Great site to decode RPO information:
Decoding RPO Codes
This is a sticky topic.
This link has:- Olds G-Body Registry
- Olds G-Body Parts Database
- RPO Code Lookup
- VIN Decoder (1981-1988) [Oldsmobile & Chevrolet]
AA4 WINDOW, SPECIAL GLAZING, DOMESTIC
AA7 WINDOW, POWER OPERATED, QUICK OPENING
AA8 WINDOW, R/CMPT LIFT
AA9 WINDOW, REAR, BLACKOUT BANDED EDGE
AB1 WINDOW, RR QUARTER, ORNAMENTAL
AB2 WINDOW SIDE BODY, STA LEFT SIDE
AB3 SEATING ARRANGEMENT, SIX PASS
AB4 SEATING ARRANGEMENT, FIVE PASS WITH BUCKET SEATS
AB5 LOCK CONTROL, SIDE DR, ELECT, KEY ACTIVATED
AB6 WINDOW, RR INSERT
AB7 WINDOW, T/GATE,HINGED
AC1 ADJUSTER, PASS ST, POWER, 6 WAY, BKT
AC2 WINDOW, SLIDING RIGHT FRT DR
AC3 ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
AD2 WINDOW, RR DR ------ DELETE
AD3 WINDOW, HINGED, ROOF
AD5 WINDOW, SIDE RR SLIDING
AD8 DOOR CHECK, RR
AD9 ADJUSTER, SEAT, POWER 2 WAY DRIVER
AE1 SEAT, FRT BKT, PASS, HIGH BACK, AIR SUSP
AE2 SEAT, DRIVER
AE7 SEAT, FRT SPLIT DRIVER PASS EASY ENTRY
AF0 ADJUSTER, SEAT EASY ENTRY, DRIVER
AF1 ADJUSTER, SEAT MANUAL----DELETE
AF2 WINDOW, STA SIDE, LH, UTILITY BODY
AF3 WINDOW, STA SIDE, RH UTILITY BODY
AF4 ADJUSTER, SEAT, MANUAL, 6 WAY DRIVER, PASS
AF5 ADJUSTER, SEAT, EASY ENTRY, PASS
AF6 SEAT, FRT BENCH, 2 PASS
AF7 SEAT, FRT BENCH SPLIT BACK, CTR ARM REST, 2 PASS
AF9 SEAT, FRT BKT, PASS DRIVER, RECL, OUTSIDE VENDOR
AG1 ADJUSTER, FRT ST, POWER, 6 WAY DRIVER, SPLIT BENCH
AG2 ADJUSTER, PASS ST POWER, 6 WAY, SPLIT BENCH
AG3 ADJUSTER, FRT ST, POWER, 6 WAY, 2 POSITION MEMORY
AG4 ADJUSTER, SEAT, MANUAL, 2 WAY, VERT, DRIVER
AG7 ADJUSTER, SEAT, POWER, 6 WAY, 2 POSITION MEMORY
AG9 ADJUSTER, SEAT, POWER, 6 WAY
AH6 WINDOW, BACK DR, UTILITY BODY
AH8 WINDOW, SIDE ACCESS DR, LH, UTILITY BODY
AH9 WINDOW, SIDE ACCESS DR, RH, UTILITY BODY
AJ1 WINDOW TINTED,DEEP, ALL EXCEPT W/S AND DRS
AJ2 SEAT RR, FLDG, SIDEWAYS JUMPSEAT
AJ3 RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AJ4 RESTRAINT SYSTEM, HEAD MOUNTED GUIDE LOOP
AJ6 TRAVEL BED, RR SEAT
AJ9 TRAVEL BED, RR SEAT RR
AK1 RESTRAINT SYSTEM, FRT, CTR, RR SEAT, FRT SHLDR,
AK5 RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AK8 RESTRAINT SYSTEM, FRT SEAT, SHLDR, 3 POINT
AK9 RESTRAINT SYSTEM, RR SEAT, SHLDR, RETR, 3 POINT
AL4 SEAT RR, BKT
AL7 SEAT, FRT SPLIT, PASS/DRIVER, 8 WAY ADJ, 2 WAY
AM3 SEAT, FRT BENCH, 2 PASS, CTR ARM REST
AM4 SEAT, FRT BENCH, N/BACK, 2 PASS
AM5 SEAT, FRT SPLIT, 3 PASS, 6 WAY ADJ, 2 WAY LUMBAR
AM6 SEAT, FRT SPLIT, 3 PASS, CTR ARM REST
AM7 SEAT, RR, FLDG
AMB SEAT, FRT SPLIT, 2 PASS INTEGRAL CONSOLE
AM9 SEAT, RR, SPLIT, BACK, FLDG
ANL SALES PACKAGE, AIR DEFL . AND FOG LP
AN1 SEAT, RR, BENCH
AN3 SEAT, FRT BKT, DRIV, PASS, ELEC BODY SUPT CONT
AN4 RESTRAINT, PROVISION CHILD
AN5 SEAT RR, BUCKET, W/INTEGRAL CHILD SEAT
AN6 ADJUSTER SEAT BACK DRIVER
AP1 RESTRAINT, CARGO PROVISIONS
AP7 PARTITION SLIDING, PLYWOOD
AP9 NET, CONVENIENCE
AQ3 SEAT RR, CTR
AQ7 SEAT, FRT SPLIT, 3 PASS, 6 WAY ADJ, RECL
AQ9 SEAT, FRT BKT PASS DRIVER RECL
AR3 RESTRAINT SYSTEM, HEAD, RR SEAT, CLOTH COVERED,
AR4 RESTRAINT SYSTEM, FRT SEAT, AUTO, PASSIVE
AR5 RESTRAINT SYSTEM, HEAD, RR SEAT, LEATHER COVERED,
AR6 RESTRAINT SYSTEM, SEAT BELT, SHLDR HARN, MAN
AR7 SEAT, FRT BKT, STANDARD
AR9 SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AS1 SEAT, FRT BKT, HIGH BACK, DRIVER
AS2 SEAT, PASSENGER, FRT BKT, HIGH BACK
AS3 SEAT, RR, SUBURBAN
AS5 SEAT, FRT BKT, DELUXE
AS7 SEAT, FRT SPLIT
AS8 RESTRAINT SYSTEM, FRT SEAT, MANUAL, ACTIVE
AT2 SEAT RR, DELETE
AT5 SEAT RR, CTR, FLDG
AT6 ADJUSTER PASS ST BK, MANUAL, RECL
AU0 LOCK CONTROL, REM0TE ENTRY
AU1 LOCK CONTROL, SIDE DR, FUEL FILLER DR, ELEC
AU2 LOCK CONTROL, CARGO DR
AU3 LOCK CONTROL, SIDE DR, ELEC
AU4 LOCK CONTROL, SIDE DR, ELEC, AUT0MATIC
AU6 LOCK CONTROL, END GATE WINDOW, REM CONT ELEC
AV3 HOOK, CARGO TIE DOWN
AV5 SEAT, FRT BKT, HIGH BACK
AV7 SEAT FRT SPLIT, SD/SO
AW2 ADJUSTER, SEAT, MANUAL, 6 WAY, DRIVER
AW3 ADJUSTER SEAT MANUAL, 6 WAY, PASS
AW4 DOOR, SLIDING SIDE EXTENSION
AW9 LOCK CONTROL, QUARTER STOW L L/CPMT
AX3 LOCK CONTROL, KEYLESS ENTRY SYSTEM
AX4 RESTRAINT, CONVERSION SEAT, MAN, EUROPEAN
AX5 PARTITION, EXPANDED METAL, LEFT SIDE
AX6 PARTITION, EXPANDED METAL, WITH RH SLIDING DR
AX7 PARTITION, EXPANDED METAL, WITH CTR SLIDING DR
AX8 SEAT, FRT BKT, PEDESTAL, DRIVER, BELTS
AX9 ATCH RR CARGO DR
AY4 RESTRAINT CONVERSION, HEAD FRT SEAT, LEATHER
AY9 ADJUSTER,SEAT, POWER 6 WAY SPLIT SEAT
A01 WINDOW, TINTED, ALL SHADED, W/S
A02 WINDOW, TINTED, SHADED UPPER
A04 WINDOW, TINTED, RR SIDE, RR
A07 WINDOW, BODY
A08 WINDOW, BODY, RIGHT SIDE
A11 WINDOW, TINTED, ALL
A12 WINDOW, RR, STA BACK DR
A13 WINDOW, SIDE DR, STA, RR
A17 WINDOW, SIDE BODY, LEFT SIDE, SWING OUT
A18 WINDOW, RR, DR, SWING OUT
A19 WINDOW, SIDE DR, RR, SWING OUT
A2Q PACKAGE,'GSI'
A20 WINDOW, RR QUARTER VENT SWING OUT
A21 WINDSHIELD, ADDITIONAL LAMINATE
A23 WINDSHIELD, HEAT REFLECTIVE
A26 WINDOW, EUROPEAN GLAZING, ALL
A28 WINDOW, RR, FULL WIDTH, SLIDING
A31 WINDOW, POWER OPERATED, SIDE
A32 WINDOW, POWER OPERATED, FRT DR
A33 WINDOW, POWER OPERATED, T/GATE OR BACK DR
A37 RESTRAINT SYSTEM, FRT SEAT, DELUXE TYPE
A40 WINDOW POWER OPERATED, RR VENT
A42 ADJUSTER SEAT, POWER, 6 WAY, BENCH
A43 MEMORY SEAT ADJUSTER, MIRROR, POWER, DRIVER
A44 ADJUSTER PASS ST, MANUAL, 4 WAY
A50 SEAT, FRT BKT
A51 SEAT, FRT BKT PASS, DRIVER
A52 SEAT, FRT BENCH
A57 SEAT PASSENGER AUXILIARY, ONE, FLDG
A59 LOCK CONTROL, RR COMPT LID, REM CONT, MANUAL
A65 SEAT, FRT BENCH, SPLIT BACK, CTR ARM REST
A70 WINDOW, RR QUARTER, REM0TE CONTROLLED
A75 SEAT CUSHION, BACK FRT, HD
A78 ADJUSTER FRT, ST BK, MANUAL, PASS & DRIVER, RECLINING
A79 ADJUSTER FRT, ST BK, MANUAL, DRIVER, RECLINING
A80 ADJUSTER FRT, ST BK, POWER DRIVER, RECLINING
A81 ADJUSTER PASS, ST BK, POWER, RECLINING
A82 RESTRAINT, HEAD
A83 ADJUSTER, SEAT BACK, RECLINING
A90 LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE AAAAA
A91 PULL DOWN, RR COMPT LID
A93 LOCK CONTPOL, QUARTER STOWAGE COMPT
A94 LOCK CONTROL, DR
A95 SEAT, FRT BUCKET, HIGH BACK, PASS & DRIVER RECL
A96 LOCK CONTROL, LUGG COMPT
A99 LOCK CONTROL, I/P COMPT
BA0 ORNAMENTATION, EXTR, DOOR, NAMEPLATE
BA1 ORNAMENTATION, EXTR HOOD
BA5 ORNAMENTATION, EXTR CUSTOM
BA6 COMPARTMENT, RR, PACKAGE SHELF, STOWAGE
BA8 COMPARTMENT, FRT SEAT STOWAGE, PASS
BA9 COMPARTMENT, FRT SEAT STOWAGE, DRIVER
BB2 TRIM, LUGG COMPT LINING ---- DELETE
BB3 ORNAMENTATION, INTR, DR POCKET, INNER LINING,
BB4 ORNAMENTATION, INTR, DR POCKET, INNER LINING, LEFT
BB5 ORNAMENTATION, INTR, HEADLINER
BC1 ORNAMENTATION, INTR, I/P
BC2 ORNAMENTATION, INTR, I/P, WOOD GRAIN
BC3 ORNAMENTATION, INTR, I/P, DELUXE
BC4 ORNAMENTATION, INTR, COAT HOOK RETRACTABLE
BC5 ORNAMENTATION, INTR, LOAD COMPT CARPET PANELS
BC8 ORNAMENTATION, INTR, DR MAP POCKETS
BC9 ORNAMENTATION, EXTR HOOD ---- DELETE
BD1 ORNAMENTATION, EXTR MLDG, ROCKER PNL ---- DELETE
BD2 ORNAMENTATION, EXTR ---- DELETE
BD3 ORNAMENTATION, INTR ACCEL/BRAKE PEDAL
BF1 COVERING REAR FLOOR MATS----DELETE
BF2 COVERING, FLOOR CARPET, DELUXE
BF3 COVERING, STEP WELL MAT
BF4 COVERING, FLOOR CARPET, CUSTOM
BF9 COVERING FRT, FLOOR MAT----DELETE
BG4 TRIM OVERRIDE ,INTERIOR, BIG FOUR
BG9 COVERING FLOOR, RUBBER
BS1 INSULATION, ACOUSTICAL PKG
BS2 INSULATION, ACOUSTICAL PKG, ADDED MATERIAL
BS4 INSULATION, BACK PNL
BS6 SEAL, DR
BV1 FLEET INCENTIVE, LAND O'LAKES (J/L/W-TRK CKMST)
BV2 ORNAMENTATION, EXTR RR C0MPT LID
BV3 ORNAMENTATION, INTR, I/P, BLACK
BV6 ORNAMENTATION, EXTR LOCK CYLINDER, PAINTED
BV7 ORNAMENTATION, EXTR PLR APLQ ---- DELETE
BV8 ORNAMENTATION, EXTR DR HANDLE, LOCK CYLINDER,
BV9 ORNAMENTATION, EXTR MLDG, BODY SIDE, WOOD GRAIN
BW1 ORNAMENTATION, EXTR RR END
BW2 MOLDING B/S, DELUXE
BW3 ORNAMENTATION, EXTR ROOF WINDOW TRIM, PAINTED
BW6 ORNAMENTATION, EXTR PLR APLQ, COLORED
BW7 ORNAMENTATION, EXTR PLR APLQ
BW8 ORNAMENTATION, EXTR, EMBLEM, BODY, RR
BX1 ORNAMENTATION, EXTR FRT END, SPECIAL
BX2 MOLDING B/S, L0WER, EXTRA WIDE
BX3 ORNAMENTATION, EXTR WOOD GRAIN SIDE PNL
BX4 ORNAMENTATION, EXTR MLDG, BODY SIDE, BRIGHT
BX5 ORNAMENTATION, EXTR MLDG, ROOF DRIP, PAINTED
BX6 ORNAMENTATION, EXTR MLDG, APLQ, CAB BACK PNL
BX8 ORNAMENTATION, EXTR MLDG, RR WINDOW REVEAL ----
BX9 ORNAMENTATION, EXTR FRT END PNL
BYP SALES, SPORT EQUIPMENT PKG
BY1 ORNAMENTATION, EXTR EMBLEM, BODY, VAR 3
BY4 ORNAMENTATION, INTR, INST PANEL, NAME PLATE
BY8 ORNAMENTATION, EXTR FRT DECOR PLATE
B05 BODY EQUIPMENT ARMORED
B1A PORT OF ENTRY CAMI
B1B MODIFICATION FOUR SEATER
B1J LINER FENDER
B1N TIRE ALL, P165/65R13 BL R/PE ST TL AL3
B1R TIRE ALL, P185/60VR14/N BL R/PE ST TL AL3
B1Y MERCHANDISED PKG, SPECIAL COMPONENTS
B18 ORNAMENTATION, INTR, DELUX
B19 ORNAMENTATION, INTR, CUSTOM
B2E SALES, SPRING SPECIAL PACKAGE
B2L PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7L PFI
B2Q PANEL, RR ROOF, BLACK ---DELETE
B2S SPRING , REAR LEAF TRANSVERSE (LH)
B2U SPRING, REAR LEAF TRANSVERSE (RH)
B2W TIRE ALL, P205/75R15/N R/PE 0WL TL 00R (TRACKER)
B2Z MERCHANDISED PKG, DELUXE VAN
B20 ORNAMENTATION, INTR, LUXURY
B22 ORNAMENTATION, INTR, EMBLEM, DR INNER PANEL
B23 ORNAMENTATION, EXTR WHEEL OPG SPOILER
B24 ORNAMENTATION, EXTR MLDG, SIDE WINDOW REVEALs
B25 TRIM EQUIPMENT LUGG COMPT, DELUXE
B26 ORNAMENTATION, INTR, DR PULL HANDLES, FRT
B29 ORNAMENTATION, INTR, DR PULL HANDLES, RR
B3D EQUIPMENT, SCHOOL BUS
B3H COVERING, FLOOR CARPET LOAD FLOOR ---DELETE
B3J EQUIPMENT DIESEL
B3K TIRE ALL, P145/BOR12/N BL R/PE ST TL ALS
B3M EQUIPMENT, SCHOOL BUS, DELUXE
B3S TIRE ALL, P205/50R15/N BL R/PE ST TL HW4
B30 COVERING, FLOOR CARPET
B32 COVERING, FRT FLOOR MATS AUX
B33 COVERING, REAR FLOOR MATS AUX
B34 COVERING, FRT FLOOR MATS CARPETED INSERT
B35 COVERING, REAR, FLOOR MATS CARPETED INSERT
B36 COVERING, FLOOR MAT, LUGG COMPT
B37 COVERING, FLOOR MATS, FRT & RR AUX
B39 COVERING, FLOOR CARPET, LOAD FLOOR
B4A PANEL ROOF, BLACK --- DELETE
B4C SALES, SPECIAL SERVICE PKG
B4F PACKAGE, SECURITY LIGHTING
B4H MODIFICATION, NOISE CONTROL , EXPORT
B4K HANDLING CHARGE, TARRYTOWN T0 MIDWAY COACH
B4M VEHICLE, CUSTOM FEATURE PACKAGE
B4N HANDLING CHARGE, TARRYTOWN T0 ESSEX MD T0 T & B IN
B4U PERFORMANCE PACKAGE, SPORT
B4V PERFORMANCE PACKAGE, SUPER SPORT
B42 COVERING, FLOOR MAT, LUGGAGE COMPARTMENT FITTED
B43 COVERING, LOAD FLOOR, TEXTURED SURFACE
B44 COVERING, LOAD FLOOR, LOOSE
B46 TRIM EQUIPMENT, SPECIAL ORDER
B48 TRIM EQUIPMENT, LUGGAGE COMPARTMENT
B5A PACKAGE, INDY CONVERTIBLE
B5I PACKAGE, INDY "GT"
B5S FLEET INCENTIVE, D & K FINANCIAL
B5Z SALES, EXTR APPEARANCE
B51 MOLDING, ROCKER, EXTRA WIDE
B53 COVERING FRT, FLOOR MATS, CARPETED INSERT DELUXE
B54 COVERING REAR, FLOOR MATS, CARPETED INSERT DELUXE
B56 MOLDING ROCKER,COLORED
B57 ORNAMENTATION P EXTR DELUXE
B58 COVERING, FLOOR MATS FRT & RR, CARPETED INSERT
B60 DECAL PACKAGE, 01
B6Q DECAL PACKAGE, 02
B6R DECAL PACKAGE, 03
B6S TRAVEL BED PACKAGE
B65 COVERING, FLOOR SIDEWALL TRUNK
B67 CONTAINER, RADI0 CASSETTE TAPES
B69 CONTAINER, COMPACT DISCS
B7N BODY EQUIPMENT, PICKUP BOX PANELS (NON-PRIME)
B7P BODY EQUIPMENT, PICKUP BOX PANELS (PRIME)
B71 MOLDING WHL OPENING, COLORED
B72 ORNAMENTATION, EXTR MLDG BELT REVEAL' COLORED
B74 MOLDING WHL OPENING, EXTRA WIDE
B75 TRIM EQUIPMENT, LUGG COMPT LINING
B77 ORNAMENTATION, EXTR MLDG W/S REVEAL, COLORED
B79 ORNAMENTATION, EXTR RR END
B80 ORNAMENTATION, EXTR MLDG ROOF DRIP
B81 MOLDING B/S ---- DELETE
B82 ORNAMENTATION, EXTR EMBLEM ---- DELETE
B83 MOLDING ROCKER, NARROW
B84 ORNAMENTATION, EXTR MLDG, B0DY SIDE
B85 RNAMENTATION, EXTR MLDG BELT REVEAL
B87 ORNAMENTATION, EXTR EMBLEM FENDER---DELETE
B88 MOLDING B/S CUSTOM
B89 ORNAMENTATION, EXTR MLDG, RR WINDOW REVEAL,
B9Q MODEL CONVERSION, HEARSE
B90 ORNAMENTATION, EXTR MLDG, SIDE WINDOW REVEAL
B91 ORNAMENTATION, EXTR MLDG DR EDGE GUARD, COLORED
B92 ORNAMENTATION, EXTR FRT FENDER NAME
B93 ORNAMENTATION, EXTR MLDG, DR EDGE GUARD
B94 ORNAMENTATION, EXTR EMBLEM, BODY, VAR I
B96 MOLDING WHL OPENING
B97 ORNAMENTATION, EXTR MLDG, LOWER ACCENT
B98 STRIP B0DY SIDE, DELETE
B99 MOLDING WHL OPENING,---- DELETE
CA1 ROOF, SUN, STEEL SLIDING, ELEC
CA2 ROOF COVERING, VINYL ---- DELETE
CA3 ROOF COVERING, STAINLESS STEEL
CA5 ROOF COVERING, VINYL, HEAVY PAD, HALO TYPE
CA9 ROOF COVERING, VINYL, PADDED, HALO TYPE
CB4 ROOF COVERING, VINYL, PADDED, RR INTEGRAL PAD
CB5 ROOF COVERING, VINYL, PADDED, FULL
CB7 ROOF COVERING, VINYL, PADDED, FRT INTEGRAL PAD
CC1 ROOF HATCH, REMOVABLE PANELS, GLASS
CC2 ROOF AUXILIARY
CC3 ROOF, HATCH, REMOVABLE PANELS. PLASTIC
CD2 INDICATOR, WSWA JAR FLUID
CD4 WIPER SYSTEM WINDSHIELD, PULSE
CD7 WIPER SYSTEM WINDSHIELD, PULSE, WET ARM
CE4 WASHER, HEADLAMP, HIGH PRESSURE
CF3 ROOF, SUN, REMOVABLE, TRANSPARENT
CF4 ROOF, SUN, GLASS SLIDING, MANUAL
CF5 ROOF, SUN, GLASS SLIDING, ELEC
CF7 ROOF, SUN REMOVABLE NON-TRANSPARENT
CF8 ROOF, COVERING, SIMULATED CONVERTIBLE
CG1 FLEET INCENTIVE, AMERICAN INTERNATIONAL REALTY
CH1 FLEET INCENTIVE, HALLMARK CARD
CH2 FLEET INCENTIVE, AMSCO
CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT
CJ3 HVAC SYSTEM AIR CONDITIONER FRT, MAN TEMP CONT,
CR0 LAMP, INTR ENG COMPT COURTESY ---DELETE
CR1 LAMP, INTR FRT DR WARNING
CR3 LAMP, INTR I/P READING
CR5 COUNTRY, YUGOSLAVIA
CR6 COUNTRY, POLAND
CR7 COUNTRY, HUNGARY
CTF SALES PACKAGE, INTERIM CONTROL
CT1 COUNTRY, BELGIUM
CT2 COUNTRY, AUSTRIA
CT3 COUNTRY, GERMANY
CT4 COUNTRY, LUXEMBOURG
CT5 COUNTRY, NETHERLANDS
CT6 COUNTRY, ITALY
CT7 COUNTRY, DENMARK
CT8 COUNTRY, PORTUGAL
CT9 COUNTRY, SPAIN
CU1 COUNTRY, NORWAY
CU2 COUNTRY, FINLAND
CU3 COUNTRY, FRANCE
CU4 COUNTRY, SWEDEN
CU5 COUNTRY, SWITZERLAND
CU6 COUNTRY, TAIWAN
CU7 COUNTRY, KUWAIT
CU8 COUNTRY, SAUDI ARABIA
CU9 COUNTRY, UNITED KINGDOM
CV1 COUNTRY, ICELAND
CV3 COUNTRY, MEXICO
CV4 COUNTRY, ISRAEL
CV7 COUNTRY, ENGLAND
CV8 COUNTRY, IRAQ
CV9 COUNTRV, TURKEY
CW1 COUNTRY, KOREA
C01 ORNAMENTATION, EXTR EMBLEM, BODY, VAR 2
C04 ROOF COVERING VINYL PADDED, RR
C05 ROOF, CONVERTIBLE FOLDING
C09 ROOF COVERING, VINYL PADDED, FULL,INTEGRAL PAD
