What's up guys. Just picked up a set of 14x7 SSII's and tried putting them on my '88 Cutlass Supreme. The rears SEEM to fit fine so far, but the fronts were rubbing really bad. I took them back off and realized the inside lip of the rim was scraping against the control arm. A problem I did not see coming unfortunately. Could I get away with just putting some 3/8" spacers on the front? Would this cause any driveability issues? Any better suggestions? Thanks guys.
14x7 SSII's rubbing in the front..?
The back spacing on SSII's are 4.25", 14x7 whereas SSIII's are 14x6 with a 3.5" BS.
That's a 3/4" difference.
I wouldn't suggest using spacers on the fronts due to the added forces from turning causing stress on a now shorter lug.
Those puppies will just shear off...
SSIII's are plentiful, I have a few sets sitting around that I don' need.
If you need just a pair for the front I have two I'll sell for $75 shipped.Lightning Rods repair service:CLICK HERE
Over the weekend I went to a local shop & the mechanic installed 1/4" spacers in the front and that seemed to do the trick; it now clears the tie rod & caliper. He said as long as we could still get 6 full turns on a lug it would be acceptable, which we did. Agreed, I'm not a big fan of spacers either but I wanted to try to make it work. I don't do any kind of racing; the fastest I ever get her up to is about 85 on the highway. Could you send me a few pics of your SSIII's?'88 Cutlass Supreme 307
I have these for $20 each and a full set of 14x6 in blue off a 61k mile car for $150Attached FilesLightning Rods repair service:CLICK HERE
