Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: 85 442 Z49 Resurrection
    Junior Member white 85 z49's Avatar
    Jul 2012
    michigan
    20
    Default 85 442 Z49 Resurrection
    The new oil pan before and after powder coating.
    Is that a new pan or did you hot tank yours?
    Is there a zinc coating on it?
    Looks sparkly
    Jul 2012
    michigan
    20
    It is a brand new oil pan and yes I put a zinc coating on it. The original pan is rusted enough that oil leaks through the pan. This was the main reason I took the car off the road in 2001.
    Jul 2012
    michigan
    20
    Here are some pictures of the car. Note the metric gauges the factory block heater and the two jacking instruction decals, one in English and one in French.
    Cool... there is anotyer guy on gBodyForum.com redoing a black 85' Canadian 442 that he just started a frame off restoration on...I wonder if they ever made Canadian versions of the 83/84 hurst?
    Jul 2012
    michigan
    20
    I plan on doing a frame off in the future, I have a 67 Impala convertible torn down right now. Gotta get one done first.
    Jul 2012
    michigan
    20
    This is what happens when you do burnouts on 20 year old tires. Amazingly it still holds air!
    Got any upclose photos of the French jacking instructions decal?
    Jul 2012
    michigan
    20
    It's a little blurry, I took it with my phone. If you need a clearer picture let me know.
    Thanks, I have a huge undertaking of making decals for these cars, do you have a more clear one of the large decal?
    Member 2002duramax's Avatar
    Oct 2011
    Grunthal, Manitoba,Canada
    46
    is there a company that makes those trunk decals? im in dire need
    Drdecal.com has the jack instructions decal in english.
    Oct 2011
    46
    i wish someone could make me the door decal with vin and the trunk build sticker
  14. #14
    Jul 2012
    michigan
    20
    Will these work better for you
  15. #15
    Sweet, thanks!
    Quote Originally Posted by white 85 z49 View Post
    Where can I find metric gauges...?
  17. #17
    Quote Originally Posted by 2002duramax View Post
    Drdecal has the vin decals, you need to type the info out.
    I have the SPID stickers, again you need to type out the info.
    Jul 2012
    michigan
    20
    Finally had some time to get back to the project and spent the weekend pulling the engine. Unfortunately we found that the exhaust lifter on cylinder #3 had a broken plunger clip and had wiped out the cam lobe. I am now planning to remove the cat and the air pump add headers and a real dual exhaust system. Any suggestions for an aftermarket cam that is a little better than stock that I can run on the ECM.
  19. #19
    I would stick with the factory grind, 196/208 @ .050 with .440/.440 lift and 109LSA if you get too much cam with the computer it will not run right.
    210/216 @ .050 will need to be advanced 4 degrees to keep the computer happy in a 307 so I would limit the amount of duration to that.
    Engle 2EP-15/18 207/216 @ .050 with .466/.496 lift should be a good cam.
    Crane also has H-260-2 204/216 @ .050, .454/.484 lift.
    Nov 2011
    Delaware
    Cool. i never seen the metric gauges nor did I know about the 2 trunk stickers. Thanks for the pics.
