Thread: Fuel Line Size
    Orlando, Fl.
    Default Fuel Line Size
    I have a 1986 442 vin 9 code.
    Someone has replaced the orignal steel fuel line with a rubber one and its making concact with the water pump.
    I want to put a steel fuel line back on to the carb.
    What size is the correct line a 3/8" w/16mm fitting or 5/16"w/14mm fitting ?
    1,277
    Correct line is 5/16" with 9/16" fittings
    No metric parts under the hood.
    GM# 22506485
    Still available from GM.
    Orlando, Fl.
    Thank you for the awesome info.
    Any idea as to a ballpark guess what one will cost approx. from GM ?
    1,277
    There are many sources, just Google.