C1B LAMP GROUP, COMPONENTS 2
C1F PACKAGE, ACCENT
C18 ARM & BLADE, WSW
C2L ROOF, PACKAGE DUAL REMOVABLE
C2X MODEL CONVERSION, VALUE LEADER
C25 WIPER SYSTEM, RR WINDOW
C27 ROOF COVERING, SOFT TRIM
C3A PAYLOAD, 1500 LBS
C3B PAYLOAD, 1000 LBS
C3C PAYLOAD, 1625 LBS
C34 HVAC SYSTEM, AIR CONDITIONER HEATER COMBINATION
C35 HEATER, RR COUPT, PROVISIONS FOR
C36 HEATER, AUXILIARY
C4G GVW RATING, 4935 LBS
C4H GVW RATING, 5050 LBS
C40 HVAC SYSTEM, HEATER OUTSIDE AIR, WITH FAN, ELECTRONIC
C41 HVAC SYSTEM, HEATER OUTSIDE AIR, WITH FAN
C42 HVAC SYSTEM, HEATER DELUXE OUTSIDE AIR
C44 TAILGATE, PLASTIC
C46 HEATER, HIGH CAPACITY
C47 DEFOGGER, RR WINDOW ---- DELETE
C49 DEFOGGER, RR WINDOW, ELECTRIC
C5A GVW RATING, 4900 LBS
C5B GVW RATING, 15,000 LBS
C5C GVW RATING, 5000 LBS
C5D GVW RATING, 4600 LBS
C5E GVW RATING, 5400 LBS
C5F GVW RATING, 4100 LBS
C5G GVW RATING, 5600 LBS
C5H GVW RATING, 5350 LBS
C5J GVW RATING, 6000 LBS
C5K GVW RATING, 5175 LBS
C5L GVW RATING, 5370 LBS
C5U GVW RATING, 6100 LBS
C5P GVW RATING, 6250 LBS
C5Q GVW RATING, 6400 LBS
C5R GVW RATING, 5800 LBS
C5S GVW RATING, 6600 LBS
C5T GVW RATING, 4200 LBS
C5U GVW RATING, 6800 LBS
C5V GVW RATING, 6850 LBS
C5W GVW RATING, 7000 LBS
C5X GVW RATING, 4650 LBS
C5Y GVW RATING, 7100 LBS
C5Z GVW RATING, 7200 LBS
C50 DEFROSTER, HEATED WINDSHIELD
C51 DEFLECTOR, RR WINDOW, AIR
C55 VENT, ROOF
C56 VENT, FORCED AIR, RIGHT SIDE
C57 VENT, FORCED AIR
C6A GVW RATING, 7300 LBS
C6B GVW RATING, 4785 LBS
C6C GVW RATING, 7400 LBS
C6D GVW RATING, 10100 LBS
C6E GVW RATING, 7500 LBS
C6F GVW RATING, 5150 LBS
C6G GVW RATING, 7600 LBS
C6H GVW RATING, 4350 LBS
C6I GVW RATING, 4850 LBS
C6J GVW RATING, 5100 LBS
C6K GVW RATING, 20000 LBS
C6L GVW RATING, 8000 LBS
C6U GVW RATING, 5950 LBS
C6N GVW RATING, 8200 L85
C6P GVW RATING, B600 LBS
C6Q GVW RATING, 6875 LBS
C6S GVW RATING, 8900 LBS
C6U GVW RATING, 9000 LBS
C6W GVW RATING, 9200 LBS
C6X GVW RATING, 4810 LBS
C6Y GVW RATING, 9600 LBS
C60 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
C61 HVAC SYSTEM, AIR CONDITIONER FRT AUTO CONTROLS
C65 HVAC SYSTEM, AIR CONDITIONER FRT SEMI-AUTO CONTROLS
C66 HVAC SYSTEM, AIR CONDITIONER PROVISIONS FOR DEALER
C67 HVAC SYSTEM, AIR CONDITIONER FRT ELECTRONIC CONTROLS
C68 HVAC SYSTEM, AIR CONDITIONER FRT AUTO, ELECTRONIC
C69 HVAC SYSTEM, RR, AIR CONDITIONER
C7A GVW RATING, 10000 LBS
C7C GVW RATING, 10500 LBS
C7E GVW RATING, 11000 LBS
C7G GVW RATING, 11500 LBS
C7J GVW RATING, ll800 LBS
C7L GVW RATING, 12000 LBS
C7M GVW RATING, 14100 LBS
C7N GVW RATING, 12300 LBS
C7P GVW RATING, 16000 LBS
C7Q GVW RATING, 10200 LBS
C7S GVW RATING, 14600 LBS
C7U GVW RATING, 5200 LBS
C7V GVW RATING, 26500 LBS
C7X GVW RATING, 5850 LBS
C7Y GVW RATING, 4700 LBS
C7Z GVW RATING, 4537 LBS
C71 LAMP, INTR, FRT DR, COURTESY
C72 LAMP, INTR, RR DR COURTESY
C75 LAMP, INTR, FRT HEADER, COURTESY AND DUAL READING
C77 LAMP, INTR, FRT HEADER COURTESY
C78 LAMP, INTR, ROOF, COURTESY AND SINGLE READING
C8B PAINT SPECIAL, (SILVER MET)
C8K PAINT SPECIAL, (MED GRAY MET )
C8T PAINT SPECIAL, (DK MAPLE RED MET)
C80 SWITCH, JAMB, FPT DR
C81 SWITCH, JAMB, RR DR
C87 LAMP, INTR, QTR COURTESY
C88 LAMP, INTR, RR HEADER, COURTESY
C89 LAMP, INTR, QTR, SINGLE READING
C9A PAINT SPECIAL, (WHITE)
C9C PAINT SPECIAL, (BLACK)
C9D PAINT SPECIAL, (DK BLUE MET. )
C9E PAINT SPECIAL, (LT BLUE MET. )
C9F PAINT SPECIAL, (DK RED MET)
C9Q PAINT SPECIAL, (DK CHESTNUT MET. )
C9R PAINT SPECIAL, (CARMINE)
C9X PAINT SPECIAL, (LT CAMEL MET)
C90 LAMP, INTR, FRT AND RR DRS, COURTESY
C91 LAMP, INTR, ROOF, COURTESY
C93 LAMP, OPERA
C94 LAMP, D0ME, DELAYED
C95 LAMP, INTR, ROOF, COURTESY AND DUAL READING
C96 LAMP, INTR, QTR, COURTESY AND SINGLE READING
C97 ILLUMINATED ENTRY,
DA0 ARM REST, FRT SEAT, STORAGE
DA1 ARM REST, RR SEAT, STORAGE
DA2 GVW RATING, 5070 LBS
DA3 GVW RATING, 5700 LBS
DA4 GVW RATING,12 500 LBS
DB3 SUNSHADE, WINDSHIELD, WITH EXTENSION
DB4 SUNSHADE, WINDSHIELD, WITH POCKETS
DC4 MIRROR I/S, R/V, TILT, DUAL READING LAMPS
DC5 MIRROR I/S, RR HEADLINING, ILLUM
DC6 MIRROR O/S, LH & RH, REM CONT, ELEC, LH & RH DEFOG,
DC7 MIRROR O/S, LH & RH, REM CONT, ELEC, BREAKAWAY,
DC8 MIRROR O/S, LH & RH, REM CONT, ELEC, BREAKAWAY,
DD0 MIRROR O/S, LH & RH, REM CONT, ELEC, DEFOG, LT
DD1 MIRROR I/S, R/V TILT, DUAL READING LAMPS, COMPASS
DD2 MIRROR I/S, SUNSHADE, COVERED
DD3 MIRROR O/S, LH & RH, REM CONT 8REAKAWAY, PAINTED
DD4 MIRROR O/S, RH, REM CONT, ELEC, CHROME
DD5 MIRROR 0/S, LH, REM CONT, ELEC, CHROME
DD7 MIRROR I/S, R/V, LT SENSITIVE, C0MPASS
DD8 MIRROR I/S, R/V, LT SENSITIVE
DD9 MIRROR O/S, LH & RH, RE4 CONT, ELEC, 8REAKAWAY,
DE1 SUNSHADE, BACK WINDOW
DE4 SUNSHADE, REMOVEABLE HATCH ROOF
DE7 MIRROR O/S, LH & RH, REM CONT, BREAKAWAY, CHROME
DE9 CONSOLE, FRT COMPT, NONSHIFTING
DF1 MIRROR O/S, CAMPER TYPE, PAINTED
DF2 MIRROR O/S, CAMPER TYPE, SST
DF3 MIRROR O/S, RH, REM CONT, CHROYE
DF4 MIRROR O/S, LH REM CONT, RH DIRECT CONT, BREAKAWAY,
DF7 MIRROR O/S, LH & RH, REM CONT, ELEC, DEFOG, CHROME
DF8 MIRROR O/S, LH & RH, REM CONT, ELEC, BREAKAWAY,
DG0 MIRROR O/S, LH & RH, REM CONT, ELEC, DEFOG, TINTED
DG1 MIRROR O/S, LH, DR MTD
DG2 MIRROR O/S, LH & RH, REM CONT, ELEC, CHROYE
DG5 MIRROR O/S, LH & RH, WEST COAST TYPE, LARGE
DG6 MIRROR O/S, LH & RH, REM CONT, ELEC, DEFOG, TINTED
DG7 MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
DG8 MIRROR 0/S, LH REM CONT, RH DIRECT CONT, BREAKAWAY,
DG9 MIRROR O/S, LH & RH, REM CONT, ELEC, SST
DH6 MIRROR I/S, SUNSHADE, ILLUM, LH & RH
DK1 CONSOLE, RR COMPT FLOOR
DK2 MIRROR O/S, LH & RH, REM CONT, ELEC, DEFOG, PAINTED
DK4 CONSOLE, FRT COMPT FLOOR, MINI OPERATING
DK6 CONSOLE ROOF, INTERIOR
DL2 DECAL, WINDOW
DL4 DECAL, PAINT SCHEME TRITONE, MEDIUM LINE STRIPE
DL5 DECAL, ROADSIDE SERVICE INFORMATION
DL8 MIRROR, O/S LH & RH REM CONT, ELEC, DEFOG
DL9 DECAL, FRT FENDER, RR QUARTER, BLACKOUT
DM1 DECAL, DR
DR1 MIRROR O/S, LH & RH, MAN CONT PAINTED
DR2 MIRROR O/S, LH, MAN CONT, CHROME
DR3 MIRROR O/S, LH & RH, MAN CONT, CHROME
DR4 MIRROR O/S, LH & RH, REM CONT, CHROME
DR5 MIRROR O/S, LH REM CONT, RH MAN CONT, CHROME
DT4 TRAY, ASH, CIGARETTE LIGHTER
DV1 SUNSHADE, WINDOW, ROOF
DW1 STRIPE, BODY SIDE, MIDDLE
DX1 STRIPE, FRT END, HWD
DX3 STRIPE, DELETE
DX4 STRIPE, 2 SIDE
DX5 STRIPE, 3 SIDE
DY1 STRIPE, 3 SIDE, VAR. 2
DY2 STRIPE, 3 SIDE, VAR. 3
DY5 STRIPE, DECK LID
D02 PAINT, ENAMEL MASTER
D03 PAINT, PROCESS, WATER BASE
D04 PAINT, LOW GLOSS FINISH
D06 CONSOLE, FRT COMPT FLOOR, ARM REST
D07 CONSOLE, FRT COMPARTMENT FLOOR, CUSTOM
D08 PAINT, HIGH GLOSS FINISH
D09 ARM REST, FRT SEAT
D1B GEAR, SPEEDO DRIVEN (D1B)
D1D GEAR, SPEEDO DRIVEN (D1D)
D1E GEAR, SPEEDO DRIVEN (D1E)
D1F GEAR, SPEEDO DRIVEN (D1F)
D1G GEAR, SPEEDO DRIVEN (D1G)
D1H GEAR, SPEEDO DRIVEN (D1H)
D1R GEAR, SPEEDO DRIVEN (D1R}
D1S GEAR, SPEEDO DRIVEN (D1S)
D1T GEAR, SPEEDO DRIVEN (D1T)
D1U GEAR, SPEEDO DRIVEN (D1U)
D1V GEAR, SPEEDO DRIVEN (D1V)
D1W GEAR, SPEEDO DRIVEN (D1W)
D1X GEAR, SPEEDO DRIVEN (D1X)
D1Y GEAR, SPEEDO DRIVEN (D1Y)
D1Z GEAR, SPEEDO DRIVEN (D1Z)
D12 PANEL, REAR SEAT, BACK PKG SHELF
D14 ARM REST, FRT DR, RH & LH
D2A GEAR, SPEEDO DRIVEN (D2A)
D2B GEAR, SPEEDO DRIVEN (D2B)
D2C GEAR, SPEEDO DRIVEN (D2C)
D2D GEAR, SPEEDO DRIVEN (D2D)
D2E GEAR, SPEEDO DRIVEN (D2E)
D2F GEAR, SPEEDO DRIVEN (D2F)
D2L GEAR, SPEEDO DRIVEN (D2L)
D2M GEAR, SPEEDO DRIVEN (D2M)
D2N GEAR, SPEEDO DRIVEN (D2N)
D2Q GEAR, SPEEDO DRIVEN (D20)
D20 SUNSHADE, WINDSHIELD, PASS SIDE
D21 SUNSHADE, WINDSHIELD
D22 MIRROR O/S, RH BELOW EYELINE, 6 S X 9, AERODYN
D24 CONTAINER, LITTER
D25 MIRROR O/S, RH BELOW EYELINE, 6.5 X 9, AERODYN,
D27 COVER, RR COMPT, TRUNK STOW
D28 MIRROR O/S ---- DELETE
D3A GEAR, SPEEDO DRIVEN (D3A)
D3B GEAR, SPEEDO DRIVEN (D3B)
D3E GEAR, SPEEDO DRIVEN (D3E)
D3H GEAR, SPEEDO DRIVEN (D3H)
D3P GEAR, SPEEDO DRIVEN (D3P)
D3Q GEAR, SPEEDO DRIVEN (D3Q)
D3R GEAR, SPEEDO DRIVEN (D3R)
D3S GEAR, SPEEDO DRIVEN (D35)
D3T GEAR, SPEEDO DRIVEN (D3T)
D3U GEAR, SPEEDO DRIVEN (D3U)
D3V GEAR, SPEEDO DRIVEN (D3V)
D3W GEAR, SPEEDO DRIVEN (D3W)
D3X GEAR, SPEEDO DRIVEN (D3X)
D3Y GEAR, SPEEDO DRIVEN (D3Y)
D31 MIRROR I/S, R/V,TILT
D33 MIRROR O/S, LH, REM CONT, PAINTED
D34 MIRROR I/S, SUNSHADE
D35 MIRROR O/S, LH REM CONT, RH DIRECT CONT, PAINTED
D36 MIRROR I/S, R/V, TILT
D4A GEAR, SPEEDO DRIVEN (D4A)
D4D GEAR, SPEEDO DRIVEN (D4D)
D4H GEAR, SPEEDO DRIVEN (D4H)
D4K GEAR, SPEEDO DRIVEN (D4K)
D4L GEAR, SPEEDO DRIVEN (D4L)
D4P GEAR, SPEEDO DRIVEN (D4P)
D4Q GEAR, SPEEDO DRIVEN (D4Q)
D4R GEAR, SPEEDO DRIVEN (D4R)
D4S GEAR, SPEEDO DRIVEN (D45)
D4U GEAR, SPEED0 DRIVEN (D4U)
D41 TRAY ASH, RR QUARTER
D42 SHADE, RR COMPT SECURITY
D43 MIRROR I/S, R/V, TILT, AUTOMATIC, INCREASED VISIBILITY
D44 MIRROR O/S, PAINTED
D45 MIRROR O/S, SST
D46 MIRROR O/S, WEST COAST TYPE, CLEARANCE LIGHTS
D47 CONSOLE FRT COMPT FLOOR
D48 MIRROR O/S, REM CONT, ELEC PAINTED
D49 MIRROR O/S, LH & RH, CHROME
D5S GEAR, SPEEDO DRIVEN (D5S)
D5T GEAR, SPEEDO DRIVEN (D5T)
D5V GEAR, SPEEDO DRIVEN (D5V)
D5W GEAR, SPEEDO DRIVEN (D5W)
D5X GEAR, SPEEDO DRIVEN (D5X)
D51 MIRROR O/S, LH, DIRECT CONT, PAINTED
D52 SPOILER, RR END, SPORT
D53 ORNAMENTATION, EXTR HWD APPLIOUE
D55 CONSOLE, FRT COMPT, FLOOR
D58 SPOILER, REAR---DELETE
D6D GEAR, SPEEDO DRIVEN (D6D)
D6E GEAR, SPEEDO DRIVEN (D6E)
D6G GEAR, SPEEDO DRIVEN (D6G)
D6H GEAR, SPEEDO DRIVEN (D6H)
D6L GEAR, SPEEDO DRIVEN (D6L)
D6M GEAR, SPEEDO DRIVEN (D6M)
D64 MIRROR I/S, RH, SUNSHADE, ILLUM
D68 MIRROR O/S, LH & RH, REM CONT, PAINTED
D69 MIRROR O/S, LH, REM CONT, CHROME
D7A GEAR, SPEEDO DRIVEN (D7A)
D7B GEAR, SPEEDO DRIVEN (D78)
D7C GEAR, SPEEDO DRIVEN (D7C)
D7H GEAR, SPEEDO DRIVEN (D7H)
D7I GEAR, SPEEDO DRIVEN (D7I)
D7J GEAR, SPEEDO DRIVEN (D7J)
D7L GEAR, SPEEDO DRIVEN (D7L)
D7S GEAR, SPEEDO DRIVEN (D75)
D7T GEAR, SPEEDO DRIVEN (D7T)
D7U GEAR, SPEEDO DRIVEN (D7U)
D7V GEAR, SPEEDO DRIVEN (D7V)
D7W GEAR, SPEEDO DRIVEN (D7W)
D7Z GEAR, SPEEDO DRIVEN (D7Z)
D73 RAIL, HAND, PICK-UP BOX
D74 MIRROR, I/S, LH SUNSHADE, ILLUM
D75 HANDLE, O/S, DR
D77 MIRROR, O/S, WIDE ANGLE, DUAL SYS, SST
D8A SENSOR, VEH SPD (D8A)
D8B SENSOR, VEH SPD (D8B)
D8C SENSOR, VEH SPD (D8C)
D8D SENSOR, VEH SPD (D8D)
D8E SENSOR, VEH SPD (D8E)
D8F SENSOR, VEH SPD (D8F)
D8G SENSOR, VEH SPD (D8G)
D8H SENSOR, VEH SPD (D8H )
D8I SENSOR, VEH SPD (D8I)
D8K SENSOR, VEH SPD (D8K)
D8L SENSOR, VEH SPD (D8L)
D8M SENSOR, VEH SPD (D8M)
D8N SENSOR, VEH SPD (D8N)
D80 SPOILER, RR END PNL
D81 SPOILER, RR, AERO WING
D83 PAINT, MONOTONE
D84 PAINT, CUSTOM TWO-TONE
D85 STRIPE, B0DY SIDE LOWER ACCENT
D86 PAINT, TWO-TONE, DELUXE
D88 DECAL, STRIPE, SPORT
D89 PAINT, SPECIAL DECOR
D9A SENSOR, VEH SPD (D9A)
D9B SENSOR, VEH SPD (D9B)
D9C SENSOR, VEH SPD (D9C)
D9D SENSOR, VEH SPD (D9D)
D9E SENSOR, VEH SPD (D9E)
D9Z GEAR, SPEEDO DRIVEN, SELECTION NOT REQUIRED
D90 STRIPE, FRT END, B0DY SIDE
D91 PAINT, TWO-TONE WITH RR QUARTER, UPPER PAINT BREAK
D92 STRIPE, EXTR DR HANDLE
D96 STRIPE, B0DY SIDE UPPER
D98 STRIPE, ACCENT
D99 PAINT, SPECIAL TWO-TONE, BODY PROVISIONS FOR
EJ8 EQUIPMENT, FLEETWOOD BODY CO.
ENV HVAC PROVISIONS, ENGINE DRESS, COMPRESSOR & CONDENSER
EN2 HVAC PROVISIONS, DELETE
E1G ADAPTER, SPEEDO (EIG)
E20 HANDLE, CONVERTIBLE RELEASE
E24 WWR SIDE, CARGO, HINGED
E26 PUMP, TILT CAB ASSIST
E28 HANDLE ASSIST
E30 B0DY EQUIPMENT, ALUMINUM 14 FT X 96 IN
E31 BDDY EQUIPMENT, STEEL 10 FT INCR WIDTH
E32 BODY EQUIPMENT, FORWARD CONTROL VAR 3
E33 BODY EQUIPMENT, FORWARD CONTROL VAR 4
E34 BODY EQUIPMENT, STEEL 10 FT STD WIDTH
E35 BODY EQUIPMENT, FLEETSIDE LESS TAILGATE, PUBX
E36 BODY EQUIPMENT, ALUUINUM io FT
E37 BODY EQUIPMENT, UTILITY
E38 BODY EQUIPMENT, STEEL 12 FT X 96 INCH
E39 BODY EQUIPMENT, ALUMINUM 12 FT X 96 INCH
E46 DOOR, RR, 66 INCH, OVERHEAD SLIDING WITH WINDOW
E48 COVER BODY SIDE, PROTECTIVE
E50 ROLL BAR
E52 DOOR RR, 83 INCH, WRAP AROUND
E53 DOOR RR, 87 INCH, WRAP AROUND
E54 BODY EQUIPMENT, RR DOOR, W/END GATE WINDOW
E55 BODY EQUIPMENT, END GATE
E56 BODY EQUIPMENT, PLATFORM
E62 BODY EQUIPMENT, STEPSIDE, PUBX
E63 BODY EQUIPMENT, FLEETSIDE, PUBX
E65 BODY HEIGHT, INCR INTR TO 80 INCH
E67 BODY LENGTH, INCR 12 INCH
E70 WHEEL HOUSINGS, RR DUAL WHEELS
E71 FLOOR, CARGO, STEEL
E72 BODY LENGTH, INCR I8 INCH
E73 BODY WIDTH, INCR INTR TO 86.4 INCH
E74 BODY WIDTH, INCR INTR TO 90.5 INCH
E75 BODY EQUIPMENT, FORWARD CONTROL VAR 5
E76 DOOR, RR, 60 INCH
E79 DOOR, RR, 74 INCH STRAP HINGES
E80 LID, RR C0MPT DELETE
E81 FLOOR, CARGO, WWD
E88 POCKET, STOWAGE
E89 PANEL, CAB, DRIVER DR OPENING FILLER WITH WINDOW
E94 CONVENIENCE PKG, BEAUVILLE
FE0 SUSPENSION SYSTEM, FRT & RR, ACTIVE
FE1 SUSPENSION SYSTEM, S0FT RIDE
FE2 SUSPENSION SYSTEM, RIDE HANDLING
FE3 SUSPENSION SYSTEM, SPORT
FE5 SUSPENSION SYSTEM, RIDE l HANDLING ---- DELETE
FE7 SUSPENSION SYSTEM, FRT & RR HD, VAR 3
FF4 ARM, TORS BAR SPRING ADJ (C)
FF5 ARM, TORS BAR SPRING ADJ (D)
FF6 ARM, TORS BAR SPRING ADJ (E)
FF7 ARM, TORS BAR SPRING ADJ (F)
FG2 SHOCK ABSORBERS, FRT & RR, FIRM RIDE
FG3 SHOCK ABSORBERS, FRT & RR, GAS PRELOADED
FK2 ARM, TORS BAR SPRING ADJ (A)
FK3 ARM, TORS BAR SPRING ADJ (B)
FNT FENDERS DELETION
FP2 RATIO, TRANSAXLE FINAL DRIVE 3.58
FP3 RATIO, TRANSAXLE FINAL DRIVE 2.73
FP5 RATIO, TRANSAXLE FINAL DRIVE 2.95
FP7 RATIO, TRANSAXLE FINAL DRIVE 3.73
FQ1 AXLE FRONT, STD RATIO
FQ2 RATIO, TRANSAXLE FINAL DRIVE 3.48
FQ6 RATIO, TRANSAXLE FINAL DRIVE 4.12
FQ8 RATIO, TRANSAXLE FINAL DRIVE 2.96
FQ9RATIO, TRANSAXLE FINAL DRIVE 3.21
FS3 SUSPENSION SYSTEM,I-BEAM CONSTRUCTION
FVM AXLE FRONT, F050, 5000 LBS CAPACITY, HYD
FVO RATIO, TRANSAXLE FINAL DRIVE 3.67
FV1 RATIO, TRANSAXLE FINAL DRIVE 3.72
FV3 RATIO, TRANSAXLE FINAL DRIVE 3.11
FV4 RATIO, TRANSAXLE FINAL DRIVE 3.71
FWX SPRING FRONT,5OOO LBS CAPACITY
FW1 RIDE AND HANDLING, MANUAL ELECTRONIC CONTROLLED
FW2 RATIO, TRANSAXLE FINAL DRIVE 3.06
FWS RATIO, TRANSAXLE FINAL DRIVE 4.10
FW7 RATIO, TRANSAXLE FINAL DRIVE 3.83
FW9 RATIO, TRANSAXLE FINAL DRIVE 3.43
FX1 RATIO, TRANSAXLE FINAL DRIVE 3.94
FX2 RATIO, TRANSAXLE FINAL DRIVE 2.66
