Results 1 to 1 of 1
Thread: loose wires
    Mar 2013
    Default loose wires
    ok problem no 1 first of all under dash light on pass. side is not going on lamp is ok but get no power.
    on same side close to the light is dangeling a relaisbox(25510871) with a plug on it with three wires gray, black/white, black/gray beside it is a plug with two wires black,and black/white that will fit on the relaibox .
    i would like to , is the loose plug belonging on the relaibox and why will somebody disconect it? and more inportant where is the box for? i cant enter the tech articles at this moment.otherwise i will look it up in a wire diagram.
    what will it do? so far everything is working.
    please replay
