Thread: Head Swap
    Default Head Swap
    Has anyone swapped a pair of J heads for a pair of C heads on a 455?
    I assume that this will require new push rods but wanted to check to see what else should be looked at...
    If you aren't going to change your rockerarms you will be ok. J and C are the same as far as the castings go.
