALUMINUM
    PX0 WHEEL, 16 X 7, ALUMINUM, STYLED
    PX1 WHEEL, 13 X 5.5 ALUMINUM
    PX3 WHEEL, 13 X 5, LIGHT METAL ALLOY
    PY0 WHEEL, 16 X 6.5, ALUMINUM
    PY3 WHEEL, 16 X 8.5, CAST ALUMINUM
    PY4 WHEEL, 14 X 5.5, LIGHT METAL ALLOY
    PY6 WHEEL, 13 X 4.5 ALUMINUM
    P01 TRIM DISCS, WHEEL, VAR 1
    P02 TRIM DISCS, WHEEL, VAR 2
    P03 COVER, WHEEL, VAR 3
    P04 TRIM DISCS, WHEEL----DELETE
    P05 WHEEL, CHROME, VAR 1
    P08 COVER, SUPER DELUXE WHEEL
    P11 CARRIER, GLIDE OUT SPARE TIRE
    P12 WHEEL, 14 X 6, CHROME
    P13 CARRIER, SIDE MOUNTED SPARE WHEEL
    P14 CARRIER, INSIDE MOUNTED, SPARE TIRE, LH
    P15 CARRIER, INSIDE MOUNTED, SPARE TIRE, RH
    P16 CARRIER, RR MOUNTED, SPARE TIRE
    P17 COVER SPARE, WHEEL
    P18 CARRIER, SPARE TIRE, WITH HOIST
    P20 HUBCAPS, WHEEL, STYLED
    P41 TIRES, EEC SPECIAL SIDE WALL
    P42 TIRES, SELF SEALING
    P43 INFLATOR, SPARE TIRE ---- DELETE
    QAB TIRE ALL, Pl9S/70R14/N BL R/PE ST TL ALS
    QA1 WHEEL, 17 X 9 S, ALUMINUM, STYLED
    OA2 WHEEL, 17 X 9.5 FRT X 11 RR, ALUMINUM, STYLED
    QA3 WHEEL, 16 X 6.0, STEEL
    QA4 WHEEL, 15 X 5.5, ALUMINUM
    QBE TIRE ALL, LT235/75R15C WL R/PE ST TL OOR
    OBK TIRE ALL, P155/BOR13/N BL R/PE ST TL ALS (959127B)
    OBN TIRE ALL, LT245/75R16/C BW R/PE ST TBL OOR
    OBX TIRE ALL, LT245/75R16/C WOL R/PE ST TEL OOR
    QBZ TIRE ALL, P205/SSVR16/N BL R/PE ST TL HWY
    QB4 WHEEL, 16 X 6, ALUMINIUM
    QB5 WHEEL, 16 X 6. 5, STEEL
    QB6 WHEEL, 17 X B 5 FRT X 9.5 RR, ALUMINUM, STYLED
    QCE TIRE ALL, P205/75R15/N BL R/PE ST TL ALS
    QCF TIRE ALL, P205/75R15/N RWL R/PE ST TL ALS
    QCG TIRE ALL, P205/75R15/N WS2 R/PE ST TL ALS
    QCR TIRE ALL, P205/70R13/N BL R/PE ST TL ALS
    QCS TIRE ALL, P205/70R13/N WS1 R/PE ST TL ALS
    QCT TIRE ALL, P205/70R13/N RWL R/PE ST TL ALS
    QCU TIRE ALL, P215/75RlS/N BL R/PE ST TL ALS
    QCV TIRE ALL, P215/75R15/N WS2 R/PE ST TL ALS
    QCW TIRE ALL, P215/75R15/N RWL R/PE ST TL ALS
    QDP TIRE ALL, P195/70RlS/N BL TBL R/PE ST AL3
    QDZ TIRE ALL, P245/SOVR16/N BL R/PE ST TL HW4
    QEB TIRE ALL, P235/75R15/N WOL R/PE ST TL OOR
    QEE TIRE ALL, P205/65R15 BL R/PE ST TL ALS 925
    QER TIRE ALL, P205/65R15 WS2 R/PE ST TL ALS 925
    QET TIRE ALL, P225/75R15/N BL R/PE ST TL ALS
    QEU TIRE ALL, P225/75R15/N WS2 R/PE ST TL ALS
    QFE TIRE ALL, P185/75R14/N BL R/PE ST TL ALS
    QFF TIRE ALL, P185/75R14/N WS2 R/PE ST TL ALS
    QFL TIRE ALL, P235/75R15 BW R/PE ST TL ALS lOSS
    QFN TIRE ALL, P235/75R15 WL R/PE ST TL ALS lOSS
    QFT TIRE ALL, P205/75R14/N BL R/PE ST TL ALS
    QGK TIRE ALL,165/605R14 BL R/ST TL 113 745 (OVERSEAS)
    QGL TIRE ALL,175/655R14 BL TL R/ST 113 B1S (OVERSEAS)
    QGM TIRE ALL,175R14 BL TL R/ST HWY 190 BBT (OVERSEAS)
    QGW TIRE ALL, P215/60R16/N BL R/PE ST TL AL3
    QGY TIRE ALL, P205/70R15/N BL R/PE ST TL ALS
    QGZ TIRE ALL, P205/70R15/N WS R/PE ST TL ALS
    QHA TIRE ALL, P235/75R15/X BW R/PE ST TL ALS
    QHB TIRE ALL, P235/75R15/X WS2 R/PE ST TL ALS
    QHE TIRE ALL, l9S/65R15/N BL R/ST TL HWY (9OH 1304PH
    QHF TIRE ALL, P205/60R15/N BL R/PE ST TL AL3
    QHH TIRE ALL, P205/60R15/N WOL R/PE ST TL AL3
    QHJ TIRE ALL, P225/70R15/N WS1 R/PE ST TL HWY
    QHP TIRE ALL, LT225/75R16/D BW R/PE ST TL ALS
    QHR TIRE ALL, LT225/75R16/D BW R/PE ST TL OOR
    QHS TIRE ALL, P185/80R13/N BL R/PE ST TL ALS
    QHT TIRE ALL, P185/80R13/N WS1 R/PE ST TL ALS
    QHX TIRE ALL, P205/70R14/N BL R/PE ST TL ALS
    QHY TIRE ALL, P205/70R14/N WS2 R/PE ST TL ALS
    QID TIRE ALL, LTl9S/75R14/C BL R/PE ST TL ALS
    QIE TIRE ALL, P165/70R12/N BL R/PE ST TL ALS
    QIF TIRE ALL, P185/60R14/N BL R/PE ST TL ALS
    QII TIRE ALL, P215/60R16 8W R/PE ST TL AL3 94H
    QIM TIRE ALL, P205/60R15/N BL R/PE ST TL AL2 90S
    QIN TIRE ALL, P205/70R15/N BL R/PE ST TL AL2 955
    QIP TIRE ALL, P205/70R15/N WS2 R/PE ST TL AL2 9SS
    QIQ TIRE ALL, P205/60R15 WOL R/PE ST TL AL2 90S
    QIT TIRE ALL, LT245/75R16/C BL R/PE ST TL ALS
    QIW TIRE ALL, LT245/75R16/E BL R/PE ST TL OOR
    QIX TIRE ALL, LT265/75R16/C BL R/PE ST TL OOR
    QIY TIRE ALL, LT265/75R16/C WOL R/PE ST TL OOR
    QIZ TIRE ALL, LT245/75R16/E BL R/PE ST TL ALS
    QJA TIRE ALL, P215/60HR14/N BL R/ST TL HWY (OVERSEAS)
    QJI TIRE ALL, Pl85/70R14/N BL R/NY TL HWY
    QJJ TIRE ALL, 31XlO.SORlSLT/C BW R/PE ST TL OOR
    QJL TIRE ALL, P205/75R15/N WOL R/PE ST TL OOR
    QJR TIRE ALL, P205/75R14/N WS2 R/PE ST TL ALS
    QJT TIRE ALL, P205/75R15/N BL R/PE ST TL OOR
    QJV TIRE ALL, LT225/75R15/C BL R/PE ST TL ALS
    QLC TIRE ALL, P245/SOZR16/N BL R/PE ST TL HW4
    QLG TIRE ALL, P205/SSR16/N BL R/PE ST TL AL3
    QLM TIRE ALL, P215/60R15/N BL R/PE ST TL ALS
    QLU TIRE ALL, P225/55VR16/N BL R/PE ST TL HWY
    QLV TIRE ALL, P225/75R15/N WS2/GOLD R/PE ST TL ALS
    QLW TIRE ALL, 175R14 BL TL R/ST ALS 120MPH/BBT OVERSEAS
    QMB TIRE ALL, P215/60R14/N BL R/PE ST TL AL3
    QME TIRE ALL, Pl9S/70R14/N BL R/PE ST TL AL2
    QMG TIRE ALL, P215/60R14/N WOL R/PE ST TL AL3
    QMR TIRE ALL, P205/65R15/N BL R/PE ST TL AL2
    QMS TIRE ALL, P205/SSR16 BL R/PE ST TL AL2 B9S
    QMT TIRE ALL, P235/SSR16/N BL R/PE ST TL AL2
    QMV TIRE ALL, P235/70R15 WS1 R/PE ST TL AL2 1025
    QMW TIRE ALL, Pl9S/75R14/N BL R/PE ST TL ALS
    QMX TIRE ALL, P195/75R14/N WS2 R/PE ST TL ALS
    QNJ TIRE ALL, P215/65R15 BW R/PE ST TL AL3 95H
    QNM TIRE ALL, P225/70R15/N BL R/PE ST TL AL2
    QNP TIRE ALL, P2Z5/70R15/N WS1 R/PE ST TL AL2
    QNR TIRE ALL, P215/65R15/N WS2 R/PE ST TL AL3
    QNS TIRE ALL, P215/65R15/N BL R/PE ST TL AL3
    QNT TIRE ALL, P215/65R15/N WOL R/PE ST TL AL3
    QNX TIRE ALL, P225/60R16/N BL R/PE ST TL AL2
    QNY TIRE ALL, P225/60R16/N WS1 R/PE ST TL AL2
    QPC TIRE ALL, PlBS/65HR14/N BL R/ST TL HWY (OVERSEAS)
    QPD TIRE ALL, Pl9S/65Rl5/N BL R/PE ST TL AL2 B9S
    QPE TIRE ALL, P215/60R16/N BL R/PE ST TL AL2
    QPH TIRE ALL, P215/65R15/N BL R/PE ST TL AL2
    QPJ TIRE ALL, P215/65R15/N WS1 R/PE ST TL AL2
    QPK TIRE ALL, P215/70R15/N BL R/PE ST TL ALS 975
    QPN TIRE ALL, P215/70R15/N WS2 R/PE ST TL ALS 97S
    QPP TIRE ALL, P215/65R15/N WL R/PE ST TL AL3 95H
    QPX TIRE ALL, P225/60R16 BW R/PE ST TL ALS 975
    QPY TIRE ALL, P225/60R16 WS2 R/PE ST TL ALS 975
    QQD TIRE ALL, P235/70RI5 WS2 R/PE ST TL ALS 102S
    QQG TIRE ALL, P235/70R15 BL R/PE ST TL AL3 102V
    QQR TIRE ALL, P235/70R15 WS1 R/PE ST TL AL3 102V
    QRF TIRE ALL, lBSSR14 BL R/ TL lOS TEXTILE (OVERSEAS)
    QSA TIRE ALL, P205/75R14/N RWL R/PE ST TL ALS
    QUK TIRE ALL, P235/70R15/N WS2/GOLD R/PE ST TL ALS
    QUS TIRE ALL, lBS/60HR14 BL R/ST TL 130 (OVERSEAS)
    QVF TIRE ALL, P225/60ZR16/N BL R/PE ST TL AL3
    QVG TIRE ALL, P225/60R16/N BL R/PE ST TL AL3 97H
    QVI TIRE ALL, P175/BDR14 BW R/PE ST TL ALS BBS
    QWT TIRE ALL, P245/60R15 WOL R/PE ST TL AL3 lOOT
    QXJ TIRE ALL, P225/60R16/N BL R/PE ST TL AL3 97U
    QYH TIRE ALL, P215/65R15/N WOL R/PE ST TL HWY
    QYZ TIRE ALL, P215/65R15/N BL R/PE ST TL HWY
    QZY TIRE ALL, P255/SOZR16/N BL R/PE ST TL HW4
    Q34 WHEEL SPARE l9.5 X 6
    Q4B GVW RATING 6200 LBS
    RC1 TURBO PERFORMANCE SPECIFIC EQUIPMENT
    RC2 LAMP GROUP COMPONENTS
    RRL WHEEL FRT, 22.5 X 6.75 6 HOLE 8.75 BC BS DCT
    RRM WHEEL RR, 22.5 X 6.75 6 HOLE 8.75 BC BS DCT (FI-277B)
    R04 WHEEL SINGLE RR
    R05 WHEEL DUAL RR
    R1P CHASSIS EQUIPUENT HEAVY DUTY, COACHBUILDER/LIVERY
    R1U CONVERSION, AUTO-FAB INC.
