This spring chart is divided into three columns as follows:
The information in the 1st column can be found on the vehicle option label and will be preceded on the option label by a numeric code which indicates the location on the vehicle
The information in the 2nd column has the service part number. The information in the 3rd column can be found on the spring tag. |
Front Springs | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Rear Springs | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Spring Codes
This is a sticky topic.
Spring Codes
"Keep them Rockets lit!"Tags: None
- Stuck
The front spring rate is 420lbs for the heavy duty F41 spring used in 442/H/O (moog part # 5606).
The normal duty spring has a spring rate of 346lbs (moog part # 5606).
Front springs were trimmed at the factory to achieve right height based on options (aluminum components, non-AC/AC, V6/V8 etc.)
For the back springs the heavy duty F41 is 142lbs (moog part # 5391) and the stock normal duty has a spring rate of around 120lbs (moog part # 5379).Lightning Rods repair service:CLICK HERE