FX3 RIDE AND HANDLING, AUTOMATIC ELECTRONIC CONTROLLED AAA
FX4 RATIO, TRANSAXLE FINAL DRIVE 3.35
FX8 RATIO, TRANSAXLE FINAL DRIVE 3.61
FY1 RATIO, TRANSAXLE FINAL DRIVE 2.36
FY3 RATIO, TRANSAXLE FINAL DRIVE 3.79
FY5 RATIO, TRANSAXLE FINAL DRIVE 3 52
F01 FRAME, HEAVY DUTY
F16 RATIO, TRANSAXLE FINAL DRIVE 2.53
F17 RATIO, TRANSAXLE FINAL DRIVE 2.84
F25 RATIO, TRANSAXLE FINAL DRIVE 3.32
F40 SUSPENSION SYSTEM, FRT, RR, HD, VAR I
F41 SUSPENSION SYSTEM, FRT, RR, FIRM RIDE, HANDLING
F42 SUSPENSION SYSTEM, FRT, HD
F44 CHASSIS, HEAVY DUTY
F47 AXLE FRONT, 2 73 RATIO
F51 SHOCK ABSORBERS, FRT & RR, HD
F58 STASILIZER SHAFT FR, HD
F59 STABILIZER SHAFT FR,
F60 SPRING FRONT, HEAVY OUTY
F61 STABILIZER SHAFT,RR
F62 RATIO TRANSAXLE FINAL DRIVE 2.39
F66 SUSPENSION SYSTEM, FRT, AIR BAG & SEATS, HD
F67 RATIO, TRANSAXLE FINAL DRIVE 3.19
F68 RATIO, TRANSAXLE FINAL DRIVE 3.45
F72 SPRING HEAVY DUTY, VAR 2
F73 DRIVE, ALL WHEEL
F75 RATIO, TRANSAXLE FINAL DRIVE 3.18
F77 RATIO, TRANSAXLE FINAL DRIVE 3.737
F79 RATIO, TRANSAXLE FINAL DRIVE 2.97
F93 SPRING FRONT,6000 LB, MULTILEAF
GH0 AXLE REAR, 3.54 RATIO
GH2 AXLE REAR, 2.29 RATIO
GH3 AXLE REAR, 2.77 RATIO
GH4 AXLE REAR, 2.92 RATIO
GK9 AXLE REAR, 4.63 RATIO
GL3 AXLE REAR, 6.17 RATIO
GM1 AXLE REAR, 2.59 RATIO
GM3 AXLE REAR, 3.45 RATIO
GM8 AXLE REAR, 2.56 RATIO
GQ1 AXLE, STD RATIO
GS4 AXLE REAR, 3.70 RATIO
GTY AXLE, WIDE TRACK
GT4 AXLE REAR, 3.73 RATIO
GT5 AXLE REAR, 4.10 RATIO
GT7 AXLE REAR, 3.33 RATIO
GT8 AXLE REAR, 4.10 RATIO
GU1 AXLE REAR, 2.41 RATIO
GU2 AXLE REAR, 2.73 RATIO
GU4 AXLE REAR, 3.08 RATIO
GU5 AXLE REAR, 3.23 RATIO
GU6 AXLE REAR, 3.42 RATIO
GV2 AXLE REAR, 5.83 RATIO
GV4 AXLE REAR, 3.36 RATIO
GV8 AXLE REAR, 2.72 RATIO
GW4 AXLE REAR, 3.31 RATIO
GW6 AXLE REAR, 3.27 RATIO
GW9 AXLE REAR, 2.93 RATIO
GX3 RATIO,TRANSAXLE FINAL DRIVE 3.33
GYS RATIO TRANSAXLE FINAL DRIVE 3.65
G44 AXLE REAR 3.07 RATIO
G5O SPRING REAR, HEAVY DUTY, VAR 1
G51 SPRING REAR, HEAVY DUTY, VAR 2
G52 SPRING, RR, 15000 LBS
G60 SPRING REAR, AUXILIARY
G66 LEVEL CONTROL, MAN, AIR
G67 LEVEL CONTROL, AUTO, AIR
G69 LEVEL CONTROL, AUTO, AIR, HD
G72 AXLE REAR, 2.14 RATIO
G75 AXLE REAR, 3.62 RATIO
G80 AXLE POSITRACTION, LIMITED SLIP
G87 RING GEAR, 8.50 INCH
G89 RING GEAR, 7.50 INCH
G92 AXLE REAR RATIO, PERFORMANCE
G9S AXLE REAR RATIO, ECONOMY
HA3 AXLE REAR, 5.29 RATIO, SINGLE SPEED
HC4 AXLE REAR, 4.56 RATIO
HC7 AXLE REAR, 5.13 RATIO, 7500 LBS, SINGLE SPEED
HC8 AXLE REAR, 3.21 RATIO, SINGLE SPEED, TRUCK
HE3 AXLE REAR, 3.07 RATIO, 3500 LBS, SINGLE SPEED,
HF7 AXLE REAR, 4.56 RATIO, IOOOO LBS, DANA 70, SINGLE
HF8 AXLE REAR, 4.88 RATIO
HK1 AXLE REAR, 2.87 RATIO
HK9 AXLE REAR, 5.86 RATIO 10000 LBS, SINGLE SPEED
HPR HEADLAMPS, DUAL, RECTANGULAR
H04 AXLE REAR, 4.11 RATIO, SINGLE SPEED
IFD TRIM, INTERIOR DESIGN (FD)
IF3 TRIM, INTERIOR DESIGN (F3)
ILD TRIM, INTERIOR DESIGN (LD)
IL3 TRIM INTERIOR DESIGN (L3)
JAF BRAKE, PROVISIONS EUROPE
JA1 BRAKE, LIGHT WEIGHT DISC DRUM
JA2 BRAKE, HEAVY WEIGHT DISC DRUM
JA3 BRAKE, SYSTEM, WAGON DISC DRUM
JA4 BRAKE, SYSTEM, PWR FRT DISC, RR DRUM, CAST IRON
JA5 BRAKE, SYSTEM, SPORT COUPE DISC DRUM
JA6 BRAKE, EXTRA LIGHT WEIGHT DISC DRUM
JA7 HANDLE, PARK BRAKE RELEASE, LEATHER
JA8 BRAKE, MEDIUM WEIGHT DISC DRUM
JB1 BRAKE, MANUAL, DISC/DRUM, 4300 LBS
JB3 BRAKE, POWER, DISC/DRUM, 4600 LBS
JB5 BRAKE, POWER, DISC/DRUM, 6400 LBS
JB6 BRAKE, POWER, DISC, DRUM 7200 LBS
JB7 BRAKE, POWER, DISC, DRUM 8400 L85
JB8 8RAKE, POWER, DISC, DRUM 10000 LBS
JC4 BRAKE, POWER, DISC, DRUM 5600 LBS
JC7 BRAKE, POWER, DISC/DRUM, 12000 LBS
JCB BRAKE, POWER, DISC/DISC, 20000 LBS
JD3 BRAKE, HYD POWER, DISC/DRUM
JD5 BRAKE, DUAL POWER, DISC/DRUM, 6400 LBS
JD6 BRAKE, HYD POWER, DISC/DRUM, 7200 LBS
JD7 BRAKE, HYD POWER, DISC/DRUM, 8400 LBS
JE1 BRAKE, SYSTEM, EUROPE
JF9 BRAKE, HYD POWER, 4 WHEEL DISC
JG1 SHAFT, PROP, ALUMINUM
JL2 BRAKE, FRT DISC, SINGLE PISTON
JL6 BRAKE, SYSTEM, MAN, FRT DISC, RR DRUM, CAST IRON
JL9 BRAKE, SYSTEM, PWR, FRT a RR OISC, ANTILOCK, FRT W
JM3 BOOSTER, BRAKE, 240MM TANDEM, HIGH FLOW
JM4 BRAKE, SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON,
JM5 BOOSTER, BRAKE, 200MM TANDEM, HIGH FLOW
JM7 BOOSTER, BRAKE HYD HI PERF, DELCO-MORAINE
JM8 BRAKE SYSTEM PWR, FRT DISC RR DRUM, ALUMINUM,
JIF BRAKE PROVISION SPECIAL TO SUIT FOREIGN REGULATION
J41 BRAKE SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON
J42 BRAKE SYSTEM, PWR. FRT DISC, RR DRUM, ALUMINUM
J50 BRAKE SYSTEM, POWER
J55 BRAKE SYSTEM, HEAVY DUTY
J85 BRAKE SYSTEM, PWR, FRT & RR DISC
KA1 HEATER SEAT
KB2 HEADS ENGINE CAST IRON
KB9 CONTROL, ELECTRONIC, TRANS SHIFT
KC4 COOLING SYSTEM, ENG OIL
KD1 COOLING SYSTEM, TRANS OIL
KG0 GENERATOR, 74 AMP
KG6 GENERATOR, 96 AMP
KG9 GENERATOR, 140 AMP
KL5 CONVERSION, NATURAL GAS
KL7 CONVERSION, LP GAS
KM9 MANIFOLD, INLET, ALUMINUM
KP2 TIMER, RETAINED ACCESSORY POWER
K42 GENERATOR,124 AMP
K01 FAN, CLUTCH DRIVE, ON/OFF
K05 HEATER ENG, BLOCK
K06 FAN, ENG COOLING
K07 HEATER, FUEL
K09 GENERATOR, 120 AUP
K10 CORD, ENG BLOCK HTR ----- DELETE
K15 LINES, FUEL VAPOR RETURN
K19 REACTOR SYSTEM, AIR INJECTION
K20 MODULE, ELECTRONIC COHTROL
K22 GENERATOR, 94 AMP
K30 CRUISE CONTROL, AUTOMATIC
K34 CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K35 CRUISE CONTROL, VACUUM RESUME
K45 AIR CLEANER, HEAVY DUTY
K46 AIR CLEANER, HEAVY OUTY, PRE-CLEANER
K60 GENERATOR, 100 AMP
K61 GENERATOR, 97 AMP
K64 GENERATOR, 78 AMP
K65 GENERATOR, 9S AMP
K68 GENERATOR,105 AMP
K69 KEY ADDITIONAL IGNITION
K70 PULSAIR, AIR INJECTION, ENGINE
K73 GENERATOR, 70 AMP
K77 GENERATOR, 56 AMP
K79 GENERATOR, 42 AMP
K8I GENERATOR, 66 AMP
K82 GENERATOR, 75 AMP
K85 GENERATOR, 37 AMP
K90 GENERATOR,108 AMP
K91 GENERATOR, 65 AMP
K96 GENERATOR, 55 AMP, BUILT-IN REGULATOR
K97 GENERATOR, 80 AMP, BUILT-IN REGULATOR
K99 GENERATOR, 85 AMP
LA5 ENGINE, GAS, 4 CYL, 1.8L, MFI, OHC, TUR80
LA7 ENGINE, DIESEL, 4 CYL, 1.5L, ISUZU
LB1 ENGINE, GAS, 6 CYL, 4.3L, 4BBL, V6, 90 DEG
LB4 ENGINE, GAS, 6 CYL, 4.3L, TBI, V6, 90 DEG
LB6 ENGINE, GAS, 6 CYL, 2.8L, UFI, V6, TRANSVERSE
LB8 ENGINE, GAS, 6 CYL, 2.8L, MFI, V6, LONGITUDINAL
LB9 ENGINE, GAS, 8 CYL, 5.0L, MFI, HO
LC0 ENGINE, GAS, 4 CYL, 1.8L, UFI, TUR80
LC1 ENGINE, GAS, 6 CYL, 2.8L, 2B8L, V6, LONGITUDINAL
LC2 ENGINE, GAS, 6 CYL, 3.8L, 4FI, V6, TURBO, HO
LC3 ENGINE, GAS, 6 CYL, 3.8L, 2B8L, V6, 90 DEG
LC5 ENGINE, GAS, 4 CYL, 1.5L, 2B8L
LC6 ENGINE, GAS, 6 CYL, 2 0L, MFI, OHC
LC7 ENGINE, GAS, 8 CYL, 4 IL, MFI
LC9 ENGINE, GAS, 4 CYL, 1.6L, 2BBL, TOYOTA
L02 ENGINE, GAS, 4 CYL, 2.3L, MFI, DOHC
LD4 ENGINE, GAS, 6 CYL, 4.1L, 4FI
LD5 ENGINE, GAS, 6 CYL, 3.8L, 2B8L, V6
LE2 ENGINE, GAS, 6 CYL, 2.8L, 2BBL, V6, TRANSVERSE
LE3 ENGINE, GAS, 6 CYL, 4.1L, 2BBL, VARAJET STANDARD
LE4 ENGINE, GAS, 4 CYL, 2.0L, MFI, OHC
LE8 ENGINE, GAS, 8 CYL, 7.4L, 4BBL, HO
LE9 ENGINE, GAS, 8 CYL, 5.0L, 4BBL, HI COMP
LF3 ENGINE, GAS, 8 CYL, 5.0L, TRUCK
LF5 ENGINE, GAS, 8 CYL, 5.7L, 2BBL, HO
LF7 ENGINE, DIESEL, 4 CYL, 3.6L
LF8 ENGINE, GAS 6 CYL 3.0L, MFI, V6, REGULAR FUEL
LF9 ENGINE, DIESEL, 8 CYL, 5.7L
LG0 ENGINE, GAS, 4 CYL, 2.3L, MFI, DOHC, HO
LG2 ENGINE, GAS, 6 CYL, 3.8L, SFI, V6
LG3 ENGINE, GAS, 6 CYL, 3.8L, MFI V6, HO
LG4 ENGINE, GAS, 8 CYL, 5.0L, 4BBL
LGS ENGINE, GAS, 6 CYL, 3.1L, 4FI, V6, TURBO
LG6 ENGINE, GAS, 6 CYL, 3.1L, TBI, V6,
LG7 ENGINE, GAS, 6 CYL, 3.3L, MFI, V6
LGB ENGINE, GAS, 8 CYL, 5.OL, 4BBL, HO
LG9 ENGINE, GAS, 6 CYL, 2.8L, MFI, V6, TURBO
LH0 ENGINE, GAS, 6 CYL, 3.1L, MFI, V6
LH6 ENGINE, DIESEL, 8 CYL, 6.2L
LH7 ENGINE, GAS, 6 CYL, 2.8L, 2BBL, 60 DEG, TRANSVERSE
LH8 ENGINE, GAS 4 CYL, 1.8L, 1 TBI, OHC
LJ5 ENGINE, DIESEL, 4 CYL, 1.8L
LK9 ENGINE, GAS, 6 CYL, 3.OL, 2BEL, V6
LL2 ENGINE, GAS, 6 CYL, 2.8L, 1 TBI V6 60 DEG, HO
LL4 ENGINE, DIESEL, 8 CYL, 6.2L, HEAVY DUTY
LL8 ENGINE, GAS, 4 CYL, 2.OL, 1 TBI, HO
LM1 ENGINE, GAS, 8 CYL, 5.7L, 4BBL
LM3 ENGINE, GAS, 4 CYL, 2.2L, 1 TBI
LM9 ENGINE, GAS, 6 CYL, 3.8L, MFI, V6, TUR8D
LN2 ENGINE, GAS, 4 CYL, 2.2L, MFI
LN3 ENGINE, GAS, 6 CYL, 3.8L, MFI, V6 (3800 SERIES)
LN7 ENGINE, GAS, 6 CYL, 3.0L, MFI V6 HO
LN8 ENGINE, GAS, 4 CYL, 2.5L 1 TBI LONGITUDINAL
LP2 ENGINE, GAS, 3 CYL, 1.OL TBI, OHC, SUZUKI
LPS ENGINE, GAS, 8 CYL, 5.7L 2BBL, HO
L01 ENGINE, GAS, 6 CYL, 3.4L, MFI, OHC, V6, HO
L02 ENGINE, GAS, 4 CYL, 2.OL, MFI
L05 ENGINE, GAS, 4 CYL, 2.OL, 1 TBI
L06 ENGINE, GAS, 8 CYL, 4.5L, MFI, HO
LQ7 ENGINE, DIESEL, 4 CYL, 2.2L, ISUZU
LQ9 ENGINE, GAS, 4 CYL, 2.5L, 1 TBI, LONGITUDINAL
LR1 ENGINE, GAS, 4 CYL, 1.95L, 2BBL
LR2 ENGINE, GAS, 6 CYL, 2.8L, 2BBL, V6, 60 DEG, TRUCK
LR6 ENGINE, GAS, 8 CYL, 4.5L, 2TBI
LR8 ENGINE, GAS, 4 CYL, 2 .8L, 1 TBI,
LR9 ENGINE, GAS, 4 CYL, 2.0L, 2BBL
LSA ENGINE, DRESS KIT, 4.3L, UPS RETROFIT
LST ENGINE, DIESEL, 4 CYL, 3.9L, CUMMINS MBT
LS3 ENGINE, GAS, 3 CYL, 1.OL, MFI, OHC, TURBO, SUZUKI
LS5 ENGINE, GAS, 4 CYL, 1.6L. I TBI, OHC, ALUMINUM,
LS9 ENGINE, GAS, 8 CYL, 5.7L, 4BBL
LT1 ENGINE, GAS, 8 CYL, 5.7L, MFI, HO
LT2 ENGINE, GAS, 4 CYL, 2.OL, TBI, OHC
LT3 ENGINE, GAS, 4 CYL, 2.OL, MFI, OHC, TURB0
LT5 ENGINE, GAS, 8 CYL, 5.7L, MFI, OHC
LT6 ENGINE, DIESEL, 6 CYL, 4.3L, V6, LONGITUDINAL
LT7 ENGINE, DIESEL, 6 CYL, 4.3L V6, TRANSVERSE
LT8 ENGINE, GAS, 8 CYL, 4.1L, 2T8I
LT9 ENGINE, GAS, 8 CYL, 5.7L, 488L, HD
LU2 ENGINE, GAS, 6 CYL, 4.3L, TBI V6, 90 DEG, HO
LV2 ENGINE, GAS, 8 CYL, 5.OL, 4BBL
LV4 ENGINE, GAS, 4 CYL, 1.6L, OHC, TURB0, PREMIUM FUEL
LV6 ENGINE, GAS, 4 CYL, 1.8L, MFI
LW0 ENGINE, GAS, 4 CYL, 1.6L, MFI, OHC, HO
LA2 ENGINE, GAS, 8 CYL, 4.5L, MFI
LAS ENGINE, GAS, 6 CYL, 3.0L, TURB0
LX8 ENGINE, DIESEL, 4 CYL, 2.OL TURBO
LY5 ENGINE, GAS, 4 CYL 1.6L 2BBL REGULAR FUEL
LY9 ENGINE, GAS, 3 CYL 1.OL 2BBL OHC, SUZUKI
L01 ENGINE, GAS, 4 CYL 1.6L MFI, OHC
L03 ENGINE, GAS, 8 CYL 5.OL TBI
L04 ENGINE, DIESEL, 4 CYL, 3.0L
L05 ENGINE, GAS, B CYL, 5.7L, 1 TBI, V8
L11 ENGINE, GAS, 4 CYL, 1.9L, PREMIUM FUEL
L17 ENGINE, GAS, 4 CYL, I.6L, 2BBL
L19 ENGINE, GAS, 8 CYL, 7.4L, 1TBI, VB
L22 ENGINE, GAS, 6 CYL, 4.1L, 1BBL
L25 ENGINE, GAS, 6 CYL, 4.BL, 1BBL
L26 ENGINE, GAS, 8 CYL, 4.9L, MFI, V8
L27 ENGINE, GAS, 6 CYL, 3.8L, MFI, V6, HO (3800 SERIES)
L32 ENGINE, GAS, 6 CYL, 3.4L, MFI, V6
L34 ENGINE, GAS, 4 CYL, 2 OL, MFI, DOHC
L35 ENGINE, GAS, 6 CYL, 4 3L, CPI, V6, 90 DEG
L37 ENGINE, GAS, 8 CYL, 4.6L, V8 OHC
L38 ENGINE, GAS, 4 CYL, 2.SL, 1 TBI, HO
L40 ENGINE, GAS, 4 CYL, 2.3L, MFI SOHC
L44 ENGINE, GAS, 6 CYL, 2.8L, MFI V6, HO
L48 ENGINE, GAS, 4 CYL, 1.4L, MFI, PREMIUM FUEL
L49 ENGINE, DIESEL, 8 CYL, 6. SL
L54 ENGINE, GAS, 4 CYL, 1.8L, MFI, REG FUEL
L65 ENGINE, DIESEL, 8 CYL, 6.5L. TURB0, HO
L67 ENGINE, GAS, 6 CYL, 3.8L, YFI, V6, SUPERCHARGED
L68 ENGINE, GAS, 4 CYL, 2.5L, 1 TBI, SHORTER LENGTH
L69 ENGINE, GAS, 8 CYL, 5.OL, 4BBL, HO
L73 ENGINE, GAS, 4 CYL, I 6L, T8I, REGULAR FUEL
L78 ENGINE, ALCOHOL, 4 CYL, 2.0L, MFI, OHC
L80 ENGINE, GAS, 6 CYL, 2.5L, MFI, HO
L82 EN6INE, GAS, 6 CYL, 3.lL, MFI, V6, HO
L91 ENGINE, GAS, 4 CYL, I.6 L, UFI, WHC
L92 ENGINE, DIESEL, 4 CYL, 1.9 L, TURBO
L93 ENGINE, DIESEL, 6 CYL, 2.5L, TURB0
L96 ENGINE, GAS, 8 CYL, 5.7L, MFI
MAE MARKETING AREA, EUROPE
MAG MARKETING AREA, GULF STATES
MAI MARKETING AREA, ISRAEL
MAJ MARKETING AREA, JAPAN
MAK MARKETING AREA, ENGLAND UNITED KINGDOM)
MAQ MARKETING AREA, IRAQ
MAS MARKETING AREA, SAUDI ARABIA
MAU MARKETING AREA, UNREGULATED
MB1 TRANSMISSION, MAN 5 SPD, BORG WARNER, 76MM, 4.03
MB4 TRANSMISSION, MAN 5 SPD, BORG WARNER, 77MM, 3.76
MB6 TRANSMISSION, MAN 5 SPD, BORG WARNER, 76MM, 4.03
MC0 TRANSMISSION, MAN 4 SPD, GETRAG, 64MM, 1ST, 4.00
MC4 TRANSMISSION, MAN 5 SPD, BORG WARNER, 77MM, 3.35
MC5 TRANSMISSION, MAN 5 SPD, B0RG WARNER, 774M, 2.55
MC9 TRANSMISSION, MAN 4 SPD, B0RG WARNER, 77MM, 4.03
MD2 TRANSMISSION, AUTO 3 SPD, STRASBOURG, THM 180C,
MD3 TRANSMISSION, AUTO 3 SPD, STRASBOURG, THM 180, OPEN
MD5 TRANSMISSION, MAN 5 SPD, GETRAG, 76MM, 3.92 IST,
MD8 TRANSMISSION, AUTO 4 SPD, THM 700 R4
MD9 TRANSMISSION, AUTO 3 SPD, THU 125 CLUTCH
ME2 TRANSMISSION, MAN 5 SPD, NEW PROCESS 55OO, 6.29
ME9 TRANSMISSION, AUTO 4 SPD, THM 440 T4
MF2 TRANSMISSION, MAN 4 SPD, B0RG WARNER, 774M, 3.76
MF4 TRANSFER CASE, NP205, 1.96 LO RANGE
MG1 TRANSMISSION, MAN 5 SPD, MUNCIE, 76MM 3.50 1ST,
MG2 TRANSMISSION, MAN 5 SPD, GETRAG, 76MM 3.50 1ST,
MG3 TRANSMISSION, MAN 5 SPD, MUNCIE, 76MM, 3.92 1ST,
MG4 TRANSMISSION, MAN 5 SPD, ISUZU, 72MM, 3.41 1ST,
MGS TRANSMISSION, MAN 5 SPD, GETRAG, 84MM, 4.00 1ST,
MH1 TRANSMISSION, AUTO 4 SPD, THM F-4, ELECTRONIC CONV
MH2 TRANSMISSION, MAN 5 SPD, BORG WARNER, 77MM, 3.50
MH3 TRANSMISSION, MAN 5 SPD, BORG WARNER, 77MM, 3.50
MH5 TRANSMISSION, MAN 4 SPD, DOUG NASH CO, 83MM, 2.88
MK2 TRANSMISSION, MAN 4 SPD, DOUG NASH CO, 83MM, 2.88
MK4 TRANSMISSION, MAN 5 SPD, B0RG WARNER, 77MM, 3.76
MK5 TRANSMISSION, MAN 5 SPD, B0RG WARNER, 77MM, 3.50
MK6 TRANSMISSION, MAN 5 SPD, B0RG WARNER, 2.95 1ST, O/D
MK7 TRANSMISSION, MAN 5 SPD, ISUZU, 3.91 IST, 1.45 3RD,
ML2 TRANSMISSION, MAN 5 SPD, B0RG WARNER, 77MM, 4.03
ML3 TRANSMISSION, MAN 5 SPD, B0RG WARNER, 77MM, 3.76
ML8 TRANSMISSION, MAN S SPD, BORG WARNER, 77MM , 3 SO
ML9 TRANSMISSION, MAN 6 SPD, ZF, 90UM, 2.66 IST, O/D
MM3 MERCHANDISED TRANS, MAN 3 SPD PROVISIONS
MM4 MERCHANDISED TRANS, MAN 4 SPD PROVISIONS
MM5 MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
MPW TRANSMISSION, MAN 4 SPD, B0RG KARNER, IO9MM, 4.02
MR2 TRANSMISSION, MAN 4 SPD, MUNCIE, 76MM, 3.50 1ST,
MR3 TRANSMISSION, MAN S SPD, ISUZU, 76MM, 3.73 1ST,
MR8 TRANSMISSION, MAN 5 SPD, ISUZU, 76MM, 3.73 1ST,
MS7 TRANSMISSION, AUTO 4 SPD, TOYOTA, ELECTRONIC CONV
MT1 TRANSMISSION, AUTO, 4 SPD, THM R2
MT2 TRANSMISSION, MAN 5 SPD, ISUZU 76MM, 3.72 1ST, .74
MT8 TRANSMISSION, MAN 5 SPD, NEW PROCESS, 1O9MM, 6.34
MU1 TRANSMISSION, MAN 5 SPD, HMD, 76MM, 3 77 1ST, 1.03
MV2 TRANSMISSION, MAN 5 SPD, 3.42 1ST
MV4 TRANSMISSION, AUTO THM 350, CONV CLUTCH
MV5 TRANSMISSION, MAN 5 SPD, HMD, 76MM, 3. SO 1ST, 1.03
MV9 TRANSMISSION, AUTO 3 SPD, THM 200, CONV CLUTCH
MW1 TRANSMISSION, MAN 5 SPD, 80RG WARNER, 77MM, 4.03
MW4 TRANSMISSION, MAN 5 SPD, GETRAG, 84MM, 1ST 3.54,
MW9 TRANSMISSION, AUTO 4 SPD, THM 200, CONV CLUTCH