    R1V APPEARANCE PACKAGE
    R1W NOISE CONTROL, AIR CLEANER, ECU
    R1X NOISE CONTROL, AIR CLEANER, ECU, EXH INTER PIPE
    R10 MANUAL, ROADSIDE SERVICE INFO
    TA6 RESISTOR, HEADLAMP LW BEAM
    TB2 FENDERS, FRT
    TL1 GRILLE, SPECIAL
    TL4 GRILLE, PAINTED
    TL6 GRILLE BLACK
    TL8 ORNAMENTATION , EXTR MLDG HOOD,
    TNQ BATTERY, ONE DELCO II5O 12V
    TPS FANILY CODE, ROOF COVERING
    TP2 BATTERY, AUX, CAMPER
    TP5 REFLECTOR, BUMPER
    TR1 LAMP, TAIL & STOP
    TR2 LAMP,TURN SIGNAL, ENLARGED
    TR4 HEADLAMPS, RECTANGULAR
    TR6 HEADLAMPS CONTROL, LEVELING SYSTEM, MANUAL
    TR7 HEADLAMPS CONTROL, LEVELING SYSTEM, AUTOMATIC
    TR9 LAMP, GROUP
    TS6 LAMP, STOP, HIGH LEVEL
    TS8 REFLECTOR, BODY SI
    TT4 HEADLAMPS, HALOGEN, 4
    TTS HEADLAMPS, HALDGEN, 2
    TU2 LAMP, MARKER, SIDE
    TU6 HEADLAMPS CONTROL, FLASH TO PASS
    TUB LAMP, INTR, STOP, HIGH LEVEL ---- DELETE
    TVR LAMP, REAR DOME AND READING
    T1A IDENTIFICATION, STEERING COLUUN EXPORT REQM'TS
    T1B ORNAMENTATION , EXTR, CADILLAC SPRING EDITION
    T1J FASCIA,'H' T-TYPE SPECIFICS
    T1S SPEEDOMETER, 120 MPH
    T1U PACKAGE, DRIVER CONFIDENCE
    T1X CONVERSION, EXPORT COMPOSITE HEADLAMP REQM'TS
    T2F BRAKE PROVISIONS, SPECIAL
    T2G ROOF COVERING, SIMULATED CONVERTIBLE, CAMBRIA
    T2H ORNAMENTATION, EXTR, EXPORT UNIQUE REQUIREMENTS
    T2J ORNAMENTATION, INTR, EXPORT UNIQUE REQUIREMENTS
    T2L IDENTIFICATION ISO SYMBOLS
    T2U SHAFT, FRONT STABILIZER, SOLID
    T2N SHAFT, FRONT STABILIZER, TUBULAR
    T2R LOCK CONTROL, REMOTE FREQ --- DELETE
    T2T CONTROL, REMOTE ILLUM ENTRY, RETAINED ACSRY PWR
    T2V CONTROL STEERING, TWO FLOW ELECTRONIC
    T2W WIRING HARNESS, HI/LOW BEAM, EXPORT
    T37 LAMP, FOG, DELUXE
    T3B LAMP, PARK & TURN SIGNAL
    T39 LAMP, TURN SIGNAL, AUX
    T43 SPOILER, RR
    T46 HOOD, STEEL
    T47 HOOD TURBO
    T52 ORNAMENTATION, EXTR FRT FENDER
    T53 LAMP PACKAGE, EMER VEH R/CMPT LID
    T61 LIGHTING, DAYTIME RUNNING
    T63 ALARM, HEADLAMPS ON WARNING SYSTEM
    T72 HEADLAMPS, LH RULE OF THE ROAD, EXPORT
    T73 HEADLAMPS, RH RULE OF THE ROAD, EXPORT
    T75 HEADLAMPS, AUBER
    T76 HEADLAMPS, REPLACEABLE BULB TYPE
    T77 HEADLAMPS, 2
    T79 LAMP, FOG, RR
    T80 HEADLAMPS, AUTO BEAM CONT
    T81 LAMP, TAIL AND STOP DELUXE
    T82 HEADLAMPS, AUTO ON-OFF CONT
    T83 HEADLAMPS, DR, SPECIAL
    T84 HEADLAMPS, RH RULE OF ROAD, EXPORT
    T85 HEADLAMPS, LH RULE OF ROAD, EXPORT
    T86 LAMP, BACKUP, PAINTED
    T87 LAMP, CORNERING
    T88 LAMP, PARKING
    T89 LAMP, TAIL & STOP, EXPORT
    T90 LAMP, SIGNALING & MARKER EXPORT
    T93 LAMP, TAIL & STOP, SPECIAL
    T96 LAMP, FOG
    UA6 THEFT DETERENT SYS
    UBO CLUSTER, INST, OIL, TEMP,TACH ,TURBO BOOST
    UB2 CLUSTER, INST, OIL, VOLTS ,TACH ,TURBO BOOST
    UB3 CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM,
    UB4 LAMP, SIDE MARKER, BOXED FOR SHIPMENT
    UB7 CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM,
    UB8 HORN, HIGH NOTE
    UC3 COMPASS, ELECTRONIC
    UD1 CLUSTER, INST, OIL, COOL TEMP
    UD2 ALARM, VEHICLE SPEED, 105 K/H
    UD4 ALARM, VEHICLE SPEED, 120 K/H
    UD6 ALARM, EXHAUST TEMP
    UD8 CLOCK, VACUUM FLUORESCENT DIGITAL
    UE6 SWITCH, HEADLAMPS
    UE8 CLOCK, ELECTRIC, DIGITAL
    UF2 LAUP, CARGO
    UF3 SWITCH, HIGH IDLE
    UF6 LAMP, INTR, CONSOLE, COURTESY
    UF7 CLUSTER, INST, OIL, COOL TEMP, VOLTS, FUEL ECON
    UH1 INDICATOR, SYS, WARNING LIGHTS
    UH6 CLUSTER, INST, OIL, COOL TEMP, VOLTS, INDICATORS
    UH7 CLUSTER, INST, COOL TEMP
    UH9 CLUSTER, INST, COOL TEMP, TRIP ODOM, TURBO
    UJ1 INDICATOR, SYSTEM, BRAKE WARNING
    UJ2 INDICATOR, ENGINE OIL LIFE
    UJ3 INDICATOR, WATER IN FUEL
    UJ5 CLUSTER INST, COOL TEMP, TRIP ODOM, VOLTS
    UJ6 INDICATOR, LW TIRE PRESS
    UJ9 CLUSTER, INST COOL TEMP, VOLTS, TACH
    UK1 FREQUENCIES, JAPANESE RADIO
    UK2 LEVER DIRECTIONAL SIGNAL, INCLUDES MULTI FUNCTIONS,
    UK3 ELECTRONIC SYSTEM, ACCESSORY CONT
    UK4 RADIO, AM/FM STEREO, SEEK/SCAN, ETR
    UK5 RADIO, AM/FM STEREO, SEEK/SCAN AUTO REV CASS, ETR
    UL1 RADIO, AM/FM STEREO CLOCK ETR
    UL2 FREQUENCIES, EUROPEAN RADIO
    UL5 RADIO, DELETE
    UL6 RADIO, AM, CLOCK, MTR
    UL9 RADIO, AM/FM STEREO, PB, CASS CLOCK MTR
    UM3 RADIO, AM STEREO-FM STEREO, SEEK/SCAN, COMPACT
    UM6 RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS,
    UM7 RADIO, AM/FM STEREO, SEEK/SCAN, CLOCK, ETR
    UN3 RADIO, AM/FM STEREO, CASS, MTR
    UN4 TAPE CARTRIDGE ---- DELETE
    UN5 RADIO, AM/F4 STEREO, SEEK/SCAN, AUTO REV CASS, CB,
    UN6 RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC
    UN8 RADIO, CITIZENS BAND
    UN9 RADIO, SUPPRESSION EQUIPMENT
    UP2 RADIO, AM STEREO & FM STEREO, SEEK/SCAN, CLOCK, ETR,
    UP4 RADIO AM, ETR
    UP5 RADIO AM STEREO-FM STEREO-WX, SEEK/SCAN, AUTO REV
    UP7 RADIO PROVISIONS, FOR MONO INSTRUMENTATION
    UP9 RADIO PROVISIONS, FOR STEREO INSTRUMENTATION
    UQ0 SPEAKER SYSTEM, 4, DUAL FRT DR MTD, DUAL STD RGE
    UQ1 RADIO PROVISIONS, FOR STEREO
    UQ2 SPEAKER SYSTEM, 6, DUAL F/D MIR PATCH TWT, DUAL F/D
    UQ3 SPEAKER SYSTEM, PERFORMANCE ENHANCED AUDIO
    UQ4 SPEAKER SYSTEM, BOSE, 4
    UQ5 SPEAKER SYSTEM, 4, DUAL FRT DR MTD, DUAL EXTD RGE
    UQ6 SPEAKER SYSTEM, 5, DUAL I/P, SAIL MTD COAX
    UQ7 SPEAKER SYSTEM, 5, DUAL I/P, SAIL MTD STD SPEAKER
    UQ8 SPEAKER SYSTEM, 4, DUAL FRT EXTD RGE, DUAL EXTD RGE
    UQ9 SPEAKER SYSTEM, DELETE
    UR3 INDICATOR, FUEL ECONOMY
    UR5 INDICATOR, LOW ENGINE OIL
    US6 ANTENNA, FIXED, PAINTED, RADIO
    US7 ANTENNA, POWER, PAINTED RADIO
    UT0 RADIO, AM STEREO/FM STEREO, SEEK/SCAN, AUTO REV
    UT1 TONE GENERATOR, WARNING
    UT2 RADIO, AM/FM STEREO, P3, SEEK/SCAN CLOCK ETR
    UT3 RADIO, AM/FM STEREO , SEEK/SCAN, AUTO REV CASS
    UT5 RADIO, AM, CLOCK, ETR
    UT6 RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC
    UT7 RADIO, AM/FM STEREO, PB, DOLBY , ETR
    UU0 RADIO, AM STEREO & FM STEREO SEEK/SCAN AUTO REV
    UU1 RADIO, AM/FM STEREO-FM STEREO-WX,SEEK/SCAN, COMPACT
    UU2 RADIO, AM/FM STEREO, CASS, DOLBY, ETR
    UU6 RADIO, AM/FM STEREO, SEEK/SCAN AUTO REV CASS
    UU7 RADIO, AM/FM STEREO, CASS, CLOCK ETR
    UU9 RADIO, AM/FM STEREO, ETR
    UV1 ALARM, VOICE REMINDER
    UV4 DISPLAY COMPASS AND RALLY TSD INFO
    UV5 DISPLAY , SERVICE REMINDER
    UV6 DISPLAY HEAD UP
    UV8 TELEPHONE, PROVISIONS FOR MOSILE
    UV9 TELEPHONE, MOBILE 6000 SERIES
    UW0 SPEAKER SYSTEM, 4, DUAL I/P MTD, DUAL ROOF MTD
    UW1 DIAGNOSTIC SYSTEM
    UW4 SPEAKER SYSTEM, 6, DUAL FRT DASH MTD F/D, DUAL
    UW5 SPEAKER SYSTEM, 6, DUAL I/P MTD, DUAL STD RGE PASS
    UW6 SPEAKER SYSTEM, 6, DUAL F/D TWEET & WWF, DUAL EXT
    UW7 RADIO, AM STEREO & FM STEREO SEEK/SCAN AUTO/REV
    UW8 HOUSING GARAGE DOOR OPENER, REM CONT
    UW9 GARAGE DOOR OPENER, REM CONT, INCLUDING HOUSING
    UX0 SPEAKER SYSTEM, 4, DUAL FLR SILL, DUAL EXTD RANGE
    UX6 SPEAKER SYSTEM, FRT DUAL
    UX7 SPEAKER SYSTEM, 4, DUAL FRT DR MTD, DL EXTND RGE
    UY1 WIRING PROVISIONS , CAMPER
    UY2 TELEPHONE, MOBILE, 2000 SERIES
    UY3 TELEPHONE, M0BILE, S.E SERIES
    UY5 SPEAKER SYSTEM,4,DUAL FRT FLR SILL, DUAL EXT
    UY7 WIRING HARNESS, TRUCK TRAILER HD
    UY9 CLUSTER, KILO & MILES, MECHANICAL DISPLAY
    UZ1 TELEPHONE, PROVISIONS FOR INTEGRATED M08ILE
    UZ3 TELEPHONE, M0BILE KEYPAD CONTROL
    U01 LAMP, FIVE, ROOF MARKER, TRUCK
    U03 HORN, NOISE REGULATION
    U05 HORN, DUAL
    U08 HORN, DUAL ELECTRIC
    UO9 HORN, FOUR NOTE
    U1A RADIO, AM STEREO-FM STEREO, SEEK/SCAN, COMPACT
    U1B RADIO, AM STEREO-FM STEREO SEEK/SCAN COMPACT
    U1C RADID, AM/FM STEREO, SEEK/SCAN, COMPACT DISC
    U1D RADIO, AM STEREO-FM STEREO-WX, SEEK/SCAN, COMPACT
    U1E RADIO, AM STEREO & FM STEREO, SEEK/SCAN COMPACT
    U1F RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC
    U1G RADIO, AM STEREO/FM STEREO, P8, SEEK/SCAN AUTO REV
    U1H RADIO, AM STEREO/FM STEREO, SEEK/SCAN, AUTO REV
    U1J RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC
    U1K RADIO, AM STEREO-FM STEREO SEEK/SCAN, DAT EQUALIZE
    U1N RADIO, AM STEREO/FM STEREoiWX/TV, SEEK/SCAN AUTO
    U1P RADIO, AM STEREO/FM STEREO/WX/TV, SEEK/SCAN, AUTO
    U1Q RADIO, AM STEREO/FM STEREO/WX/TV, SEEK/SCAN, CD
    U11 CLUSTER, INST, POLICE, CERTIFIED, SPEEDO
    U12 SPEEDOMETER, DUAL SCALE WITH KILO ODOMETER
    U14 CLUSTER, INST, OIL, COOL TEMP, VOLTS, GAGES
    U16 TACHOMETER, ENGINE
    U17 CLUSTER INST, OIL, COOL TEUP, VOLTS, CLOCK, FUEL
    U19 SPEEDOMETER,INST, KILO & MILES KILO ODOMETER
    U2A CLUSTER, INST, COOL TEMP, TRIP ODOM, DR INFO CTR
    U2S CLUSTER, INST, OIL, COOL TEMP, TACH, TRIP ODOM
    U2C CLUSTER, INST, KILO & MILES, MILES ODOM
    U2D CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM
    U2E CLUSTER, INST, COOL TEMP, TRIP ODOM
    U2F CLUSTER, INST, OIL, COOL TEMP, TRIP ODOM, TACH
    U21 CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
    U22 CLUSTER, INST, OIL COOL TEMP, BATTERY, CLOCK
    U23 CLUSTER, INST, TRIM ODOM
    U25 LAMP, INTR, RR COMPT, COURTESY
    U26 LAMP, INTR, ENG COMPT, COURTESY
    U27 LAMP, INTR, I/P COMPT, COURTESY
    U28 LAMP, INTR, ASH TRAY, COURTESY
    U29 LAMP, INTR I/P, COURTESY
    U35 CLOCK, ELECTRIC
    U37 LIGHTER CIGARETTE
    U38 INDICATOR, LOW COOLANT
    U39 CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM
    U40 DISPLAY , DIGITAL DIRECT READOUT, TRIP MONITOR
    U46 MONITOR, EXTERNAL LAMP
    U47 LAMP, INTR, ENG COMPT, COURTESY, EXTENDABLE
    U50 CLUSTER,INST, OIL, COOL TEMP, VOLTS, TRIP ODOM
    U51 DISPLAY, FUEL ECONOMY, TSD INFO, SERVICE REM INDER
    U52 CLUSTER INST, ELECTRONIC
    U56 PLAYER TAPE, CASSETTE
    U58 RADIO, AM/FM STEREO, MTR
    U63 RADIO, AM, MTR
    U64 SPEAKER SYSTEM, 4, DUAL FRT DASH MTD, DUAL STD RGE
    U65 SPEAKER SYSTEM, 6, DUAL FRT DASH MTD, F/D, DUAL
    U66 SPEAKER SYSTEM, 4, DUAL FRT DASH MTD, DUAL EXTD RGE
    U67 SPEAKER SYSTEM, 8, DUAL F/D 2 TWEET, TWO WOOF, DUAL
    U68 DISPLAY,DRIVER INFO CENTER
    U69 RADIO, AM/FM, MTR
    U71 ANTENNA, ROOF , RADIO
    U72 ANTENNA, POWER, FRT, RADIO
    U73 ANTENNA, FIXED, RADIO
    U74 ANTENNA, RADIO ----DELETE
    U75 ANTENNA, POWER, RADIO
    U76 ANTENNA, WINDSHIELD, RADIO
    U77 ANTENNA, RR WINDOW, RADIO
    U78 ANTENNA , POWER , RADIO/TELEPHONE TRISAND
    U79 SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
    U80 SPEAKER SYSTEM, RR
    U81 SPEAKER SYSTEM, RR, DUAL
    U83 ANTENNA, POWER, CITIZENS SAND/RADIO TRIBAND
    U85 SPEAKER SYSTEM,8 QUAD FRT DR MTD, SHELF QUAD
    U89 WIRING HARNESS,CAR TRAILER
    U93 ANTENNA, FIXED TELEPHONE
    U94 LIGHT CABLE TRAILER, 7 WIRE, VAR 3
    U95 SPEAKER SYSTEM, DOOR
    U96 SPEAKER SYSTEM 6, DUAL F/D TWEET & WOOF, DUAL
    VA2 RADIATDR SUPPORT STEEL
    VB1 LABEL, SHIPPING, JAPAN
    VB2 BUMPER,RR STEP, PAINTED, IMPACT STRIP
    VB3 BUMPER RR, STEP CHROME, IMPACT STRIP
    VB4 PROVISION OPTIONS, GULF STATES ORGANIZATION
    VB5 BUMPER FRT PAINTED
    VB6 PROVISION OPTIONS, HOT CLIMATE
    VB7 BUMPER, FRONT AND REAR SPORT
    VC9 OWNERS MANUAL, MERCHANDISED OPTIONS
    VD1 PROVISION OPTIONS, EUROPE
    VD2 BUMPER, FRT & RR, CHROME, W/IMPACT STRIPS
    VD4 BUMPER PROVISIONS, FRT, STEEL
    VD5 BUMPER PROVISIONS, RR, STEEL
    VD6 BUMPER PROVISIONS, FRT, ALUMINUM
    VD7 BUMPER PROVISIONS, RR, ALUMINUM
    VE1 PROVISION OPTIONS, JAPAN
    VE5 BUMPER, FRT & RR, IMPACT, CHROME
    VE6 BUMPER, FRT & RR, IMPACT, COLORED
    VF1 BUMPER, RR, CHROME
    VF6 BUMPER, RR, STEP,
    VG2 PROTECTOR, WAX SPRAY ON ---- DELETE
    VG3 BUMPER FRT, IMPACT STRIP
    VGS BUMPER RR, IMPACT STRIP
    VG8 VEHICLE, BUYER NOTICE LABEL
    VG9 PROTECTOR, WAX, EXTERIOR BODY
    VH4 MUD FLAPS,
    VH5 PLATE, VEHICLE IDENTIFICATION
    VH6 BUMPER FRT, BLACK
    VH7 BUMPER, CUSTOM
    VH9 ENVELOPE, OWNER INFO MAN
    VJ1 LICENSE PLATE, RR MOUNTING PKG ---- JAPANESE
    VJ5 LICENSE PLATE, MOUNTING INCLUDES BUMPER GUARD,
    VJ6 LICENSE PLATE, RR POCKET, DELUXE
    VJ9 LABEL, EMISSION, COMPLIANCE, CALIFORNIA
    VK3 LICENSE PLATE, FRT MOUNTING PKG
    VLA APPEARANCE PACKAGE, WORK TRUCK
    VL4 LICENSE PLATE, FRT MOUNTING PKG, EEC
    VL5 LICENSE PLATE, RR MOUNTING PKG ---- EXPORT
    VL6 LICENSE PLATE, FRT MOUNTING PKG, JAPANESE
    VND GOVERNOR, VEHICLE SPEED - 50 MPH
    VNE GOVERNOR, VEHICLE SPEED - 55 MPH
    VNF GOVERNOR, VEHICLE SPEED - VARIABLE 35-55 MPH
    VN1 FLEET PROGRAM, GUARANTEED IOO% REPURCHASE, FAST
    VN2 FLEET PROGRAM, GUARANTEED 100% REPURCHASE, CONTROLL
