455 rear main seal swap
  • 455 rear main seal swap
    i thought i saw on here about being able to use a ford 2 piece rear main seal in stead of the rope seal but i cant find the post now ! can anyone help with maybe a p/n for this 2 piece seal im about to put the engine together soon !! thanks ,tony
    Funny you bring this up, I'm about to reseal my 403 and my brother is rebuilding his 455 for his 75 442. I belive it was a BBF rear main seal that was thicker and filled the gap better than the standard rope seal, most likely a 460 or a 427. I check the factory main size on each to confirm. Also, make sure you clock the seal about 5 to 10 degrees to stagger the seal about a 1/4" so there is continuity beyond the cap to block seal channel. basically one end of the seal going into the cap and the other into the block.
    I had a fun time last may blowing a rear main seal or pan seal on a 455 and showering traffic behind me with oil and smoke. I was doing about 55 and it looked like a mosqito fogger going down the road with the oil burning up on the exhaust system. Good thing I caught it right away or it would have been disasterous
    Another thing to check with the main seals when doing a factory rebuild is if the stock harmonic balancer is worn where it makes contact with the front seal on the timing cover. Sometimes you have to have a brass ring machined on otherwise it will leak like a seive...
      thanks for the info ,i'll try to get the specs and if i can get the correct one i'll post p/ns here for others
        460 ford seal is what your looking for
          got it ,put it in ,got engine together ,i'll post pics shortly
            Does anyone know what seal works best for 260-403?
            I am looking to redo my 403 soon...
              You doin any work to the crank? I have heard a neoprene one works good but you have to polish were the seal goes on the crank. I have heard of people using a AMC 258 inline 6 or a 292 Ford
