Header ?
  • Header ?
    What is eveyone running for headers with a 350 olds? Looking for a set of 1 7/8 that fit good and clears the ac/heater box under the hood.
    Your headers will be well below the ac/heater box. Hit up Jegs on line and check them out. I beleave if you want 1 7/8 they may be $$$. If you plan on keeping the car forever Go with GOOOOD headers to start with. HINT: ( Check the mounting flange to the head. If you don't have a good solid flange you won't have a set of headers that won't leak.) I've been running my Hooker Pro/comps for over 7 years and have had a leak.
      I ran some cheep ones from Jegs once (worst mistake with regards to leaks and quality), the passengers side had plenty of clearance but I needed to remove the oil filter neck to get it in.
      I had to lift the engine a little on the drivers side, I just loosened the engine mount bolt and used a pry bar to tilt the engine a little.
        back in the day I ran a cheap set of Blackjack headers in a 79 cutlass with a 75 350 olds. Use good gaskets and prep your header flange to make sure of no interference issues and good head contact, they worked fine for me.. no issues
          Back in the Day Blackjack was a good header. Damn good quality at a fair pirce.
            I heard Lemons headers were really nice, too bad they don't make anything for G-body's w/Olds motors. They only have them for SBC and BBC:
            http://www.lemonsheaders.com/products/bbr-550.htm