MXO MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
MX1 MERCHANDISED, TRANS, AUTO PROVISIONS
MX2 TRANSMISSION, AUTO 3 SPD, THM 350, CONV CLUTCH 3
MX6 TRANSMISSION, MAN 4 SPD, MUNCIE, 76MM, 3.31 1ST,
MY1 TRANSMISSION, MAN 4 SPD, BRASIL, 70MM, 3.75 1ST
MY2 TRANSUISSION, MAN S SPD, HMD, 85MM, 4.D2 1T, O/D
MY5 TRANSMISSION, MAN 5 SPD, HMD, 3.50 1ST, 1.03
MY6 TRANSMISSION, MAN 4 SPD, NEW PROCESS, 89MM, 3.09
MY7 TRANSMISSION, MAN S SPD, ISUZU, 3.92 1ST, 1.33 3RD,
MY8 TRANSMISSION, MAN 4 SPD, MUNCIE, 75MM, 3.53 1ST,
MZU TRANSMISSION, MAN 4 SPD, NEW PROCESS, 435
M08 TRANSMISSION, MAN 4 SPD, BORG ARNER, 77MM, 3.50
M10 TRANSMISSION, AUTO 4 SPD, IZUZU, ELECTRONIC CONV
M13 TRANSMISSION, AUTO 4 SPD, HMD F31
M17 TRANSMISSION, MAN 4 SPD, MUNCIE, 76MM, 3.31 1ST,
Ml9 TRANSMISSION, MAN 4 SPD, MUNCIE, 76MM, 3.53 1ST,
M20 TRANSMISSION, MAN 4 SPD, 117MM, 6.55 1ST
M21 TRANSMISSION, MAN 4 SPD, 82MM, 2.43 1ST
M26 TRANSMISSION, MAN 4 SPD, MUNCIE, 76MM, 3.50 1ST,
M27 TRANSMISSION, MAN S SPD, GETRAG, 84MM, 2.46 1ST,
M29 TRANSMISSION, MAN 6 SPD, BORG WARNER 85MM, 2.97
M31 TRANSMISSION, AUTO THM 250 CONV CLUTCH
M32 TRANSMISSION, MAN 5 SPD ISUZU 76MM 3.72 1ST, .70
M33 TRANSMISSION, AUTO 3 SPD, TORQUE CONV
M34 TRANSMISSION, AUTO 3 SPD, THM 125
M39 TRANSMISSION, MAN 5 SPD B0RG WARNER, 77MM, 2.95
M40 TRANSMISSION, AUTO 3 SPD, TORQUE CONV VAR 1
M62 TRANSMISSION, MAN 3 SPD, 76MM, 2.85 RATIO
M64 TRANSMISSION, MAN 3 SPD, 76MM, 3.5O RATIO
M73 TRANSMISSION, MAN 4 SPD, ISUZU, 77.5MM, 4.09 RATIO
M75 TRANSMISSION, MAN 5 SPD, 77MM, 3.40 IST
M77 TRANSMISSION, MAN 4 SPD, BORG WARNER, 77MM, 4.07
M79 TRANSMISSION, MAN 5 SPD, ISUZU, 72MM, 3.41 IST,
NA1 EMISSION SYSTEM GVW, LESS THAN 85OO LB
NA2 EMISSION SYSTEM, GERMANY
NA4 EMISSION SYSTEM, GVW,AB0VE 8500 LB
NA5 EMISSION SYSTEM, FEDERAL, TIER O
NA6 EMISSION SYSTEM, HIGH ALTITUDE REQUIREMENTS
NA9 EVAPORATIVE SYSTEM, EMISSION
NB1 EMISSION SYSTEM, CLOSED LOOP
NB2 EMISSION SYSTEM , CALIFORNIA , TIER O
NB3 EMISSION SYSTEM, ABOVE IOO0O LB GVW
NB5 EXHAUST SYSTEM, SINGLE
NC3 TAILPIPE, MODIFICATIONS
NC5 EXHAUST SYSTEM, OVAL VERTICAL TAILPIPES, CHROME
NC6 EXHAUST SYSTEM, SPORTY
NC7 EMISSION OVERRIDE, FEDERAL SYSTEM
NC6 EMISSION SYSTEM, CALIFORNIA, ULEV
ND3 LABEL EMISSION, CONTROL
NE2 FUEL TANK, 151L, 40 GAL
NF2 EMISSION SYSTEM, FEDERAL, TIER 1
NH2 FUEL TANK, 113L, 30 GAL
NJ8 FUEL TANK, 129L, 34 GAL
NJ9 FUEL TANK 80 GAL LH OR RH FILL
NK3 STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER
NK4 STEERING WHEEL, SPORT LEATHER
NK5 STEERING WHEEL, STANDARD
NK7 FUEL TANK, 117L, 31 GAL
NL2 FUEL TANK, AUXILIARY
NL4 FUEL TANK, 303L, 80 GAL
NL6 FUEL TANK, 13 GAL, SINGLE
NL7 FUEL TANK,I25L, 33 GAL
NL8 FUEL TANK,I32L, 35 GAL, LH, RECT, STEEL
NL9 FUEL TANK,IO2L, 27 GAL
NM1 EMISSION SYSTEM, SWITZERLAND, SWEDEN
NM5 EMISSION SYSTEM, CANADIAN REOUIREMENTS
NM6 EMISSION SYSTEM, RECALIBRATED
NM8 LEADED FUEL SYSTEM,
NN1 EMISSION SYSTEM, DUAL BED MONOLITH CONV
NN4 FUEL TANK, 227L, 60 GAL
NN5 EMISSION OVERRIDE, CALIFORNIA SYSTEM, FEDERAL
NN7 LOCK, FUEL FILLER DR ---- DELETE
NN8 EMISSION OVERRIDE, UNLEADED FUEL, EXPORT
NN9 EMISSION SYSTEM, LEADED FUEL, EXPORT
NPG SHIELD, NOISE ABATEMENT
NP1 TRANSFER CASE, ELECTRONIC SHIFT CONT, TWO SPEED
NP5 STEERING WHEEL, LEATHER WRAPPED
NP7 STEERING COLUMN, EEC APPROVED
NQE FUEL TANK,20 GAL, SINGLE
NQ5 CAP, STRG WHL HORN, DELUXE
NV5 SHIELD, DIFFERENTIAL CARRIER
NV7 STEERING, POWER, VARIABLE EFFORT
NWO WHEEL, 16 X 6.5, CAST ALUMINUM
NW9 TRACTION CONTROL, ELECTRONIC
NXX EVAPORATIVE SYSTEM, FEDERAL
NX1 WHEEL, I3 X 5.5, LIGHT METAL ALLOY
NXB WHEEL, 14 X 6, LIGHT 4ETAL ALLOY
NY1 SHIELD, FUEL TANK
NY7 SHIELD, TRANSFER CASE
NZZ SALES PACKAGE, SKID PLATE OFF ROAD SPOT
N04 LOCK CONTROL, FUEL FILLER CAP, REM CONT
N05 LQCK CONTROL, FUEL FILLER CAP
N08 LQCK CONTROL, FUEL FILLER DR REM CONT
N09 LOCK CONTROL, FUEL FILLER DR
N10 EXHAUST SYSTEM DUAL
N14 CONVERSION METHANOL FUEL
N18 COVER SIMULATED WIRE WHEEL, LOCKING PACKAGE
N23 FUEL TANK, 83L, 22 GAL
N24 WHEEL I5 X 7 ALUMINUM CAST, 5 INCH BOLT CIRCLE
N25 EXHAUST, EXTENSION
N27 STEERING WHEEL, 2 SPOKES STD
N31 STEERING WHEEL, CUSTOM
N33 STEERING COLUMN, TILT TYPE
N34 STEERING WHEEL, WOOD GRAINED PLASTIC
N36 STEERING WHEEL, 4 SPOKES, SPORT
N37 STEERING COLUMN, TILT, TELESCOPING
N40 STEERING, POWER, NON-VARIABLE RATIO
N41 STEERING, POWER, VARIABLE RATIO
N45 STEERING WHEEL, 3 SPOKES
N46 STEERING WHEEL, FOUR SPOKES
N51 STEERING, MANUAL
N54 STEERING WHEEL, 3 SPOKE, SPORT
N60 WHEEL, ALUMINUM, PAINTED
N64 WHEEL & TIRE,SPARE, SPACE SAVER, ALUMINUM
N65 WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
N66 WHEEL, RALLY TYPE , VARI
N67 WHEEL, RALLY TYPE , VAR2
N68 WHEEL, I5 X 5.5, CHROME
N70 WHEEL, I3 X 5.5
N72 WHEEL, CUSTOMER PROPERTY
N73 WHEEL, CUSTOM SPORT, VAR 4
N77 WHEEL, 16 X 7, STEEL STYLED
N78 WHEEL, I4 X 6, ALUMINUM, HUB CAP, WHEEL NUTS
N81 TIRES, SPARE FULLSIZE
N83 WHEEL, I5 X 7, CHROME STYLED
N84 TIRES, SPARE ---- DELETE
N85 WHEEL, 14 X 6 HD
N89 WHEEL, TURBO ALUMINUM
N90 WHEEL, 15 X 7,ALUMINUM CAST,4.75 INCH BOLT CIRCLE
N91 COVER, SIMULATED WIRE WHEEL, LOCK
N95 COVER, SIMULATED WIRE WHEEL
N96 WHEEL, I6 X 8, CAST ALUMINUM
N97 WHEEL, 15, HD
N98 WHEEL, CHROME, VAR 2
N99 WHEEL, HEAVY DUTY
PA1 COVER, WHEEL, VAR 5
PA3 WHEEL, 15 X 7, ALUMINUM, STYLED
PA4 COVER, WHEEL, PAINTED
PA5 HUBCAPS, WHEEL
PA6 WHEEL, STYLED, PAINTED
PB1 COVER, WHEEL 15 INCH
PB2 COVER, WHEEL TRIM ABS, PLASTIC
PB3 HUBCAPS, COVERS & RETAINERS
PB4 LOCK CONTROL, WHEEL
PB5 WHEEL, 13 X 5.5, MILD STEEL
PB6 WHEEL, INCREASED SIZE
PB7 WHEEL, 14 X 6, PAINTED
PB9 WHEEL, 14 X 5.5, STEEL
PC1 WHEEL, 14 X 6, STEEL
PC2 WHEEL, 14 X 7, STEEL, STYLED
PC3 WHEEL, 14 X 7, STEEL
PC4 WHEEL, 14 X 6, STEEL, STYLED
PC5 WHEEL, 15 X 7, STEEL, STYLED
PC6 WHEEL, 14 X 5.5, LIGHT METAL ALLOY
PC7 WHEEL, 14 X 5.5, STYLED, STEEL
PC8 WHEEL, 13 X 5.5, STEEL STYLED PAINTED
PD4 WHEEL, 15 X 7, LIGHT METAL ALLOY, 5 SPOKES
PD7 WHEEL, 14 X 6.5, CAST ALUMINUM
PD8 WHEEL, 14 X 6, ALUMINUM STYLED
PD9 WHEEL, 13 X 5, MILD STEEL
PE0 WHEEL, 16 X 8, ALUMINUM, LIGHT WEIGHT, STYLED
PE1 WHEEL, 14 X 7, ALUMINUM STYLED
PE7 WHEEL, 13 X 5.5, TRIANGULAR HOLES
PF1 WHEEL, 15 X 6, STEEL STYLED
PF2 WHEEL, 15 X 7, ALUMINUM
PF3 WHEEL, 15 X 6.5, ALUMINUM
PF4 WHEEL, 16 X 7, ALUMINUM
PF5 WHEEL, 16 X 7, LIGHT METAL ALLOY
PF6 WHEEL, 15 X 6.5, ALUMINUM, STYLED
PF7 WHEEL, 15 X 6, ALUMINUM CAST, STYLED
PF8 WHEEL, I4 X 6, STEEL, STYLED, 4 SPOKE
PG0 WHEEL, 16 X 6, ALUMINUM, STYLED
PG1 WHEEL, 15 X 6, STEEL
PG2 WHEEL, 15 X 5.5, STEEL
PG4 WHEEL, 14 X 5.5, ALUMINUM
PG5 WHEEL, 15 X 6, ALUMINUM CAST
PG9 WHEEL, 15 X 6, LIGHT METAL ALLOY
PH0 WHEEL, 15 X 6 FRT, X 7 RR, ALUMINUM
PH1 WHEEL, 15 X 7, STEEL
PH3 WHEEL, 15 X 6, ALUMINUM CAST, 115MM BOLT CIRCLE
PH4 WHEEL, 14 X 5, LIGHT METAL ALLOY
PH5 WHEEL, 14 X 6, ALUMINUM
PH6 WHEEL, 15 X 6, ALUMINUM
PH8 WHEEL, 15, WIRE SPOKE
PNV CARRIER, OUTSIDE SPARE TIRE MOUNT NOT DESIRED
PRA SALES PROCESSING OP, POSTAL SERVICE, COMPANION, AAA
PW7 WHEEL, 16 X 8, ALUMINUM, STYLED
PW8 WHEEL, 15 X 6, ALUMINUM, STYLED
PW9 WHEEL, 16 X 9.5, CAST ALUMINUM
PX0 WHEEL, 16 X 7, ALUMINUM, STYLED
PX1 WHEEL, 13 X 5.5 ALUMINUM
PX3 WHEEL, 13 X 5, LIGHT METAL ALLOY
PY0 WHEEL, 16 X 6.5, ALUMINUM
PY3 WHEEL, 16 X 8.5, CAST ALUMINUM
PY4 WHEEL, 14 X 5.5, LIGHT METAL ALLOY
PY6 WHEEL, 13 X 4.5 ALUMINUM
P01 TRIM DISCS, WHEEL, VAR 1
P02 TRIM DISCS, WHEEL, VAR 2
P03 COVER, WHEEL, VAR 3
P04 TRIM DISCS, WHEEL----DELETE
P05 WHEEL, CHROME, VAR 1
P08 COVER, SUPER DELUXE WHEEL
P11 CARRIER, GLIDE OUT SPARE TIRE
P12 WHEEL, 14 X 6, CHROME
P13 CARRIER, SIDE MOUNTED SPARE WHEEL
P14 CARRIER, INSIDE MOUNTED, SPARE TIRE, LH
P15 CARRIER, INSIDE MOUNTED, SPARE TIRE, RH
P16 CARRIER, RR MOUNTED, SPARE TIRE
P17 COVER SPARE, WHEEL
P18 CARRIER, SPARE TIRE, WITH HOIST
P20 HUBCAPS, WHEEL, STYLED
P41 TIRES, EEC SPECIAL SIDE WALL
P42 TIRES, SELF SEALING
P43 INFLATOR, SPARE TIRE ---- DELETE
QAB TIRE ALL, Pl9S/70R14/N BL R/PE ST TL ALS
QA1 WHEEL, 17 X 9 S, ALUMINUM, STYLED
OA2 WHEEL, 17 X 9.5 FRT X 11 RR, ALUMINUM, STYLED
QA3 WHEEL, 16 X 6.0, STEEL
QA4 WHEEL, 15 X 5.5, ALUMINUM
QBE TIRE ALL, LT235/75R15C WL R/PE ST TL OOR
OBK TIRE ALL, P155/BOR13/N BL R/PE ST TL ALS (959127B)
OBN TIRE ALL, LT245/75R16/C BW R/PE ST TBL OOR
OBX TIRE ALL, LT245/75R16/C WOL R/PE ST TEL OOR
QBZ TIRE ALL, P205/SSVR16/N BL R/PE ST TL HWY
QB4 WHEEL, 16 X 6, ALUMINIUM
QB5 WHEEL, 16 X 6. 5, STEEL
QB6 WHEEL, 17 X B 5 FRT X 9.5 RR, ALUMINUM, STYLED
QCE TIRE ALL, P205/75R15/N BL R/PE ST TL ALS
QCF TIRE ALL, P205/75R15/N RWL R/PE ST TL ALS
QCG TIRE ALL, P205/75R15/N WS2 R/PE ST TL ALS
QCR TIRE ALL, P205/70R13/N BL R/PE ST TL ALS
QCS TIRE ALL, P205/70R13/N WS1 R/PE ST TL ALS
QCT TIRE ALL, P205/70R13/N RWL R/PE ST TL ALS
QCU TIRE ALL, P215/75RlS/N BL R/PE ST TL ALS
QCV TIRE ALL, P215/75R15/N WS2 R/PE ST TL ALS
QCW TIRE ALL, P215/75R15/N RWL R/PE ST TL ALS
QDP TIRE ALL, P195/70RlS/N BL TBL R/PE ST AL3
QDZ TIRE ALL, P245/SOVR16/N BL R/PE ST TL HW4
QEB TIRE ALL, P235/75R15/N WOL R/PE ST TL OOR
QEE TIRE ALL, P205/65R15 BL R/PE ST TL ALS 925
QER TIRE ALL, P205/65R15 WS2 R/PE ST TL ALS 925
QET TIRE ALL, P225/75R15/N BL R/PE ST TL ALS
QEU TIRE ALL, P225/75R15/N WS2 R/PE ST TL ALS
QFE TIRE ALL, P185/75R14/N BL R/PE ST TL ALS
QFF TIRE ALL, P185/75R14/N WS2 R/PE ST TL ALS
QFL TIRE ALL, P235/75R15 BW R/PE ST TL ALS lOSS
QFN TIRE ALL, P235/75R15 WL R/PE ST TL ALS lOSS
QFT TIRE ALL, P205/75R14/N BL R/PE ST TL ALS
QGK TIRE ALL,165/605R14 BL R/ST TL 113 745 (OVERSEAS)
QGL TIRE ALL,175/655R14 BL TL R/ST 113 B1S (OVERSEAS)
QGM TIRE ALL,175R14 BL TL R/ST HWY 190 BBT (OVERSEAS)
QGW TIRE ALL, P215/60R16/N BL R/PE ST TL AL3
QGY TIRE ALL, P205/70R15/N BL R/PE ST TL ALS
QGZ TIRE ALL, P205/70R15/N WS R/PE ST TL ALS
QHA TIRE ALL, P235/75R15/X BW R/PE ST TL ALS
QHB TIRE ALL, P235/75R15/X WS2 R/PE ST TL ALS
QHE TIRE ALL, l9S/65R15/N BL R/ST TL HWY (9OH 1304PH
QHF TIRE ALL, P205/60R15/N BL R/PE ST TL AL3
QHH TIRE ALL, P205/60R15/N WOL R/PE ST TL AL3
QHJ TIRE ALL, P225/70R15/N WS1 R/PE ST TL HWY
QHP TIRE ALL, LT225/75R16/D BW R/PE ST TL ALS
QHR TIRE ALL, LT225/75R16/D BW R/PE ST TL OOR
QHS TIRE ALL, P185/80R13/N BL R/PE ST TL ALS
QHT TIRE ALL, P185/80R13/N WS1 R/PE ST TL ALS
QHX TIRE ALL, P205/70R14/N BL R/PE ST TL ALS
QHY TIRE ALL, P205/70R14/N WS2 R/PE ST TL ALS
QID TIRE ALL, LTl9S/75R14/C BL R/PE ST TL ALS
QIE TIRE ALL, P165/70R12/N BL R/PE ST TL ALS
QIF TIRE ALL, P185/60R14/N BL R/PE ST TL ALS
QII TIRE ALL, P215/60R16 8W R/PE ST TL AL3 94H
QIM TIRE ALL, P205/60R15/N BL R/PE ST TL AL2 90S
QIN TIRE ALL, P205/70R15/N BL R/PE ST TL AL2 955
QIP TIRE ALL, P205/70R15/N WS2 R/PE ST TL AL2 9SS
QIQ TIRE ALL, P205/60R15 WOL R/PE ST TL AL2 90S
QIT TIRE ALL, LT245/75R16/C BL R/PE ST TL ALS
QIW TIRE ALL, LT245/75R16/E BL R/PE ST TL OOR
QIX TIRE ALL, LT265/75R16/C BL R/PE ST TL OOR
QIY TIRE ALL, LT265/75R16/C WOL R/PE ST TL OOR
QIZ TIRE ALL, LT245/75R16/E BL R/PE ST TL ALS
QJA TIRE ALL, P215/60HR14/N BL R/ST TL HWY (OVERSEAS)
QJI TIRE ALL, Pl85/70R14/N BL R/NY TL HWY
QJJ TIRE ALL, 31XlO.SORlSLT/C BW R/PE ST TL OOR
QJL TIRE ALL, P205/75R15/N WOL R/PE ST TL OOR
QJR TIRE ALL, P205/75R14/N WS2 R/PE ST TL ALS
QJT TIRE ALL, P205/75R15/N BL R/PE ST TL OOR
QJV TIRE ALL, LT225/75R15/C BL R/PE ST TL ALS
QLC TIRE ALL, P245/SOZR16/N BL R/PE ST TL HW4
QLG TIRE ALL, P205/SSR16/N BL R/PE ST TL AL3
QLM TIRE ALL, P215/60R15/N BL R/PE ST TL ALS
QLU TIRE ALL, P225/55VR16/N BL R/PE ST TL HWY
QLV TIRE ALL, P225/75R15/N WS2/GOLD R/PE ST TL ALS
QLW TIRE ALL, 175R14 BL TL R/ST ALS 120MPH/BBT OVERSEAS
QMB TIRE ALL, P215/60R14/N BL R/PE ST TL AL3
QME TIRE ALL, Pl9S/70R14/N BL R/PE ST TL AL2
QMG TIRE ALL, P215/60R14/N WOL R/PE ST TL AL3
QMR TIRE ALL, P205/65R15/N BL R/PE ST TL AL2
QMS TIRE ALL, P205/SSR16 BL R/PE ST TL AL2 B9S
QMT TIRE ALL, P235/SSR16/N BL R/PE ST TL AL2
QMV TIRE ALL, P235/70R15 WS1 R/PE ST TL AL2 1025
QMW TIRE ALL, Pl9S/75R14/N BL R/PE ST TL ALS
QMX TIRE ALL, P195/75R14/N WS2 R/PE ST TL ALS
QNJ TIRE ALL, P215/65R15 BW R/PE ST TL AL3 95H
QNM TIRE ALL, P225/70R15/N BL R/PE ST TL AL2
QNP TIRE ALL, P2Z5/70R15/N WS1 R/PE ST TL AL2
QNR TIRE ALL, P215/65R15/N WS2 R/PE ST TL AL3
QNS TIRE ALL, P215/65R15/N BL R/PE ST TL AL3
QNT TIRE ALL, P215/65R15/N WOL R/PE ST TL AL3
QNX TIRE ALL, P225/60R16/N BL R/PE ST TL AL2
QNY TIRE ALL, P225/60R16/N WS1 R/PE ST TL AL2
QPC TIRE ALL, PlBS/65HR14/N BL R/ST TL HWY (OVERSEAS)
QPD TIRE ALL, Pl9S/65Rl5/N BL R/PE ST TL AL2 B9S
QPE TIRE ALL, P215/60R16/N BL R/PE ST TL AL2
QPH TIRE ALL, P215/65R15/N BL R/PE ST TL AL2
QPJ TIRE ALL, P215/65R15/N WS1 R/PE ST TL AL2
QPK TIRE ALL, P215/70R15/N BL R/PE ST TL ALS 975
QPN TIRE ALL, P215/70R15/N WS2 R/PE ST TL ALS 97S
QPP TIRE ALL, P215/65R15/N WL R/PE ST TL AL3 95H
QPX TIRE ALL, P225/60R16 BW R/PE ST TL ALS 975
QPY TIRE ALL, P225/60R16 WS2 R/PE ST TL ALS 975
QQD TIRE ALL, P235/70RI5 WS2 R/PE ST TL ALS 102S
QQG TIRE ALL, P235/70R15 BL R/PE ST TL AL3 102V
QQR TIRE ALL, P235/70R15 WS1 R/PE ST TL AL3 102V
QRF TIRE ALL, lBSSR14 BL R/ TL lOS TEXTILE (OVERSEAS)
QSA TIRE ALL, P205/75R14/N RWL R/PE ST TL ALS
QUK TIRE ALL, P235/70R15/N WS2/GOLD R/PE ST TL ALS
QUS TIRE ALL, lBS/60HR14 BL R/ST TL 130 (OVERSEAS)
QVF TIRE ALL, P225/60ZR16/N BL R/PE ST TL AL3
QVG TIRE ALL, P225/60R16/N BL R/PE ST TL AL3 97H
QVI TIRE ALL, P175/BDR14 BW R/PE ST TL ALS BBS
QWT TIRE ALL, P245/60R15 WOL R/PE ST TL AL3 lOOT
QXJ TIRE ALL, P225/60R16/N BL R/PE ST TL AL3 97U
QYH TIRE ALL, P215/65R15/N WOL R/PE ST TL HWY
QYZ TIRE ALL, P215/65R15/N BL R/PE ST TL HWY
QZY TIRE ALL, P255/SOZR16/N BL R/PE ST TL HW4
Q34 WHEEL SPARE l9.5 X 6
Q4B GVW RATING 6200 LBS
RC1 TURBO PERFORMANCE SPECIFIC EQUIPMENT
RC2 LAMP GROUP COMPONENTS
RRL WHEEL FRT, 22.5 X 6.75 6 HOLE 8.75 BC BS DCT
RRM WHEEL RR, 22.5 X 6.75 6 HOLE 8.75 BC BS DCT (FI-277B)
R04 WHEEL SINGLE RR
R05 WHEEL DUAL RR
R1P CHASSIS EQUIPUENT HEAVY DUTY, COACHBUILDER/LIVERY
R1U CONVERSION, AUTO-FAB INC.