    VN3 FLEET PROGRAM, DEALER DAILY RENTAL
    VP1 SPOILER FRT
    VP6 NOISE CONTROL,
    VQA FAN, ENGINE EATON VISCIOUS DRIVE
    VR2 TRAILER HITCH, FACTORY INSTALLED
    VR4 TRAILER HITCH, WEIGHT DISTRIBUTING PLATFORM
    VR5 PROVISIONS, SLOW VEHICLE WARNING TRIANGLE MOUNTING
    VT3 BUMPER, FRT PAINTED DELUXE, IMPACT STRIPS
    VT5 BUMPER RR, COLOR KEYED
    VT7 PROVISION OPTIONS, UNREGULATED COUNTRIES
    VU9 FLASHLIGHT, MOUNTING PROVISIONS
    VV1 FUEL, UNLEADED GAS
    VV4 CONTAINER, STOWAGE
    VV5 P.O.E. INSTALLATION, AIR CONDITIONER
    VV6 P.O.E. INSTALLATION, CRUISE CONTROL
    VXX BUMPER FRT,---DELETE---
    VYU PROVISIONS, SNOW PLOW PREP
    VY7 KNOB, TRANS CONT LEVER, LEATHER
    V01 RADIATOR, HEAVY DUTY, VAR I
    V02 RADIATOR, HEAVY DUTY, WITH TRANS OIL COOLER
    V03 COOLING SYSTEM, EXTRA CAPACITY
    V05 RADIATOR, HEAVY WTY
    V08 COOLING SYSTEM, HEAVY WTY
    V1C EXHAUST, SINGLE OUTLET EXHAUST
    V1F PAINT, SPECIAL METALLIC - CHARGE
    V1L TRIM, SPECIAL
    V10 PROVISION OPTIONS, COLD CLIMATE
    V12 COOLING SYSTEM, POWER STEERING, FLUID
    V13 PROVISION OPTIONS, COLD CLIMATE ---- DELETE
    V2C WHEEL COLOR, ALUMINUM (MACH FINISHED)
    V22 GRILLE, CHROME, RADIATOR
    V27 GUARDS, BUMPER, FRT,
    V28 GUARDS, BUMPER, FRT, PAINTED
    V29 GUARDS, BUMPER, FRT, DELETE
    V3C PLANT OPERATION, NON-ASBESTOS BRAKE LININGS
    V3N PLANT OPERATION, COLUMN SHIFT
    V30 GUARDS, BUMPER, FRT AND RR
    V31 GUARDS, BUMPER, FRT, CHROUE
    V32 GUARDS, BUMPER, RR
    V33 TOOL KIT ROAD EMERGENCY
    V35 BUMPER, RR, WITH RECESSED LIGHTING
    V37 BUUPER, FRT & RR, CHROME
    V38 BUMPER, RR, TRUCK
    V4A TRIM, SPRING SPECIAL
    V4E MERCHANDISED PKG, CADILLAC BROUGHAM
    V4F EQUIPMENT, COACHBUILDER OPTION
    V4I NOISE CONTROL, AIR CLEANER, ECM, MUFFLER
    V4J IDENTIFICATION, MID-YEAR INTRODUCTION
    V4N PROCESSING, GOLD KEY PROGRAM ---- DELETE
    V4P TRAILER PROVISIONS, NOT TO EXCEED 7000 LBS
    V4R PROVISION OPTIONS, VEHICLE SECURITY
    V4S MERCHANDISED PKG, FLEETWOOD D' ELEGANCE
    V4U EQUIPMENT, COACHBUILDER, NOT TO EXCEED 7200 LBS
    V4X MERCHANDISED PKG, TOURING OPTION
    V41 KIT, ACCESSORY
    V42 BUMPER RR, STEP, CHROME
    V43 BUMPER RR, STEP, PAINTED
    V46 BUMPER FRT, CHROME
    V5O LICENSE PLATE, FRAME RR ONLY
    V51 LICENSE PLATE, FRAME, FRT AND RR
    V52 LUGGAGE CARRIER, RR COMPARTMENT
    V54 LUGGAGE CARRIER, ROOF, PAINTED
    V55 LUGGAGE CARRIER, ROOF CHROME
    V56 LUGGAGE CARRIER, RR COMPARTMENT LID, PAINTED
    V58 LUGGAGE CARRIER, RR COMPARTMENT LID, CHROME
    V69 TRAILER PROVISIONS, NOT TO EXCEED 4000 LBS
    V70 HOOK, TOW, FRAME MOUNTED
    V76 HOOK, TOW
    V78 VEHICLE STATEMENT DELETE
    V81 TRAILER PROVISIONS, NOT TO EXCEED 2000 LBS, SAE
    V82 TRAILER PROVISIONS 2000 TO 3500 LBS, SAE CLASS 2
    V83 VEHICLE STATEMENT ECE ORGANIZATION
    V92 TRAILER PROVISIONS
    V97 VEHICLE PREPARATION, EXPORT
    WA4 MERCHANDISED PKG, CADILLAC SPECIAL EDITION
    WB4 ORNAMENTATION, WOODGRAIN APPLIQUE DELETE
    WB6 PACKAGE, DELETE EQUIPUENT LESABRE/SKYLARK
    WD6 PROMOTIONAL PROGRAM, MEXICO SALES
    WE2 MERCHANDISED PKG, LESABRE 'T' TYPE, GRAND NATIONAL
    WF1 MERCHANDISED PKG, CADILLAC DEVILLE TOURING SEDAN
    WF7 CONVERSION, FLEETWOOD - SIXTY SPECIAL
    WG1 SALES, PROCESSING FOR DR POWER SEAT
    WJ7 TRIM OVERRIDE ,INTERIOR 'LEATHER'
    WL2 MANIFOLD, EXHAUST, CI
    WL3 MERCHANDISED PKG, TROFEO
    WS4 MODEL CONVERSION, TRANS AM
    WS6 PERFORMANCE PACKAGE, SPECIAL
    WS9 MODEL CONVERSION, FORMULA
    WV9 MERCHANDISED PKG, VALUE LEADER
    WW1 APPEARANCE PACKAGE, AERO #l
    WW2 APPEARANCE PACKAGE, AERO #2
    WW3 APPEARANCE PACKAGE, AERO #3
    WW4 APPEARANCE PACKAGE, AERO #4
    WW6 APPEARANCE PACKAGE, AERO #6
    WW7 APPEARANCE PACKAGE, AERO #7
    WW8 APPEARANCE PACKAGE, AERO #8
    WX1 PAINT, TWO TONE-DELETE
    WX2 SALES LEATHER APPOINTMENTS
    WX7 WIRING PROVISIONS
    W02 PACKAGE SPORT APPEARANCE
    W03 SALES, (NOT USED 2-l5-91/OK TO REUSE)
    W06 MODEL CONVERSION, CENTURY LIMITED WAGON
    W09 M0DEL CONVERSION, CENTURY LIMITED SEDAN
    W10 MERCHANDISED PKG, PARK AVENUE MODEL
    W12 MERCHANDISED PKG, NINETY-EIGHT TOURING SEDAN
    W14 MERCHANDISED PKG, NINETY-EIGHT REGENCY ELITE
    W16 APPEARANCE PACKAGE, PGA SPECIAL EDITION
    W18 MERCHANDISED PKG, 5OTH ANNIVERSARY NINETY-EIGHT
    W21 MERCHANDISED PKG, DRIVER ENTHUSIAST
    W24 MERCHANDISED PKG, PARK AVENUE 'ULTRA'
    W25 APPEARANCE PACKAGE, "SPRING SPECIAL"
    W29 EXPORT VEHICLE, SEAT BACK LOCK (COUPE)
    W30 MERCHANDISED PKG, SPORT
    W32 MERCHANDISED PKG, DELUXE SPORT
    W36 APPEARANCE PACKAGE, "GT LOOK ALIKE"
    W40 MERCHANDISED PKG, QUAD 442
    W41 MERCHANDISED PKG, HIGH OUTPUT QUAD 442
    W44 MERCHANDISED PKG, SPORTY
    W45 MODEL CONVERSION, INTERNATIONAL SERIES COUPE
    W49 MODEL CONVERSION, INTERNATIONAL SERIES SEDAN
    W62 ORNAMENTATION, AERO PACKAGE
    W63 PACKAGE, GROUP 02
    W66 MERCHANDISED PKG, FORMULA
    W68 MERCHANDISED PKG, FIREBIRD, SPORT APPEARANCE
    W81 WRANGLER, PACKAGE "B"
    W90 APPLICATION, MANDATORY SCHOOL BUS
    XAA TIRE FRONT, P255/45ZR17 BL R/PE ST TL HW4
    XAU TIRE FRONT, P275/40ZR17/N BL R/PE ST TL HW4
    XNA TIRE FRONT, 205/65R15 BW R/PE ST TL HWY 94H
    X6W HUB, LOCKING MANUAL
    X6Z HUB, LOCKING AUTOMATIC
    X88 CONVERSION NAME PLT CHEVROLET
    YAA TIRE REAR, P285/40ZR17 BL R/PE ST TL HW4
    YAU TIRE REAR, P275/40ZR17/N BL R/PE ST TL HW4
    YA2 DDOR SIDE RR, SLIDING
    YA9 AXLE, (3400-LBS)
    YBE TIRE REAR, P315/35ZR17/N BL R/PE ST TL HWY
    YC1 CONVENIENCE PKG, DECOR LEVEL #1
    YC2 CONVENIENCE PKG, DECOR LEVEL #2
    YC3 CONVENIENCE PKG, DECOR LEVEL #3
    YC4 AXLE (5OOO LB)
    YC5 CONVENIENCE PKG, DECOR LEVEL #5
    YC6 CONVENIENCE PKG, DECOR LEVEL #6
    YC7 CONVENIENCE PKG, DECOR LEVEL #7
    YC9 CONVENIENCE PKG, DECOR LEVEL #9
    YE2 CONVENIENCE PKG, DECOR LEVEL #2, LOW TRIM
    YE3 CONVENIENCE PKG, DECOR LEVEL #3, HIGH TRIM
    YE9 CONVENIENCE PKG, COMFORT & DECOR LEVEL #3
    YF3 CERTIFICATION, EMISSION, FEDERAL
    YF5 CERTIFICATION, EMISSION, CALIFORNIA
    YF7 SALES PACKAGE, RECREATIONAL VEHICLE UPFITTER
    YG3 ORNAMENTATION, BODY SIDE 6 WHL OPENING BRIGHT
    YG5 IDENTIFICATION, SEO USAGE
    YGB IDENTIFICATION, P E P VEHICLE
    YG9 WARRANTY, ENGINE ONLY, 100,000 MILES, 5 YEARS
    YHX TIRE REAR, P205/70R14/N BL R/PE ST TL ALS
    YHY TIRE REAR, P205/70R14/N WS2 R/PE ST TL ALS
    YJT TIRE REAR, P205/75R15/N BL R/PE ST TL OOR
    YJ3 DECAL, 4 X 4
    YK3 ORDER PROTECTION, NO CHANGE
    YL1 TRIM OVERRIDE, UPHOLSTERY, LEATHER/VINYL
    YL2 PAINT SPECIAL, FIREMIST
    YL4 TRIM OVERRIDE, UPHOLSTERY, CLOTH
    YL5 COMMERCIAL BODY, BUILDER SUPERIOR
    YL6 STRIPE COLOR, ACCENT ---- DELETE
    YL7 COMMERCIAL BODY, BUILDER S & S COACH
    YL9 COMMERCIAL BODY, BUILDER HESS
    YM5 STRIPE ACCENT DELETE
    YM6 PROCESSING STOCK SALES
    YNA TIRE REAR, 205/65R15 BW R/PE ST TL HWY 94H
    YP1 MERCHANDISED PKG, CALIFORNIA SEVILLE
    YP3 MERCHANDISED PKG, ELDORADO BIARRITZ
    YP4 MERCHANDISED PKG, SEVILLE ELEGANTE
    YP5 MERCHANDISED PKG, ELDORADO TOURING COUPE
    YP6 MERCHANDISED PKG, SEVILLE TOURING SEDAN
    YP8 MERCHANDISED PKG, CONVERTIBLE
    YP9 MERCHANDISED PKG, SPRING SPECIAL
    YR1 SEAT,FRT CUSTOM
    YR3 SEAT FRT LUXURY
    YT1 BUILD UP DR & QTR
    YT2 BUILD UP DR & QTR, CUSTOM
    YUB TIRE REAR,P195/7DR15/N BL TL R/PE ST AL3
    YW9 SALES PACKAGE, UPS RETROFIT KIT
    YD1 RING GEAR, 7.50 IN., SAGINAW, (S.P.O.)
    Y02 RING GEAR, 7.50 IN., DANA, (S.P.O.)
    Y03 RING GEAR, 7.62 IN., SAGINAW, (S.P.O.)
    Y04 RING GEAR, 8.50 IN., SAGINAW, (S.P.O.)
    Y05 RING GEAR, 8.50 IN., DANA (S P 0.)
    Y06 RING GEAR, 9.50 IN., SAGINAW, (S.P 0.)
    Y07 RING GEAR, 9.50 IN., DANA (S.P.O )
    Y08 RING GEAR, 9.75 IN., SAGINAW, (S.P.O.)
    Y09 RING GEAR, 9.75 IN., DANA (S.P.O.)
    Y10 RING GEAR, 10.50 IN., SAGINAW , ( S.P.O. )
    Y11 RING GEAR, 10.50 IN., DANA (S.P.O )
    Y12 RING GEAR, 12.0O IN., ROCKWELL (S.P.O.)
    Y13 RING GEAR, 11.50 IN., DANA, (S.P.O.)
    Y40 MERCHANDISED PKG, CADILLAC SPCL PGA TOUR EDITION
    Y48 MERCHANDISED PKG, ELECTRA - T TYPE
    Y5E WARRANTY ENGINE ONLY, 150,000 MILES, 5 YEARS
    Y56 MERCHANDISED PKG, GRAN TOURING
    Y61 PROVISION OPTIONS, END RELEASE SEAT BELT BUCKLES
    Y67 DISPLAY , REMINDER PACKAGE
    Y70 PARTS PKG, HEADLINER - VALUE LEADER
    Y72 PARTS PKG, HEADLINER
    Y73 PARTS PKG, DELUXE HEADLINER
    Y79 PROVISION OPTIONS, LOAD BEARING SEAT ADJ
    Y81 MERCHANDISED PKG, FIREBIRD
    Y83 MERCHANDISED PKG, TRANS AM
    Y84 MERCHANDISED PKG, GTA, TRANS AM
    Y85 MERCHANDISED PKG, SSE
    Y86 MERCHANDISED PKG, CAMARO RS
    Y88 PACKAGE, STE SPECIAL TOURING EDITION
    Y89 MERCHANDISED PKG, FIREBIRD SE
    Y91 MERCHANDISED PKG, LUXURY EDITION
    Y92 MERCHANDISED PKG, SPECIAL EDITION
    Y97 PACKAGE, GSE SPECIAL EDITION
    Y98 CONTROL, RIDE SYSTEM ELECTRONIC
    Y99 SALES, HANDLING PKG
    ZAA TIRE SPARE, COMPACT
    ZA7 PACKAGE, VALUE LEADER-CANADIAN
    ZE5 IDENTIFICATION, TRIM LEVEL BASE
    ZJ2 FLEET INCENTIVE , PHILLIPS PETROLEUM (A/B/C/H/L/W-TRK
    ZJ7 WHEEL,SPECIAL HUB CAP 6 TRIM RING
    ZL1 NOISE CONTROL WITH LESS THAN 8000 LB GVW
    ZL8 INVOICE, AUTO FAB, INC.
    ZM3 INVOICE, AUTO FAB INC . ' CAMEO ' EL ' PICKUP
    ZM4 SALES PACKAGE, LUGGAGE CARRIER/RR WINWW DEFLECTOR
    ZM5 SALES PACKAGE, UNDERBODY SHIELD
    ZM6 CHASSIS PACKAGE, OFF-ROAD SUSPENSION
    ZM7 SALES PACKAGE, COMBINATION - INTERMITTENT WIPER/TIL
    ZM8 SALES PACKAGE, COMBINATION - ELECTRIC TAILGATE
    ZN5 PAINT SPECIAL, TWO TONE SPORT
    ZP3 SEATING ARRANGEMENT, FIFTEEN PASSENGER
    ZP5 SEATING ARRANGEMENT, FIVE PASSENGER
    ZP7 SEATING ARRANGEMENT, SEVEN PASSENGER
    ZP8 SEATING ARRANGEMENT, EIGHT PASSENGER
    ZQ2 SALES PACKAGE, DRIVER CONVENIENCE
    ZQ3 SALES PACKAGE, DRIVER CONVENIENCE II
    ZQ9 APPEARANCE PACKAGE, EXTERIOR TRIM, BLACK OUT
    ZR1 PERFORMANCE PACKAGE, SPECIAL COUPE
    ZR9 APPEARANCE PACKAGE, "SYCLONE" PICKUP
    ZVB MODEL CONVERSION, LUUINA EURO
    ZW2 WINDOW PKG, RR DOORS
    ZW3 WINDOW PKG, SIDE RR DR, RR DR
    ZW4 WINDOW PKG, RIGHT HAND SIDE, RR DRS
    ZW6 WINDOW PKG, COMPLETE BODY
    ZW9 B0DY EQUIPMENT, BASE BODY OR CHASSIS
    ZX2 SEATING ARRANGEMENT, DRIVER & PASSENGER, HIGHBACK
    ZX4 WINDOW PKG, LEFT HAND SIDE, SIDE RR DR, RR DR
    ZX6 WINDOW PKG, RR DR, SIDE RR DR, SWING OUT
    ZY1 COLOR COMBINATION, SOLID
    ZY2 COLOR COMBINATION, TWO TONE
    ZY3 COLOR COMBINATION, SPECIAL TWO TONE
    ZY4 COLOR COMBINATION, DELUXE TWO TONE
    ZV6 COLOR COMBINATION, TWO TONE TREATMENT
    ZY7 COLOR COMBINATION, LOWER ACCENT, TWO TONE
    ZY8 COLOR COMBINATION, CUSTOM, TWO TONE
    Z02 PERFORMANCE PACKAGE, TURBO
    Z03 APPEARANCE PACKAGE, 25TH ANNIVERSARY
    Z04 MODEL CONVERSION, 'GTZ' BERETTA
    Z05 CONVENIENCE PKG
    Z07 PERFORMANCE PACKAGE AGGRESSIVE SPORT
    Z08 MODEL CONVERSION, CONVERTIBLE
    Z09 MODEL CONVERSION, CAPRICE CLASSIC
    Z10 MODEL CONVERSION, CARGO VAN
    Z12 SALES, EXTR FUNCTIONAL & APPEARANCE
    Z13 M0DEL CONVERSION, BUICK REGAL GRAN SPORT
    Z21 MOOEL CONVERSION 'GT- BERETTA
    Z22 MOOEL CONVERSION, ROADMASTER ITT LMTD
    Z25 APPEARANCE PACKAGE, 40TH ANNIVERSARY
    Z26 MERCHANDISED PKG,OPEL CONVERSION
    Z28 MERCHANDISED PKG, SPECIAL PERFORMANCE
    Z34 MODEL CONVERSION CHEVROLET LUMINA 'Z34'
    Z41 CONVERSION OPTION, CANAOIAN PONTIAC
    Z47 CONVERSION OPTION, CANADIAN CHEVROLET
    Z49 EXPORT, CANADIAN MODIF MANDATORY BASE EOUIP
    Z5G IDENTIFICATION, CALLAWAY ORDERS
    Z50 MODEL CONVERSION, PONTIAC TEMPEST
    Z5I PACKAGE, PERFORMANCE HANDLING
    Z52 MERCHANDISED PKG, SPORT HANDLING
    Z54 MODEL CONVERSION, CORSICA LTZ
    Z62 CONVENIENCE PKG, COMFORT & DECOR LEVEL #l
    Z65 PACKAGE, MONTE CARLO SS
    Z7H MODEL CONVERSION, CHEVROLET LUMINA
    Z7K MODEL CONVERSION, PONTIAC GRAND PRIX SE
    Z7L MODEL CONVERSION, PONTIAC GRAND PRIX LE
    Z7M MODEL CONVERSION, PONTIAC GRAND PRIX GT
    Z7N MOOEL CONVERSION, PONTIAC GRAND PRIX STE
    Z7P MODEL CONVERSION, OLDSMOBILE CUTLASS SUPREME S
    Z7Q MOOEL CONVERSION, OLDSM0BILE CUTLASS INTERNATIONAL
    Z7R MODEL CONVERSION, OLDSMOBILE CUTLASS SL
    Z7S MOOEL CONVERSION, OLDSMOBILE CUTLASS SUPREME S
    Z7T MOOEL CONVERSION, BUICK REGAL CUSTOM
    Z7U MOOEL CONVERSIO N, BUICK REGAL LIMITED
    Z70 CONVERSION NAME PLT,OLDSMOBILE
    Z71 CHASSIS PACKAGE, OFF-ROAD
    Z72 TRAILER PPOVISIONS, HITCH, BALL TYPE, L.D.
    Z73 CONVENIENCE PKG INTERIOR TRUCK DECOR
    Z74 APPEARANCE PACKAGE, SONOMA GT
    Z76 CAMPER PROVISIONS , SPECIAL CHASSIS (COMMERCIAL)
    Z79 APPEAPANCE PACKAGE, TYPHOON
    Z8I CAMPER PROVISIONS, SPECIAL
    Z82 TRAILER PROVISIONS, SPECIAL EQUIPMENT, H.0.
    Z83 CHASSIS PACKAGE, SOLID SMOOTH RIDE
    Z85 CHASSIS PACKAGE, HIGH PAYLOAD FIRM RIDE
    Z88 CONVERSION NAME PLT GMTB
    00L SECONDARY COLOR, EXTERIOR, PRIME
    00U PRIMARY COLOR, EXTERIOR, PRIME
    01L SECONDARY COLOR, EXTERIOR, SPECIAL (91)
    01U PRIMARY COLOR, EXTERIOR, SPECIAL, (91)
    02A STRIPE COLOR, ACCENT, TWO TONE, BEIGE/GARNET (93)
    02L SECONDARY COLOR, EXTERIOR, SPECIAL, CHART NOT
    02U PRIMARY COLOR, EXTERIOR, SPECIAL, CHART NOT
    04U PRIMARY COLOR, EXTERIOR, FLAX PEARL, (92)
    05P WHEEL COLOR, ARGENT (91)
    06P WHEEL COLOR, BLACK/SILVER (91)
    07A STRIPE COLOR, ACCENT, TWO TONE, WHITE/MED BEECHWOOD**
    07P WHEEL COLOR, GRAY/RED (91)
    08Q MOLDING COLOR , MARY KAY PINK (91)
    08U PRIMARY COLOR, EXTERIOR, MARY KAY PINK (91)
    09A STRIPE COLOR, ACCENT, TWO TONE, WHITE/DK SAPPHIRE
    09U PRIMARY COLOR, EXTERIOR, OPAQUE WHITE (91)
    1A2 SEO VEHICLE, PUBLIC SERVICE
    1C1 SEO VEHICLE, EXPORT, NON POLICE VERSION
    1K5 LEVER, AUTO TRANS, LOW GEAR LOCKOUT
    1LE PERFORMANCE PACKAGE COMPONENTS
    1M1 MARKING, REFLECTIVE WHITE, U.S. ARMY
    1M3 MARKING, REFLECTIVE WHITE, U.S. NAVY
    1M4 MARKING, REFLECTIVE BLACK, U S . NAVY
    1M5 MARKING, REFLECTIVE YELLOW
    1M6 MARKING, REFLECTIVE BLUE U.S NAVY
    1M8 MARKING, REFLECTIVE WHITE, OEFENSE LOGISTICS AGENCY
    1N4 MARKING, REFLECTIVE BLACK ARMY NATIONAL GUARD
    1NS MARKING, REFLECTIVE BLACK, U.S. ARMY
    1N6 MARKING, REFLECTIVE YELLOW, U.S. AIR FORCE
    1N7 MARKING, LUSTERLESS BLACK , U S AIR FORCE
    1PV PAINT SCHEME, 21
    1SV PACKAGE, OPTION 20
    1TA AXLE, FULL FLOATING
    1T1 HOSE, RADIATOR & HEATER SI RUB
    1Z2 VEHICLE PREPARATION, ANTI CORROSION HOT MELT
    10A STRIPE COLOR, ACCENT, TWO TONE, LT GRAY/RED (91)
    10I INTERIOR TRIM, ARCTIC WHITE (93)
    10N TRIM COMBINATION, VINYL, ARCTIC WHITE (N) (93)
    10P WHEEL COLOR, GRAY WHITE (91)
    10Q MOLDING COLOR , ARCTIC WHITE (91)
    10T TOP COLOR, ARCTIC WHITE (91)
    10U PRIMARY COLOR , EXTERIOR, ARCTIC hHITE (91)
    103 TRIM COMBINATION, LEATHER, ARCTIC WHITE (93)
    11I INTERIOR TRIM , WHITE (I) (92)
    11N TRIM COMBINATION, VINYL, WHITE (N) (92)
    11P WHEEL COLOR, PINK (92)
    112 TRIM COMBINATION, LEATHER, WHITE (2) (91)
    113 TRIM COMBINATION, LEATHER, WHITE (3) (91)
    114 TRIM COMBINATION, LEATHER, WHITE (4) (91)
    115 TRIM COMBINATION, LEATHER, WHITE (S) (91)
    116 TRIM COMBINATION, LEATHER, WHITE (6) (91)
    119 SEAT BELT COLOR WHITE (9) (91)
    12A STRIPE COLOR ACCENT SILVER MET (91)
    12B TRIM COMBINATION,CLOTH, GRAPHITE (B) (92)
    12C TRIM COMBINATION,CLOTH, GRAPHITE (C) (92)
    12D TRIM COMBINATION,CLOTH, GRAPHITE (D) (92)
    12E TRIM COMBINATION CLOTH, GRAPHITE (E) (92)
    12F COVERING COLOR FLOOR MAT, GRAPHITE (92)
    12H TRIM COMBINATION CLOTH GRAPHITE (H) (92)
    12I INTERIOR TRIM, GRAPHITE (92)
    12K AUX TOP COLOR WHITE (91)
    12L SECONDARY COLOR, EXTERIOR, SILVER MET (91)
    12P WHEEL COLOR PLATINUM
    12Q MOLDING COLOR, SILVER MET (91)
    12U PRIMARY COLOR, EXTERIOR SILVER MET (91)
    122 TRIM COMBINATION, LEATHER, GRAPHITE (2) (92)
    123 TRIM COMBINATION, LEATHER, GRAPHITE (3) (92)
    124 TRIM COMBINATION, LEATHER, GRAPHITE (4 ) (92)
    125 TRIM COMBINATION, LEATHER, GRAPHITE (S) (92)
    126 TRIM COMBINATION, LEATHER, GRAPHITE (6) (92)
    128 TRIM COMBINATION, CLOTH, GRAPHITE (B) (92)
    129 SEAT BELT COLOR, GRAPHITE (92)
    13A STRIPE COLOR, ACCENT, BRIGHT SILVER MET (91)
    13B TRIM COMBINATION, CLOTH, LT SLATEGRAY (B) (92)
    13C TRIM COMBINATION, CLOTH, LT SLATEGRAY (C)
    13D TRIM COMBINATION, CLOTH, LT SLATEGRAY (D)
    13E TRIM COMBINATION, CLOTH, LT SMOKE GRAY (E) (92)
    13G TRIM COMBINATION, CLOTH, LT GRAY (G) (91T)
    13H TRIM COMBINATION, CLOTH, LT SMOKE GRAY (H) (91)
    13I INTERIOR TRIM, LT SMOKE GRAY (91)
    13L SECONDARY COLOR, EXTERIOR, BRIGHT SILVER MET (91)
    13Q MOLDING COLOR, BRT SILVER MET (91)
    13T TOP COLOR, BRIGHT SILVER MET (91)
    13U PRIMARY COLOR , EXTERIOR, BRIGHT SILVER MET (91)
    13V TRIM COMBINATION, VINYL, LT GRAY (V)
    13W TRIM COMBINATION, VINYL, LT GRAY (W)
    132 TRIM COMBINATION, LEATHER, GRAY (2) (91)
    14A STRIPE COLOR ACCENT, LT GRAY (91)
    14B TRIM COMBINATION, CLOTH, LT GRAY (B) (92)
    14C TRIM C0MBINATION, CLOTH, LT GRAY (C) (92)
    14D TRIM C0MBINATION, CLOTH, LT GRAY (D) (92)
    14E TRIM COMBINATION, CLOTH, LT GRAY (E) (92)
    14F COVERING COLOR, FLOOR MAT, LT GRAY (92)
    14G TRIM COMBINATION, CLOTH, LT GRAY (G) (92)
    14H TRIM C0MBINATION, CLOTH, LT GRAY (H) (93)
    14I INTERIOR TRIM , LT GRAY (I) (92)
    14J TRIM COMBINATION, CLOTH, LT GRAY J (93)
    14L SECONDARY COLOR, XTERIOR, LT GRAY MET (92)
    14N TRIM COMBINATION, VINYL, LIGHT GRAY (N) (92)
    14Q M0LDING COLOR , BLACK 4ET, (91)
    14R TRIM COMBINATION, VINYL, LT GRAY (R) (92)
    14U PRIMARY COLOR , EXTERIOR, LT GRAY 4ET (92)
    142 TRIM COMBINATION, LEATHER, LT GRAY (2) (92)
    143 TRIM COMBINATION, LEATHER, LT GRAY (3) (92)
    144 TRIM COMBINATION, LEATHER, LT GRAY (4) (92)
    145 TRIM COMBINATION, LEATHER, LT GRAY (5) (92)
    146 TRIM COMBINATION, LEATHER, LT GRAY (6) (92)
    149 SEAT BELT, COLOR, LT GRAY (92)
    15A STRIPE COLOR, ACCENT, MED GRAY MET, (91)
    15B TRIM COMBINATION, CLOTH, MED SLATE GRAY (B) (91)
    15C TRIM C0MBINATION, CLOTH, MED SLATE GRAY (C) (91)
    15D TRIM COMBINATION, CLOTH, MED SLATE GRAY (D) (91)
    15E TRIM C0MBINATION, CLOTH, MED SLATE GPAY (E) (91)
    15F COVERING COLOR, FLOOR MAT, MED SLATE GRAY (91 )
    15G TRIM COMBINATION, CLOTH, SLATE GRAY (G)
    15H TRIM COMBINATION, CLOTH, MED SLATE GRAY (H) (91)
    15IINTERIOR TRIM, MED SLATE GRAY (91)
    l5J TRIM COMBINATION, CLOTH, MED SLATE GRAY (J) (91)
    15L SECONDARY COLOR, EXTERIOR, ASTRAL SILVER (91)
    15P WHEEL COLOR SILVER MET (91)
    l5Q MOLDING COLOR, MED GRAY MET (91)
    15U PRIMARY COLOR, EXTERIOR ASTRAL SILVER (91)
    1E3 TRIM COMBINATION, LEATHER, MED SLATE GRAY (2) (3t1
    154 TRIM COMBINATION, LEATHER, MED SLATE GRAY (4) (91)
    155 TRIM C0MBINATION, LEATHER, MED SLATE GRAY (5) (91)
    156 TRIM COMBINATION, LEATHER, MED SLATE GRAY (6) (91)
    15B TRIM COMBINATION, CLOTH, MED SLATE (91)
    159 SEAT BELT COLOR, MED SLATE GRAY (91)
    16A STRIPE COLOR, ACCENT, TWO TONE, BLACK/GARNET RED
    16L SECONDARY COLOR, EXTERIOR, WARM GRAY MET (91)
    16P WHEEL COLOR, BRT WHITE (91)
    16Q MOLDING COLOR , BRITE WHITE (91)
    16S ROOF COLOR, GRAY, REMOVABLE PANEL
    16T TOP COLOR, BRITE WHITE (94)
    16U PRIMARY COLOR , EXTERIOR, WARM GRAY 4ET (91)
    17A STRIPE COLOR, ACCENT, SILVER (91)
    17F COVERING COLOR, FLOOR MAT, CHARCOAL (91)
    17I INTERIOR TRIM , CHARCOAL (91)
    17L SECONDARY COLOR, EXTERIOR, LT SLATE MET (91)
    17P WHEEL COLOR, SILVER (91)
    17Q MOLDING COLOR , SILVER (91)
    17T TOP COLOR, PEARL GRAY (91)
    17U PRIMARY COLOR , EXTERIOR, LT SLATE MET (91)
    172 TRIM COMBINATION, LEATHER, CHARCOAL (2) (91)
    179 SEAT BELT, COLOR CHARCOAL (91)
    18A STRIPE COLOR, ACCENT, SLATE GRAY (91)
    18B TRIM COMBINATION, CLOTH, CHARCOAL
    18C TRIM COMBINATION, CLOTH, DK CHARCOAL, (C)
    18D TRIM COMBINATION, CLOTH, DK CHARCOAL, (D)
    18E TRIM COMBINATION, CLOTH, DK CHARCDAL, (E)
    18H TRIM COMBINATION, CLOTH, DK CHARCOAL, (H)
    18I INTERIOR TRIM, DK CHARCOAL, (I) (91)
    18P WHEEL COLOR, CHARCOAL MET (91)
    18Q MOLDING COLOR, SLATE GRAY (91)
    18T TOP COLOR, SLATE GRAY (91)
    18U PRIMARY COLOR, EXTERIOR, SLATE GRAY (91)
    18W TRIM COMBINATION, VINYL, DK CHARCOAL (W)
    182 TRIM COMBINATION, LEATHER, OK CHARCOAL (2) (91)
    19A STRIPE COLOR, ACCENT, TWO TONE, MED GRAY MET/BLACK
    19B TRIM COMBINATION, CLOTH, BLACK (B) (91)
    19C TRIM COMBINATION, CLOTH, BLACK (C) (91)
    19D TRIM COMBINATION, CLOTH, BLACK (D)
    19E TRIM COMBINATION, CLOTH BLACK (E) (91)
    19F COVERING COLOR, FLOOR MAT, BLACK (91)
    19H TRIM COMBINATION, CLOTH, BLACK (H)
    19I INTERIOR TRIM, BLACK (I) (91)
    19J TRIM COMBINATION, CLOTH, BLACK (J)
    19K AUX TOP COLOR BLACK (91)
    19L SECONDARY COLOR, EXTERIOR, LAMP BLACK (91)
    19R TRIM COMBINATION, VINYL BLACK (R)
    19U PRIMARY COLOR, EXTERIOR, LAMP BLACK (91)
    19W TRIM COMBINATION, VINYL BLACK (W)
    192 TRIM COMBINATION, LEATHER, BLACK (2) (91 )
    193 TRIM COMBINATION, LEATHER, BLACK (3) (91)
    194 TRIM COMBINATION, LEATHER, BLACK (4) (91)
    195 TRIM COMBINATION, LEATHER, BLACK (5) (91)
    198 TRIM C0MBINATION, LEATHER, BLACK (6) (92)
    198 TRIM COM8INATION, CLOTH, BLACK (8) (91)
    199 SEAT BELT COLOR, BLACK (91)
    20A STRIPE COLOR, ACCENT, DK ROYAL BLUE (94)
    20B TRIM COMBINATION, CLOTH, VERY DK SAPPHIRE (8) (91)
    20C TRIM COMBINATION, CLOTH, VERY DK SAPPHIRE (C) (91)
    20D TRIM C0MBINATION, CLOTH. VERY DK SAPPHIRE (D) (91)
    20E TRIM COMBINATION, CLOTH, VERY DK SAPPHIRE (E) (91)
    20F COVERING COLOR, FLODR MAT, VERY DK SAPPHIRE (91)
    20G TRIM COMBINATION, CLOTH, VERY DK SAPPHIRE (G) (91)
    20H TRIM C0MBINATION, CLOTH, VERY DK SAPPHIRE (H) (91)
    20I INTERIOR TRIM, VERY DK SAPPHIRE (91)
    20J TRIM COMBINATION,CLOTH, VERY DK SAPPHIRE (J) (91)
    20L SECONDARY COLOR, EXTERIOR, LT QUASAR BLUE MET (92)
    20N TRIM COMBINATION, VINYL(N), VERY DK SAPPHIRE (1991)
    20Q MOLDING COLOR, LT QUASAR 8LUE MET (91)
    20U PRIMARY COLOR, EXTERIOR, LT QUASAR BLUE MET (93)
    20V TRIM COMBINATION, VINYL, SAPPHIRE BLUE (V) (92)
    201 TRIM COMBINATION, VINYL, VERY DK SAPPHIRE (W)
    202 TRIM COMBINATION, LEATHER, VERY DK SAPPHIRE (2)
    203 TRIM C0MBINATION, LEATHER, VERY DK SAPPHIRE (3)
    204 TRIM C0MBINATION, LEATHER, VERY DK SAPPHIRE (91)
    205 TRIM C0MBINATION, LEATHER, VERY DK SAPPHIRE (5)
    206 TRIM C0MBINATION, VINYL, HD, VERY DK SAPPHIRE
    207 TRIM C0MBINATION, CLOTH, HD, VERY DK SAPPHIRE
    208 TRIM C0MBINATION, CLOTH, VERY DK SAPPHIRE (8) (91)
    209 SEAT BELT, COLOR VERY DK SAPPHIRE (91)
    21A STRIPE COLOR, ACCENT DK SAPPHIRE BLUE (91)
    21I INTERIOR TRIM, DK MONTANA BLUE (I) (94)
    21P WHEEL COLOR, NEON BLUE (91)
    21Q MOLDING COLOR, NEON BLUE MET (92)
    21U PRIMARY COLOR EXTERIOR, NEON BLUE MET (91)
    22A STRIPE COLOR ACCENT LT SAPPHIRE BLUE (91)
    22B TRIM C0MBINATION, CLOTH, DK ROYAL BLUE (B)
    22C TRIM C0MBINATION, CLOTH, DK ROYAL BLUE (C)
    22D TRIM C0MBINATION, CLOTH, DK ROYAL BLUE (D)
    22E TRIM COMBINATION, CLOTH, DK ROYAL BLUE (E)
    22G TRIM COMBINATION, CLOTH, DK ROYAL BLUE (G)
    22H TRIM C0MBINATION, CLOTH, DK ROYAL BLUE (H)
    22I INTERIOR TRIM, DK STEEL BLUE (91)
    22L SECONDARY COLOR, EXTERIOR BAHAMA BLUE MET (91)
    22Q MOLDING CDLOR, LT SAPPHIRE BLUE MET (91)
    22T TOP COLOR, LT SAPPHIRE BLUE MET (91)
    22U PRIMARY COLOR, EXTERIOR BAHAMA BLUE MET (91)
    222 TRIM C0MBINATION, LEATHER DK ROYAL BLUE (2)
    223 TRIM COMBINATION, LEATHER DK STEEL BLUE (3) (91)
    224 TRIM COMBINATION, LEATHER, DK ROYAL BLUE (4)
    229 SEAT BELT COLOR, DK STEEL BLUE (91)
    23A STRIPE COLOR, ACCENT, LT BLUE (91)
    23G TRIM COMBINATION, CLOTH, BLUE (G)
    23I INTERIOR TRIM, LT BLUE (91)
    23Q MOLDING COLOR, MED MAUI BLUE MET (91)
    23U PRIMARY COLOR, EXTERIOR, MED MAUI BLUE MET (91)
    23V TRIM COMBINATION,VINYL, BLUE (V)
    23W TRIM COMBINATION, VINYL, BLUE (M)
    24A STRIPE COLOR, ACCENT , TWO TONE , DK BLUE/SLATE {91 )
    24B TRIM COMBINATION, CLOTH, DK BLUE (B) (91)
    24C TRIM COMBINATION, CLOTH, DK BLUE (C) (91)
    24D TRIM COMBINATION, LOTH, DK BLUE (D) (91)
    24E TRIM COMBINATION, CLOTH, DK BLUE (E) (91)
    24G TRIM COMBINATION, CLOTH, DK BLUE (G) (91)
    24I INTERIOR TRIM, DK BLUE (I) (91)
    24L SECONDARY COLOR, EXTERIOR, BRIGHT BLUE MET (91)
    24Q MOLDING COLOR, BRT BLUE MET {91)
    245 ROOF COLOR,BLUE, REMOVABLE PANEL
    24U PRIMARY COLOR, EXTERIOR, BRIGHT BLUE MET (91)
    24V TRIM COMBINATION, VINYL, DK BLUE (V) (91)
    24M TRIM COMBINATION, VINYL, DK BLUE (4) (91)
    25A STRIPE COLOR, ACCENT, TWO TONE, SILVER/BLUE (91)
    25U PRIMARY COLOR, EXTERIOR, STEEL BLUE MET (91)
    26A STRIPE COLOR, ACCENT, TWO TONE, DK SAPPHIRE/RED
    26L SECONDARY COLOR, EXTERIOR, PASTEL BLUE (91)
    26T TOP COLOR, DK BLUE (91)
    26U PRIMARY COLOR, EXTERIOR, PASTEL BLUE (91)
    27A STRIPE COLOR, ACCENT, TW0 TONE, LT BLUE/DK BLUE
    27B TRIM COMBINATION, CLOTH, DK BLUE (B)
    27C TRIM COMBINATION, CLOTH, DK BLUE (C)
    27D TRIM COMBINATION, CLOTH, DK BLUE (D)
    27E TRIM COMBINATION, CLOTH, DK BLUE (E)
    27G TRIM CQMBINATION, CLOTH, DK BLUE (G)
    27H TRIM COMBINATION, CLOTH, DK BLUE (H)
    27L SECONDARY COLOR, EXTERIOR, MED SAPPHIRE BLUE MET
    27N TRIM COMBINATION, VINYL, DK BLUE (N)
    27P WHEEL COLOR, LT BLUE MET (91)
    27Q MOLDING COLOR, MED SAPPHIRE BLUE MET (91)
    27R TRIM COMBINATION, VINYL, DK BLUE (R)
    27U PRIMARY COLOR, EXTERIOR, LT FRENCH BLUE MET (91)
    27V TRIM COMBINATION, VINYL, DK BLUE (V)
    27W TRIM COMBINATION, VINYL, DX BLUE (M)
    27X TRIM COMBINATION, VINYL, DK BLUE (X)
    27Y TRIM COMBINATION, VINYL, DK BLUE (Y)
    27Z TRIM COMBINATION, VINYL, DK BLUE (Z)
    272 TRIM COMBINATION, LEATHER, DK BLUE (2)
    273 TRIM COMBINATION, LEATHER, DK BLUE (3)
    274 TRIM COMBINATION, LEATHER, DK BLUE (4)
    275 TRIM COMBINATION, LEATHER, DK BLUE (5)
    276 TRIM COMBINATION, LEATHER, DK BLUE (6)
    28A STRIPE COLOR, ACCENT, BLUE (91)
    28I INTERIOR TRIM, MED BLUE (91)
    28L SECONDARY COLOR, EXTERIOR, BLACK SAPPHIRE MET (91)
    28Q MOLDING COLOR, BLACK SAPPHIRE MET (91)
    28T TOP COLOR, BLACK SAPPHIRE MET (91)
    28U PRIMARY COLOR, EXTERIOR, BLACK SAPPHIRE MET (91)
    29A STRIPE COLOR, ACCENT, MED BLUE (91)
    29L SECONDARY COLOR, EXTERIOR, DK BLUE (91)
    29T TOP COLOR, DK SAPPHIRE MET (91)
    29U PRIMARY COLOR, EXTERIOR, DK BLUE (91)
    30A STRIPE COLOR, ACCENT, TWO TONE, LT BLUE MET/GRAY
    30L SECONDARY COLOR, EXTERIOR, GRAY BLUE MET (91)
    30U PRIMARY COLOR, EXTERIOR, GRAY BLUE MET (91)
    31A STRIPE COLOR, ACCENT MINT GREEN MICA (92)
    31U PRIMARY COLOR, EXTERIOR, ARCTIC WHITE PEARL (92)
    32A STRIPE COLOR, ACCENT, LT TEAL MET (92)
    32U PRIMARY COLOR ,EXTERIOR, MED BRIGHT TEAL MT (94)
    33A STRIPE COLOR, ACCENT, TWO TONE, VERMILLION/GARNET
    33K AUX TOP COLOR , LT DRIFTWOOD (91)
    33L SECONDARY COLOR, EXTERIOR, LT MESA BROWN (91)
    33P WHEEL COLOR , LT DRIFTWOOD MET (91)
    33Q MOLDING COLOR, LT DRIFTWOOD MET (91)
    33T TOP COLOR, LT DRIFTWOOD MET (91)
    33U PRIMARY COLOR, EXTERIOR, LT MESA BROWN (91)
    34A STRIPE COLOR, ACCENT, VERMILLION (91)
    34K AUX TOP COLOR, GOLD (91)
    34L SECONDARY COLOR, EXTERIOR, LT MESA BRN MET (91)
    34P WHEEL COLOR, LT MESA BROWN MET (91)
    34Q MOLDING COLOR, LT TEAL MET (92)
    34U PRIMARY COLOR, EXTERIOR, LT MESA BROWN MET (91)
    35A STRIPE COLOR, ACCENT, TWO TONE, VERMILLION/BLACK
    35L SECONDARY COLOR, EXTERIQR, YELLOW (92)
    35U PRIMARY COLOR, EXTERIOR, YELLOW (92)
    36A STRIPE COLOR, ACCENT, TWO TONE, LT TEAL/BLACK (93)
    36L SECONDARY COLOR, EXTERIOR, MED DK TEAL MET (92)
    36P WHEEL COLOR, YELLOW (92)
    36U PRIMARY COLOR, EXTERIOR, MED DK TEAL MET (92)
    37A STRIPE COLOR, ACCENT, TWO TONE, DK BRQWN MET/8LACK
    37L SECONDARY COLOR, EXTERIOR, DK BRT TEAL MET (91)
    37P WHEEL COLOR, DK BRIGHT TEAL MET (91)
    37Q MOLDING COLOR, DK BRIGHT TEAL MET
    37U PRIMARY COLOR, EXTERIOR, LT BROWN (91)
    38A STRIPE COLOR, ACCENT, TWO TONE, LT TEAL MET/BEIGE
    38F COVERING COLOR, FLOOR MAT, NATURAL BEIGE (91)
    38I INTERIOR TRIM, NATURAL BEIGE (91)
    38U PRIMARY COLOR, EXTERIOR, CHAMPAGNE MET (91)
    382 TRIM COMBINATION, LEATHER, NATURAL BEIGE (2) (91)
    389 SEAT BELT COLOR, NATURAL BEIGE (91)
    39A STRIPE COLOR, ACCENT, MED BROWN (91)
    39U PRIMARY COLOR, EXTERIOR, DK ADRIATIC BLUE MET (94)
    4X8 SEO-INSTRUiENT PNL DELUXE
    4Zl SEO-SPARE WHL & STO, NO TIRE
    4Z2 SEO-2ND SEAT & BELT
    4Z3 SEO-MATS COLOR KEYED
    40A STRIPE COLOR, ACCENT, WHITE (91)
    40L SECONDARY COLOR, EXTERIOR, WHITE (91)
    40P WHEEL COLOR, WHITE (91)
    40Q MOLDING COLOR, WHITE (91)
    40T TOP COLOR, WHITE (91)
    40U PRIMARY COLOR, EXTERIOR, WHITE (91)
    41A STRIPE COLOR ACCENT BLACK (91)
    41L SECONDARY COLOR, EXTERIOR, BLACK (91)
    41P WHEEL COLOR BLACK (91)
    41Q MOLDING COLOR, BLACK (91)
    41T TOP COLOR, BLACK (91)
    42A STRIPE COLOR, ACCENT TWO TONE SILVER/BLACK (91)
    42B TRIM COMBINATION, CLOTH, MED GRAYFERN (B)
    42C TRIM COMBINATIQN, CLOTH, MED GRAYFERN (C)
    42D TRIM COMBINATION, CLOTH, MED GRAYFERN (D)
    42E TRIM COMBINATIQN, CLOTH, MED GRAYFERN (E)
    42H TRIM C0MBINATION, CLOTH, MED GRAYFERN (H)
    42L SECONDARY COLOR, EXTERIOR, SKY BLUE (91)
    42P WHEEL COLOR, TURQUOISE MET (91)
    42U PRIMARY COLOR , EXTERIOR, SKY BLUE (91)
    422 TRIM COMBINATION, LEATHER, MED GRAY FERN (2)
    424 TRIM COMBINATION, LEATHER, MED GRAY FERN (4)
    43A STRIPE COLOR, ACCENT, MED GREEN (91)
    43B TRIM COMBINATION, CLOTH, MED SAGE (B)
    43C TRIM COMBINATION, CLOTH, MED SAGE (C)
    43D TRIM COMBINATION, CLOTH, MED SAGE (D)
    43E TRIM COMBINATION, CLOTH, MED SAGE (E)
    43G TRIM COMBINATION, CLOTH, MED SAGE (G)
    43H TRIM COMBINATION, CLOTH, MED SAGE ( H )
    43I INTERIOR TRIM, MED SAGE (I)
    43L SECONDARY COLOR, EXTERIOR, SEAFOAM GREEN (91)
    43P WHEEL COLOR, BRT AQUA (92)
    43Q MOLDING COLOR, MED AQUA MET (91)
    43U PRIMARY COLOR, EXTERIOR, SEAFOAM GREEN (91)
    44A STRIPE COLOR, ACCENT, TWO TONE, LT BROWN/DOESKIN
    44L SECONDARY COLOR, EXTERIOR, FOREST GREEN MET (91)
    44U PRIMARY COLOR, EXTERIOR, FOREST GREEN MET (91)
    45A STRIPE COLOR, ACCENT, TWO TONE, MED BEECHWOOD/LT
    45Q MOLDING COLOR, MED GREEN MET (91)
    45U PRIMARY COLOR, EXTERIOR, MED GREEN MET (91)
    46A STRIPE COLOR, ACCENT, TWO TONE, VERMILION/SLATE
    46U PRIMARY COLOR, EXTERIOR, DK GREEN (91)
    47A STRIPE COLOR, ACCENT, TWO TONE, VERMILLION/BEIGE
    47B TRIM COMBINATION, CLOTH, DK RED (B) (91)
    47C TRIM COMBINATION, CLOTH, DK RED (C) (91)
    41D TRIM COMBINATION, CLOTH, DK RED (D) (91)
    47E TRIM COMBINATION, CLOTH, DK RED (E) (91)
    47G TRIM CDMBINATION, CLOTH, DK RED (G) (91)
    47I INTERIDR TRIM, DK RED (I) (91)
    47L SECDNDARY CDLOR, EXTERIOR, DK BLUE MET (91)
    47Q MOLDING CDLOR, EURO RED (91)
    47U PRIMARY COLOR, EXTERIOR, DK BLUE MET (91)
    47V TRIM COMBINATION, VINYL, DK RED (V) (91)
    47W TRIM COMBINATION, VINYL , DK RED (W) (91 )
    472 TRIM COMBINATIDN, LEATHER, DK RED (2) (91)
    48A STRIPE COLOR, ACCENT, SANDSTONE (92)
    48B TRIM CDMBINATION, CLOTH, MED EMERALD (B)
    48C TRIM COMBINATION, CLOTH, MED EMERALD (C)
    48D TRIM COMBINATION, CLOTH, MED EMERALD (D)
    48E TRIM COMBINATION, CLOTH, MED EMERALD (E)
    4BH TRIM COMBINATION, CLOTH, MED EMERALD (H)
    48I INTERIOR TRIM, MED EMERALD (I)
    48L SECONDARY COLOR EXTERIOR, DK RED (91)
    48Q MDLDING COLOR, DK YELLDW GREEN MET (91)
    48U PRIMARY COLOR EXTERIOR, DK RED (91)
    482 TRIM COMBINATION, LEATHER, MED EMERALD (2)
    483 TRIM COMBINATION, LEATHER, MED EMERALD (3)
    484 TRIM COMBINATION, LEATHER MED EMERALD (4)
    49A STRIPE COLOR ACCENT LT ANTELOPE (91)
    49B TRIM COMBINATION, CLOTH, MIDNIGHT SAGE (B)
    49C TRIM COMBINATION, CLOTH, MIDNIGHT SAGE (C)
    49D TRIM COMBINATION, CLOTH, MIDNIGHT SAGE (D)
    49E TRIM COMBINATION, CLOTH, MIDNIGHT SAGE (E)
    49H TRIM COMBINATION, CLOTH, MIDNIGHT SAGE (H)
    49U PRIMARY COLOR, EXTERIOR, VERDORO GREEN MET ( 92 )
    492 TRIM COMBINATION, LEATHER, MIDNIGHT SAGE (2)
    494 TRIM COMBINATION, LEATHER, MIDNIGHT SAGE (4)
    5AN TIRE ALL, P225/7DHR15/N WS2 R/PE ST TL AL3
    5AQ TIRE ALL, P225/7DHR15/N BL R/PE ST TL AL3
    5A1 PANEL LEFT, ADSCO (#7280-20-1)
    5A2 PANEL RIGHT, ADSCO (#728D-45-1)
    5A3 PANEL LEFT, INTERIOR, PARTITION,TOP SCREEN ADSCO
    5A4 PANEL RIGHT, INTERIOR PARTITION, ADSCO #728D-46-1
    5A5 RADIATOR, H/D COOLING MANUAL TRANS
    5A6 RADIATOR, H/D COOLING AUTO TRANS
    5A7 WHEEL SPARE, DELETION
    5BI PANEL CENTER, FIXED INTERIOR, PARTITION, TOP SCREEN
    5B2 PANEL CENTER, PARTITION PANEL (FIXED} #7280-51-1
    5B3 PANEL CENTER, INT, PARTITION, ADSCO #72BD-52-1
    5B7 PANEL CENTER, INTERIOR PARTITION, HINGED, ADSCO
    5B8 PANEL CENTER, INTERIOR PARTITION, HINGED ADSCO #
    5CI PANEL, LH, PLEXIGLASS, ADSCO #5226-2
    5C2 PANEL, CTR, PLEXIGLASS, ADSCO #5226-2
    5C3 PANEL, RH, PLEXIGLASS, ADSCO #5226-2
    5C7 HOOK, CARGO TIE DN, BODY - I0 FT
    5C8 HOOK, CARGO TIE DN, BODY - 12 FT
    5C9 HOOK, CARGO TIE DN, BODY - 14 FT
    5D4 COOLING SYSTEM, EXPORT H/D
    5D5 FAN, RADIATOR B00STER
    5D8 PAINT PROCESS, BUMPER, FRT, SPECIAL
    5D9 PAINT PROCESS, BUMPER, RR, SPECIAL
    5E8 MARKING, REFLECTIVE BLACK, DEPARTMENT OF DEFENSE
    5E9 MARKING, REFLECTIVE YELLOW ON BLUE, U.S AIR FORCE
    5F4 SPRING REAR, II000 LB
    5F5 DECAL, ADSCO-WEST ELECTRIC STRIPING, (5858/5859)
    5F6 LEVER, PARKING BRAKE ORSCHELIN
    5F7 MARKING, RED ON REFLECTIVE WHITE, U.S. AIR FORCE
    5H1 PANEL, SERVICE, INTERIOR (#10541/lDS42)
    5H2 LAMP, CARGO , ADSCO (SEARS ROEBUCK) (#7799)
    5H3 LAMP, CARGO ADSCO (SEARS ROE8UCK #7798) (2)
    5H5 WINDOW, SCREEN , SI CARGO DR (SEARS-ROEBUCK) (#7797)
    5H6 WINDOW SCREEN, RR DR (SEARS-ROEBUCK) (#7795)
    5H8 CYLINDER UNIT FOR SINGLE KEY SYSTEM, CODED 8OLO
    5JK TIRE ALL P225/70HRIS/N BL P/PE ST TL HWY
    5J2 GENERAT0R, DELETE
    5J9 SPRING RR, AUXILIARY ASSIST
    5K4 EQUIPMENT, PARALLEL BAR KIT - FRITO LAY
    5L7 MARKING, VEH, U S. MARINE CORPS-REFL BLACK
    5N1 DOOR RR, 38 IN, W/GLASS
    5N2 DOOR RR, 74 IN W/GLASS
    5P1 INTERIOR PACKAGE, PARCEL SERVICE, FEDERAL EXPRESS/CR
    5P2 WHEEL, ALUMINUM, SPECIAL
    5P3 TIRES, SPARE, CARRIER
    5P4 NET PACKAGE, ENDGATE
    5P6 INTERIOR PACKAGE, PARCEL SERVICE, FEDERAL EXPRESS/AD
