Thread: Oldsmobile Torque Specs
    1,217
    Default Oldsmobile Torque Specs
    Oldsmobile Small-Block Engines
    Cylinder Head Bolts (1/2in. bolt) 130 ft. lbs.
    Cylinder Head Studs (1/2in.) 120 ft. lbs.
    Camshaft Sprocket Bolt 65 ft. lbs.
    Exhaust Manifold Bolts 35 ft. lbs.
    Flywheel-to-Crankshaft Bolts 75-85 ft. lbs.
    Harmonic Balancer-to-Crankshaft Bolt 130 ft. lbs.
    Intake Manifold Bolts (Cast iron intake) 35 ft. lbs.
    Intake Manifold Bolts (Aluminum intake w/hardened washers) 35 ft. lbs.
    Main Bearing Cap Bolts Caps #1-4 75 ft. lbs.
    Cap #5 110 ft. lbs.
    Oil Filter Adapter-to-Block Bolts 30 ft. lbs.
    Oil Pan Bolts 15 ft. lbs.
    Oil Pump-to-Rear Main Bolts 35 ft. lbs.
    Rocker Arm Pivot Bolt 25 ft. lbs.
    Rod Bearing Bolts (3/8in. bolt) 42 ft. lbs.
    Oldsmobile Big-Block Engines
    Cylinder Head Bolts (7/16in. bolt) 80-85 ft. lbs.
    Cylinder Head Studs (7/16in. stud) 85 ft. lbs.
    Cap #5 110 ft. lbs.
    Torque sequence-Oldsmobile Big-block & small-block engines
    Great resource! Thanks for posting. BTW, in the CSM for the '87, it gives a high torque spec for the harmonic balancer. "Crankshaft balancer to crankshaft....200 - 310 ft. lb". Why would the manual have such a high spec? Sounds like overkill, or the sound of a bolt breaking off in the crankshaft snout... Your spec sounds much more reasonable.
