Replacing window sweeps inner and outter having problems getting the passanger sidd window adjusted so its nice and tight to the rubber any tips or tricks would be great driver side went easy but the passanger side not so much keep getting a gap at the top rear of the window get it lined up tighten it down then when I roll the window down and back up it has the gap again
Window adjustment
There are a few places for adjustment.
I would start with the two bolts on the top of the frame at the jamb where there is a rod which slips into a notched nylon block on the glass. This could be causing the block to catch or rub on the rod making the back of the window not go up all the way. Also, this block can sometimes brakes resulting in the rod not doing the job to pull the window in snug leaving a gap.
There are also felt rub blocks that are adjustable at the top of the door too.Lightning Rods repair service:CLICK HERE
Sweet I will check it out tomorrow I messed with it a couple hours and got nowhere started to get frustrated so I had to stop before I broke something the two bolts near the jamb are you talking about it at the very top of the door toward the rear right? Thats about the only thing I didnt mess with
