I have an Olds 350 DX Diesel motor, complete in running condition and have considered using it but I have thought it through and may install a 425 crank and go for the 411CI small block gasoline conversion (I know it costs $$$). I have heard that you can bore these blocks out but how much is another question, has anyone persued a DX build?
Olds 350DX Diesel Engine
You should just convert it over to Bio-Diesel with the way Gas is going:
http://frybrid.com/
http://www.greasecar.com/
http://www.goldenfuelsystems.com/
http://www.vegpoweredsystems.com/
http://www.prairiefirebiofuels.org/Vince
86 Salon - 455 powered
Check this out for a 440 Olds Stroker, I guess they couldn't shave 2 more C.I.'s
http://mondellotwister.com/ArtStroker440.htm
I'm converting an 84 350DX to run on Biodiesel and putting into an 86 442, I'll post the buildup here as it progresses.Lightning Rods repair service:CLICK HERE
Well I abandon my buildup due to having too many projects and not enough time but here is some good technical information with regards to Diesel Olds motors:
http://members.tripod.com/~A350Diesel/350tech.htmlLightning Rods repair service:CLICK HERE