R1V APPEARANCE PACKAGE
R1W NOISE CONTROL, AIR CLEANER, ECU
R1X NOISE CONTROL, AIR CLEANER, ECU, EXH INTER PIPE
R10 MANUAL, ROADSIDE SERVICE INFO
TA6 RESISTOR, HEADLAMP LW BEAM
TB2 FENDERS, FRT
TL1 GRILLE, SPECIAL
TL4 GRILLE, PAINTED
TL6 GRILLE BLACK
TL8 ORNAMENTATION , EXTR MLDG HOOD,
TNQ BATTERY, ONE DELCO II5O 12V
TPS FANILY CODE, ROOF COVERING
TP2 BATTERY, AUX, CAMPER
TP5 REFLECTOR, BUMPER
TR1 LAMP, TAIL & STOP
TR2 LAMP,TURN SIGNAL, ENLARGED
TR4 HEADLAMPS, RECTANGULAR
TR6 HEADLAMPS CONTROL, LEVELING SYSTEM, MANUAL
TR7 HEADLAMPS CONTROL, LEVELING SYSTEM, AUTOMATIC
TR9 LAMP, GROUP
TS6 LAMP, STOP, HIGH LEVEL
TS8 REFLECTOR, BODY SI
TT4 HEADLAMPS, HALOGEN, 4
TTS HEADLAMPS, HALDGEN, 2
TU2 LAMP, MARKER, SIDE
TU6 HEADLAMPS CONTROL, FLASH TO PASS
TUB LAMP, INTR, STOP, HIGH LEVEL ---- DELETE
TVR LAMP, REAR DOME AND READING
T1A IDENTIFICATION, STEERING COLUUN EXPORT REQM'TS
T1B ORNAMENTATION , EXTR, CADILLAC SPRING EDITION
T1J FASCIA,'H' T-TYPE SPECIFICS
T1S SPEEDOMETER, 120 MPH
T1U PACKAGE, DRIVER CONFIDENCE
T1X CONVERSION, EXPORT COMPOSITE HEADLAMP REQM'TS
T2F BRAKE PROVISIONS, SPECIAL
T2G ROOF COVERING, SIMULATED CONVERTIBLE, CAMBRIA
T2H ORNAMENTATION, EXTR, EXPORT UNIQUE REQUIREMENTS
T2J ORNAMENTATION, INTR, EXPORT UNIQUE REQUIREMENTS
T2L IDENTIFICATION ISO SYMBOLS
T2U SHAFT, FRONT STABILIZER, SOLID
T2N SHAFT, FRONT STABILIZER, TUBULAR
T2R LOCK CONTROL, REMOTE FREQ --- DELETE
T2T CONTROL, REMOTE ILLUM ENTRY, RETAINED ACSRY PWR
T2V CONTROL STEERING, TWO FLOW ELECTRONIC
T2W WIRING HARNESS, HI/LOW BEAM, EXPORT
T37 LAMP, FOG, DELUXE
T3B LAMP, PARK & TURN SIGNAL
T39 LAMP, TURN SIGNAL, AUX
T43 SPOILER, RR
T46 HOOD, STEEL
T47 HOOD TURBO
T52 ORNAMENTATION, EXTR FRT FENDER
T53 LAMP PACKAGE, EMER VEH R/CMPT LID
T61 LIGHTING, DAYTIME RUNNING
T63 ALARM, HEADLAMPS ON WARNING SYSTEM
T72 HEADLAMPS, LH RULE OF THE ROAD, EXPORT
T73 HEADLAMPS, RH RULE OF THE ROAD, EXPORT
T75 HEADLAMPS, AUBER
T76 HEADLAMPS, REPLACEABLE BULB TYPE
T77 HEADLAMPS, 2
T79 LAMP, FOG, RR
T80 HEADLAMPS, AUTO BEAM CONT
T81 LAMP, TAIL AND STOP DELUXE
T82 HEADLAMPS, AUTO ON-OFF CONT
T83 HEADLAMPS, DR, SPECIAL
T84 HEADLAMPS, RH RULE OF ROAD, EXPORT
T85 HEADLAMPS, LH RULE OF ROAD, EXPORT
T86 LAMP, BACKUP, PAINTED
T87 LAMP, CORNERING
T88 LAMP, PARKING
T89 LAMP, TAIL & STOP, EXPORT
T90 LAMP, SIGNALING & MARKER EXPORT
T93 LAMP, TAIL & STOP, SPECIAL
T96 LAMP, FOG
UA6 THEFT DETERENT SYS
UBO CLUSTER, INST, OIL, TEMP,TACH ,TURBO BOOST
UB2 CLUSTER, INST, OIL, VOLTS ,TACH ,TURBO BOOST
UB3 CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM,
UB4 LAMP, SIDE MARKER, BOXED FOR SHIPMENT
UB7 CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM,
UB8 HORN, HIGH NOTE
UC3 COMPASS, ELECTRONIC
UD1 CLUSTER, INST, OIL, COOL TEMP
UD2 ALARM, VEHICLE SPEED, 105 K/H
UD4 ALARM, VEHICLE SPEED, 120 K/H
UD6 ALARM, EXHAUST TEMP
UD8 CLOCK, VACUUM FLUORESCENT DIGITAL
UE6 SWITCH, HEADLAMPS
UE8 CLOCK, ELECTRIC, DIGITAL
UF2 LAUP, CARGO
UF3 SWITCH, HIGH IDLE
UF6 LAMP, INTR, CONSOLE, COURTESY
UF7 CLUSTER, INST, OIL, COOL TEMP, VOLTS, FUEL ECON
UH1 INDICATOR, SYS, WARNING LIGHTS
UH6 CLUSTER, INST, OIL, COOL TEMP, VOLTS, INDICATORS
UH7 CLUSTER, INST, COOL TEMP
UH9 CLUSTER, INST, COOL TEMP, TRIP ODOM, TURBO
UJ1 INDICATOR, SYSTEM, BRAKE WARNING
UJ2 INDICATOR, ENGINE OIL LIFE
UJ3 INDICATOR, WATER IN FUEL
UJ5 CLUSTER INST, COOL TEMP, TRIP ODOM, VOLTS
UJ6 INDICATOR, LW TIRE PRESS
UJ9 CLUSTER, INST COOL TEMP, VOLTS, TACH
UK1 FREQUENCIES, JAPANESE RADIO
UK2 LEVER DIRECTIONAL SIGNAL, INCLUDES MULTI FUNCTIONS,
UK3 ELECTRONIC SYSTEM, ACCESSORY CONT
UK4 RADIO, AM/FM STEREO, SEEK/SCAN, ETR
UK5 RADIO, AM/FM STEREO, SEEK/SCAN AUTO REV CASS, ETR
UL1 RADIO, AM/FM STEREO CLOCK ETR
UL2 FREQUENCIES, EUROPEAN RADIO
UL5 RADIO, DELETE
UL6 RADIO, AM, CLOCK, MTR
UL9 RADIO, AM/FM STEREO, PB, CASS CLOCK MTR
UM3 RADIO, AM STEREO-FM STEREO, SEEK/SCAN, COMPACT
UM6 RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS,
UM7 RADIO, AM/FM STEREO, SEEK/SCAN, CLOCK, ETR
UN3 RADIO, AM/FM STEREO, CASS, MTR
UN4 TAPE CARTRIDGE ---- DELETE
UN5 RADIO, AM/F4 STEREO, SEEK/SCAN, AUTO REV CASS, CB,
UN6 RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC
UN8 RADIO, CITIZENS BAND
UN9 RADIO, SUPPRESSION EQUIPMENT
UP2 RADIO, AM STEREO & FM STEREO, SEEK/SCAN, CLOCK, ETR,
UP4 RADIO AM, ETR
UP5 RADIO AM STEREO-FM STEREO-WX, SEEK/SCAN, AUTO REV
UP7 RADIO PROVISIONS, FOR MONO INSTRUMENTATION
UP9 RADIO PROVISIONS, FOR STEREO INSTRUMENTATION
UQ0 SPEAKER SYSTEM, 4, DUAL FRT DR MTD, DUAL STD RGE
UQ1 RADIO PROVISIONS, FOR STEREO
UQ2 SPEAKER SYSTEM, 6, DUAL F/D MIR PATCH TWT, DUAL F/D
UQ3 SPEAKER SYSTEM, PERFORMANCE ENHANCED AUDIO
UQ4 SPEAKER SYSTEM, BOSE, 4
UQ5 SPEAKER SYSTEM, 4, DUAL FRT DR MTD, DUAL EXTD RGE
UQ6 SPEAKER SYSTEM, 5, DUAL I/P, SAIL MTD COAX
UQ7 SPEAKER SYSTEM, 5, DUAL I/P, SAIL MTD STD SPEAKER
UQ8 SPEAKER SYSTEM, 4, DUAL FRT EXTD RGE, DUAL EXTD RGE
UQ9 SPEAKER SYSTEM, DELETE
UR3 INDICATOR, FUEL ECONOMY
UR5 INDICATOR, LOW ENGINE OIL
US6 ANTENNA, FIXED, PAINTED, RADIO
US7 ANTENNA, POWER, PAINTED RADIO
UT0 RADIO, AM STEREO/FM STEREO, SEEK/SCAN, AUTO REV
UT1 TONE GENERATOR, WARNING
UT2 RADIO, AM/FM STEREO, P3, SEEK/SCAN CLOCK ETR
UT3 RADIO, AM/FM STEREO , SEEK/SCAN, AUTO REV CASS
UT5 RADIO, AM, CLOCK, ETR
UT6 RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC
UT7 RADIO, AM/FM STEREO, PB, DOLBY , ETR
UU0 RADIO, AM STEREO & FM STEREO SEEK/SCAN AUTO REV
UU1 RADIO, AM/FM STEREO-FM STEREO-WX,SEEK/SCAN, COMPACT
UU2 RADIO, AM/FM STEREO, CASS, DOLBY, ETR
UU6 RADIO, AM/FM STEREO, SEEK/SCAN AUTO REV CASS
UU7 RADIO, AM/FM STEREO, CASS, CLOCK ETR
UU9 RADIO, AM/FM STEREO, ETR
UV1 ALARM, VOICE REMINDER
UV4 DISPLAY COMPASS AND RALLY TSD INFO
UV5 DISPLAY , SERVICE REMINDER
UV6 DISPLAY HEAD UP
UV8 TELEPHONE, PROVISIONS FOR MOSILE
UV9 TELEPHONE, MOBILE 6000 SERIES
UW0 SPEAKER SYSTEM, 4, DUAL I/P MTD, DUAL ROOF MTD
UW1 DIAGNOSTIC SYSTEM
UW4 SPEAKER SYSTEM, 6, DUAL FRT DASH MTD F/D, DUAL
UW5 SPEAKER SYSTEM, 6, DUAL I/P MTD, DUAL STD RGE PASS
UW6 SPEAKER SYSTEM, 6, DUAL F/D TWEET & WWF, DUAL EXT
UW7 RADIO, AM STEREO & FM STEREO SEEK/SCAN AUTO/REV
UW8 HOUSING GARAGE DOOR OPENER, REM CONT
UW9 GARAGE DOOR OPENER, REM CONT, INCLUDING HOUSING
UX0 SPEAKER SYSTEM, 4, DUAL FLR SILL, DUAL EXTD RANGE
UX6 SPEAKER SYSTEM, FRT DUAL
UX7 SPEAKER SYSTEM, 4, DUAL FRT DR MTD, DL EXTND RGE
UY1 WIRING PROVISIONS , CAMPER
UY2 TELEPHONE, MOBILE, 2000 SERIES
UY3 TELEPHONE, M0BILE, S.E SERIES
UY5 SPEAKER SYSTEM,4,DUAL FRT FLR SILL, DUAL EXT
UY7 WIRING HARNESS, TRUCK TRAILER HD
UY9 CLUSTER, KILO & MILES, MECHANICAL DISPLAY
UZ1 TELEPHONE, PROVISIONS FOR INTEGRATED M08ILE
UZ3 TELEPHONE, M0BILE KEYPAD CONTROL
U01 LAMP, FIVE, ROOF MARKER, TRUCK
U03 HORN, NOISE REGULATION
U05 HORN, DUAL
U08 HORN, DUAL ELECTRIC
UO9 HORN, FOUR NOTE
U1A RADIO, AM STEREO-FM STEREO, SEEK/SCAN, COMPACT
U1B RADIO, AM STEREO-FM STEREO SEEK/SCAN COMPACT
U1C RADID, AM/FM STEREO, SEEK/SCAN, COMPACT DISC
U1D RADIO, AM STEREO-FM STEREO-WX, SEEK/SCAN, COMPACT
U1E RADIO, AM STEREO & FM STEREO, SEEK/SCAN COMPACT
U1F RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC
U1G RADIO, AM STEREO/FM STEREO, P8, SEEK/SCAN AUTO REV
U1H RADIO, AM STEREO/FM STEREO, SEEK/SCAN, AUTO REV
U1J RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC
U1K RADIO, AM STEREO-FM STEREO SEEK/SCAN, DAT EQUALIZE
U1N RADIO, AM STEREO/FM STEREoiWX/TV, SEEK/SCAN AUTO
U1P RADIO, AM STEREO/FM STEREO/WX/TV, SEEK/SCAN, AUTO
U1Q RADIO, AM STEREO/FM STEREO/WX/TV, SEEK/SCAN, CD
U11 CLUSTER, INST, POLICE, CERTIFIED, SPEEDO
U12 SPEEDOMETER, DUAL SCALE WITH KILO ODOMETER
U14 CLUSTER, INST, OIL, COOL TEMP, VOLTS, GAGES
U16 TACHOMETER, ENGINE
U17 CLUSTER INST, OIL, COOL TEUP, VOLTS, CLOCK, FUEL
U19 SPEEDOMETER,INST, KILO & MILES KILO ODOMETER
U2A CLUSTER, INST, COOL TEMP, TRIP ODOM, DR INFO CTR
U2S CLUSTER, INST, OIL, COOL TEMP, TACH, TRIP ODOM
U2C CLUSTER, INST, KILO & MILES, MILES ODOM
U2D CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM
U2E CLUSTER, INST, COOL TEMP, TRIP ODOM
U2F CLUSTER, INST, OIL, COOL TEMP, TRIP ODOM, TACH
U21 CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
U22 CLUSTER, INST, OIL COOL TEMP, BATTERY, CLOCK
U23 CLUSTER, INST, TRIM ODOM
U25 LAMP, INTR, RR COMPT, COURTESY
U26 LAMP, INTR, ENG COMPT, COURTESY
U27 LAMP, INTR, I/P COMPT, COURTESY
U28 LAMP, INTR, ASH TRAY, COURTESY
U29 LAMP, INTR I/P, COURTESY
U35 CLOCK, ELECTRIC
U37 LIGHTER CIGARETTE
U38 INDICATOR, LOW COOLANT
U39 CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM
U40 DISPLAY , DIGITAL DIRECT READOUT, TRIP MONITOR
U46 MONITOR, EXTERNAL LAMP
U47 LAMP, INTR, ENG COMPT, COURTESY, EXTENDABLE
U50 CLUSTER,INST, OIL, COOL TEMP, VOLTS, TRIP ODOM
U51 DISPLAY, FUEL ECONOMY, TSD INFO, SERVICE REM INDER
U52 CLUSTER INST, ELECTRONIC
U56 PLAYER TAPE, CASSETTE
U58 RADIO, AM/FM STEREO, MTR
U63 RADIO, AM, MTR
U64 SPEAKER SYSTEM, 4, DUAL FRT DASH MTD, DUAL STD RGE
U65 SPEAKER SYSTEM, 6, DUAL FRT DASH MTD, F/D, DUAL
U66 SPEAKER SYSTEM, 4, DUAL FRT DASH MTD, DUAL EXTD RGE
U67 SPEAKER SYSTEM, 8, DUAL F/D 2 TWEET, TWO WOOF, DUAL
U68 DISPLAY,DRIVER INFO CENTER
U69 RADIO, AM/FM, MTR
U71 ANTENNA, ROOF , RADIO
U72 ANTENNA, POWER, FRT, RADIO
U73 ANTENNA, FIXED, RADIO
U74 ANTENNA, RADIO ----DELETE
U75 ANTENNA, POWER, RADIO
U76 ANTENNA, WINDSHIELD, RADIO
U77 ANTENNA, RR WINDOW, RADIO
U78 ANTENNA , POWER , RADIO/TELEPHONE TRISAND
U79 SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
U80 SPEAKER SYSTEM, RR
U81 SPEAKER SYSTEM, RR, DUAL
U83 ANTENNA, POWER, CITIZENS SAND/RADIO TRIBAND
U85 SPEAKER SYSTEM,8 QUAD FRT DR MTD, SHELF QUAD
U89 WIRING HARNESS,CAR TRAILER
U93 ANTENNA, FIXED TELEPHONE
U94 LIGHT CABLE TRAILER, 7 WIRE, VAR 3
U95 SPEAKER SYSTEM, DOOR
U96 SPEAKER SYSTEM 6, DUAL F/D TWEET & WOOF, DUAL
VA2 RADIATDR SUPPORT STEEL
VB1 LABEL, SHIPPING, JAPAN
VB2 BUMPER,RR STEP, PAINTED, IMPACT STRIP
VB3 BUMPER RR, STEP CHROME, IMPACT STRIP
VB4 PROVISION OPTIONS, GULF STATES ORGANIZATION
VB5 BUMPER FRT PAINTED
VB6 PROVISION OPTIONS, HOT CLIMATE
VB7 BUMPER, FRONT AND REAR SPORT
VC9 OWNERS MANUAL, MERCHANDISED OPTIONS
VD1 PROVISION OPTIONS, EUROPE
VD2 BUMPER, FRT & RR, CHROME, W/IMPACT STRIPS
VD4 BUMPER PROVISIONS, FRT, STEEL
VD5 BUMPER PROVISIONS, RR, STEEL
VD6 BUMPER PROVISIONS, FRT, ALUMINUM
VD7 BUMPER PROVISIONS, RR, ALUMINUM
VE1 PROVISION OPTIONS, JAPAN
VE5 BUMPER, FRT & RR, IMPACT, CHROME
VE6 BUMPER, FRT & RR, IMPACT, COLORED
VF1 BUMPER, RR, CHROME
VF6 BUMPER, RR, STEP,
VG2 PROTECTOR, WAX SPRAY ON ---- DELETE
VG3 BUMPER FRT, IMPACT STRIP
VGS BUMPER RR, IMPACT STRIP
VG8 VEHICLE, BUYER NOTICE LABEL
VG9 PROTECTOR, WAX, EXTERIOR BODY
VH4 MUD FLAPS,
VH5 PLATE, VEHICLE IDENTIFICATION
VH6 BUMPER FRT, BLACK
VH7 BUMPER, CUSTOM
VH9 ENVELOPE, OWNER INFO MAN
VJ1 LICENSE PLATE, RR MOUNTING PKG ---- JAPANESE
VJ5 LICENSE PLATE, MOUNTING INCLUDES BUMPER GUARD,
VJ6 LICENSE PLATE, RR POCKET, DELUXE
VJ9 LABEL, EMISSION, COMPLIANCE, CALIFORNIA
VK3 LICENSE PLATE, FRT MOUNTING PKG
VLA APPEARANCE PACKAGE, WORK TRUCK
VL4 LICENSE PLATE, FRT MOUNTING PKG, EEC
VL5 LICENSE PLATE, RR MOUNTING PKG ---- EXPORT
VL6 LICENSE PLATE, FRT MOUNTING PKG, JAPANESE
VND GOVERNOR, VEHICLE SPEED - 50 MPH
VNE GOVERNOR, VEHICLE SPEED - 55 MPH
VNF GOVERNOR, VEHICLE SPEED - VARIABLE 35-55 MPH
VN1 FLEET PROGRAM, GUARANTEED IOO% REPURCHASE, FAST
VN2 FLEET PROGRAM, GUARANTEED 100% REPURCHASE, CONTROLL
VN3 FLEET PROGRAM, DEALER DAILY RENTAL
VP1 SPOILER FRT
VP6 NOISE CONTROL,
VQA FAN, ENGINE EATON VISCIOUS DRIVE
VR2 TRAILER HITCH, FACTORY INSTALLED
VR4 TRAILER HITCH, WEIGHT DISTRIBUTING PLATFORM
VR5 PROVISIONS, SLOW VEHICLE WARNING TRIANGLE MOUNTING
VT3 BUMPER, FRT PAINTED DELUXE, IMPACT STRIPS
VT5 BUMPER RR, COLOR KEYED
VT7 PROVISION OPTIONS, UNREGULATED COUNTRIES
VU9 FLASHLIGHT, MOUNTING PROVISIONS
VV1 FUEL, UNLEADED GAS
VV4 CONTAINER, STOWAGE
VV5 P.O.E. INSTALLATION, AIR CONDITIONER
VV6 P.O.E. INSTALLATION, CRUISE CONTROL
VXX BUMPER FRT,---DELETE---
VYU PROVISIONS, SNOW PLOW PREP
VY7 KNOB, TRANS CONT LEVER, LEATHER
V01 RADIATOR, HEAVY DUTY, VAR I
V02 RADIATOR, HEAVY DUTY, WITH TRANS OIL COOLER
V03 COOLING SYSTEM, EXTRA CAPACITY
V05 RADIATOR, HEAVY WTY
V08 COOLING SYSTEM, HEAVY WTY
V1C EXHAUST, SINGLE OUTLET EXHAUST
V1F PAINT, SPECIAL METALLIC - CHARGE
V1L TRIM, SPECIAL
V10 PROVISION OPTIONS, COLD CLIMATE
V12 COOLING SYSTEM, POWER STEERING, FLUID
V13 PROVISION OPTIONS, COLD CLIMATE ---- DELETE
V2C WHEEL COLOR, ALUMINUM (MACH FINISHED)
V22 GRILLE, CHROME, RADIATOR
V27 GUARDS, BUMPER, FRT,
V28 GUARDS, BUMPER, FRT, PAINTED
V29 GUARDS, BUMPER, FRT, DELETE
V3C PLANT OPERATION, NON-ASBESTOS BRAKE LININGS
V3N PLANT OPERATION, COLUMN SHIFT
V30 GUARDS, BUMPER, FRT AND RR
V31 GUARDS, BUMPER, FRT, CHROUE
V32 GUARDS, BUMPER, RR
V33 TOOL KIT ROAD EMERGENCY
V35 BUMPER, RR, WITH RECESSED LIGHTING
V37 BUUPER, FRT & RR, CHROME
V38 BUMPER, RR, TRUCK
V4A TRIM, SPRING SPECIAL
V4E MERCHANDISED PKG, CADILLAC BROUGHAM
V4F EQUIPMENT, COACHBUILDER OPTION
V4I NOISE CONTROL, AIR CLEANER, ECM, MUFFLER
V4J IDENTIFICATION, MID-YEAR INTRODUCTION
V4N PROCESSING, GOLD KEY PROGRAM ---- DELETE
V4P TRAILER PROVISIONS, NOT TO EXCEED 7000 LBS
V4R PROVISION OPTIONS, VEHICLE SECURITY
V4S MERCHANDISED PKG, FLEETWOOD D' ELEGANCE
V4U EQUIPMENT, COACHBUILDER, NOT TO EXCEED 7200 LBS
V4X MERCHANDISED PKG, TOURING OPTION
V41 KIT, ACCESSORY
V42 BUMPER RR, STEP, CHROME
V43 BUMPER RR, STEP, PAINTED
V46 BUMPER FRT, CHROME
V5O LICENSE PLATE, FRAME RR ONLY
V51 LICENSE PLATE, FRAME, FRT AND RR
V52 LUGGAGE CARRIER, RR COMPARTMENT
V54 LUGGAGE CARRIER, ROOF, PAINTED
V55 LUGGAGE CARRIER, ROOF CHROME
V56 LUGGAGE CARRIER, RR COMPARTMENT LID, PAINTED
V58 LUGGAGE CARRIER, RR COMPARTMENT LID, CHROME
V69 TRAILER PROVISIONS, NOT TO EXCEED 4000 LBS
V70 HOOK, TOW, FRAME MOUNTED
V76 HOOK, TOW
V78 VEHICLE STATEMENT DELETE
V81 TRAILER PROVISIONS, NOT TO EXCEED 2000 LBS, SAE
V82 TRAILER PROVISIONS 2000 TO 3500 LBS, SAE CLASS 2
V83 VEHICLE STATEMENT ECE ORGANIZATION
V92 TRAILER PROVISIONS
V97 VEHICLE PREPARATION, EXPORT
WA4 MERCHANDISED PKG, CADILLAC SPECIAL EDITION
WB4 ORNAMENTATION, WOODGRAIN APPLIQUE DELETE
WB6 PACKAGE, DELETE EQUIPUENT LESABRE/SKYLARK
WD6 PROMOTIONAL PROGRAM, MEXICO SALES
WE2 MERCHANDISED PKG, LESABRE 'T' TYPE, GRAND NATIONAL
WF1 MERCHANDISED PKG, CADILLAC DEVILLE TOURING SEDAN
WF7 CONVERSION, FLEETWOOD - SIXTY SPECIAL
WG1 SALES, PROCESSING FOR DR POWER SEAT
WJ7 TRIM OVERRIDE ,INTERIOR 'LEATHER'
WL2 MANIFOLD, EXHAUST, CI
WL3 MERCHANDISED PKG, TROFEO
WS4 MODEL CONVERSION, TRANS AM
WS6 PERFORMANCE PACKAGE, SPECIAL
WS9 MODEL CONVERSION, FORMULA
WV9 MERCHANDISED PKG, VALUE LEADER
WW1 APPEARANCE PACKAGE, AERO #l
WW2 APPEARANCE PACKAGE, AERO #2
WW3 APPEARANCE PACKAGE, AERO #3
WW4 APPEARANCE PACKAGE, AERO #4
WW6 APPEARANCE PACKAGE, AERO #6
WW7 APPEARANCE PACKAGE, AERO #7
WW8 APPEARANCE PACKAGE, AERO #8
WX1 PAINT, TWO TONE-DELETE
WX2 SALES LEATHER APPOINTMENTS
WX7 WIRING PROVISIONS
W02 PACKAGE SPORT APPEARANCE
W03 SALES, (NOT USED 2-l5-91/OK TO REUSE)
W06 MODEL CONVERSION, CENTURY LIMITED WAGON
W09 M0DEL CONVERSION, CENTURY LIMITED SEDAN
W10 MERCHANDISED PKG, PARK AVENUE MODEL
W12 MERCHANDISED PKG, NINETY-EIGHT TOURING SEDAN
W14 MERCHANDISED PKG, NINETY-EIGHT REGENCY ELITE
W16 APPEARANCE PACKAGE, PGA SPECIAL EDITION
W18 MERCHANDISED PKG, 5OTH ANNIVERSARY NINETY-EIGHT
W21 MERCHANDISED PKG, DRIVER ENTHUSIAST
W24 MERCHANDISED PKG, PARK AVENUE 'ULTRA'
W25 APPEARANCE PACKAGE, "SPRING SPECIAL"
W29 EXPORT VEHICLE, SEAT BACK LOCK (COUPE)
W30 MERCHANDISED PKG, SPORT
W32 MERCHANDISED PKG, DELUXE SPORT
W36 APPEARANCE PACKAGE, "GT LOOK ALIKE"
W40 MERCHANDISED PKG, QUAD 442
W41 MERCHANDISED PKG, HIGH OUTPUT QUAD 442
W44 MERCHANDISED PKG, SPORTY
W45 MODEL CONVERSION, INTERNATIONAL SERIES COUPE
W49 MODEL CONVERSION, INTERNATIONAL SERIES SEDAN
W62 ORNAMENTATION, AERO PACKAGE
W63 PACKAGE, GROUP 02
W66 MERCHANDISED PKG, FORMULA
W68 MERCHANDISED PKG, FIREBIRD, SPORT APPEARANCE
W81 WRANGLER, PACKAGE "B"
W90 APPLICATION, MANDATORY SCHOOL BUS
XAA TIRE FRONT, P255/45ZR17 BL R/PE ST TL HW4
XAU TIRE FRONT, P275/40ZR17/N BL R/PE ST TL HW4
XNA TIRE FRONT, 205/65R15 BW R/PE ST TL HWY 94H
X6W HUB, LOCKING MANUAL
X6Z HUB, LOCKING AUTOMATIC
X88 CONVERSION NAME PLT CHEVROLET
YAA TIRE REAR, P285/40ZR17 BL R/PE ST TL HW4
YAU TIRE REAR, P275/40ZR17/N BL R/PE ST TL HW4
YA2 DDOR SIDE RR, SLIDING
YA9 AXLE, (3400-LBS)
YBE TIRE REAR, P315/35ZR17/N BL R/PE ST TL HWY
YC1 CONVENIENCE PKG, DECOR LEVEL #1
YC2 CONVENIENCE PKG, DECOR LEVEL #2
YC3 CONVENIENCE PKG, DECOR LEVEL #3
YC4 AXLE (5OOO LB)
YC5 CONVENIENCE PKG, DECOR LEVEL #5
YC6 CONVENIENCE PKG, DECOR LEVEL #6
YC7 CONVENIENCE PKG, DECOR LEVEL #7
YC9 CONVENIENCE PKG, DECOR LEVEL #9
YE2 CONVENIENCE PKG, DECOR LEVEL #2, LOW TRIM
YE3 CONVENIENCE PKG, DECOR LEVEL #3, HIGH TRIM
YE9 CONVENIENCE PKG, COMFORT & DECOR LEVEL #3
YF3 CERTIFICATION, EMISSION, FEDERAL
YF5 CERTIFICATION, EMISSION, CALIFORNIA
YF7 SALES PACKAGE, RECREATIONAL VEHICLE UPFITTER
YG3 ORNAMENTATION, BODY SIDE 6 WHL OPENING BRIGHT
YG5 IDENTIFICATION, SEO USAGE
YGB IDENTIFICATION, P E P VEHICLE
YG9 WARRANTY, ENGINE ONLY, 100,000 MILES, 5 YEARS
YHX TIRE REAR, P205/70R14/N BL R/PE ST TL ALS
YHY TIRE REAR, P205/70R14/N WS2 R/PE ST TL ALS
YJT TIRE REAR, P205/75R15/N BL R/PE ST TL OOR
YJ3 DECAL, 4 X 4
YK3 ORDER PROTECTION, NO CHANGE
YL1 TRIM OVERRIDE, UPHOLSTERY, LEATHER/VINYL
YL2 PAINT SPECIAL, FIREMIST
YL4 TRIM OVERRIDE, UPHOLSTERY, CLOTH
YL5 COMMERCIAL BODY, BUILDER SUPERIOR
YL6 STRIPE COLOR, ACCENT ---- DELETE
YL7 COMMERCIAL BODY, BUILDER S & S COACH
YL9 COMMERCIAL BODY, BUILDER HESS
YM5 STRIPE ACCENT DELETE
YM6 PROCESSING STOCK SALES
YNA TIRE REAR, 205/65R15 BW R/PE ST TL HWY 94H
YP1 MERCHANDISED PKG, CALIFORNIA SEVILLE
YP3 MERCHANDISED PKG, ELDORADO BIARRITZ
YP4 MERCHANDISED PKG, SEVILLE ELEGANTE
YP5 MERCHANDISED PKG, ELDORADO TOURING COUPE
YP6 MERCHANDISED PKG, SEVILLE TOURING SEDAN
YP8 MERCHANDISED PKG, CONVERTIBLE
YP9 MERCHANDISED PKG, SPRING SPECIAL
YR1 SEAT,FRT CUSTOM
YR3 SEAT FRT LUXURY
YT1 BUILD UP DR & QTR
YT2 BUILD UP DR & QTR, CUSTOM
YUB TIRE REAR,P195/7DR15/N BL TL R/PE ST AL3
YW9 SALES PACKAGE, UPS RETROFIT KIT
YD1 RING GEAR, 7.50 IN., SAGINAW, (S.P.O.)
Y02 RING GEAR, 7.50 IN., DANA, (S.P.O.)
Y03 RING GEAR, 7.62 IN., SAGINAW, (S.P.O.)
Y04 RING GEAR, 8.50 IN., SAGINAW, (S.P.O.)
Y05 RING GEAR, 8.50 IN., DANA (S P 0.)
Y06 RING GEAR, 9.50 IN., SAGINAW, (S.P 0.)
Y07 RING GEAR, 9.50 IN., DANA (S.P.O )
Y08 RING GEAR, 9.75 IN., SAGINAW, (S.P.O.)
Y09 RING GEAR, 9.75 IN., DANA (S.P.O.)
Y10 RING GEAR, 10.50 IN., SAGINAW , ( S.P.O. )
Y11 RING GEAR, 10.50 IN., DANA (S.P.O )
Y12 RING GEAR, 12.0O IN., ROCKWELL (S.P.O.)
