Olds 350 swap
  • Olds 350 swap
    Ok, so I know that an Olds 350 will bolt into my 87 cutlass but, will I have to scrap the 'puter? Kinda going for the "stock look" with a kick. Plus, I don't want to butch the hell out of it if anyone down the road would want to return it to stock. Also, will the stock 200r4 be able to handle it?
    Thanks.
    The 350 will run off the computer with a stock to a very mild cam, in fact it will run better IMO because the fuel will be properly mixed and the advance will be dialed in. You dont need the AIR system.
    Your trans will hold up as long as you don't beat on it daily. I had a 455 in front of a TH2004R with no issues.
