Need some help replacing the power antenna on my 84 H/O like parts numbers, vendor, and procedure. Antenna powered down except for the last 6". Had to unhook battery as antenna motor continued to run even when key was in off position. Any help would be appreciated-
Replacing Power Antenna on 84 H/O
Originally posted by Jbender View PostNeed some help replacing the power antenna on my 84 H/O like parts numbers, vendor, and procedure. Antenna powered down except for the last 6". Had to unhook battery as antenna motor continued to run even when key was in off position. Any help would be appreciated-
I can permanantly fix the antenna for you if you like if you remove it and ship it to me, more info:
http://www.gbodyolds.com/forum/showt...=4177#post4177Lightning Rods repair service:CLICK HERE
