I need to find out what the name of the part that connects to the transmission where the speedometer cable connects (Maybe vehicle speed sensor) and get a part number on it so I can order it and get my speedometer working.
Transmission part number identification
If your speedometer isn't working the gear is stripped from the "bullet" shaped speedo gear housing.
It is discontinued and hard to find, aftermarkets are available here:
http://www.transmissioncenter.net/200-4r.htmLightning Rods repair service:CLICK HERE
It comes to be that I have a Th350 transmission powered by a V6! That has got to be the best news I have ever heard with this damn car! Now, I gotta find this particular part. It has 38T stamped on it which I assume is 38 teeth.(which I believe is a VSS) for my transmission so my speedometer will work.20140502_151808.jpg
Found my answer at this site: http://www.laspeedometergear.com/
Specifically athttp://www.laspeedometergear.com/38_...meter_Gear.htm