Y13 RING GEAR, 11.50 IN., DANA, (S.P.O.)
Y40 MERCHANDISED PKG, CADILLAC SPCL PGA TOUR EDITION
Y48 MERCHANDISED PKG, ELECTRA - T TYPE
Y5E WARRANTY ENGINE ONLY, 150,000 MILES, 5 YEARS
Y56 MERCHANDISED PKG, GRAN TOURING
Y61 PROVISION OPTIONS, END RELEASE SEAT BELT BUCKLES
Y67 DISPLAY , REMINDER PACKAGE
Y70 PARTS PKG, HEADLINER - VALUE LEADER
Y72 PARTS PKG, HEADLINER
Y73 PARTS PKG, DELUXE HEADLINER
Y79 PROVISION OPTIONS, LOAD BEARING SEAT ADJ
Y81 MERCHANDISED PKG, FIREBIRD
Y83 MERCHANDISED PKG, TRANS AM
Y84 MERCHANDISED PKG, GTA, TRANS AM
Y85 MERCHANDISED PKG, SSE
Y86 MERCHANDISED PKG, CAMARO RS
Y88 PACKAGE, STE SPECIAL TOURING EDITION
Y89 MERCHANDISED PKG, FIREBIRD SE
Y91 MERCHANDISED PKG, LUXURY EDITION
Y92 MERCHANDISED PKG, SPECIAL EDITION
Y97 PACKAGE, GSE SPECIAL EDITION
Y98 CONTROL, RIDE SYSTEM ELECTRONIC
Y99 SALES, HANDLING PKG
ZAA TIRE SPARE, COMPACT
ZA7 PACKAGE, VALUE LEADER-CANADIAN
ZE5 IDENTIFICATION, TRIM LEVEL BASE
ZJ2 FLEET INCENTIVE , PHILLIPS PETROLEUM (A/B/C/H/L/W-TRK
ZJ7 WHEEL,SPECIAL HUB CAP 6 TRIM RING
ZL1 NOISE CONTROL WITH LESS THAN 8000 LB GVW
ZL8 INVOICE, AUTO FAB, INC.
ZM3 INVOICE, AUTO FAB INC . ' CAMEO ' EL ' PICKUP
ZM4 SALES PACKAGE, LUGGAGE CARRIER/RR WINWW DEFLECTOR
ZM5 SALES PACKAGE, UNDERBODY SHIELD
ZM6 CHASSIS PACKAGE, OFF-ROAD SUSPENSION
ZM7 SALES PACKAGE, COMBINATION - INTERMITTENT WIPER/TIL
ZM8 SALES PACKAGE, COMBINATION - ELECTRIC TAILGATE
ZN5 PAINT SPECIAL, TWO TONE SPORT
ZP3 SEATING ARRANGEMENT, FIFTEEN PASSENGER
ZP5 SEATING ARRANGEMENT, FIVE PASSENGER
ZP7 SEATING ARRANGEMENT, SEVEN PASSENGER
ZP8 SEATING ARRANGEMENT, EIGHT PASSENGER
ZQ2 SALES PACKAGE, DRIVER CONVENIENCE
ZQ3 SALES PACKAGE, DRIVER CONVENIENCE II
ZQ9 APPEARANCE PACKAGE, EXTERIOR TRIM, BLACK OUT
ZR1 PERFORMANCE PACKAGE, SPECIAL COUPE
ZR9 APPEARANCE PACKAGE, "SYCLONE" PICKUP
ZVB MODEL CONVERSION, LUUINA EURO
ZW2 WINDOW PKG, RR DOORS
ZW3 WINDOW PKG, SIDE RR DR, RR DR
ZW4 WINDOW PKG, RIGHT HAND SIDE, RR DRS
ZW6 WINDOW PKG, COMPLETE BODY
ZW9 B0DY EQUIPMENT, BASE BODY OR CHASSIS
ZX2 SEATING ARRANGEMENT, DRIVER & PASSENGER, HIGHBACK
ZX4 WINDOW PKG, LEFT HAND SIDE, SIDE RR DR, RR DR
ZX6 WINDOW PKG, RR DR, SIDE RR DR, SWING OUT
ZY1 COLOR COMBINATION, SOLID
ZY2 COLOR COMBINATION, TWO TONE
ZY3 COLOR COMBINATION, SPECIAL TWO TONE
ZY4 COLOR COMBINATION, DELUXE TWO TONE
ZV6 COLOR COMBINATION, TWO TONE TREATMENT
ZY7 COLOR COMBINATION, LOWER ACCENT, TWO TONE
ZY8 COLOR COMBINATION, CUSTOM, TWO TONE
Z02 PERFORMANCE PACKAGE, TURBO
Z03 APPEARANCE PACKAGE, 25TH ANNIVERSARY
Z04 MODEL CONVERSION, 'GTZ' BERETTA
Z05 CONVENIENCE PKG
Z07 PERFORMANCE PACKAGE AGGRESSIVE SPORT
Z08 MODEL CONVERSION, CONVERTIBLE
Z09 MODEL CONVERSION, CAPRICE CLASSIC
Z10 MODEL CONVERSION, CARGO VAN
Z12 SALES, EXTR FUNCTIONAL & APPEARANCE
Z13 M0DEL CONVERSION, BUICK REGAL GRAN SPORT
Z21 MOOEL CONVERSION 'GT- BERETTA
Z22 MOOEL CONVERSION, ROADMASTER ITT LMTD
Z25 APPEARANCE PACKAGE, 40TH ANNIVERSARY
Z26 MERCHANDISED PKG,OPEL CONVERSION
Z28 MERCHANDISED PKG, SPECIAL PERFORMANCE
Z34 MODEL CONVERSION CHEVROLET LUMINA 'Z34'
Z41 CONVERSION OPTION, CANAOIAN PONTIAC
Z47 CONVERSION OPTION, CANADIAN CHEVROLET
Z49 EXPORT, CANADIAN MODIF MANDATORY BASE EOUIP
Z5G IDENTIFICATION, CALLAWAY ORDERS
Z50 MODEL CONVERSION, PONTIAC TEMPEST
Z5I PACKAGE, PERFORMANCE HANDLING
Z52 MERCHANDISED PKG, SPORT HANDLING
Z54 MODEL CONVERSION, CORSICA LTZ
Z62 CONVENIENCE PKG, COMFORT & DECOR LEVEL #l
Z65 PACKAGE, MONTE CARLO SS
Z7H MODEL CONVERSION, CHEVROLET LUMINA
Z7K MODEL CONVERSION, PONTIAC GRAND PRIX SE
Z7L MODEL CONVERSION, PONTIAC GRAND PRIX LE
Z7M MODEL CONVERSION, PONTIAC GRAND PRIX GT
Z7N MOOEL CONVERSION, PONTIAC GRAND PRIX STE
Z7P MODEL CONVERSION, OLDSMOBILE CUTLASS SUPREME S
Z7Q MOOEL CONVERSION, OLDSM0BILE CUTLASS INTERNATIONAL
Z7R MODEL CONVERSION, OLDSMOBILE CUTLASS SL
Z7S MOOEL CONVERSION, OLDSMOBILE CUTLASS SUPREME S
Z7T MOOEL CONVERSION, BUICK REGAL CUSTOM
Z7U MOOEL CONVERSIO N, BUICK REGAL LIMITED
Z70 CONVERSION NAME PLT,OLDSMOBILE
Z71 CHASSIS PACKAGE, OFF-ROAD
Z72 TRAILER PPOVISIONS, HITCH, BALL TYPE, L.D.
Z73 CONVENIENCE PKG INTERIOR TRUCK DECOR
Z74 APPEARANCE PACKAGE, SONOMA GT
Z76 CAMPER PROVISIONS , SPECIAL CHASSIS (COMMERCIAL)
Z79 APPEAPANCE PACKAGE, TYPHOON
Z8I CAMPER PROVISIONS, SPECIAL
Z82 TRAILER PROVISIONS, SPECIAL EQUIPMENT, H.0.
Z83 CHASSIS PACKAGE, SOLID SMOOTH RIDE
Z85 CHASSIS PACKAGE, HIGH PAYLOAD FIRM RIDE
Z88 CONVERSION NAME PLT GMTB
00L SECONDARY COLOR, EXTERIOR, PRIME
00U PRIMARY COLOR, EXTERIOR, PRIME
01L SECONDARY COLOR, EXTERIOR, SPECIAL (91)
01U PRIMARY COLOR, EXTERIOR, SPECIAL, (91)
02A STRIPE COLOR, ACCENT, TWO TONE, BEIGE/GARNET (93)
02L SECONDARY COLOR, EXTERIOR, SPECIAL, CHART NOT
02U PRIMARY COLOR, EXTERIOR, SPECIAL, CHART NOT
04U PRIMARY COLOR, EXTERIOR, FLAX PEARL, (92)
05P WHEEL COLOR, ARGENT (91)
06P WHEEL COLOR, BLACK/SILVER (91)
07A STRIPE COLOR, ACCENT, TWO TONE, WHITE/MED BEECHWOOD**
07P WHEEL COLOR, GRAY/RED (91)
08Q MOLDING COLOR , MARY KAY PINK (91)
08U PRIMARY COLOR, EXTERIOR, MARY KAY PINK (91)
09A STRIPE COLOR, ACCENT, TWO TONE, WHITE/DK SAPPHIRE
09U PRIMARY COLOR, EXTERIOR, OPAQUE WHITE (91)
1A2 SEO VEHICLE, PUBLIC SERVICE
1C1 SEO VEHICLE, EXPORT, NON POLICE VERSION
1K5 LEVER, AUTO TRANS, LOW GEAR LOCKOUT
1LE PERFORMANCE PACKAGE COMPONENTS
1M1 MARKING, REFLECTIVE WHITE, U.S. ARMY
1M3 MARKING, REFLECTIVE WHITE, U.S. NAVY
1M4 MARKING, REFLECTIVE BLACK, U S . NAVY
1M5 MARKING, REFLECTIVE YELLOW
1M6 MARKING, REFLECTIVE BLUE U.S NAVY
1M8 MARKING, REFLECTIVE WHITE, OEFENSE LOGISTICS AGENCY
1N4 MARKING, REFLECTIVE BLACK ARMY NATIONAL GUARD
1NS MARKING, REFLECTIVE BLACK, U.S. ARMY
1N6 MARKING, REFLECTIVE YELLOW, U.S. AIR FORCE
1N7 MARKING, LUSTERLESS BLACK , U S AIR FORCE
1PV PAINT SCHEME, 21
1SV PACKAGE, OPTION 20
1TA AXLE, FULL FLOATING
1T1 HOSE, RADIATOR & HEATER SI RUB
1Z2 VEHICLE PREPARATION, ANTI CORROSION HOT MELT
10A STRIPE COLOR, ACCENT, TWO TONE, LT GRAY/RED (91)
10I INTERIOR TRIM, ARCTIC WHITE (93)
10N TRIM COMBINATION, VINYL, ARCTIC WHITE (N) (93)
10P WHEEL COLOR, GRAY WHITE (91)
10Q MOLDING COLOR , ARCTIC WHITE (91)
10T TOP COLOR, ARCTIC WHITE (91)
10U PRIMARY COLOR , EXTERIOR, ARCTIC hHITE (91)
103 TRIM COMBINATION, LEATHER, ARCTIC WHITE (93)
11I INTERIOR TRIM , WHITE (I) (92)
11N TRIM COMBINATION, VINYL, WHITE (N) (92)
11P WHEEL COLOR, PINK (92)
112 TRIM COMBINATION, LEATHER, WHITE (2) (91)
113 TRIM COMBINATION, LEATHER, WHITE (3) (91)
114 TRIM COMBINATION, LEATHER, WHITE (4) (91)
115 TRIM COMBINATION, LEATHER, WHITE (S) (91)
116 TRIM COMBINATION, LEATHER, WHITE (6) (91)
119 SEAT BELT COLOR WHITE (9) (91)
12A STRIPE COLOR ACCENT SILVER MET (91)
12B TRIM COMBINATION,CLOTH, GRAPHITE (B) (92)
12C TRIM COMBINATION,CLOTH, GRAPHITE (C) (92)
12D TRIM COMBINATION,CLOTH, GRAPHITE (D) (92)
12E TRIM COMBINATION CLOTH, GRAPHITE (E) (92)
12F COVERING COLOR FLOOR MAT, GRAPHITE (92)
12H TRIM COMBINATION CLOTH GRAPHITE (H) (92)
12I INTERIOR TRIM, GRAPHITE (92)
12K AUX TOP COLOR WHITE (91)
12L SECONDARY COLOR, EXTERIOR, SILVER MET (91)
12P WHEEL COLOR PLATINUM
12Q MOLDING COLOR, SILVER MET (91)
12U PRIMARY COLOR, EXTERIOR SILVER MET (91)
122 TRIM COMBINATION, LEATHER, GRAPHITE (2) (92)
123 TRIM COMBINATION, LEATHER, GRAPHITE (3) (92)
124 TRIM COMBINATION, LEATHER, GRAPHITE (4 ) (92)
125 TRIM COMBINATION, LEATHER, GRAPHITE (S) (92)
126 TRIM COMBINATION, LEATHER, GRAPHITE (6) (92)
128 TRIM COMBINATION, CLOTH, GRAPHITE (B) (92)
129 SEAT BELT COLOR, GRAPHITE (92)
13A STRIPE COLOR, ACCENT, BRIGHT SILVER MET (91)
13B TRIM COMBINATION, CLOTH, LT SLATEGRAY (B) (92)
13C TRIM COMBINATION, CLOTH, LT SLATEGRAY (C)
13D TRIM COMBINATION, CLOTH, LT SLATEGRAY (D)
13E TRIM COMBINATION, CLOTH, LT SMOKE GRAY (E) (92)
13G TRIM COMBINATION, CLOTH, LT GRAY (G) (91T)
13H TRIM COMBINATION, CLOTH, LT SMOKE GRAY (H) (91)
13I INTERIOR TRIM, LT SMOKE GRAY (91)
13L SECONDARY COLOR, EXTERIOR, BRIGHT SILVER MET (91)
13Q MOLDING COLOR, BRT SILVER MET (91)
13T TOP COLOR, BRIGHT SILVER MET (91)
13U PRIMARY COLOR , EXTERIOR, BRIGHT SILVER MET (91)
13V TRIM COMBINATION, VINYL, LT GRAY (V)
13W TRIM COMBINATION, VINYL, LT GRAY (W)
132 TRIM COMBINATION, LEATHER, GRAY (2) (91)
14A STRIPE COLOR ACCENT, LT GRAY (91)
14B TRIM COMBINATION, CLOTH, LT GRAY (B) (92)
14C TRIM C0MBINATION, CLOTH, LT GRAY (C) (92)
14D TRIM C0MBINATION, CLOTH, LT GRAY (D) (92)
14E TRIM COMBINATION, CLOTH, LT GRAY (E) (92)
14F COVERING COLOR, FLOOR MAT, LT GRAY (92)
14G TRIM COMBINATION, CLOTH, LT GRAY (G) (92)
14H TRIM C0MBINATION, CLOTH, LT GRAY (H) (93)
14I INTERIOR TRIM , LT GRAY (I) (92)
14J TRIM COMBINATION, CLOTH, LT GRAY J (93)
14L SECONDARY COLOR, XTERIOR, LT GRAY MET (92)
14N TRIM COMBINATION, VINYL, LIGHT GRAY (N) (92)
14Q M0LDING COLOR , BLACK 4ET, (91)
14R TRIM COMBINATION, VINYL, LT GRAY (R) (92)
14U PRIMARY COLOR , EXTERIOR, LT GRAY 4ET (92)
142 TRIM COMBINATION, LEATHER, LT GRAY (2) (92)
143 TRIM COMBINATION, LEATHER, LT GRAY (3) (92)
144 TRIM COMBINATION, LEATHER, LT GRAY (4) (92)
145 TRIM COMBINATION, LEATHER, LT GRAY (5) (92)
146 TRIM COMBINATION, LEATHER, LT GRAY (6) (92)
149 SEAT BELT, COLOR, LT GRAY (92)
15A STRIPE COLOR, ACCENT, MED GRAY MET, (91)
15B TRIM COMBINATION, CLOTH, MED SLATE GRAY (B) (91)
15C TRIM C0MBINATION, CLOTH, MED SLATE GRAY (C) (91)
15D TRIM COMBINATION, CLOTH, MED SLATE GRAY (D) (91)
15E TRIM C0MBINATION, CLOTH, MED SLATE GPAY (E) (91)
15F COVERING COLOR, FLOOR MAT, MED SLATE GRAY (91 )
15G TRIM COMBINATION, CLOTH, SLATE GRAY (G)
15H TRIM COMBINATION, CLOTH, MED SLATE GRAY (H) (91)
15IINTERIOR TRIM, MED SLATE GRAY (91)
l5J TRIM COMBINATION, CLOTH, MED SLATE GRAY (J) (91)
15L SECONDARY COLOR, EXTERIOR, ASTRAL SILVER (91)
15P WHEEL COLOR SILVER MET (91)
l5Q MOLDING COLOR, MED GRAY MET (91)
15U PRIMARY COLOR, EXTERIOR ASTRAL SILVER (91)
1E3 TRIM COMBINATION, LEATHER, MED SLATE GRAY (2) (3t1
154 TRIM COMBINATION, LEATHER, MED SLATE GRAY (4) (91)
155 TRIM C0MBINATION, LEATHER, MED SLATE GRAY (5) (91)
156 TRIM COMBINATION, LEATHER, MED SLATE GRAY (6) (91)
15B TRIM COMBINATION, CLOTH, MED SLATE (91)
159 SEAT BELT COLOR, MED SLATE GRAY (91)
16A STRIPE COLOR, ACCENT, TWO TONE, BLACK/GARNET RED
16L SECONDARY COLOR, EXTERIOR, WARM GRAY MET (91)
16P WHEEL COLOR, BRT WHITE (91)
16Q MOLDING COLOR , BRITE WHITE (91)
16S ROOF COLOR, GRAY, REMOVABLE PANEL
16T TOP COLOR, BRITE WHITE (94)
16U PRIMARY COLOR , EXTERIOR, WARM GRAY 4ET (91)
17A STRIPE COLOR, ACCENT, SILVER (91)
17F COVERING COLOR, FLOOR MAT, CHARCOAL (91)
17I INTERIOR TRIM , CHARCOAL (91)
17L SECONDARY COLOR, EXTERIOR, LT SLATE MET (91)
17P WHEEL COLOR, SILVER (91)
17Q MOLDING COLOR , SILVER (91)
17T TOP COLOR, PEARL GRAY (91)
17U PRIMARY COLOR , EXTERIOR, LT SLATE MET (91)
172 TRIM COMBINATION, LEATHER, CHARCOAL (2) (91)
179 SEAT BELT, COLOR CHARCOAL (91)
18A STRIPE COLOR, ACCENT, SLATE GRAY (91)
18B TRIM COMBINATION, CLOTH, CHARCOAL
18C TRIM COMBINATION, CLOTH, DK CHARCOAL, (C)
18D TRIM COMBINATION, CLOTH, DK CHARCOAL, (D)
18E TRIM COMBINATION, CLOTH, DK CHARCDAL, (E)
18H TRIM COMBINATION, CLOTH, DK CHARCOAL, (H)
18I INTERIOR TRIM, DK CHARCOAL, (I) (91)
18P WHEEL COLOR, CHARCOAL MET (91)
18Q MOLDING COLOR, SLATE GRAY (91)
18T TOP COLOR, SLATE GRAY (91)
18U PRIMARY COLOR, EXTERIOR, SLATE GRAY (91)
18W TRIM COMBINATION, VINYL, DK CHARCOAL (W)
182 TRIM COMBINATION, LEATHER, OK CHARCOAL (2) (91)
19A STRIPE COLOR, ACCENT, TWO TONE, MED GRAY MET/BLACK
19B TRIM COMBINATION, CLOTH, BLACK (B) (91)
19C TRIM COMBINATION, CLOTH, BLACK (C) (91)
19D TRIM COMBINATION, CLOTH, BLACK (D)
19E TRIM COMBINATION, CLOTH BLACK (E) (91)
19F COVERING COLOR, FLOOR MAT, BLACK (91)
19H TRIM COMBINATION, CLOTH, BLACK (H)
19I INTERIOR TRIM, BLACK (I) (91)
19J TRIM COMBINATION, CLOTH, BLACK (J)
19K AUX TOP COLOR BLACK (91)
19L SECONDARY COLOR, EXTERIOR, LAMP BLACK (91)
19R TRIM COMBINATION, VINYL BLACK (R)
19U PRIMARY COLOR, EXTERIOR, LAMP BLACK (91)
19W TRIM COMBINATION, VINYL BLACK (W)
192 TRIM COMBINATION, LEATHER, BLACK (2) (91 )
193 TRIM COMBINATION, LEATHER, BLACK (3) (91)
194 TRIM COMBINATION, LEATHER, BLACK (4) (91)
195 TRIM COMBINATION, LEATHER, BLACK (5) (91)
198 TRIM C0MBINATION, LEATHER, BLACK (6) (92)
198 TRIM COM8INATION, CLOTH, BLACK (8) (91)
199 SEAT BELT COLOR, BLACK (91)
20A STRIPE COLOR, ACCENT, DK ROYAL BLUE (94)
20B TRIM COMBINATION, CLOTH, VERY DK SAPPHIRE (8) (91)
20C TRIM COMBINATION, CLOTH, VERY DK SAPPHIRE (C) (91)
20D TRIM C0MBINATION, CLOTH. VERY DK SAPPHIRE (D) (91)
20E TRIM COMBINATION, CLOTH, VERY DK SAPPHIRE (E) (91)
20F COVERING COLOR, FLODR MAT, VERY DK SAPPHIRE (91)
20G TRIM COMBINATION, CLOTH, VERY DK SAPPHIRE (G) (91)
20H TRIM C0MBINATION, CLOTH, VERY DK SAPPHIRE (H) (91)
20I INTERIOR TRIM, VERY DK SAPPHIRE (91)
20J TRIM COMBINATION,CLOTH, VERY DK SAPPHIRE (J) (91)
20L SECONDARY COLOR, EXTERIOR, LT QUASAR BLUE MET (92)
20N TRIM COMBINATION, VINYL(N), VERY DK SAPPHIRE (1991)
20Q MOLDING COLOR, LT QUASAR 8LUE MET (91)
20U PRIMARY COLOR, EXTERIOR, LT QUASAR BLUE MET (93)
20V TRIM COMBINATION, VINYL, SAPPHIRE BLUE (V) (92)
201 TRIM COMBINATION, VINYL, VERY DK SAPPHIRE (W)
202 TRIM COMBINATION, LEATHER, VERY DK SAPPHIRE (2)
203 TRIM C0MBINATION, LEATHER, VERY DK SAPPHIRE (3)
204 TRIM C0MBINATION, LEATHER, VERY DK SAPPHIRE (91)
205 TRIM C0MBINATION, LEATHER, VERY DK SAPPHIRE (5)
206 TRIM C0MBINATION, VINYL, HD, VERY DK SAPPHIRE
207 TRIM C0MBINATION, CLOTH, HD, VERY DK SAPPHIRE
208 TRIM C0MBINATION, CLOTH, VERY DK SAPPHIRE (8) (91)
209 SEAT BELT, COLOR VERY DK SAPPHIRE (91)
21A STRIPE COLOR, ACCENT DK SAPPHIRE BLUE (91)
21I INTERIOR TRIM, DK MONTANA BLUE (I) (94)
21P WHEEL COLOR, NEON BLUE (91)
21Q MOLDING COLOR, NEON BLUE MET (92)
21U PRIMARY COLOR EXTERIOR, NEON BLUE MET (91)
22A STRIPE COLOR ACCENT LT SAPPHIRE BLUE (91)
22B TRIM C0MBINATION, CLOTH, DK ROYAL BLUE (B)
22C TRIM C0MBINATION, CLOTH, DK ROYAL BLUE (C)
22D TRIM C0MBINATION, CLOTH, DK ROYAL BLUE (D)
22E TRIM COMBINATION, CLOTH, DK ROYAL BLUE (E)
22G TRIM COMBINATION, CLOTH, DK ROYAL BLUE (G)
22H TRIM C0MBINATION, CLOTH, DK ROYAL BLUE (H)
22I INTERIOR TRIM, DK STEEL BLUE (91)
22L SECONDARY COLOR, EXTERIOR BAHAMA BLUE MET (91)
