need rear glas molding clip dimension
  • need rear glas molding clip dimension
    Gentlemen,
    I will be installing the rear glass chrome trim pieces (eliminated vinyl top) and need to know the clip locations and how many are used.
    I could just backtrack by placing the trim over the glass and estimate but if someone could give me a number, it would be greatly appreciated.
    Happy Thanksgiving!
    Much to thank God for.
    78 Cutlass Supreme
    Drive it everyday!
    sigpic
    I'm not sure about 78-80 but 81-88 has 3 on the sides and 6 on the top with the two centers spaced closer together spaced about 4 inches in the center between the two and the others being spaced about 6 inches apart.
    The lower valance panel has 4 clips on it.
      Thanks, very much appreciated.
      Any Idea how deep into the pinch weld the clips go? I think I will get this dimension from the front windshield clips-assuming that the molding style is identical to the rear.
      78 Cutlass Supreme
      Drive it everyday!
      sigpic
        Not sure on that, the clips are mounted to studs but you can always just sheetmetal screw them in.
