There are two different versions of the H.O. 307 VIN 9 engine. From 1983 through 1985 the VIN 9 engine was a hydraulic flat tappet cam engine with larger port 5A heads use on both '83 and '84 Hurst Olds and '85 442. In 1986 and 1987 Oldsmobile perfected the design of the 307 with a roller cam and lifters and incorporating a swirl port design 7A head with smaller ports. This design produced more torque at lower RPM but reduced the horse power rating by 10.
It is said that the peak of GM's carburated technology was Oldsmobile's 86-90 roller cammed 307. It is said that VIN 9 307's could also be found in some Cadillacs which can be a good start for a VIN 9 swap into your stock VIN Y Cutlass. Now many will say why not go with bigger cubes, all small blocks are a direct bolt in as well as big blocks to a certain extent. Well if you are looking for a V8 with great gas milage, smooth throttle response that is comparable to fuel injection and a good relyable daily driver then the 307 is for you.
Factory Performance Specs:
VIN 9 '83-'85
180 [email protected] rpm
245 [email protected] rpm
VIN 9 '86-'90
170 hp @ 4000 rpm
250 ft-lbs @ 2600 rpm
Here is a list of parts Oldsmobile used to change a VIN Y drive line into a VIN 9
Engine
Here is a list of parts that seperated the VIN 9 from the VIN Y:
Harmonic Balancer
Larger like all SBO and BBO balancers: GM# 417142
Intake
The manifolds are the same however the carb and aircleaner are as follows:
4MV Rochester Qjet: GM# 17083553 (1983) 17084553 (1984 & 85) and 17086009 (1986 & 87)
Dual Snorkal Air Cleaner: GM# 25042690
Cam
0.440/0.440 lift 196/208 @0.050 lift 109LSA for 83-85
256/270 109LSA
0.435/0.438 194/210 0.050 lift 109LSA for 86-90
VIN 9's have a longer duration than the VIN Y
VIN 9 lifters are interchangeable with VIN Y
'83-'85 0.842" hyrdaulic flat tappet GM# 22519934
'86-'90 0.921" hydraulic roller: GM# 922531804 (pictured below)
Higer Rate Valve Springs:
'83-'90 VIN 9: GM# 22510372
Spring Pressure @ 1.270": VIN9 203-217 lbs, VINY 180-194 lbs.
Spring Pressure @ 1.670": VIN9 85-95 lbs, VINY 76-84 lbs.
Spring free length: VIN9 2.090", VINY 1.960"
Pushrod Length: 8.265" hyd. / 7.718" roller
Exhaust
The '83-'85 5A head VIN Y and '83-'90 VIN 9's used the same cast iron exhaust manifolds however the '86-'87 7A head VIN Y used tubular stainless steel.
All '83-'90 VIN 9 LH: GM# 22503678
All '83-'90 VIN 9 LH: GM# 22521449
If you want to give that factory look go with a Walker Exhaust system with a Y pipe split into duals.
If you can find NOS factory here are the part numbers:
Y-pipe: GM# 22516113
RH Muffler/Tailpipe: GM# 22526204
LH Muffler/Tailpipe: GM# 22526205Tailpipe hangers: GM# RH 22520308 and LH 22520309
Transmission:
VIN 9 cars use a 4 speed overdrive TH-2004r with different shift points due to different governors and also have a higher 2400RPM stall D5 converter (GM# 8653400 with CBBF on the paper tag, 2050RPM stall with 14 blade stator) than the stock VIN Y TH-2004r transmission.
D5 Torque converter PN's
'83-'85 OZ & BQ: 8634993
'86-87 KZF: 8642965 (BRF 8656903)
There were two different Transmissions offerered for VIN 9 vehicles
1983-85 has code OZ on the trans tag while '86-'87 reads KZF. These transmissions have a wide open throttle shift point (WOT) of 4800rpm than the VIN Y TH2004R which has a WOT shift point of 3000rpm.
The gear ratios: 1st: 2.74, 2nd: 1.57, 3rd: 1.00 and 4th (OD): 0.67
Here is some more info in 4-speeds:
The WOT shift points of CZF (Monte SS) and BQ and BRF(GN) 2004R's are at 5200rpm (due to a larger governor GM# 8655976)
The 86 and 87 BRF GN transmissions also have a larger servo for heaver shifting.
Valve Body:
1983 OZ: GM# 8639918
1984 OZ: GM# 8639131
1985 OZ: GM# 8639493
1986 & 87 KZF: GM# 8657286
ECM
1985: VIN 9 ECM GM# 16040813
Will dig up more info on this later.
Rear End
Though not necessary but always good is the a 3.73 gearing to get the same performace as a VIN 9 car.
It is not important which 10 bolt rear end you use, a 7.5" ('83 VIN 9) or the harder to find and more expensive 8.5" ('84-'87 VIN 9) will suffice since you are not pushing more than 400hp.
Also, 3.42, 3.23 and 3.08 gears are a good selection as well depending on your application.
VIN 9 '83-'85
VIN 9 '86-'90
170 hp @ 4000 rpm
Engine
Harmonic Balancer
Intake
Cam
256/270 109LSA
Exhaust
Transmission:
Valve Body:
ECM
Rear End
