1983 - OZ, blue tag
1984 - OZ, yellow tag
1985 - OZ, pink tag
1986 - KZF, blue tag
1987 - KZF, yellow tag
VIN 9 cars use a 4 speed overdrive TH-2004r with different shift points due to different governors and also have a higher 2400RPM stall D5 converter (GM# 8653400 with CBBF on the paper tag, 2050RPM stall with 14 blade stator) than the stock VIN Y TH-2004r transmission.
D5 Torque converter PN's
'83-'85 OZ & BQ: 8634993
'86-87 KZF: 8642965 (BRF 8656903)
There were two different Transmissions offerered for VIN 9 vehicles
1983-85 has code OZ on the trans tag while '86-'87 reads KZF. These transmissions have a wide open throttle shift point (WOT) of 4800rpm than the VIN Y TH2004R which has a WOT shift point of 3000rpm.
The gear ratios: 1st: 2.74, 2nd: 1.57, 3rd: 1.00 and 4th (OD): 0.67
Governor:
BRF, BQ and CZF GN/Monte SS TH2004Rs have WOT 1st gear 5200 rpm upshift governor, part#8655976, WOT 1st gear upshift on OZ and KZF Hurst/442 is 4800 rpm part# 8634982 vs. 3000 rpm stock.
Shift points:
BRF, BQ and CZF:
1-2: 5200 rpm
2-3: 4900 rpm
3-4: 4400 rpm
OZ and KZF:
1-2: 4800 rpm
2-3: 4500 rpm
3-4: 4000 rpm
Valve Body:
1983 OZ: GM# 8639918
1984 OZ: GM# 8639131
1985 OZ: GM# 8639493
1986 & 87 KZF: GM# 8657286
1985 - OZ, pink tag
Governor:
Shift points:
BRF, BQ and CZF:
1-2: 5200 rpm
2-3: 4900 rpm
3-4: 4400 rpm
OZ and KZF:
1-2: 4800 rpm
2-3: 4500 rpm
3-4: 4000 rpm
Valve Body:
