Thread: lowering for cutlass 87
    Dec 2012
    puerto rico
    Default lowering for cutlass 87
    How to loweeing my 87 cutlass s10 suspensión work?
    1,274
    The 82-97 S-10 shares the same upper and lowers control arms and spindles as the 81-88 G-body.
    If you want to run air ride there are Tubular Dropped Lowers, that has `bag cups attached. They are marketed as an S-10 part, but they also bolt onto a G-body.
    Or you can use 2" Drop spindles in the front and shorter shocks and springs in the rear.
    You will need to realign everything once installed.
