If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
2.14 gears came in 3 speed cars, I had one in an 84 Calais.
If you put one in a car with a 4 speed you will actuall get worse fuel economy due to the amount of power needed to turn the driveline in overdrive.
Lol, I pity the poor bastard that would have no choice but to do that...omg
The 200-4R is a good one!..... Unless you ae making massive power, I would also consider a 3.08 or 3.42 rear end...those should do the trick for you as well....
