Thread: Weatherstripping Part Numbers
    1,265
    Default Weatherstripping Part Numbers
    20363106 RH (and LH) Sealing Strip Inner Window (use for both sides)
    20363107 LH Sealing Strip Inner Window (arbritrary part number)
    Belt moldings (window sweeps)
    20674292 RH B85 Wide Molding
    20674293 LH B85 Wide Molding
    20674276 RH Sealing Strip (rubber part of wide molding)
    20674277 LH Sealing Strip (rubber part of wide molding)
    20674278 RH Sealing Strip Outer Small bead (83-84 H/O and 87 442) w/o B85
    20674279 LH Sealing Strip Outer Small bead (83-84 H/O and 87 442) w/o B85
    20490800 Trunk seal (Trim to fit, glue the ends)
    For G47 WITH T-tops (CC1):
    20211820 RH T-Top main seal
    20211821 LH T-Top main seal
    20217186 RH T-top side panel seal
    20217187 LH T-top side panel seal
    20139617 PAIR (2) of the secondary T-top seals
    20201220 RH Door Weatherstrip W/STR1
    20201221 LH Door Weatherstrip W/STR1
    For G47 WITHOUT T-tops:
    20737658 RH Window/Roof Side Seal
    20737659 LH Window/Roof Side Seal
    Thanks d00d! Looks like the sweeps inner and outer are available except the 20363107 number is unrecognized.
    joe vitek
    1,265
    I believe the inner door panel sweep uses the same one for both sides, 20363106.