22Q MOLDING CDLOR, LT SAPPHIRE BLUE MET (91)
22T TOP COLOR, LT SAPPHIRE BLUE MET (91)
22U PRIMARY COLOR, EXTERIOR BAHAMA BLUE MET (91)
222 TRIM C0MBINATION, LEATHER DK ROYAL BLUE (2)
223 TRIM COMBINATION, LEATHER DK STEEL BLUE (3) (91)
224 TRIM COMBINATION, LEATHER, DK ROYAL BLUE (4)
229 SEAT BELT COLOR, DK STEEL BLUE (91)
23A STRIPE COLOR, ACCENT, LT BLUE (91)
23G TRIM COMBINATION, CLOTH, BLUE (G)
23I INTERIOR TRIM, LT BLUE (91)
23Q MOLDING COLOR, MED MAUI BLUE MET (91)
23U PRIMARY COLOR, EXTERIOR, MED MAUI BLUE MET (91)
23V TRIM COMBINATION,VINYL, BLUE (V)
23W TRIM COMBINATION, VINYL, BLUE (M)
24A STRIPE COLOR, ACCENT , TWO TONE , DK BLUE/SLATE {91 )
24B TRIM COMBINATION, CLOTH, DK BLUE (B) (91)
24C TRIM COMBINATION, CLOTH, DK BLUE (C) (91)
24D TRIM COMBINATION, LOTH, DK BLUE (D) (91)
24E TRIM COMBINATION, CLOTH, DK BLUE (E) (91)
24G TRIM COMBINATION, CLOTH, DK BLUE (G) (91)
24I INTERIOR TRIM, DK BLUE (I) (91)
24L SECONDARY COLOR, EXTERIOR, BRIGHT BLUE MET (91)
24Q MOLDING COLOR, BRT BLUE MET {91)
245 ROOF COLOR,BLUE, REMOVABLE PANEL
24U PRIMARY COLOR, EXTERIOR, BRIGHT BLUE MET (91)
24V TRIM COMBINATION, VINYL, DK BLUE (V) (91)
24M TRIM COMBINATION, VINYL, DK BLUE (4) (91)
25A STRIPE COLOR, ACCENT, TWO TONE, SILVER/BLUE (91)
25U PRIMARY COLOR, EXTERIOR, STEEL BLUE MET (91)
26A STRIPE COLOR, ACCENT, TWO TONE, DK SAPPHIRE/RED
26L SECONDARY COLOR, EXTERIOR, PASTEL BLUE (91)
26T TOP COLOR, DK BLUE (91)
26U PRIMARY COLOR, EXTERIOR, PASTEL BLUE (91)
27A STRIPE COLOR, ACCENT, TW0 TONE, LT BLUE/DK BLUE
27B TRIM COMBINATION, CLOTH, DK BLUE (B)
27C TRIM COMBINATION, CLOTH, DK BLUE (C)
27D TRIM COMBINATION, CLOTH, DK BLUE (D)
27E TRIM COMBINATION, CLOTH, DK BLUE (E)
27G TRIM CQMBINATION, CLOTH, DK BLUE (G)
27H TRIM COMBINATION, CLOTH, DK BLUE (H)
27L SECONDARY COLOR, EXTERIOR, MED SAPPHIRE BLUE MET
27N TRIM COMBINATION, VINYL, DK BLUE (N)
27P WHEEL COLOR, LT BLUE MET (91)
27Q MOLDING COLOR, MED SAPPHIRE BLUE MET (91)
27R TRIM COMBINATION, VINYL, DK BLUE (R)
27U PRIMARY COLOR, EXTERIOR, LT FRENCH BLUE MET (91)
27V TRIM COMBINATION, VINYL, DK BLUE (V)
27W TRIM COMBINATION, VINYL, DX BLUE (M)
27X TRIM COMBINATION, VINYL, DK BLUE (X)
27Y TRIM COMBINATION, VINYL, DK BLUE (Y)
27Z TRIM COMBINATION, VINYL, DK BLUE (Z)
272 TRIM COMBINATION, LEATHER, DK BLUE (2)
273 TRIM COMBINATION, LEATHER, DK BLUE (3)
274 TRIM COMBINATION, LEATHER, DK BLUE (4)
275 TRIM COMBINATION, LEATHER, DK BLUE (5)
276 TRIM COMBINATION, LEATHER, DK BLUE (6)
28A STRIPE COLOR, ACCENT, BLUE (91)
28I INTERIOR TRIM, MED BLUE (91)
28L SECONDARY COLOR, EXTERIOR, BLACK SAPPHIRE MET (91)
28Q MOLDING COLOR, BLACK SAPPHIRE MET (91)
28T TOP COLOR, BLACK SAPPHIRE MET (91)
28U PRIMARY COLOR, EXTERIOR, BLACK SAPPHIRE MET (91)
29A STRIPE COLOR, ACCENT, MED BLUE (91)
29L SECONDARY COLOR, EXTERIOR, DK BLUE (91)
29T TOP COLOR, DK SAPPHIRE MET (91)
29U PRIMARY COLOR, EXTERIOR, DK BLUE (91)
30A STRIPE COLOR, ACCENT, TWO TONE, LT BLUE MET/GRAY
30L SECONDARY COLOR, EXTERIOR, GRAY BLUE MET (91)
30U PRIMARY COLOR, EXTERIOR, GRAY BLUE MET (91)
31A STRIPE COLOR, ACCENT MINT GREEN MICA (92)
31U PRIMARY COLOR, EXTERIOR, ARCTIC WHITE PEARL (92)
32A STRIPE COLOR, ACCENT, LT TEAL MET (92)
32U PRIMARY COLOR ,EXTERIOR, MED BRIGHT TEAL MT (94)
33A STRIPE COLOR, ACCENT, TWO TONE, VERMILLION/GARNET
33K AUX TOP COLOR , LT DRIFTWOOD (91)
33L SECONDARY COLOR, EXTERIOR, LT MESA BROWN (91)
33P WHEEL COLOR , LT DRIFTWOOD MET (91)
33Q MOLDING COLOR, LT DRIFTWOOD MET (91)
33T TOP COLOR, LT DRIFTWOOD MET (91)
33U PRIMARY COLOR, EXTERIOR, LT MESA BROWN (91)
34A STRIPE COLOR, ACCENT, VERMILLION (91)
34K AUX TOP COLOR, GOLD (91)
34L SECONDARY COLOR, EXTERIOR, LT MESA BRN MET (91)
34P WHEEL COLOR, LT MESA BROWN MET (91)
34Q MOLDING COLOR, LT TEAL MET (92)
34U PRIMARY COLOR, EXTERIOR, LT MESA BROWN MET (91)
35A STRIPE COLOR, ACCENT, TWO TONE, VERMILLION/BLACK
35L SECONDARY COLOR, EXTERIQR, YELLOW (92)
35U PRIMARY COLOR, EXTERIOR, YELLOW (92)
36A STRIPE COLOR, ACCENT, TWO TONE, LT TEAL/BLACK (93)
36L SECONDARY COLOR, EXTERIOR, MED DK TEAL MET (92)
36P WHEEL COLOR, YELLOW (92)
36U PRIMARY COLOR, EXTERIOR, MED DK TEAL MET (92)
37A STRIPE COLOR, ACCENT, TWO TONE, DK BRQWN MET/8LACK
37L SECONDARY COLOR, EXTERIOR, DK BRT TEAL MET (91)
37P WHEEL COLOR, DK BRIGHT TEAL MET (91)
37Q MOLDING COLOR, DK BRIGHT TEAL MET
37U PRIMARY COLOR, EXTERIOR, LT BROWN (91)
38A STRIPE COLOR, ACCENT, TWO TONE, LT TEAL MET/BEIGE
38F COVERING COLOR, FLOOR MAT, NATURAL BEIGE (91)
38I INTERIOR TRIM, NATURAL BEIGE (91)
38U PRIMARY COLOR, EXTERIOR, CHAMPAGNE MET (91)
382 TRIM COMBINATION, LEATHER, NATURAL BEIGE (2) (91)
389 SEAT BELT COLOR, NATURAL BEIGE (91)
39A STRIPE COLOR, ACCENT, MED BROWN (91)
39U PRIMARY COLOR, EXTERIOR, DK ADRIATIC BLUE MET (94)
4X8 SEO-INSTRUiENT PNL DELUXE
4Zl SEO-SPARE WHL & STO, NO TIRE
4Z2 SEO-2ND SEAT & BELT
4Z3 SEO-MATS COLOR KEYED
40A STRIPE COLOR, ACCENT, WHITE (91)
40L SECONDARY COLOR, EXTERIOR, WHITE (91)
40P WHEEL COLOR, WHITE (91)
40Q MOLDING COLOR, WHITE (91)
40T TOP COLOR, WHITE (91)
40U PRIMARY COLOR, EXTERIOR, WHITE (91)
41A STRIPE COLOR ACCENT BLACK (91)
41L SECONDARY COLOR, EXTERIOR, BLACK (91)
41P WHEEL COLOR BLACK (91)
41Q MOLDING COLOR, BLACK (91)
41T TOP COLOR, BLACK (91)
42A STRIPE COLOR, ACCENT TWO TONE SILVER/BLACK (91)
42B TRIM COMBINATION, CLOTH, MED GRAYFERN (B)
42C TRIM COMBINATIQN, CLOTH, MED GRAYFERN (C)
42D TRIM COMBINATION, CLOTH, MED GRAYFERN (D)
42E TRIM COMBINATIQN, CLOTH, MED GRAYFERN (E)
42H TRIM C0MBINATION, CLOTH, MED GRAYFERN (H)
42L SECONDARY COLOR, EXTERIOR, SKY BLUE (91)
42P WHEEL COLOR, TURQUOISE MET (91)
42U PRIMARY COLOR , EXTERIOR, SKY BLUE (91)
422 TRIM COMBINATION, LEATHER, MED GRAY FERN (2)
424 TRIM COMBINATION, LEATHER, MED GRAY FERN (4)
43A STRIPE COLOR, ACCENT, MED GREEN (91)
43B TRIM COMBINATION, CLOTH, MED SAGE (B)
43C TRIM COMBINATION, CLOTH, MED SAGE (C)
43D TRIM COMBINATION, CLOTH, MED SAGE (D)
43E TRIM COMBINATION, CLOTH, MED SAGE (E)
43G TRIM COMBINATION, CLOTH, MED SAGE (G)
43H TRIM COMBINATION, CLOTH, MED SAGE ( H )
43I INTERIOR TRIM, MED SAGE (I)
43L SECONDARY COLOR, EXTERIOR, SEAFOAM GREEN (91)
43P WHEEL COLOR, BRT AQUA (92)
43Q MOLDING COLOR, MED AQUA MET (91)
43U PRIMARY COLOR, EXTERIOR, SEAFOAM GREEN (91)
44A STRIPE COLOR, ACCENT, TWO TONE, LT BROWN/DOESKIN
44L SECONDARY COLOR, EXTERIOR, FOREST GREEN MET (91)
44U PRIMARY COLOR, EXTERIOR, FOREST GREEN MET (91)
45A STRIPE COLOR, ACCENT, TWO TONE, MED BEECHWOOD/LT
45Q MOLDING COLOR, MED GREEN MET (91)
45U PRIMARY COLOR, EXTERIOR, MED GREEN MET (91)
46A STRIPE COLOR, ACCENT, TWO TONE, VERMILION/SLATE
46U PRIMARY COLOR, EXTERIOR, DK GREEN (91)
47A STRIPE COLOR, ACCENT, TWO TONE, VERMILLION/BEIGE
47B TRIM COMBINATION, CLOTH, DK RED (B) (91)
47C TRIM COMBINATION, CLOTH, DK RED (C) (91)
41D TRIM COMBINATION, CLOTH, DK RED (D) (91)
47E TRIM COMBINATION, CLOTH, DK RED (E) (91)
47G TRIM CDMBINATION, CLOTH, DK RED (G) (91)
47I INTERIDR TRIM, DK RED (I) (91)
47L SECDNDARY CDLOR, EXTERIOR, DK BLUE MET (91)
47Q MOLDING CDLOR, EURO RED (91)
47U PRIMARY COLOR, EXTERIOR, DK BLUE MET (91)
47V TRIM COMBINATION, VINYL, DK RED (V) (91)
47W TRIM COMBINATION, VINYL , DK RED (W) (91 )
472 TRIM COMBINATIDN, LEATHER, DK RED (2) (91)
48A STRIPE COLOR, ACCENT, SANDSTONE (92)
48B TRIM CDMBINATION, CLOTH, MED EMERALD (B)
48C TRIM COMBINATION, CLOTH, MED EMERALD (C)
48D TRIM COMBINATION, CLOTH, MED EMERALD (D)
48E TRIM COMBINATION, CLOTH, MED EMERALD (E)
4BH TRIM COMBINATION, CLOTH, MED EMERALD (H)
48I INTERIOR TRIM, MED EMERALD (I)
48L SECONDARY COLOR EXTERIOR, DK RED (91)
48Q MDLDING COLOR, DK YELLDW GREEN MET (91)
48U PRIMARY COLOR EXTERIOR, DK RED (91)
482 TRIM COMBINATION, LEATHER, MED EMERALD (2)
483 TRIM COMBINATION, LEATHER, MED EMERALD (3)
484 TRIM COMBINATION, LEATHER MED EMERALD (4)
49A STRIPE COLOR ACCENT LT ANTELOPE (91)
49B TRIM COMBINATION, CLOTH, MIDNIGHT SAGE (B)
49C TRIM COMBINATION, CLOTH, MIDNIGHT SAGE (C)
49D TRIM COMBINATION, CLOTH, MIDNIGHT SAGE (D)
49E TRIM COMBINATION, CLOTH, MIDNIGHT SAGE (E)
49H TRIM COMBINATION, CLOTH, MIDNIGHT SAGE (H)
49U PRIMARY COLOR, EXTERIOR, VERDORO GREEN MET ( 92 )
492 TRIM COMBINATION, LEATHER, MIDNIGHT SAGE (2)
494 TRIM COMBINATION, LEATHER, MIDNIGHT SAGE (4)
5AN TIRE ALL, P225/7DHR15/N WS2 R/PE ST TL AL3
5AQ TIRE ALL, P225/7DHR15/N BL R/PE ST TL AL3
5A1 PANEL LEFT, ADSCO (#7280-20-1)
5A2 PANEL RIGHT, ADSCO (#728D-45-1)
5A3 PANEL LEFT, INTERIOR, PARTITION,TOP SCREEN ADSCO
5A4 PANEL RIGHT, INTERIOR PARTITION, ADSCO #728D-46-1
5A5 RADIATOR, H/D COOLING MANUAL TRANS
5A6 RADIATOR, H/D COOLING AUTO TRANS
5A7 WHEEL SPARE, DELETION
5BI PANEL CENTER, FIXED INTERIOR, PARTITION, TOP SCREEN
5B2 PANEL CENTER, PARTITION PANEL (FIXED} #7280-51-1
5B3 PANEL CENTER, INT, PARTITION, ADSCO #72BD-52-1
5B7 PANEL CENTER, INTERIOR PARTITION, HINGED, ADSCO
5B8 PANEL CENTER, INTERIOR PARTITION, HINGED ADSCO #
5CI PANEL, LH, PLEXIGLASS, ADSCO #5226-2
5C2 PANEL, CTR, PLEXIGLASS, ADSCO #5226-2
5C3 PANEL, RH, PLEXIGLASS, ADSCO #5226-2
5C7 HOOK, CARGO TIE DN, BODY - I0 FT
5C8 HOOK, CARGO TIE DN, BODY - 12 FT
5C9 HOOK, CARGO TIE DN, BODY - 14 FT
5D4 COOLING SYSTEM, EXPORT H/D
5D5 FAN, RADIATOR B00STER
5D8 PAINT PROCESS, BUMPER, FRT, SPECIAL
5D9 PAINT PROCESS, BUMPER, RR, SPECIAL
5E8 MARKING, REFLECTIVE BLACK, DEPARTMENT OF DEFENSE
5E9 MARKING, REFLECTIVE YELLOW ON BLUE, U.S AIR FORCE
5F4 SPRING REAR, II000 LB
5F5 DECAL, ADSCO-WEST ELECTRIC STRIPING, (5858/5859)
5F6 LEVER, PARKING BRAKE ORSCHELIN
5F7 MARKING, RED ON REFLECTIVE WHITE, U.S. AIR FORCE
5H1 PANEL, SERVICE, INTERIOR (#10541/lDS42)
5H2 LAMP, CARGO , ADSCO (SEARS ROEBUCK) (#7799)
5H3 LAMP, CARGO ADSCO (SEARS ROE8UCK #7798) (2)
5H5 WINDOW, SCREEN , SI CARGO DR (SEARS-ROEBUCK) (#7797)
5H6 WINDOW SCREEN, RR DR (SEARS-ROEBUCK) (#7795)
5H8 CYLINDER UNIT FOR SINGLE KEY SYSTEM, CODED 8OLO
5JK TIRE ALL P225/70HRIS/N BL P/PE ST TL HWY
5J2 GENERAT0R, DELETE
5J9 SPRING RR, AUXILIARY ASSIST
5K4 EQUIPMENT, PARALLEL BAR KIT - FRITO LAY
5L7 MARKING, VEH, U S. MARINE CORPS-REFL BLACK
5N1 DOOR RR, 38 IN, W/GLASS
5N2 DOOR RR, 74 IN W/GLASS
5P1 INTERIOR PACKAGE, PARCEL SERVICE, FEDERAL EXPRESS/CR
5P2 WHEEL, ALUMINUM, SPECIAL
5P3 TIRES, SPARE, CARRIER
5P4 NET PACKAGE, ENDGATE
5P6 INTERIOR PACKAGE, PARCEL SERVICE, FEDERAL EXPRESS/AD
5Q2 CONVENIENCE PKG, CARGO VAN
5R2 SEAT RR, INTERMEDIATE, DELETION
5R9 SPEAKER SYSTEM, RR, DELETE
5U9 COVERING, FLOOR MATS, FRT
5V1 CARRIER, SPARE WHEEL W/O TIRE
5V4 APPEARANCE PACKAGE, VEHICLE PROVISIONS #l
5V6 CONVENIENCE PKG, DELUXE
5V7 APPEARANCE PACKAGE, VEHICLE PROVISIONS #2
5X8 CYLINDER UNIT, SIDE CARGO & RR DOOR
5Y1 CARRIER, I/S P/U BOX, MOUNTED, SPARE
5Y9 CLUSTER, INST, DELETION
5Z1 CONTAINER, ENG OIL PAN, 5 QUART
5Z4 WHEEL & TIRE, SPARE, DELETION
5Z5 HUBCAPS, DELETION
5Z7 APPEARANCE PACKAGE, MISC PARTS REQ'D FROM GM T & B
5Z9 ANTENNA, RADIO, DELETE
50F COVERING COLOR, FLOOR MAT, LT YELLOW (91 )
50I INTERIOR TRIM , LT YELLOW (91)
50L SECONDARY COLOR, EXTERIOR, BLUE WHITE (91)
50P WHEEL COLOR, BLUE WHITE (92)
50Q MOLDING COLOR, FLAX (91)
50T TOP COLOR, FLAX (91)
50U PRIMARY COLOR, EXTERIOR BLUE WHITE (91)
503 TRIM COMBINATION, LEATHER, LT YELLOW (3)
504 TRIM COMBINATION, LEATHER, LT YELLOW (4) (91)
505 TRIM COMBINATION, LEATHER, LT YELLOW (S) (91)
506 TRIM COMBINATION, LEATHER LT YELLOW (6}
509 SEAT BELT, COLOR LT YELLOW (9) (91)
51A STRIPE COLOR, ACCENT TWO TONE MED BEECHWOOD/DK
51L SECONDARY COLOR, EXTERIOR SEDONA TAN (91)
51T TOP COLOR, DK ANTELOPE MET (91)
51U PRIMARY COLOR EXTERIOR, SEDONA TAN (91)
52A STRIPE COLOR, ACCENT TWO TONE BLACK/BEIGE MET
52B TRIM COMBINATION, CLOTH, LT NEUTRAL (B) (92)
52D TRIM COMBINATION, CLDTH, LT NEUTRAL (D) (92)
52F COVERING COLOR, FLOOR MAT, LT NEUTRAL (92)
52G TRIM COMBINATION, CLOTH, LT NEUTRAL (G) (92)
52I INTERIOR TRIM, LT NEUTRAL (I) (92)
52L SECONDARY COLOR, EXTERIOR, SEDONA TAN (91)
52P WHEEL COLOR, GOLD MET (91)
52Q MOULDING COLOR, JAMACIA YELLOW (92)
52U PRIMARY COLOR, EXTERIOR, JAMAICA YELLOW (92)
522 TRIM COMBINATION, LEATHER, LT NEUTRAL (2) (92)
523 TRIM COMBINATION, LEATHER, LT NEUTRAL (3) (92)
524 TRIM COMBINATION, LEATHER, LT NEUTRAL (4) (92)
525 TRIM COMBINATION, LEATHER, LT NEUTRAL (S) (92)
526 TRIM COMBINATION, LEATHER, CHAMOIS (6)
529 SEAT BELT COLOR, LT NEUTRAL (9) (92)
53A STRIPE COLOR, ACCENT, TWO TONE, BLACK/GOLD MET (91)
53U PRIMARY COLOR, EXTERIOR, COMPETITION YELLOW, (91)
54A STRIPE COLOR, ACCENT, MED GOLD (91)
54B TRIM COMBINATION, CLOTH , TAUPE ( B) (92)
54D TRIM COMBINATION, CLOTH, TAUPE (D) (92)
54F COVERING COLOR, FLOOR MAT, TAUPE (92)
54G TRIM COMBINATION, CLOTH, TAUPE (G) (92)
54I INTERIOR TRIM , TAUPE (I) (92)
54L SECONDARY COLOR, EXTERIOR, MED FLAX (91)
54Q MDLDING COLOR, SUNFIRE YELLOW (93)
54U PRIMARY COLOR, EXTERIOR, MED FLAX (91)
542 TRIM COMBINATION, LEATHER, TAUPE (2) (92)
543 TRIM COMB NATION, LEATHER, TAUPE (3) (92)
544 TRIM COMBINATION, LEATHER, TAUPE (4) (92)
545 TRIM COMBINATION, LEATHER, TAUPE (S) (92)
546 TRIM COMBINATION, LEATHER, TAUPE (6) (92)
549 SEAT BELT COLOR, TAUPE (9) (92)
55A STRIPE COLOR, ACCENT, GOLD (91)
55Q MOLDING COLOR, LT CANYON YELLOW (92)
55T TOP COLOR, DK BROWN (91)
55U PRIMARY COLOR, EXTERIOR, LT CANYON YELLOW (92)
56A STRIPE COLOR, ACCENT, TWO TONE, DK BROWN/ALMOND
56T TOP COLOR, ALABASTER (91)
56U PRIMARY COLOR, EXTERIOR, ALABASTER (91)
57A STRIPE COLOR, ACCENT, DK TEAL (92)
57L SECONDARY COLOR, EXTERIOR, CAMEL BEIGE (91 )
57P WHEEL COLOR, BEIGE MET (92)
57Q MOLDING COLOR , CAMEL BEIGE (91)
57T TOP COLOR, CAMEL BEIGE (91)
57U PRIMARY COLOR, EXTERIOR, CAMEL BEIGE (91)
58A STRIPE COLOR, ACCENT TWO TONE, BLACK/ORANGE (91)
58L SECONDARY COLOR, EXTERIOR, LT SANDSTONE MET (91)
58T TOP COLOR, LT SADDLE (91)
58U PRIMARY COLOR, EXTERIOR, LT SANDSTONE MET (91)
59A STRIPE COLOR, ACCENT, COPPER BEIGE (91)
59T TOP COLOR, BRONZE MET (93)
59U PRIMARY COLOR, EXTERIOR ORANGE MET (92)
6A2 STEERING COLUMN, SEO KEYED
6A3 COVERING, FLOOR MATS FRT & RR H. D.
6A4 CYLINDER UNIT, SINGLE KEY SYSTEM NO SPECIFIC CODE
6A5 CYLINDER UNIT FOR SINGLE KEY SYSTEM
6B2 HANDLE, REAR DOOR, INOPERATIVE
6B4 TIRE SPARE RELOCATION LH LUG COMPT FL.