    5Q2 CONVENIENCE PKG, CARGO VAN
    5R2 SEAT RR, INTERMEDIATE, DELETION
    5R9 SPEAKER SYSTEM, RR, DELETE
    5U9 COVERING, FLOOR MATS, FRT
    5V1 CARRIER, SPARE WHEEL W/O TIRE
    5V4 APPEARANCE PACKAGE, VEHICLE PROVISIONS #l
    5V6 CONVENIENCE PKG, DELUXE
    5V7 APPEARANCE PACKAGE, VEHICLE PROVISIONS #2
    5X8 CYLINDER UNIT, SIDE CARGO & RR DOOR
    5Y1 CARRIER, I/S P/U BOX, MOUNTED, SPARE
    5Y9 CLUSTER, INST, DELETION
    5Z1 CONTAINER, ENG OIL PAN, 5 QUART
    5Z4 WHEEL & TIRE, SPARE, DELETION
    5Z5 HUBCAPS, DELETION
    5Z7 APPEARANCE PACKAGE, MISC PARTS REQ'D FROM GM T & B
    5Z9 ANTENNA, RADIO, DELETE
    50F COVERING COLOR, FLOOR MAT, LT YELLOW (91 )
    50I INTERIOR TRIM , LT YELLOW (91)
    50L SECONDARY COLOR, EXTERIOR, BLUE WHITE (91)
    50P WHEEL COLOR, BLUE WHITE (92)
    50Q MOLDING COLOR, FLAX (91)
    50T TOP COLOR, FLAX (91)
    50U PRIMARY COLOR, EXTERIOR BLUE WHITE (91)
    503 TRIM COMBINATION, LEATHER, LT YELLOW (3)
    504 TRIM COMBINATION, LEATHER, LT YELLOW (4) (91)
    505 TRIM COMBINATION, LEATHER, LT YELLOW (S) (91)
    506 TRIM COMBINATION, LEATHER LT YELLOW (6}
    509 SEAT BELT, COLOR LT YELLOW (9) (91)
    51A STRIPE COLOR, ACCENT TWO TONE MED BEECHWOOD/DK
    51L SECONDARY COLOR, EXTERIOR SEDONA TAN (91)
    51T TOP COLOR, DK ANTELOPE MET (91)
    51U PRIMARY COLOR EXTERIOR, SEDONA TAN (91)
    52A STRIPE COLOR, ACCENT TWO TONE BLACK/BEIGE MET
    52B TRIM COMBINATION, CLOTH, LT NEUTRAL (B) (92)
    52D TRIM COMBINATION, CLDTH, LT NEUTRAL (D) (92)
    52F COVERING COLOR, FLOOR MAT, LT NEUTRAL (92)
    52G TRIM COMBINATION, CLOTH, LT NEUTRAL (G) (92)
    52I INTERIOR TRIM, LT NEUTRAL (I) (92)
    52L SECONDARY COLOR, EXTERIOR, SEDONA TAN (91)
    52P WHEEL COLOR, GOLD MET (91)
    52Q MOULDING COLOR, JAMACIA YELLOW (92)
    52U PRIMARY COLOR, EXTERIOR, JAMAICA YELLOW (92)
    522 TRIM COMBINATION, LEATHER, LT NEUTRAL (2) (92)
    523 TRIM COMBINATION, LEATHER, LT NEUTRAL (3) (92)
    524 TRIM COMBINATION, LEATHER, LT NEUTRAL (4) (92)
    525 TRIM COMBINATION, LEATHER, LT NEUTRAL (S) (92)
    526 TRIM COMBINATION, LEATHER, CHAMOIS (6)
    529 SEAT BELT COLOR, LT NEUTRAL (9) (92)
    53A STRIPE COLOR, ACCENT, TWO TONE, BLACK/GOLD MET (91)
    53U PRIMARY COLOR, EXTERIOR, COMPETITION YELLOW, (91)
    54A STRIPE COLOR, ACCENT, MED GOLD (91)
    54B TRIM COMBINATION, CLOTH , TAUPE ( B) (92)
    54D TRIM COMBINATION, CLOTH, TAUPE (D) (92)
    54F COVERING COLOR, FLOOR MAT, TAUPE (92)
    54G TRIM COMBINATION, CLOTH, TAUPE (G) (92)
    54I INTERIOR TRIM , TAUPE (I) (92)
    54L SECONDARY COLOR, EXTERIOR, MED FLAX (91)
    54Q MDLDING COLOR, SUNFIRE YELLOW (93)
    54U PRIMARY COLOR, EXTERIOR, MED FLAX (91)
    542 TRIM COMBINATION, LEATHER, TAUPE (2) (92)
    543 TRIM COMB NATION, LEATHER, TAUPE (3) (92)
    544 TRIM COMBINATION, LEATHER, TAUPE (4) (92)
    545 TRIM COMBINATION, LEATHER, TAUPE (S) (92)
    546 TRIM COMBINATION, LEATHER, TAUPE (6) (92)
    549 SEAT BELT COLOR, TAUPE (9) (92)
    55A STRIPE COLOR, ACCENT, GOLD (91)
    55Q MOLDING COLOR, LT CANYON YELLOW (92)
    55T TOP COLOR, DK BROWN (91)
    55U PRIMARY COLOR, EXTERIOR, LT CANYON YELLOW (92)
    56A STRIPE COLOR, ACCENT, TWO TONE, DK BROWN/ALMOND
    56T TOP COLOR, ALABASTER (91)
    56U PRIMARY COLOR, EXTERIOR, ALABASTER (91)
    57A STRIPE COLOR, ACCENT, DK TEAL (92)
    57L SECONDARY COLOR, EXTERIOR, CAMEL BEIGE (91 )
    57P WHEEL COLOR, BEIGE MET (92)
    57Q MOLDING COLOR , CAMEL BEIGE (91)
    57T TOP COLOR, CAMEL BEIGE (91)
    57U PRIMARY COLOR, EXTERIOR, CAMEL BEIGE (91)
    58A STRIPE COLOR, ACCENT TWO TONE, BLACK/ORANGE (91)
    58L SECONDARY COLOR, EXTERIOR, LT SANDSTONE MET (91)
    58T TOP COLOR, LT SADDLE (91)
    58U PRIMARY COLOR, EXTERIOR, LT SANDSTONE MET (91)
    59A STRIPE COLOR, ACCENT, COPPER BEIGE (91)
    59T TOP COLOR, BRONZE MET (93)
    59U PRIMARY COLOR, EXTERIOR ORANGE MET (92)
    6A2 STEERING COLUMN, SEO KEYED
    6A3 COVERING, FLOOR MATS FRT & RR H. D.
    6A4 CYLINDER UNIT, SINGLE KEY SYSTEM NO SPECIFIC CODE
    6A5 CYLINDER UNIT FOR SINGLE KEY SYSTEM
    6B2 HANDLE, REAR DOOR, INOPERATIVE
    6B4 TIRE SPARE RELOCATION LH LUG COMPT FL.
    6B7 WIRING PROVISIONS ROOF PNL ACCESS HOLE CENTER
    6C1 SEAT, FRT BENCH, HEAVY DUTY
    6C2 SEAT, RR BENCH, HEAVY DUTY
    6C4 SEAT, HEAVY DUTY, FRONT (46/45) SPLIT
    6C5 LAMP, INTR ROOF, COURTESY AND READING
    6C6 SWITCH, REAR DOOR JAMB, LH & RH
    6C7 LAMP, DOME PASSENGER
    6C8 CA8LE, RG58 A/U COAX RADIO ANTENNA
    6C9 CONDUIT, TWO WAY RADIO CONTROL CABLE
    6E2 CYLINDER UNIT, FOR SINGLE KEY SYSTEM, CODED 37D2
    6E8 CYLINDER UNIT, FOR SINGLE KEY SYSTEM,
    6F5 WIRING PROVISIONS, ROOF
    6F8 TRAY, ASH FRT DR
    6G2 REINFORCEMENT, ROOF PANEL
    6H6 LOCK, AUTOMATIC TRUNK, RELEASE, RT
    6J1 WIRING PROVISIONS, IGNITION AND MAIN POWER SUPPLY
    6J2 WIRING PROVISIONS, HEADLIGHT FLASHER AND GRILLE
    6J3 WIRING PROVISIONS, HEADLIGHT FLASHER, GRILLE LIGHTS
    6J4 WIRING PROVISIONS, HORN/SIREN CIRCUIT
    6J5 WIRING PROVISIONS, ROOF PNL ACCESS HOLE
    6J6 LAMP PACKAGE, EMER VEH R/WDO PNL
    6K3 LOCK, AUTO SIDE CARGO & RR DOOR
    6K5 CONSOLE, FRT COMPARTMENT FLOOR
    6K6 SEAT, BUCKET TYPE, DRIVER
    6K8 SEAT, BUCKET TYPE, DRIVER & PASS
    6L2 LINING, FULL LENGTH
    6L8 MIRROR O/S, STAINLESS
    6M1 MIRROR O/S, RR VIEW, WHITE
    6M3 MIRROR O/S, LH & RH, WIDE ANGLE
    6M4 LINING FULL LENGTH (110 IN WB)
    6M9 TIRE SPARE, DELETE, W/WHEEL
    6N1 HANDLE, INSIDE L.H. DOOR AND LOCK RELEASE
    6N3 HANDLE, I/S, RR DOOR RELEASE ASSIST
    6N4 HANDLE, I/S, RR DOQR RELEASE
    6N5 HANDLE INOPERATIVE, RR WINDOW
    6N6 LOCK CONTROL, RR DOOR, INOPERATIVE
    6N8 HANDLE, REAR SEAT ASSIST
    6N9 MIRROR O/S, STAINLESS STEEL HEADS
    6P1 ARM REST, RH DOOR
    6P2 ARM REST, DELETION
    6P3 MIRROR O/S, PAINTED WHITE
    6P7 MIRROR O/S, RR VIEW L & R REM CONT, CHROME
    602 REINFORCEMENT PICK UP B0X
    6R2 COVER SPARE TIRE
    6R6 TRIM, SEAT SEAMLESS VINYL, FRONT & REAR
    6R7 TRIM, SEAT, SEAMLESS CLOTH, FRONT & REAR
    6R8 TRIM, SEAT SEAMLESS CLOTH-FRT SEAMLESS VINYL-RR
    6S7 TRIM OVERRIDE, CLOTH SEAT TRIM, REPLACING VINYL
    6T5 TRIM EXTR, WHITE
    6V6 MODIFICATION, CHASSIS RECREATION VEHICLE
    6Y1 ORNAMENTATION EXTR MLDG, FRT DOOR BODY SI,
    6Y2 SEAT RR, ----DELETE
    6Y4 WHEEL & TIRE SPARE DELETE
    6Z2 SEAL, SPEEDOMETER SHAFT
    60B TRIM COMBINATION, CLOTH, LT DRIFTWOOD ( B)
    60C TRIM COMBINATION, CLOTH, MED COGNAC (C) (91)
    60D TRIM COMBINATION, CLOTH, LT DRIFTWOOD (D)
    60E TRIM COMBINATION, CLOTH, LT DRIFTWOOD (E)
    60G TRIM COMBINATION, CLOTH, LT DRIFTWOOD (G)
    60H TRIM COMBINATION, CLOTH, LT DRIFTWOOD (H)
    60I INTERIOR TRIM, MED COGNAC (91)
    60U PRIMARY COLOR EXTERIOR, BEIGE TITANIUM (92)
    60V TRIM COMBINATION, VINYL, DK COGNAC (V) (1988 TRK)
    60W TRIM COMBINATION, VINYL, DK COGNAC (W) (1988 TRK)
    602 TRIM COMBINATION, LEATHER, LT DRIFTWOOD (2)
    603 TRIM COMBINATION, LEATHER, LT DRIFTWOOD (3)
    604 TRIM COMBINATION, LEATHER, LT DRIFTWOOD (4)
    609 SEAT BELT COLOR, MED COGNAC (91)
    61A STRIPE COLOR, ACCENT, TWO TONE, ALMOND/DK BROWN
    61I INTERIOR TRIM, DK SIENNA (I)
    61L SECONDARY COLOR, EXTERIOR, TAN (91)
    61U PRIMARY COLOR, EXTERIOR, TAN (91)
    62A STRIPE COLOR, ACCENT, ORANGE (91)
    62B TRIM COMBINATION, CLOTH, LT SADDLE (B)
    62C TRIM COMBINATION, CLOTH, LT SADDLE (C)
    62D TRIM COMBINATION, CLOTH, LT SADDLE (D)
    62E TRIM COMBINATION, CLOTH, LT SADDLE (E)
    62G TRIM COMBINATION, CLOTH, LT SADDLE (G)
    62H TRIM COMBINATION, CLOTH, LT SADDLE (H)
    62I INTERIOR TRIM, LT SADDLE (I)
    62L SECONDARY COLOR, EXTERIOR, LT TAUPE (92)
    62N TRIM COMBINATION, VINYL, LT SADDLE (N)
    62Q MOLDING COLOR, LT 8EECHWOOD MET (91)
    62R TRIM COMBINATION, VINYL, LT SADDLE (R)
    62T TOP COLOR, LT BEECHWOOD MET (91)
    62U PRIMARY COLOR EXTERIOR, LT BEECHWOOD MET (91)
    62V TRIM COMBINATION, VINYL, LT SADDLE (V)
    62W TRIM COMBINATION, VINYL, LT SADDLE (W)
    62Y TRIM COMBINATION, VINYL, LT SADDLE (Y)
    62Z TRIM COMBINATION, VINYL LT SADDLE (Z)
    622 TRIM COMBINATION, LEATHER, LT SADDLE (2)
    623 TRIM COMBINATION, LEATHER, LT SADDLE (3)
    626 TRIM COMBINATION, LEATHER, LT SADDLE (6)
    63A STRIPE COLOR, ACCENT, TWO TONE, LT AUBURN/DK AUBURN
    63F COVERING COLOR, FLOOR MAT, MED SADDLE (93 E/K)
    63I INTERIOR TRIM, MEDIUM SADDLE (93)
    63L SECONDARY COLOR, EXTERIOR, MED TAUPE MET (92)
    63T TOP COLOR, MED TAUPE (92)
    63U PRIMARY COLOR, EXTERIOR, MED TAUPE MET (92)
    639 SEAT BELT, COLOR SADDLE (1989 PASS V)
    64A STRIPE COLOR, ACCENT, LT AUBURN (91)
    64B TRIM COMBINATION, CLOTH, LT BEIGE (B) (92)
    64C TRIM COMBINATION, CLOTH, LT BEIGE (C) (92)
    B4D TRIM COMBINATION, CLOTH, LT BEIGE (D) (92)
    64E TRIM COMBINATION, CLOTH, LT BEIGE (92)
    64F COVERING COLOR, FLOOR MAT, LT BEIGE (92)
    64G TRIM COMBINATION, CLOTH, LT BEIGE (G) (92)
    64H TRIM COMBINATION, CLOTH, BEIGE (H) (92)
    64I INTERIOR TRIM, LIGHT BEIGE (I) (92)
    64J TRIM COMBINATION, CLOTH, LT BEIGE (J) (92)
    64N TRIM COMBINATION, VINYL, LT BEIGE (N) (92)
    645 ROOF COLOR, BRONZE, REMOVABLE PANEL
    64T TOP COLOR, LT AUBURN MET (91)
    64U PRIMARY COLOR, EXTERIOR, LT AUBURN MET (91)
    64V TRIM COMBINATION, VINYL, LT BEIGE (V) (92)
    64W TRIM COMBINATION, VINYL , LT BEIGE (W) (92)
    642 TRIM COMBINATION, LEATHER, LT BEIGE (2) (92)
    643 TRIM COMBINATION, LEATHER, LT BEIGE (3) (92)
    644 TRIM COMBINATION, LEATHER, LT BEIGE (4) (92)
    645 TRIM COMBINATION, LEATHER, LT BEIGE (5) (92)
    649 SEAT BELT COLOR, LIGHT BEIGE (9) (92)
    65A STRIPE COLOR, ACCENT, TWO TONE, LT AUBURN/DK CLARET
    65B TRIM COMBINATION, CLOTH, MED ANTELOPE (B) (91)
    65C TRIM COMBINATION, CLOTH, MED ANTELOPE (C) (91)
    65D TRIM COMBINATION, CLOTH, MED ANTELOPE (D) (91)
    65E TRIM COMBINATION, CLOTH, MED ANTELOPE (E) (91}
    65F COVERING COLOR, FLOOR MAT, MED ANTELOPE (91)
    65G TRIM COMBINATION, CLOTH, MED ANTELOPE (G) (91)
    65H TRIM COMBINATION, CLOTH, MED ANTELOPE (H) (1989)
    65I INTERIOR TRIM, MED ANTELOPE (91)
    65L SECONDARY COLOR,EXTERIOR, LT CAMEL TITANIUM (91)
    65Q MOLDING COLOR, LT CAMEL TITANIUM (91)
    65T TOP COLOR, LT CAMEL TITANIUM (91)
    65U PRIMARY COLOR, EXTERIOR, LT CAMEL TITANIUU (91)
    652 TRIM COMBINATION, LEATHER, MED ANTELOPE (2) (91)
    653 TRIM COMBINATION, LEATHER, MED ANTELOPE (3) (91)
    654 TRIM COMBINATION, LEATHER, MED ANTELOPE (4) (91)
    655 TRIM COMBINATION, LEATHER, MED ANTELOPE (5) (91)
    659 SEAT BELT COLOR, MED ANTELOPE (9) (91)
    66A STRIPE COLOR, ACCENT, DK AUBURN (91)
    66B TRIM COMBINATION, CLOTH, MED BEECHWOOD (B)
    66C TRIM COMBINATION, CLOTH, MED BEECHWOOD (C)
    66D TRIM COMBINATION, CLOTH, MED BEECHWOOD (D)
    66E TRIM COMBINATION, CLOTH, MED BEECHWOOD (E}
    66F COVERING, COLOR, FLOOR MAT MED BEECHWOOD (91)
    66G TRIM COMBINATION, CLOTH, MED BEECHWOOD (G}
    66H TRIM COMBINATION, CLOTH MED BEECHWOOD, (1989 PASS)
