1982 Cutlass Supreme lighting problems
  • 1982 Cutlass Supreme lighting problems
    been having issues with headlights not working at all...
    Ive got a new column mount dimmer switch and a new connector in case that turns out to be the trouble when I go to replace it
    I'm also a bit skeptical on the dash mounted headlight switch so I want to get a new one of those and the rotary instrument panel dimmer that mounts right beside the head light/parking light switch
    Cant seem to find the part numbers for this.
    Does anyone have the part numbers for the dash headlight switch and rotary dimmer switch for the instrument cluster lamps?
    I just wanna rip this apart once and change all the pieces instead of going back in a month later
    Im also having a noisy speedo cable issue and not having a lot of luck finding out the numbers for that either (with cruise)
    Headlight switch is 1972717
    IP dimmer is 1972718
    I have an NOS upper speedometer cable with cruise if you are still looking for one.
    Messages me if so.
