Thread: hood clearance
    Aug 2013
    Hudson Iowa
    16
    Default hood clearance
    I have a 1986 supreme with a 455 swapped in, was bone stock so to wake it up I put on an edelbrock performer intake and a spread bore vac secondary holley... having trouble figuring out a air filter setup to work and keep my factory hood as it is a sleeper car and I want it to look stock when hood is closed... any ideas or advice would be greatly appreciated!
    Drop base or 2" air cleaner.
    Aug 2013
    Hudson Iowa
    16
    Got it to clear the factory hood, barely but its getting closer to showing unsuspecting mustang owners what an olds can do! Now its on to headers and exhaust
    Are you going with Hookers?
    I have a pair of Kooks if you are wanting to stay inside the frame rails.
    Aug 2013
    Hudson Iowa
    16
    Not sure yet... really need a good set so it can flow good enough... how much?