    66I INTERIOR TRIM, MED BEECHWOOD (91)
    66J TRIM COMBINATION, CLOTH, MED BEECHWOOD (J) (1989)
    66L SECONDARY COLOR, EXTERIOR, DK AUBURN MET (91)
    66Q MOLDING COLOR, DK AUBURN MET (91)
    66T TOP COLOR, DK AUBURN MET (91)
    66U PRIMARY COLOR, EXTERIOR, DK AUBURN MET (91)
    662 TRIM COMBINATION, LEATHER, MED BEECHWOOD (91)
    663 TRIM COMBINATION, LEATHER, MED BEECHWOOD (3) (92)
    664 TRIM COMBINATION, LEATHER MED BEECHWOOD (4) (91)
    665 TRIM COMBINATION, LEATHER NED BEECHWOOD (5) (91)
    666 TRIM COMBINATION, LEATHER, MED BEECHWOOD (6) (91 )
    667 TRIM COMBINATION, CLOTH, HD, MED BEECHWOOD
    668 TRIM COMBINATION, LEATHER, MED BEECHWOOD (B) (92)
    669 SEAT BELT COLOR, MED BEECHWOOD (9) (91)
    67A STRIPE COLOR, ACCENT, LT CAMEL MET (91)
    67B TRIM COMBINATION, CLOTH, LT CAMEL (B) (91)
    67C TRIM COMBINATION, CLOTH, LT CAMEL (C) (91)
    67D TRIM COMBINATION, CLOTH, LT CAMEL (D) (91)
    67E TRIM COMBINATION, CLOTH, LT CAMEL (E) (91)
    67F COVERING COLOR, FLOOR MAT, CAMEL (91)
    67G TRIM COMBINATION, CLOTH, CAMEL (G)
    67H TRIM COMBINATION, CLOTH, LT CAMEL (H) (91)
    67I INTERIOR TRIM, LT CAMEL (91)
    67J TRIM COMBINATION, CLOTH, LT CAMEL (J) (91)
    67L SECONDARY COLOR, EXTERIOR, LT CAMEL MET (91)
    67N TRIM COMBINATION, VINYL, CAMEL (N)
    67P WHEEL COLOR, LT CAMEL MET (91)
    67Q MOLDING COLOR, LT CAMEL MET (91)
    67T TOP COLOR, LT CAMEL MET (91)
    67U PRIMARY COLOR, EXTERIOR, LT CAMEL MET (91)
    672 TRIM COMBINATION, LEATHER, LT CAMEL (2j (91)
    673 TRIM COMBINATION, LEATHER, LT CAMEL (3)(91)
    674 TRIM COMBINATION, LEATHER, LT CAMEL (4) (91)
    675 TRIM COMBINATION, LEATHER, LT CAMEL (5) (91)
    676 TRIM COMBINATION, LEATHER, LT CAMEL (6) (91)
    678 TRIM COMBINATION, CLOTH, LT CAMEL (B) (91)
    679 SEAT BELT, COLOR,LT CAMEL (91)
    68A STRIPE COLOR, ACCENT, TWO TONE, LT AUBURN/LT
    68B TRIM COMBINATION, CLOTH, DK AUBURN ( B) (91 )
    68C TRIM COMBINATION, CLOTH, DK AUBURN (91)
    68D TRIM COMBINATION, CLOTH, DK AUBURN (D) (91)
    68E TRIM COMBINATION, CLOTH, DK AUBURN (E) (91)
    68F COVERING COLOR, FLOOR MAT, DK AUBURN (91)
    68G TRIM COMBINATION, CLOTH, DK AUBURN (G) (91)
    68I INTERIOR TRIM, DK AUBURN (91)
    68L SECONDARY COLOR, EXTERIOR, CINNAMON MET ( 92 )
    68R TRIM COMBINATION , VINYL , RUSSET (R)
    68T TOP COLOR, NEUTRAL BEIGE (91)
    68U PRIMARY COLOR, EXTERIOR, CINNAMON MET (92}
    682 TRIM COMBINATION, LEATHER, DK AUBURN (2) (91 )
    683 TRIM COMBINATION, LEATHER, DK AUBURN (3) (91)
    684 TRIM COMBINATION, LEATHER, DK AUBURN (4) (91)
    685 TRIM COMBINATION, LEATHER, DK AUBURN (S) (91)
    689 SEAT BELT, COLOR, DK AUBURN (9) (91)
    69A STRIPE COLOR, ACCENT, LT BEIGE (91)
    69B TRIM COMBINATION, CLOTH, MED BEIGE (B)
    69C TRIM COMBINATION, CLOTH, MED BEIGE (C)
    69D TRIM COMBINATION, CLOTH, MED BEIGE (D)
    69E TRIM COMBINATION, CLOTH, MED BEIGE (E)
    69G TRIM COMBINATION, CLOTH, MED BEIGE (G)
    69H TRIM COMBINATION, CLOTH, MED BEIGE (H)
    69L SECONDARY COLOR, EXTERIOR, ROOTBEER MET (92)
    69Q MOLDING COLOR, ROOTBEER, MET (92)
    69T TOP COLOR, ROOTBEER (92)
    69U PRIMARY COLOR, EXTERIOR, MED BEECHWOOD MET (91)
    69V TRIM COMBINATION, VINYL, MED BEIGE (V)
    69W TRIM COMBINATION, VINYL MED BEIGE (W)
    692 TRIM COMBINATION, LEATHER, MED BEIGE (2)
    693 TRIM COMBINATION, LEATHER, MED BEIGE (3)
    694 TRIM COMBINATION, LEATHER, MED BEIGE (4)
    696 TRIM COMBINATION, LEATHER, MED BEIGE (6)
    7B3 SUSPENSION SYSTEM, SPECIAL HANDLING
    7B4 SUSPENSION SYSTEM, SPECIAL RYDER
    7B7 SUSPENSION SYSTEM, HEAVY DUTY, FRONT
    7J1 PACKAGE,HOT CLIMATE
    7L1 GENERATOR , A/C 120 AMP
    7L4 THROTTLE CONTROL,MANUAL ASM
    7L8 COOLING SYSTEM, TRANS, OIL, H D
    7L9 COOLING SYSTEM, STEERING, OIL
    7P8 COOLING SYSTEM, ENG OIL, SEE KC4
    7S1 FUEL TANK, RH MOUNTED, 20 GAL
    7T6 FUEL, FITTING, LINE TAKE
    7X6 SPOTLAMP, LEFT HAND, PILLAR MOUNTED, HALOGEN
    7X7 SPOTLAMP, LEFT AND RIGHT, PILLAR MOUNTED, HALOGEN
    7XB SPOTLAMP, PROVISIONS, LH
    7X9 SPOTLAMP, PROVISIONS, LH W RH
    7Y1 LAMP, ENGINE COMPARTMENT
    7Y2 LAMP, DOOR OPENING WARNING
    7Y4 METER, ENGINE, HOUR
    7Y5 BATTERY , HO, AUXILIARY
    7Y6 SWITCH, DOME LAMP DOOR JAMB INOPERATIVE
    7Z1 HORN, DUAL, HIGH NOTE
    7Z4 CLUSTER, INST, OIL, COOL TEMP, VOLTS SEE U14
    7Z5 CIRCUIT BREAKERS, ADDITIONAL 12 VOLT
    7Z7 CLUSTER INST, KILO, GOVERNMENT LEADED FUEL
    7Z8 SPEEDOMETER, PRODUCTION TYPE
    7Z9 CLUSTER POLICE TYPE-TELLTALE
    70A STRIPE COLOR ACCENT, TWO TONE, RED/DK CLARET (91)
    70B TRIM COMBINATION, CLOTH, DK MAPLE RED (B) (91)
    70C TRIM COMBINATION, CLOTH, DK MAPLE RED (C) (91)
    70D TRIM COMBINATION, CLOTH, DK MAPLE RED (D) (91)
    70E TRIM COMBINATION, CLOTH, DK MAPLE RED (E) (91)
    70F COVERING COLOR, FLOOR MAT DK MAPLE RED (91)
    70G TRIM COMBINATION, CLOTH, OK MAPLE RED (G) (91)
    70H TRIM COMBINATION, CLOTH, DK MAPLE RED (H) (91)
    70I INTERIOR TRIM, DK MAPLE RED (91)
    70J TRIM COMBINATION, CLOTH, DK MAPLE RED (J) (91)
    70L SECONDARY COLOR, EXTERIOR, RED (91)
    70N TRIM COMBINATION, VINYL, DK MAPLE RED (N)
    70R TRIM COMBINATION, VINYL, DK MAPLE RED (R)
    70T TOP COLOR, TORCH RED (93)
    70U PRIMARY COLOR, EXTERIOR, TORCH RED (91)
    70V TRIM COMBINATION, VINYL, DK MAPLE RED (V)
    702 TRIM COMBINATION, LEATHER, DK MAPLE RED (2) (91)
    703 TRIM COMBINATION, LEATHER, DK MAPLE RED (3) (91)
    709 SEAT BELT COLOR, DK MAPLE RED (9) (91)
    71A STRIPE COLOR, ACCENT, TWO TONE, SILVER/RED (91)
    71F COVERING COLOR, FLOOR MAT, MAROON (91)
    71I INTERIOR TRIM, MAROON (91)
    710 MOLDING COLOR, RED (91)
    71T TOP COLOR, RUBY RED (93)
    71U PRIMARY COLOR, EXTERIOR, RED ORANGE (91)
    712 TRIM COMBINATION, LEATHER, MAROON (2) (91)
    719 SEAT BELT COLOR, MAROON (91)
    72A STRIPE COLOR, ACCENT, MED GARNET RED (91)
    72B TRIM COMBINATION, CLOTH, DK CARMINE (B)
    72C TRIM COMBINATION, CLOTH, DK CARMINE (C)
    72D TRIM COMBINATION, CLOTH, DK CARMINE (D)
    72E TRIM COMBINATION, CLOTH, DK CARMINE (E)
    72F COVERING, COLOR FLOOR MAT, DK CARMINE (91)
    72G TRIM COMBINATION, CLOTH, DK CARMINE (G)
    72H TRIM COMBINATION CLOTH, DK CARMINE (H)
    72I INTERIOR TRIM, DK CARMINE (91)
    72L SECONDARY COLOR, EXTERIOR, MED GARNET RED MET (91)
    72N TRIM COMBINATION VINYL, DK CARMINE (N)
    72P WHEEL COLOR, MED GARNET RED MET (91)
    72Q MOLDING COLOR, MED GARNET RED MET (91)
    72R TRIM COMBINATION, VINYL, DK CARUINE (R)
    72T TOP COLOR, MED GARNET RED MET (91)
    72U PRIMARY COLOR, EXTERIOR, MED GARNET RED MET (91)
    72V TRIM COMBINATION, VINYL, DK CARMINE (V)
    72W TRIM COMBINATION, VINYL, DK CARMINE (W)
    72Y TRIM COMBINATION, VINYL, DK CARMINE (Y)
    72Z TRIM COMBINATION, VINYL, DK CARMINE (Z)
    722 TRIM COMBINATION, LEATHER, DK CARMINE (2) (91)
    723 TRIM COMBINATION, LEATHER, DK CARMINE (3) (91)
    724 TRIM COMBINATION, LEATHER, DK CARMINE (4)
    726 TRIM COMBINATION, LEATHER, DK CARMINE (6)
    729 SEAT BELT COLOR, DK CARMINE (9) (91)
    73A STRIPE COLOR, ACCENT, TWO TONE, VERMILLION/CARMINE
    73B TRIM COMBINATION, CLOTH, FLAME RED (B) (91)
    73C TRIM COMBINATION, CLOTH, FLAME REO (C) (91)
    73F COVERING COLOR, FLOOR MAT, FLAME RED (91)
    73I INTERIOR TRIM, FLAME RED (I) (91)
    73U PRIMARY COLOR ,EXTERIOR, YELLOW RED MET (91)
    732 TRIM COMBINATION, LEATHER, FLAME RED (2) (91)
    733 TRIM COMBINATION, LEATHER, FLAME RED (3) (91)
    734 TRIM COMBINATION, LEATHER. FLAME RED (4) (91)
    739 SEAT BELT COLOR, FLAME RED (91)
    74A STRIPE COLOR, ACCENT, TWO TONE, BLACK/RED (91)
    74I INTERIOR TRIM , CARMINE (I)
    74L SECONDARY COLOR, EXTERIOR, FLAME RED MET (91)
    74Q MOLDING COLOR, FLAME RED MET (91)
    74T TOP COLOR, FLAME RED MET (91)
    74U PRIMARY COLOR, EXTERIOR, VICTORY RED (91)
    742 TRIM COMBINATION, LEATHER, CARMINE (2)
    744 TRIM COMBINATION, LEATHER, DK CARMINE (4) SSV
    75A STRIPE COLOR ACCENT, RED (91)
    75B TRIM COMBINATION, CLOTH, BORDEAUX RED (B) (93)
    75F COVERING, COLOR FLOOR MAT, BORDEAUX RED (94)
    75G TRIM COMBINATION, CLOTH, BORDEAUX RED (G) (93)
    75I INTERIOR TRIM, BORDEAUX RED (93)
    75L SECONDARY COLOR, EXTERIOR, BRILLIANT RED BET (91)
    75Q MOLDING COLOR , BRILLIANT RED MET (91)
    75U PRIMARY COLOR, EXTERIOR BRILLIANT RED MET (91)
    752 TRIM COMBINATION, LEATHER, BORDEAUX RED (2) (93)
    753 TRIM C0MBINATION, LEATHER, BORDEAUX RED (3) (93)
    754 TRIM COMBINATION, LEATHER, BORDEAUX RED (4) (94)
    759 SEAT BELT, COLOR, B0RDEAUX RED (93)
    76A STRIPE COLOR, ACCENT, DK GARNET RED (91)
    76L SECONDARY COLOR, EXTERIOR, DK GARNET RED MET (91)
    760 MOLDING COLOR, DK GARNET RED MET (91)
    76T TOP COLOR DK, GARNET RED MET (91)
    76U PRIMARY COLOR, EXTERIOR, DK GARNET RED MET (91)
    77A STRIPE COLOR, ACCENT, VICTORY RED t92)
    77B TRIM COMBINATION, CLOTH, DK MAPLE tB)
    77C TRIM COMBINATION, CLOTH, DK MAPLE (C)
    77D TRIM COMBINATION, CLOTH, DK MAPLE (D)
    77E TRIM COMBINATION, CLOTH, DK MAPLE (E)
    77G TRIM COMBINATION, CLOTH, DK MAPLE (G)
    77H TRIM COMBINATION, CLOTH, DK MAPLE (H)
    77I INTERIOR TRIM, DK MAPLE (I)
    77L SECONDARY COLOR, EXTERIOR, DARK CHERRY MET (92)
    77Q MOLDING COLOR, DK MAPLE RED MET
    77T TOP COLOR, DK CHERRY MET (92)
    77U PRIMARY COLOR, EXTERIOR, DARK CHERRY MET (92)
    77V TRIM C0MBINATION, VINYL, DK MAPLE (V)
    77W TRIM C0MBINATION, DK MAPLE (W)
    772 TRIM COMBINATION, LEATHER, DK MAPLE (2)
    773 TRIM C0MBINATION, LEATHER, DK MAPLE (3)
    774 TRIM COMBINATION, LEATHER, DK MAPLE (4)
    78A STRIPE COLOR, ACCENT, TWO TONE, RED/DK RED (92}
    78B TRIM C0MBINATION, CLOTH, GARNET RED (B) (91)
    78C TRIM COMBINATION, CLOTH, GARNET RED (C) (91)
    78D TRIM C0MBINATION, CLOTH, GARNET RED (D) (91)
    78E TRIM COMBINATION, CLOTH, GARNET RED (E) (91)
    78F COVERING COLOR, FLOOR MAT, GARNET (91)
    78G TRIM COMBINATION, CLOTH, GARNET RED (G) (91)
    78H TRIM COMBINATION, CLOTH, GARNET RED (H) (91)
    78I NTERIOR TRIM, GARNET RED (91)
    78J TRIM COMBINATION, CLOTH, GARNET RED (J) (91)
    78L SECONOARY COLOR, EXTERIOR, DK YELLOW RED MET (91>
    78X MOLDING COLOR, DK RED (91)
    78T TOP COLOR, D MAPLE, RED MET (91)
    78U PRIMARY COLOR, EXTERIOR, DK YELLOW RED MET (91)
    782 TRIM COMBINATION, LEATHER, GARNET RED (2) (91)
    783 TRIM COMBINATION, LEATHER, GARNET RED (3) (91)
    784 TRIM COMBINATION, LEATHER, GARNET RED (4) (91)
    785 TRIM C0MBINATION, LEATHER, GARNET RED (5) (91)
    786 TRIM COMBINATION, LEATHER, GARNET RED (6) (92)
    788 TRIM COMBINATION, CLOTH, GARNET RED (B) (92)
    789 SEAT BELT COLOR, GARNET RED (91)
    79A STRIPE COLOR, ACCENT, DK CLARET (91)
    798 TRIM COMBINATION, CLOTH, RUBY RED (B) (93)
    79C TRIM COMBINATION, CLOTH, RUBY RED (C) (93)
    79D TRIM COMBINATION, CLOTH, RUBY RED (D) (93)
    79E TRIM COMBINATION, CLOTH, RUBY REO (E) (93)
    79F COVERING COLOR, FLOOR MAT, DK CLARET (1989 PASS D)
