I recently replaced my front turn signals to LED's (I replaced all 4 rear tail lights with LED's with no problem) and now my turn signals do not work. I hit the emergency lights and they flash, but when I hit the turn signal, the signal in the dash illuminates to about 40% of what it should be in brightness and I do not get a flickering turn signal or any lights working. Do I need to replace my flasher or is there an easy work around trick for it?
All around LED's - No Turn Signals
Originally posted by Visceron View PostI recently replaced my front turn signals to LED's (I replaced all 4 rear tail lights with LED's with no problem) and now my turn signals do not work. I hit the emergency lights and they flash, but when I hit the turn signal, the signal in the dash illuminates to about 40% of what it should be in brightness and I do not get a flickering turn signal or any lights working. Do I need to replace my flasher or is there an easy work around trick for it?
Most likely its the wrong bulbs or something along those lines... work backwards, try installing the old ones.
Best to get a chassis service manual off of eBay with a wire diagram.
Or try these:
http://www.gbodyolds.com/forum/showt...ing-SchematicsLightning Rods repair service:CLICK HERE
