Thread: 86 manual trans
    Apr 2011
    Buffalo, NY
    37
    Default 86 manual trans
    What is recommended to swap to a manual trans in an 86, 442?
    86 442 T-tops
    350/200-4R/3.73 posi
    Spohn suspension
    1,278
    Quote Originally Posted by 86-blk442 View Post
    Well first thing is that your crank needs to be drilled for the pilot bearing.
    And it also depends on the type, T-56, Saginaw, Muncie, Tremec and if you are looking to use a hydraulic clutch.
    I would say a T-56 is the way to go, Iceman makes the crossmember.
    If you are going with an olds then you will either need an adapter plate if using a chevy setup or a very rare bellhousing from a 5-speed from a 260.
    I believe you can use the earlier '60's/'70's bellhousing as well.
    There is an aftermarket Olds T-56 bellhousing but it isn't cheap.
    Here is what you typically need for the clutch pedals:
    Some have used the 3-Gen F-body setup but you need to
    Here is what a few guys did:
    http://realoldspower.prophpbb.com/topic2249-10.html
    and Andrew Geeting's setup:
    Quote Originally Posted by FE3X CLONE
    Dave, this info is from my T-56 swap but could still help with a 4 speed swap as well.
    Transmission:
    Manufacturer: Borg Warner/ General Motors
    Model: 1996 T-56
    Part No.: Unknown
    Dealer: N/A
    Cost: $700.00 +/-
    Bellhousing:
    Manufacturer: McLeod
    Model: SFI approved Blowproof Modular line
    Part No.: 8710-15
    Dealer: Summit Racing Equipment http://www.summitracing.com/parts/MCL-8710-15/
    Cost: $441.99
    Note: Due to the shorter input shaft of the LT1 style T-56, this kit is necessary as it also comes with a special pilot bushing that helps support the input shaft in the crank.
    Flywheel:
    Manufacturer: Oldsmobile
    Part No.: Unknown
    Cost: $100.00+/-
    Clutch:
    Manufacturer: Centerforce
    Model: DFX, SFI approved
    Part No.: 01148552
    Dealer: Summit Racing Equipment http://www.summitracing.com/parts/CTF-01148552/
    Cost: $325.95
    Note: This part number is for a Chevelle however it fits an Oldsmobile just fine.
    Flywheel bolts:
    Manufacturer: ARP
    Model: Pro Series
    Part No.: 200-2802
    Dealer: Summit Racing Equipment http://www.summitracing.com/parts/ARP-200-2802/
    Cost: $13.84
    Pressure Plate bolts:
    Manufacturer: ARP
    Model: Pro Series
    Part No.: 230-2202
    Dealer: Summit Racing Equipment http://www.summitracing.com/parts/ARP-230-2202/
    Cost: $25.95
    Hydraulic Throw-out bearing:
    Manufacturer: Weir Hot Rod Products
    Model: Unknown
    Part No.: Unknown
    Cost: $150.00 +/-
    Note: This T/O bearing was bought with a Weir Hot Rod Products bellhousing "kit" however I wanted an SFI approved steel bellhousing and decided to sell the WHRP bellhousing. I kept the T/O bearing but due to the difference in bellhousings needed to make a spacer that fit between the transmission face and T/O bearing.
    Hydraulic Clutch Master Cylinder:
    Manufacturer: General Motors
    Model: N/A
    Part No.: 12570277
    Dealer: GMPartsdirect.com
    Cost: $139.18
    Note: The main body of the clutch and master cylinder are used however the braided line is discarded for an aftermarket line that doesn't have the funky quick disconnect fitting on it. An adapter fitting is available from Earl's Plumbing to join the braided stainless steel line to the GM clutch cylinder.
    Clutch Pedal:
    Manufacturer: John Bzdel
    Model: N/A
    Part No: Unknown
    Dealer: John Bzdel http://www.ls7montess.com
    Cost: $150.00+/-
    Note: This is a clutch pedal with geometry designed to mate properly with the above LS1 clutch master cylinder. It bolts directly onto the stock automatic pedal assembly and requires that the stock brake pedal be trimmed down for clearance. It is also required to fabricate a positive stop as well as a bracket for the neutral safety switch.
    Neutral Safety Switch:
    Model: N/A
    Part No.: Unknown
    Dealer: Autozone, Advance Auto Parts, O'reily's, etc.
    Cost: $7.00 +/-
    Note: This is a NSS from a 3rd generation ('82-'92) GM F-body.
    Transmission Crossmember:
    Manufacturer: 'Iceman'
    Model: T-56 dual hump
    Part No.: Unknown
    Dealer: 'Iceman'
    Cost: $150.00+/-
    Transmission Yoke:
    Manufacturer: Strange Engineering
    Model: N/A
    Part No.: Depends on application
    Cost: $50.00+/-
    Note: The T-56 takes the same transmission yoke as a TH-2004R, TH-350, etc. I didn't include a part number or model as it depends on what size U-joints your running. In my case I have the 1350 series.
    Apr 2011
    Buffalo, NY
    37
    I will have to look at my crank, I know I took pictures but I could swear I saw a couple of steps and a hole about an 2 inches (+/-) deep in the back of my crankshaft. However, when I purchased the engine it had a flexplate on it. As far as I know the block is a 1973 vintage.
    86 442 T-tops
    Spohn suspension
