Thread: supper stock industries 10333 cam
    Aug 2013
    columbus ohio
    Icon14 supper stock industries 10333 cam
    I just picked up a 350 olds engine out of a 69 cutlass. It has a new cam in the box. Can't find any specs on the cam. It is an SSI # 10333. Can anybody tell me the specs or give me a website to look it up. I don't want to put a large camshaft in my stock engine. Thanks!
    It's not a large cam, pretty much stock, good for street use.
    Duration @0.50 is 204-214 Lift .448/.472
    SSI's are cheap cams sold by PAW and basically have a Chevy style grind.
    I wouldn't waste your time with that $70 cam since they are known to wipe lobes....
    Cams aren't too expensive to begin with so finding something that is a bit more robust might be a wise choice.
    What type of converter and rear end are you going to be running?
    What are your goals with the engine? Street, street/strip, etc...
    That is the first thing you need to ask yourself before installing a cam in any motor.