    79G TRIM COMBINATION, CLOTH, RUBY RED (G) (94)
    79H TRIM COMBINATION, CLOTH, DK CLARET (H)
    79I INTERIOR TRIM, RUBY RED (93)
    79J TRIM COMBINATION, CLOTH, RUBY RED (J) (93)
    79N TRIM COMBINATION, VINYL, DK CLARET (N)
    79R TRIM COMBINATION,VINYL, DK CLARET (R)
    79U PRIMARY COLOR, EXTERIOR, BURGUNDY MET (91)
    79V TRIM COMBINATION, VINYL, DK CLARET (V)
    79W TRIM COMBINATION, VINYL, DK CLARET (W)
    792 TRIM COMBINATION, LEATHER, RUBY RED (2) (93)
    793 TRIM COMBINATION, LEATHER, RUBY RED (3) (93)
    794 TRIM COMBINATION, LEATHER, RUBY RED (4) (94)
    799 SEAT BELT COLOR, RUBY RED (93)
    8A3 GENERATOR, 124 AMP, CS144
    8A8 TACHOMETER,
    8B2 MIRROR O/S, RH & LH, WIDELOOP, PAINTED
    8B3 COOLANT, ETHELENE GLYCOL) (-34 DEGREES)
    8B5 RADIO PROVISIONS, INSTALLATION
    8B7 HOSE, RADIATOR & HEATER (SPECIAL)
    8B8 ODOMETER, SPECIAL INSTRUMENT CLUSTER
    8C5 JACK, C9 ELECTRICAL OUTLET
    8C9 SEAT, FRT/LAP & SHOULDER BELT DELETE
    8D2 FUEL, ADDITIONAL (I GAL)
    8D5 HEADLAMPS, SINGLE RECTANGULAR ASSIST
    8D6 REINFORCEMENT, RR FRAME RAIL
    8E1 FUEL, ADDITIONAL - 3 GALLONS
    8E2 SEAT, DELETION, FRONT
    8E6 BUMPER RR, PAINTED
    8E8 BUMPER FRT, PAINTED
    8F1 FUEL, ADDITIONAL TWO GALLONS
    8F4 BUMPER RR, STEP
    8GB LAMP, PASSENGER-DOME
    8G9 MIRROR O/S, RH & LH, "WIDELOOP", STAINLESS
    8H1 INSULATION, EXTRA-FLOOR
    8H3 FLOOR, 3/4' PLYWOOD UNION CITY BODY
    8H5 BUMPER FRT, DELETE
    8H9 FLASHER, HEAVY DUTY TURN SIGNAL
    8K3 SPEAKER SYSTEM, RADIO, INSTRUMENT PANEL
    8M3 SWITCH, DOME LIGHT R . H . DOOR OPERATED
    8M5 BUMPER FRT, PAINTED, BLACK, WRAP AROUND
    8M7 HEADLAMPS, SUBSTITUTION
    8MB HANDLE, I EA ON INSIDE OF RR HANDLES
    8M9 HANDLE, I EA MOUNTED INSIDE OF DOOR
    8N1 SALES PACKAGE, COLD CLIMATE, DIESEL USED WITH
    8N4 SPEAKER SYSTEM, INSTRUMENT PANEL (COAXIAL)
    8N9 SPEAKER, RDO DELETE
    8P3 INDICATOR, TRANSMISSION FLUID
    8P5 WINDOW, PARTITION 13 X 18 INCH
    8P6 BUMPER RR, SPECIAL PAINT
    8Q2 VENT, STATIC TYPE ROOF
    8Q5 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
    8Q7 VENT, ADSCO, ROOF (DRIVERS COMPARTMENT#10540)
    8Q9 VENT, ROOF ADSCO-EVANS(STATIC) (#S999)
    8R6 FUEL, SENDER ASM, HIGH TEMP
    8R9 CONTAINER, INSTRUMENT ADSCO(SEARS) (#5969)
    8S4 MIRROR O/S, LH 6 RH, WEST COAST TYPE, LARGE, W/6 IN
    8S9 CHASSIS, SPECIAL, UTILITY 80DY
    8U4 HEATER ENG, BLOCK (SEO)
    8W5 GENERATOR, 105 AMP
    8W7 SEAT, BUCKET TYPE, DRIVER & PASS, LOW BACK FRT
    8W9 SPRING, FRONT SUSPENSION
    8X4 PARTITION, PLYWOOD, W/CTR SLIDING DOOR
    8X7 SHOCK ABSORBERS, FRT & RR, GAS PRELOADED, DELCO/BILS
    8X8 VANITY, MAINTAINENCE (OPER SI CARGO DOOR) ADSCO(#6135
    8Z1 ENGINE, DELETE
    8Z2 TRANSMISSION, DELETE
    8Z3 GENERATOR, IOO AMP, HEAVY DUTY, PENSKE/RYDER
    8Z5 CAP, METAL VALVE STEM
    80A STRIPE COLOR, ACCENT, TWO TONE, RED/DK SAPPHIRE
    80B TRIM COMBINATION, CLOTH, SAND (B)
    80C TRIM COMBINATION, CLOTH, SAND (C)
    80D TRIM COMBINATION, CLOTH, SAND (D)
    80G TRIM COMBINATION, CLOTH, SAND (G)
    80I INTERIOR TRIM, SAND (I)
    80Q MOLDING COLOR, MED QUASAR BLUE MET (91)
    80U PRIMARY COLOR, EXTERIOR, MED QUASAR BLUE MET (91)
    81A STRIPE COLOR, ACCENT, TWO TONE, RED/BLACK (91)
    81P WHEEL CDLOR, BRIGHT RED (91)
    81Q MOLDIMG COLOR, BRIGHT RED (91)
    81U PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
    82A STRIPE COLOR, ACCENT, LT SAPPHIRE TITANIUM (91)
    82B TRIM COMBINATION, CLOTH, MED DK GRAY (91)
    82C TRIM COMBINATION, CLOTH, MED DK GRAY (C) (91)
    82D TRIM COMBINATION, CLOTH, MED DK GRAY ( D) (91 )
    82E TRIM COMBINATION, CLOTH, MED DK GRAY (E) (91)
    82F COVERING COLOR, FLOOR MAT, MED DK GRAY (91)
    82G TRIM COMBINATION, CLOTH, MED DK GRAY (G) (91)
    82H TRIM COMBINATION, CLOTH MED DK GRAY (H) (91)
    82I INTERIOR TRIM, MED DK GRAY (91)
    82J TRIM COMBINATION, CLOTH, MED DK GRAY (J) (91)
    82L SECONDARY COLOR, EXTERIOR, LT SAPPHIRE TITANIUM
    82N TRIM COMBINATION, VINYL, DK MED GRAY (N)
    82Q MOLDING COLOR, LT SAPPHIRE TITANIUM (91)
    82R TRIM COMBINATION, VINYL , DK MED GRAY (R)
    82T TOP COLOR, LT SAPPHIRE TITANIUM (91)
    82U PRIMARY COLOR, EXTERIOR, LT SAPPHIRE TITANIUM (91)
    82V TRIM COMBINATION, VINYL, DK MED GRAY (V)
    82W TRIM COMBINATION, VINYL, DK MED GRAY (W)
    82Y TRIM COMBINATION, VINYL, DK MED GRAY (Y)
    82Z TRIM COMBINATION, VINYL, DK MED GRAY (Z)
    822 TRIM COMBINATION, LEATHER, MED DK GRAY (2} (91)
    823 TRIM COMBINATION, LEATHER, MED DK GRAY (3) (91)
    826 TRIM COM8INATION, LEATHER, DK MED GRAY (6)
    829 SEAT BELT COLOR, MED DK GRAY (91)
    83A STRIPE COLOR, ACCENT, TWO TONE, GUNMETAL/GARNET RED
    83L SECONDARY COLOR, EXTERIOR, MED SAPPHIRE BLUE FM
    83Q MOLDING COLOR , MED SAPPHIRE BLUE FM (91)
    83T TOP COLOR, MED SAPPHIRE BLUE FM (91)
    83U PRIMARY COLOR, EXTERIOR, MED SAPPHIRE BLUE FM (91)
    84L SECONDARY COLOR, EXTERIOR, HAWAIIAN ORCHID (92)
    84P WHEEL COLOR GRAY (91)
    84Q MOLDING COLOR, HAWAIIAN ORCHID (92)
    84U PRIMARY COLOR, EXTERIOR HAWAIIAN ORCHID (92)
    85A STRIPE COLOR, ACCENT, MED SLATE GRAY (91)
    85L SECONDARY COLOR, EXTERIOR MED SLATE GRAY MET (91)
    85P WHEEL COLOR, MED SLATE GRAY MET (91)
    85Q MOLDING COLOR, MED SLATE GRAY MET (91)
    85T TOP COLOR, MED SLATE GRAY MET (91)
    85U PRIMARY COLOR, EXTERIOR, MED SLATE GRAY MET (91)
    86A STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
    86U PRIMARY COLOR, EXTERIOR, WHEATLAND YELLOW (91)
    87A STRIPE COLOR, ACCENT, GUNMETAL MET (91)
    87L SECONDARY COLOR, EXTERIOR GUNMETAL MET (91)
    87Q MOLDING COLOR, GUNMETAL MET (92)
    87T TOP COLOR, GUNMETAL MET (91)
    87U PRIMARY COLOR, EXTERIOR, GUNMETAL MET (91)
    88A STRIPE COLOR, ACCENT, TWO TONE, GOLD/BLACK (91)
    88L SECONDARY COLOR, EXTERIOR, TANGIER ORANGE (91)
    88T TOP COLOR, DK PLUM MET ( 92 )
    88U PRIMARY COLOR , EXTERIOR, TANGIER ORANGE (91)
    89A STRIPE COLOR, ACCENT, TWO TONE, RED/LT GRAY (91)
    89U PRIMARY COLOR, EXTERIOR, AUTUMN MAPLE MET (91)
    9A4 SALES PACKAGE, REC VEHICLE, MARK III
    9A5 SALES PACKAGE, REC VEHICLE, DELETION
    9A6 SALES PACKAGE, REC VEHICLE, STARCRAFT
    9A7 SALES PACKAGE, RECREATIONAL VEHICLE
    9B8 MODIFICATION, RYDER TRUCK VEHICLE
    9C1 SEO VEHICLE, POLICE CAR
    9C2 GOVERNOR, ELECTRONIC SPEED SENSOR - 85 MPH
    9C6 SEO VEHICLE, TAXI CAB
    9C7 MIRROR O/S, LH & RH, WEST COAST TYPE, LARGE,
    9D2 RACK, SHELVES, ROLL OUT
    9D9 MIRROR I/S, R/V, DELETION
    9F2 MIRROR O/S, DELETION
    9G4 TIRE REAR, DELETE 2 O/S (SPL ORDER)
    9G6 SWITCH, DOME LAMP, RH RR DR JAMB
    9G7 SWITCH, D0ME LAMP, FRT SIDE CARGO, RR DR JAMB
    9H2 FUEL TANK, DELETION
    9H5 LAMP, DELETION, ROOF MARKER
    9H7 CARRIER SPARE TIRE, WITH HOIST, DELETION
    9J4 BUMPER, RR DELETE
    9J6 STEERING COLUMN, TILT TYPE (SEO)
    9J7 MIRROR AUX O/S, 6.5" X 6" DUAL SPOT, CONVEX
    9K3 AIR CLEANER 'OFF ROAD' PACKAGE
    9K6 RADIO PROVISIONS, AM/FM STEREO RADIO, MISC MOUNTING
    9K9 RUSTPROOFING, (OUTSIDE SOURCE) (TROPICAL) (MEETS
    9L1 RUSTPROOFING, (OUTSIDE SOURCE) (MEETS FED STD 297)
    9L5 FUEL SCREEN, ANTI-SYPHON
    9L7 RADIO PROVISIONS, MISC. MOUNTING REQ.
    9L8 RESTRAINT SYSTEM, FRT SEAT, W/DUAL MODE RETRACTOR
    9L9 CYLINDER UNIT, DUAL KEY SYSTEM
    9M2 CYLINDER UNIT, CURTIS BURNS - C0MM0N KEYS
    9M3 COVERING, MAT, RUBBER, STEP WELL
    9M6 SUSPENSION SYSTEM, STEERING UODIFICATION
    9Q1 DECAL, ADSCO-SEARS
    9Q3 CONVENIENCE PKG, SPECIAL
    9Q4 SPRING REAR, LOWERED
    9Q7 END GATE, DELETION, ASSEUBLY
    9R7 INTERIOR PACKAGE SEAT RED
    9S6 WIRING PROVISIONS, TAIL LIGHT, HEAVY GAGE
    9T1 DOOR RR, 74 IN STRAP HINGES - UCB
    9T2 DOOR RR, 66 IN OVERHEAD, SLIDING W/WINDOW - UCB
    9T3 PARTITION, SLIDING, PLYWOOD W/CENTER SLIDING WOR -
    9T4 PARTITION, EXPANDED METAL, W/CTR SLIDING WOR - UCB
    9T5 DOOR, RR,60 IN, CTR SLIDING WOR
    9T7 SALES PACKAGE, PLUMBING, HEATING, AND A/C
    9T8 SALES PACKAGE, ELECTRICAL CONTRACTOR
    9T9 SALES PACKAGE, GENERAL SERVICE CONTRACTOR
    9U2 CYLINDER UNIT, CITY OF BOSTON/STATE OF TEXAS -
    9U7 CYLINDER UNIT, HERTZ-PENSKE
    9U9 CYLINDER UNIT, RYDER-COMMON KEYS
    9V1 COLOR, BLACK
    9V2 COLOR, ORANGE
    9V4 COLOR, WHEATLAND YELLOW
    9V5 COLOR, WOODLAND GREEN
    9V9 COLOR, DOESKIN TAN
    9W2 COLOR, POLAR WHITE
    9W3 COLOR, WHEATLAND YELLOW, LEAD FREE
    9W4 COLOR, TANGIER ORANGE, LEAD FREE
    9W7 HEADLAMPS, ON-WARNING SYSTEM
    9X5 TRIM OVERRIDE, CLOTH
    90A STRIPE COLOR, ACCENT, TWO TONE, GOLD/DK AUBURN (91)
    90C TRIM COMBINATION, CLOTH, MED SMOKE GRAY (C) (91)
    90E TRIM COMBINATION, CLOTH, MED SMOKE GRAY (E) (91)
    90I INTERIOR TRIM, MED SMOKE GRAY (91)
    90L SECONDARY COLOR, EXTERIOR, GRAY MET (91)
    90U PRIMARY COLOR, EXTERIOR, GRAY MET (91)
    90V TRIM COMBINATION, VINYL , MED SMOKE GRAY (91)
    903 TRIM COMBINATION, LEATHER, MED SMOKE GRAY (3) (91)
    909 SEAT BELT COLOR, MED SMOKE GRAY (91)
    91L SECONDARY COLOR, EXTERIOR, DK POLO GREEN MET (91)
    91Q MOLDING COLOR, DK POLO GREEN MET (91)
    91T TOP COLOR, DK POLO GREEN MET (91)
    91U PRIMARY COLOR, EXTERIOR, DK POLO GREEN MET (91)
    92U PRIMARY COLOR, EXTERIOR, DAWN GRAY MET (91)
    93Q MOLDING COLOR, WHITE DIAMOND (91)
    93U PRIMARY COLOR, EXTERIOR, WHITE DIAMOND (91)
    94B TRIM COMBINATION, CLOTH, LT QUARTZ (B)
    94C TRIM COMBINATION, CLOTH, LT QUARTZ (C)
    94L SECONDARY COLOR, EXTERIOR, BLUE RED MET (91)
    94U PRIMARY COLOR, EXTERIOR, BLUE RED MET (91)
    942 TRIM COMBINATION, LEATHER, LT QUARTZ (2)
    943 TRIM COMBINATION, LEATHER, LT QUARTZ (3)
    95L SECONDARY COLOR, EXTERIOR, LT ANTELOPE FM (91)
    95O MOLDING COLOR, LT ANTELOPE FM (91)
    95T TOP COLOR, LT ANTELOPE FM (91)
    95U PRIMARY COLOR EXTERIOR, LT ANTELOPE FM (91)
    96L SECONDARY COLOR, EXTERIOR, DK SMOKE GRAY MET (91 )
    96T TOP COLOR, DK DRIFTWOOD MET (92)
    96U PRIMARY COLOR, EXTERIOR, ULTRA SILVER MET (91)
    97A STRIPE COLOR, ACCENT, TWO TONE, WARM GRAY MET/DK
    97K AUX TOP COLOR, DK GRAY (91)
    97L SECONDARY COLOR, EXTERIOR, DK GRAY MET (91)
    97U PRIMARY COLOR, EXTERIOR, DK GRAY MET (91)
    98K AUX TOP COLOR, BLACK SAPPHIRE (91)
    98L SECONDARY COLOR, EXTERIOR, VERY DK SAPPHIRE MET
    98U PRIMARY COLOR, EXTERIOR, ULTRA BLUE MET (91)
    99A STRIPE COLOR, ACCENT, DK SLATE GRAY (91)
    99B TRIM COMBINATION, CLOTH, BLK CHERRY (B)
    99C TRIM COMBINATION, CLOTH, BLK CHERRY (C)
    99D TRIM COMBINATION, CLOTH, BLK CHERRY (D)
    99E TRIM COMBINATION, CLOTH, BLK CHERRY (E)
    99G TRIM COMBINATION, CLOTH, BLK CHERRY (G)
    99H TRIM COMBINATIDN, CLOTH, BLK CHERRY (H)
    99I INTERIOR TRIM, BLK CHERRY (I)
    99L SECONDARY COLOR, EXTERIOR , DK SLATE MET (91 )
    99Q MOLDING COLOR, DK SLATE GRAY MET (91)
    99T TOP COLOR, DK SLATE GRAY MET (91)
    99U PRIMARY COLOR, EXTERIOR, DK SLATE MET (91)
    992 TRIM COMBINATION, LEATHER, BLK CHERRY (2)
    993 TRIM COMBINATION, LEATHER, BLK CHERRY (3)
