Results 1 to 12 of 12
Thread: NOS Parts
    1,274
    Default NOS Parts
    All prices or best offer, parts are all NEW ORIGINAL GM STOCK in original packaging and free of issues unless stated otherwise.
    If you don?t see something here that you are looking for send a PM.
    Serious buyers only please, no picture collectors.
    Interested parties please send a PM.
    Buyer responsible for all shipping and payment fees.
    83 H/O Center Dash Bezel $250 with Doc's signature on a certificate of authenticity...
    83 H/O Header Emblem, some shelf wear $200
    83 H/O Sand Gray Door panel material (enough to cover a pair of upper door panels ) $250
    83 H/O Name Plate Decals $50 each
    RH 81-83 tail light $300
    Lightning Rods Shifter Tag $50
    RH T-top weather strip PN 20211820 $250
    LH T-top weather strip PN 20211821 $250
    81-86 Headlight Bezels $125
    LH 87-88 chrome grille $125
    LH 82 Cutlass Grille (split vertical sections, very rare) $150
    LH 81/86 Cutlass Grille (LH side tab is missing, I presume due to being an early design from '81) $75
    RH 84 H/O / Calais Grille $125
    85-86 Hood Ornament $125
    RH Lower Door Wide Molding $100
    RH Lower RH Front Quarter Wide Molding $50
    RH Lower RH Rear Quarter Wide Molding $75
    LH Lower LH Rear Quarter Wide Molding $75
    87 442 120 MPH Speedometer Head $400
    78-85 Center Dash trim $75
    78-83 Radio Bezel $125
    84-85 Radio Bezel $125
    87 442 RH Sheffield Gray dash bezel $300
    78-88 RH vents $75 pair
    83-84 RH Briar Brown front shoulder belt $75
    Reclining bucket seat chrome side trim $250
    LH T-top Visor Trim, Blue $75
    82-88 Cruise delete w/delay turn lever $55
    82-83 Cruise w/o delay turn lever w/correct hash markings $125
    82-83 w/delay and early hash mark design. Black sleeve can be swapped out for chrome one. $155
    84-88 w/delay, some shelf wear $70
    82-83 Cruise resume valve $75
    82-83 Cruise Transducer and Resume Valve $150
    82-83 Temp Sender $50
    86-88 EFE Switch $20
    78-88 260/307/350 EFE Valve $75
    84-85 VIN9 Hurst/442 EGR Valve $75
    81-88 307 Fan Clutch $75
    Rocker Cover Breather Grommet $10
    Lower Radiator Hose clamp with belt shield $35
    Near mint condition Jack $75
    83-84 Maple Rear floor mats $75
    Column shift nob $20
    Brougham Gold Edition trunk lock bezel and emblems $175
    Power Antenna $225
    Jack:
    [/URL]
    83 H/O Stripes, missing RH upper fender, RH upper door and RH lower quarter:
    [/URL]
    83 H/O Dash Bezel:
    [/URL]
    83-84 Sand Gray Door Panel Material:
    [/URL]
    Lightning Rods Shifter Tag:
    [/URL]
    81/86 LH Grille:
    83-84 RH Briar Brown Shoulder Belt:[/URL]
    81-88 Lower Wide Moldings, see above for description:
    [/URL]
    87-88 LH Chrome Grille:
    [/URL]
    1982 LH Chrome Grille:
    [/URL]
    1981/86 LH Chrome Grille:
    [/URL]
    [/URL]
    NOS T-top Weatherstrip
    [/URL]
    NOS RH 87 442 Dash Trim
    [/URL]
    NOS LH Blue T-top Visor Trim
    NOS 84 VIN9 Hurst Olds / 85 442 EGR Valve
    NOS 1987 442 120 MPH Speedo Head
    1,274
    1,274
    82-88 cruise delete turn signal lever with delay wipers
    82-83 Cruise lever without delay
    82-83 Temp Sensor
    82-83 Maple Rear Floor Mats
    1,274
    Gold Edition emblems $225
    NOS column shifter handle $20
  5. #5
    Aug 2016
    alberta, canada
    1
    hello, right now i am looking for the left rear lower molding that goes behind the rear wheel, i will need more stuff later, thank you,
    jed
  6. #6
    1,274
    Quote Originally Posted by freezone60 View Post
    jed
    Need a zip for shipping
  7. #7
    Jun 2017
    Anderson indiana
    3
    In search of driver side fender "inner and outer" and a front bumper cover for a1987 supreme brougham with fender mounted turn, high and low beam light indicators mounted on fenders. Also looking for the fiber optic lines for the same side.
  8. #8
    1,274
    Quote Originally Posted by Herbert View Post
    I have a fender from an '84 Hurst Olds $125, that's about it.
    Apr 2018
    las vegas nv
    2
    hello im new to sight i need claret maroon floor mats front 1988 oldsmobile cutlass supreme classic brougham thank you
  10. #10
    1,274
    I have a pair of factory GM G-body mats for $75, PM if interested.
    Apr 2018
    las vegas nv
    2
    how would i go about seeing them what kind of condition also i believe the passenger mat has a gm emblem if satisfied how would i buy them
  12. #12
    1,274
    PM if interested
