Thread: All around LED's - No Turn Signals
    Default All around LED's - No Turn Signals
    I recently replaced my front turn signals to LED's (I replaced all 4 rear tail lights with LED's with no problem) and now my turn signals do not work. I hit the emergency lights and they flash, but when I hit the turn signal, the signal in the dash illuminates to about 40% of what it should be in brightness and I do not get a flickering turn signal or any lights working. Do I need to replace my flasher or is there an easy work around trick for it?
    Quote Originally Posted by Visceron View Post
    It's not the flasher, might be the bulbs are not properly installed or the turn signal switch in the column.
    Most likely its the wrong bulbs or something along those lines... work backwards, try installing the old ones.
    Best to get a chassis service manual off of eBay with a wire diagram.
    Or try these:
    http://www.gbodyolds.com/forum/showt...ing-Schematics
    I've noticed that the turn signals do not work when I have my parking or head lights turned on. I was told to get a resistor or something that balances out the wattage. I was also told that the led's draw less wattage.
    From what I have gathered, I need to put something in line with the turn signals to give them enough power to blink. Since the LED's draw less wattage, I need to get something to correct that.