6B7 WIRING PROVISIONS ROOF PNL ACCESS HOLE CENTER
6C1 SEAT, FRT BENCH, HEAVY DUTY
6C2 SEAT, RR BENCH, HEAVY DUTY
6C4 SEAT, HEAVY DUTY, FRONT (46/45) SPLIT
6C5 LAMP, INTR ROOF, COURTESY AND READING
6C6 SWITCH, REAR DOOR JAMB, LH & RH
6C7 LAMP, DOME PASSENGER
6C8 CA8LE, RG58 A/U COAX RADIO ANTENNA
6C9 CONDUIT, TWO WAY RADIO CONTROL CABLE
6E2 CYLINDER UNIT, FOR SINGLE KEY SYSTEM, CODED 37D2
6E8 CYLINDER UNIT, FOR SINGLE KEY SYSTEM,
6F5 WIRING PROVISIONS, ROOF
6F8 TRAY, ASH FRT DR
6G2 REINFORCEMENT, ROOF PANEL
6H6 LOCK, AUTOMATIC TRUNK, RELEASE, RT
6J1 WIRING PROVISIONS, IGNITION AND MAIN POWER SUPPLY
6J2 WIRING PROVISIONS, HEADLIGHT FLASHER AND GRILLE
6J3 WIRING PROVISIONS, HEADLIGHT FLASHER, GRILLE LIGHTS
6J4 WIRING PROVISIONS, HORN/SIREN CIRCUIT
6J5 WIRING PROVISIONS, ROOF PNL ACCESS HOLE
6J6 LAMP PACKAGE, EMER VEH R/WDO PNL
6K3 LOCK, AUTO SIDE CARGO & RR DOOR
6K5 CONSOLE, FRT COMPARTMENT FLOOR
6K6 SEAT, BUCKET TYPE, DRIVER
6K8 SEAT, BUCKET TYPE, DRIVER & PASS
6L2 LINING, FULL LENGTH
6L8 MIRROR O/S, STAINLESS
6M1 MIRROR O/S, RR VIEW, WHITE
6M3 MIRROR O/S, LH & RH, WIDE ANGLE
6M4 LINING FULL LENGTH (110 IN WB)
6M9 TIRE SPARE, DELETE, W/WHEEL
6N1 HANDLE, INSIDE L.H. DOOR AND LOCK RELEASE
6N3 HANDLE, I/S, RR DOOR RELEASE ASSIST
6N4 HANDLE, I/S, RR DOQR RELEASE
6N5 HANDLE INOPERATIVE, RR WINDOW
6N6 LOCK CONTROL, RR DOOR, INOPERATIVE
6N8 HANDLE, REAR SEAT ASSIST
6N9 MIRROR O/S, STAINLESS STEEL HEADS
6P1 ARM REST, RH DOOR
6P2 ARM REST, DELETION
6P3 MIRROR O/S, PAINTED WHITE
6P7 MIRROR O/S, RR VIEW L & R REM CONT, CHROME
602 REINFORCEMENT PICK UP B0X
6R2 COVER SPARE TIRE
6R6 TRIM, SEAT SEAMLESS VINYL, FRONT & REAR
6R7 TRIM, SEAT, SEAMLESS CLOTH, FRONT & REAR
6R8 TRIM, SEAT SEAMLESS CLOTH-FRT SEAMLESS VINYL-RR
6S7 TRIM OVERRIDE, CLOTH SEAT TRIM, REPLACING VINYL
6T5 TRIM EXTR, WHITE
6V6 MODIFICATION, CHASSIS RECREATION VEHICLE
6Y1 ORNAMENTATION EXTR MLDG, FRT DOOR BODY SI,
6Y2 SEAT RR, ----DELETE
6Y4 WHEEL & TIRE SPARE DELETE
6Z2 SEAL, SPEEDOMETER SHAFT
60B TRIM COMBINATION, CLOTH, LT DRIFTWOOD ( B)
60C TRIM COMBINATION, CLOTH, MED COGNAC (C) (91)
60D TRIM COMBINATION, CLOTH, LT DRIFTWOOD (D)
60E TRIM COMBINATION, CLOTH, LT DRIFTWOOD (E)
60G TRIM COMBINATION, CLOTH, LT DRIFTWOOD (G)
60H TRIM COMBINATION, CLOTH, LT DRIFTWOOD (H)
60I INTERIOR TRIM, MED COGNAC (91)
60U PRIMARY COLOR EXTERIOR, BEIGE TITANIUM (92)
60V TRIM COMBINATION, VINYL, DK COGNAC (V) (1988 TRK)
60W TRIM COMBINATION, VINYL, DK COGNAC (W) (1988 TRK)
602 TRIM COMBINATION, LEATHER, LT DRIFTWOOD (2)
603 TRIM COMBINATION, LEATHER, LT DRIFTWOOD (3)
604 TRIM COMBINATION, LEATHER, LT DRIFTWOOD (4)
609 SEAT BELT COLOR, MED COGNAC (91)
61A STRIPE COLOR, ACCENT, TWO TONE, ALMOND/DK BROWN
61I INTERIOR TRIM, DK SIENNA (I)
61L SECONDARY COLOR, EXTERIOR, TAN (91)
61U PRIMARY COLOR, EXTERIOR, TAN (91)
62A STRIPE COLOR, ACCENT, ORANGE (91)
62B TRIM COMBINATION, CLOTH, LT SADDLE (B)
62C TRIM COMBINATION, CLOTH, LT SADDLE (C)
62D TRIM COMBINATION, CLOTH, LT SADDLE (D)
62E TRIM COMBINATION, CLOTH, LT SADDLE (E)
62G TRIM COMBINATION, CLOTH, LT SADDLE (G)
62H TRIM COMBINATION, CLOTH, LT SADDLE (H)
62I INTERIOR TRIM, LT SADDLE (I)
62L SECONDARY COLOR, EXTERIOR, LT TAUPE (92)
62N TRIM COMBINATION, VINYL, LT SADDLE (N)
62Q MOLDING COLOR, LT 8EECHWOOD MET (91)
62R TRIM COMBINATION, VINYL, LT SADDLE (R)
62T TOP COLOR, LT BEECHWOOD MET (91)
62U PRIMARY COLOR EXTERIOR, LT BEECHWOOD MET (91)
62V TRIM COMBINATION, VINYL, LT SADDLE (V)
62W TRIM COMBINATION, VINYL, LT SADDLE (W)
62Y TRIM COMBINATION, VINYL, LT SADDLE (Y)
62Z TRIM COMBINATION, VINYL LT SADDLE (Z)
622 TRIM COMBINATION, LEATHER, LT SADDLE (2)
623 TRIM COMBINATION, LEATHER, LT SADDLE (3)
626 TRIM COMBINATION, LEATHER, LT SADDLE (6)
63A STRIPE COLOR, ACCENT, TWO TONE, LT AUBURN/DK AUBURN
63F COVERING COLOR, FLOOR MAT, MED SADDLE (93 E/K)
63I INTERIOR TRIM, MEDIUM SADDLE (93)
63L SECONDARY COLOR, EXTERIOR, MED TAUPE MET (92)
63T TOP COLOR, MED TAUPE (92)
63U PRIMARY COLOR, EXTERIOR, MED TAUPE MET (92)
639 SEAT BELT, COLOR SADDLE (1989 PASS V)
64A STRIPE COLOR, ACCENT, LT AUBURN (91)
64B TRIM COMBINATION, CLOTH, LT BEIGE (B) (92)
64C TRIM COMBINATION, CLOTH, LT BEIGE (C) (92)
B4D TRIM COMBINATION, CLOTH, LT BEIGE (D) (92)
64E TRIM COMBINATION, CLOTH, LT BEIGE (92)
64F COVERING COLOR, FLOOR MAT, LT BEIGE (92)
64G TRIM COMBINATION, CLOTH, LT BEIGE (G) (92)
64H TRIM COMBINATION, CLOTH, BEIGE (H) (92)
64I INTERIOR TRIM, LIGHT BEIGE (I) (92)
64J TRIM COMBINATION, CLOTH, LT BEIGE (J) (92)
64N TRIM COMBINATION, VINYL, LT BEIGE (N) (92)
645 ROOF COLOR, BRONZE, REMOVABLE PANEL
64T TOP COLOR, LT AUBURN MET (91)
64U PRIMARY COLOR, EXTERIOR, LT AUBURN MET (91)
64V TRIM COMBINATION, VINYL, LT BEIGE (V) (92)
64W TRIM COMBINATION, VINYL , LT BEIGE (W) (92)
642 TRIM COMBINATION, LEATHER, LT BEIGE (2) (92)
643 TRIM COMBINATION, LEATHER, LT BEIGE (3) (92)
644 TRIM COMBINATION, LEATHER, LT BEIGE (4) (92)
645 TRIM COMBINATION, LEATHER, LT BEIGE (5) (92)
649 SEAT BELT COLOR, LIGHT BEIGE (9) (92)
65A STRIPE COLOR, ACCENT, TWO TONE, LT AUBURN/DK CLARET
65B TRIM COMBINATION, CLOTH, MED ANTELOPE (B) (91)
65C TRIM COMBINATION, CLOTH, MED ANTELOPE (C) (91)
65D TRIM COMBINATION, CLOTH, MED ANTELOPE (D) (91)
65E TRIM COMBINATION, CLOTH, MED ANTELOPE (E) (91}
65F COVERING COLOR, FLOOR MAT, MED ANTELOPE (91)
65G TRIM COMBINATION, CLOTH, MED ANTELOPE (G) (91)
65H TRIM COMBINATION, CLOTH, MED ANTELOPE (H) (1989)
65I INTERIOR TRIM, MED ANTELOPE (91)
65L SECONDARY COLOR,EXTERIOR, LT CAMEL TITANIUM (91)
65Q MOLDING COLOR, LT CAMEL TITANIUM (91)
65T TOP COLOR, LT CAMEL TITANIUM (91)
65U PRIMARY COLOR, EXTERIOR, LT CAMEL TITANIUU (91)
652 TRIM COMBINATION, LEATHER, MED ANTELOPE (2) (91)
653 TRIM COMBINATION, LEATHER, MED ANTELOPE (3) (91)
654 TRIM COMBINATION, LEATHER, MED ANTELOPE (4) (91)
655 TRIM COMBINATION, LEATHER, MED ANTELOPE (5) (91)
659 SEAT BELT COLOR, MED ANTELOPE (9) (91)
66A STRIPE COLOR, ACCENT, DK AUBURN (91)
66B TRIM COMBINATION, CLOTH, MED BEECHWOOD (B)
66C TRIM COMBINATION, CLOTH, MED BEECHWOOD (C)
66D TRIM COMBINATION, CLOTH, MED BEECHWOOD (D)
66E TRIM COMBINATION, CLOTH, MED BEECHWOOD (E}
66F COVERING, COLOR, FLOOR MAT MED BEECHWOOD (91)
66G TRIM COMBINATION, CLOTH, MED BEECHWOOD (G}
66H TRIM COMBINATION, CLOTH MED BEECHWOOD, (1989 PASS)
66I INTERIOR TRIM, MED BEECHWOOD (91)
66J TRIM COMBINATION, CLOTH, MED BEECHWOOD (J) (1989)
66L SECONDARY COLOR, EXTERIOR, DK AUBURN MET (91)
66Q MOLDING COLOR, DK AUBURN MET (91)
66T TOP COLOR, DK AUBURN MET (91)
66U PRIMARY COLOR, EXTERIOR, DK AUBURN MET (91)
662 TRIM COMBINATION, LEATHER, MED BEECHWOOD (91)
663 TRIM COMBINATION, LEATHER, MED BEECHWOOD (3) (92)
664 TRIM COMBINATION, LEATHER MED BEECHWOOD (4) (91)
665 TRIM COMBINATION, LEATHER NED BEECHWOOD (5) (91)
666 TRIM COMBINATION, LEATHER, MED BEECHWOOD (6) (91 )
667 TRIM COMBINATION, CLOTH, HD, MED BEECHWOOD
668 TRIM COMBINATION, LEATHER, MED BEECHWOOD (B) (92)
669 SEAT BELT COLOR, MED BEECHWOOD (9) (91)
67A STRIPE COLOR, ACCENT, LT CAMEL MET (91)
67B TRIM COMBINATION, CLOTH, LT CAMEL (B) (91)
67C TRIM COMBINATION, CLOTH, LT CAMEL (C) (91)
67D TRIM COMBINATION, CLOTH, LT CAMEL (D) (91)
67E TRIM COMBINATION, CLOTH, LT CAMEL (E) (91)
67F COVERING COLOR, FLOOR MAT, CAMEL (91)
67G TRIM COMBINATION, CLOTH, CAMEL (G)
67H TRIM COMBINATION, CLOTH, LT CAMEL (H) (91)
67I INTERIOR TRIM, LT CAMEL (91)
67J TRIM COMBINATION, CLOTH, LT CAMEL (J) (91)
67L SECONDARY COLOR, EXTERIOR, LT CAMEL MET (91)
67N TRIM COMBINATION, VINYL, CAMEL (N)
67P WHEEL COLOR, LT CAMEL MET (91)
67Q MOLDING COLOR, LT CAMEL MET (91)
67T TOP COLOR, LT CAMEL MET (91)
67U PRIMARY COLOR, EXTERIOR, LT CAMEL MET (91)
672 TRIM COMBINATION, LEATHER, LT CAMEL (2j (91)
673 TRIM COMBINATION, LEATHER, LT CAMEL (3)(91)
674 TRIM COMBINATION, LEATHER, LT CAMEL (4) (91)
675 TRIM COMBINATION, LEATHER, LT CAMEL (5) (91)
676 TRIM COMBINATION, LEATHER, LT CAMEL (6) (91)
678 TRIM COMBINATION, CLOTH, LT CAMEL (B) (91)
679 SEAT BELT, COLOR,LT CAMEL (91)
68A STRIPE COLOR, ACCENT, TWO TONE, LT AUBURN/LT
68B TRIM COMBINATION, CLOTH, DK AUBURN ( B) (91 )
68C TRIM COMBINATION, CLOTH, DK AUBURN (91)
68D TRIM COMBINATION, CLOTH, DK AUBURN (D) (91)
68E TRIM COMBINATION, CLOTH, DK AUBURN (E) (91)
68F COVERING COLOR, FLOOR MAT, DK AUBURN (91)
68G TRIM COMBINATION, CLOTH, DK AUBURN (G) (91)
68I INTERIOR TRIM, DK AUBURN (91)
68L SECONDARY COLOR, EXTERIOR, CINNAMON MET ( 92 )
68R TRIM COMBINATION , VINYL , RUSSET (R)
68T TOP COLOR, NEUTRAL BEIGE (91)
68U PRIMARY COLOR, EXTERIOR, CINNAMON MET (92}
682 TRIM COMBINATION, LEATHER, DK AUBURN (2) (91 )
683 TRIM COMBINATION, LEATHER, DK AUBURN (3) (91)
684 TRIM COMBINATION, LEATHER, DK AUBURN (4) (91)
685 TRIM COMBINATION, LEATHER, DK AUBURN (S) (91)
689 SEAT BELT, COLOR, DK AUBURN (9) (91)
69A STRIPE COLOR, ACCENT, LT BEIGE (91)
69B TRIM COMBINATION, CLOTH, MED BEIGE (B)
69C TRIM COMBINATION, CLOTH, MED BEIGE (C)
69D TRIM COMBINATION, CLOTH, MED BEIGE (D)
69E TRIM COMBINATION, CLOTH, MED BEIGE (E)
69G TRIM COMBINATION, CLOTH, MED BEIGE (G)
69H TRIM COMBINATION, CLOTH, MED BEIGE (H)
69L SECONDARY COLOR, EXTERIOR, ROOTBEER MET (92)
69Q MOLDING COLOR, ROOTBEER, MET (92)
69T TOP COLOR, ROOTBEER (92)
69U PRIMARY COLOR, EXTERIOR, MED BEECHWOOD MET (91)
69V TRIM COMBINATION, VINYL, MED BEIGE (V)
69W TRIM COMBINATION, VINYL MED BEIGE (W)
692 TRIM COMBINATION, LEATHER, MED BEIGE (2)
693 TRIM COMBINATION, LEATHER, MED BEIGE (3)
694 TRIM COMBINATION, LEATHER, MED BEIGE (4)
696 TRIM COMBINATION, LEATHER, MED BEIGE (6)
7B3 SUSPENSION SYSTEM, SPECIAL HANDLING
7B4 SUSPENSION SYSTEM, SPECIAL RYDER
7B7 SUSPENSION SYSTEM, HEAVY DUTY, FRONT
7J1 PACKAGE,HOT CLIMATE
7L1 GENERATOR , A/C 120 AMP
7L4 THROTTLE CONTROL,MANUAL ASM
7L8 COOLING SYSTEM, TRANS, OIL, H D
7L9 COOLING SYSTEM, STEERING, OIL
7P8 COOLING SYSTEM, ENG OIL, SEE KC4
7S1 FUEL TANK, RH MOUNTED, 20 GAL
7T6 FUEL, FITTING, LINE TAKE
7X6 SPOTLAMP, LEFT HAND, PILLAR MOUNTED, HALOGEN
7X7 SPOTLAMP, LEFT AND RIGHT, PILLAR MOUNTED, HALOGEN
7XB SPOTLAMP, PROVISIONS, LH
7X9 SPOTLAMP, PROVISIONS, LH W RH
7Y1 LAMP, ENGINE COMPARTMENT
7Y2 LAMP, DOOR OPENING WARNING
7Y4 METER, ENGINE, HOUR
7Y5 BATTERY , HO, AUXILIARY
7Y6 SWITCH, DOME LAMP DOOR JAMB INOPERATIVE
7Z1 HORN, DUAL, HIGH NOTE
7Z4 CLUSTER, INST, OIL, COOL TEMP, VOLTS SEE U14
7Z5 CIRCUIT BREAKERS, ADDITIONAL 12 VOLT
7Z7 CLUSTER INST, KILO, GOVERNMENT LEADED FUEL
7Z8 SPEEDOMETER, PRODUCTION TYPE
7Z9 CLUSTER POLICE TYPE-TELLTALE
70A STRIPE COLOR ACCENT, TWO TONE, RED/DK CLARET (91)
70B TRIM COMBINATION, CLOTH, DK MAPLE RED (B) (91)
70C TRIM COMBINATION, CLOTH, DK MAPLE RED (C) (91)
70D TRIM COMBINATION, CLOTH, DK MAPLE RED (D) (91)
70E TRIM COMBINATION, CLOTH, DK MAPLE RED (E) (91)
70F COVERING COLOR, FLOOR MAT DK MAPLE RED (91)
70G TRIM COMBINATION, CLOTH, OK MAPLE RED (G) (91)
70H TRIM COMBINATION, CLOTH, DK MAPLE RED (H) (91)
70I INTERIOR TRIM, DK MAPLE RED (91)
70J TRIM COMBINATION, CLOTH, DK MAPLE RED (J) (91)
70L SECONDARY COLOR, EXTERIOR, RED (91)
70N TRIM COMBINATION, VINYL, DK MAPLE RED (N)
70R TRIM COMBINATION, VINYL, DK MAPLE RED (R)
70T TOP COLOR, TORCH RED (93)
70U PRIMARY COLOR, EXTERIOR, TORCH RED (91)
70V TRIM COMBINATION, VINYL, DK MAPLE RED (V)
702 TRIM COMBINATION, LEATHER, DK MAPLE RED (2) (91)
703 TRIM COMBINATION, LEATHER, DK MAPLE RED (3) (91)
709 SEAT BELT COLOR, DK MAPLE RED (9) (91)
71A STRIPE COLOR, ACCENT, TWO TONE, SILVER/RED (91)
71F COVERING COLOR, FLOOR MAT, MAROON (91)
71I INTERIOR TRIM, MAROON (91)
710 MOLDING COLOR, RED (91)
71T TOP COLOR, RUBY RED (93)
71U PRIMARY COLOR, EXTERIOR, RED ORANGE (91)
712 TRIM COMBINATION, LEATHER, MAROON (2) (91)
719 SEAT BELT COLOR, MAROON (91)
72A STRIPE COLOR, ACCENT, MED GARNET RED (91)
72B TRIM COMBINATION, CLOTH, DK CARMINE (B)
72C TRIM COMBINATION, CLOTH, DK CARMINE (C)
72D TRIM COMBINATION, CLOTH, DK CARMINE (D)
72E TRIM COMBINATION, CLOTH, DK CARMINE (E)
72F COVERING, COLOR FLOOR MAT, DK CARMINE (91)
72G TRIM COMBINATION, CLOTH, DK CARMINE (G)
72H TRIM COMBINATION CLOTH, DK CARMINE (H)
72I INTERIOR TRIM, DK CARMINE (91)
72L SECONDARY COLOR, EXTERIOR, MED GARNET RED MET (91)
72N TRIM COMBINATION VINYL, DK CARMINE (N)
72P WHEEL COLOR, MED GARNET RED MET (91)
72Q MOLDING COLOR, MED GARNET RED MET (91)
72R TRIM COMBINATION, VINYL, DK CARUINE (R)
72T TOP COLOR, MED GARNET RED MET (91)
72U PRIMARY COLOR, EXTERIOR, MED GARNET RED MET (91)
72V TRIM COMBINATION, VINYL, DK CARMINE (V)
72W TRIM COMBINATION, VINYL, DK CARMINE (W)
72Y TRIM COMBINATION, VINYL, DK CARMINE (Y)
72Z TRIM COMBINATION, VINYL, DK CARMINE (Z)
722 TRIM COMBINATION, LEATHER, DK CARMINE (2) (91)
723 TRIM COMBINATION, LEATHER, DK CARMINE (3) (91)
724 TRIM COMBINATION, LEATHER, DK CARMINE (4)
726 TRIM COMBINATION, LEATHER, DK CARMINE (6)
729 SEAT BELT COLOR, DK CARMINE (9) (91)
73A STRIPE COLOR, ACCENT, TWO TONE, VERMILLION/CARMINE
73B TRIM COMBINATION, CLOTH, FLAME RED (B) (91)
73C TRIM COMBINATION, CLOTH, FLAME REO (C) (91)
73F COVERING COLOR, FLOOR MAT, FLAME RED (91)
73I INTERIOR TRIM, FLAME RED (I) (91)
73U PRIMARY COLOR ,EXTERIOR, YELLOW RED MET (91)
732 TRIM COMBINATION, LEATHER, FLAME RED (2) (91)
733 TRIM COMBINATION, LEATHER, FLAME RED (3) (91)
734 TRIM COMBINATION, LEATHER. FLAME RED (4) (91)
739 SEAT BELT COLOR, FLAME RED (91)
74A STRIPE COLOR, ACCENT, TWO TONE, BLACK/RED (91)
74I INTERIOR TRIM , CARMINE (I)
74L SECONDARY COLOR, EXTERIOR, FLAME RED MET (91)
74Q MOLDING COLOR, FLAME RED MET (91)
74T TOP COLOR, FLAME RED MET (91)
74U PRIMARY COLOR, EXTERIOR, VICTORY RED (91)
742 TRIM COMBINATION, LEATHER, CARMINE (2)
744 TRIM COMBINATION, LEATHER, DK CARMINE (4) SSV
75A STRIPE COLOR ACCENT, RED (91)
75B TRIM COMBINATION, CLOTH, BORDEAUX RED (B) (93)
75F COVERING, COLOR FLOOR MAT, BORDEAUX RED (94)
75G TRIM COMBINATION, CLOTH, BORDEAUX RED (G) (93)
75I INTERIOR TRIM, BORDEAUX RED (93)
75L SECONDARY COLOR, EXTERIOR, BRILLIANT RED BET (91)
75Q MOLDING COLOR , BRILLIANT RED MET (91)
75U PRIMARY COLOR, EXTERIOR BRILLIANT RED MET (91)
752 TRIM COMBINATION, LEATHER, BORDEAUX RED (2) (93)
753 TRIM C0MBINATION, LEATHER, BORDEAUX RED (3) (93)
754 TRIM COMBINATION, LEATHER, BORDEAUX RED (4) (94)
759 SEAT BELT, COLOR, B0RDEAUX RED (93)
76A STRIPE COLOR, ACCENT, DK GARNET RED (91)
76L SECONDARY COLOR, EXTERIOR, DK GARNET RED MET (91)
760 MOLDING COLOR, DK GARNET RED MET (91)
76T TOP COLOR DK, GARNET RED MET (91)
76U PRIMARY COLOR, EXTERIOR, DK GARNET RED MET (91)
77A STRIPE COLOR, ACCENT, VICTORY RED t92)
77B TRIM COMBINATION, CLOTH, DK MAPLE tB)
77C TRIM COMBINATION, CLOTH, DK MAPLE (C)
77D TRIM COMBINATION, CLOTH, DK MAPLE (D)
77E TRIM COMBINATION, CLOTH, DK MAPLE (E)
77G TRIM COMBINATION, CLOTH, DK MAPLE (G)
77H TRIM COMBINATION, CLOTH, DK MAPLE (H)
77I INTERIOR TRIM, DK MAPLE (I)
77L SECONDARY COLOR, EXTERIOR, DARK CHERRY MET (92)
77Q MOLDING COLOR, DK MAPLE RED MET
77T TOP COLOR, DK CHERRY MET (92)
77U PRIMARY COLOR, EXTERIOR, DARK CHERRY MET (92)
77V TRIM C0MBINATION, VINYL, DK MAPLE (V)
77W TRIM C0MBINATION, DK MAPLE (W)
772 TRIM COMBINATION, LEATHER, DK MAPLE (2)
773 TRIM C0MBINATION, LEATHER, DK MAPLE (3)
774 TRIM COMBINATION, LEATHER, DK MAPLE (4)
78A STRIPE COLOR, ACCENT, TWO TONE, RED/DK RED (92}
78B TRIM C0MBINATION, CLOTH, GARNET RED (B) (91)
78C TRIM COMBINATION, CLOTH, GARNET RED (C) (91)
78D TRIM C0MBINATION, CLOTH, GARNET RED (D) (91)
78E TRIM COMBINATION, CLOTH, GARNET RED (E) (91)
78F COVERING COLOR, FLOOR MAT, GARNET (91)
78G TRIM COMBINATION, CLOTH, GARNET RED (G) (91)
78H TRIM COMBINATION, CLOTH, GARNET RED (H) (91)
78I NTERIOR TRIM, GARNET RED (91)
78J TRIM COMBINATION, CLOTH, GARNET RED (J) (91)
78L SECONOARY COLOR, EXTERIOR, DK YELLOW RED MET (91>
78X MOLDING COLOR, DK RED (91)
78T TOP COLOR, D MAPLE, RED MET (91)
78U PRIMARY COLOR, EXTERIOR, DK YELLOW RED MET (91)
782 TRIM COMBINATION, LEATHER, GARNET RED (2) (91)
783 TRIM COMBINATION, LEATHER, GARNET RED (3) (91)
784 TRIM COMBINATION, LEATHER, GARNET RED (4) (91)
785 TRIM C0MBINATION, LEATHER, GARNET RED (5) (91)
786 TRIM COMBINATION, LEATHER, GARNET RED (6) (92)
788 TRIM COMBINATION, CLOTH, GARNET RED (B) (92)
789 SEAT BELT COLOR, GARNET RED (91)
79A STRIPE COLOR, ACCENT, DK CLARET (91)
798 TRIM COMBINATION, CLOTH, RUBY RED (B) (93)
79C TRIM COMBINATION, CLOTH, RUBY RED (C) (93)
79D TRIM COMBINATION, CLOTH, RUBY RED (D) (93)
79E TRIM COMBINATION, CLOTH, RUBY REO (E) (93)
79F COVERING COLOR, FLOOR MAT, DK CLARET (1989 PASS D)
79G TRIM COMBINATION, CLOTH, RUBY RED (G) (94)
79H TRIM COMBINATION, CLOTH, DK CLARET (H)
79I INTERIOR TRIM, RUBY RED (93)
79J TRIM COMBINATION, CLOTH, RUBY RED (J) (93)
79N TRIM COMBINATION, VINYL, DK CLARET (N)
79R TRIM COMBINATION,VINYL, DK CLARET (R)
79U PRIMARY COLOR, EXTERIOR, BURGUNDY MET (91)
79V TRIM COMBINATION, VINYL, DK CLARET (V)
79W TRIM COMBINATION, VINYL, DK CLARET (W)
792 TRIM COMBINATION, LEATHER, RUBY RED (2) (93)
793 TRIM COMBINATION, LEATHER, RUBY RED (3) (93)
794 TRIM COMBINATION, LEATHER, RUBY RED (4) (94)
799 SEAT BELT COLOR, RUBY RED (93)
8A3 GENERATOR, 124 AMP, CS144
8A8 TACHOMETER,
8B2 MIRROR O/S, RH & LH, WIDELOOP, PAINTED
8B3 COOLANT, ETHELENE GLYCOL) (-34 DEGREES)
8B5 RADIO PROVISIONS, INSTALLATION
8B7 HOSE, RADIATOR & HEATER (SPECIAL)
8B8 ODOMETER, SPECIAL INSTRUMENT CLUSTER
8C5 JACK, C9 ELECTRICAL OUTLET
8C9 SEAT, FRT/LAP & SHOULDER BELT DELETE
8D2 FUEL, ADDITIONAL (I GAL)
8D5 HEADLAMPS, SINGLE RECTANGULAR ASSIST
8D6 REINFORCEMENT, RR FRAME RAIL
8E1 FUEL, ADDITIONAL - 3 GALLONS
8E2 SEAT, DELETION, FRONT
8E6 BUMPER RR, PAINTED
8E8 BUMPER FRT, PAINTED
8F1 FUEL, ADDITIONAL TWO GALLONS
8F4 BUMPER RR, STEP
8GB LAMP, PASSENGER-DOME
8G9 MIRROR O/S, RH & LH, "WIDELOOP", STAINLESS
8H1 INSULATION, EXTRA-FLOOR
8H3 FLOOR, 3/4' PLYWOOD UNION CITY BODY
8H5 BUMPER FRT, DELETE
8H9 FLASHER, HEAVY DUTY TURN SIGNAL
8K3 SPEAKER SYSTEM, RADIO, INSTRUMENT PANEL
8M3 SWITCH, DOME LIGHT R . H . DOOR OPERATED
8M5 BUMPER FRT, PAINTED, BLACK, WRAP AROUND
8M7 HEADLAMPS, SUBSTITUTION
8MB HANDLE, I EA ON INSIDE OF RR HANDLES
8M9 HANDLE, I EA MOUNTED INSIDE OF DOOR
8N1 SALES PACKAGE, COLD CLIMATE, DIESEL USED WITH
8N4 SPEAKER SYSTEM, INSTRUMENT PANEL (COAXIAL)
8N9 SPEAKER, RDO DELETE
8P3 INDICATOR, TRANSMISSION FLUID
8P5 WINDOW, PARTITION 13 X 18 INCH
8P6 BUMPER RR, SPECIAL PAINT
8Q2 VENT, STATIC TYPE ROOF
8Q5 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
8Q7 VENT, ADSCO, ROOF (DRIVERS COMPARTMENT#10540)
8Q9 VENT, ROOF ADSCO-EVANS(STATIC) (#S999)
8R6 FUEL, SENDER ASM, HIGH TEMP
8R9 CONTAINER, INSTRUMENT ADSCO(SEARS) (#5969)
8S4 MIRROR O/S, LH 6 RH, WEST COAST TYPE, LARGE, W/6 IN
8S9 CHASSIS, SPECIAL, UTILITY 80DY
8U4 HEATER ENG, BLOCK (SEO)
8W5 GENERATOR, 105 AMP
8W7 SEAT, BUCKET TYPE, DRIVER & PASS, LOW BACK FRT
8W9 SPRING, FRONT SUSPENSION
8X4 PARTITION, PLYWOOD, W/CTR SLIDING DOOR
8X7 SHOCK ABSORBERS, FRT & RR, GAS PRELOADED, DELCO/BILS
8X8 VANITY, MAINTAINENCE (OPER SI CARGO DOOR) ADSCO(#6135
8Z1 ENGINE, DELETE
8Z2 TRANSMISSION, DELETE
8Z3 GENERATOR, IOO AMP, HEAVY DUTY, PENSKE/RYDER
8Z5 CAP, METAL VALVE STEM
80A STRIPE COLOR, ACCENT, TWO TONE, RED/DK SAPPHIRE
80B TRIM COMBINATION, CLOTH, SAND (B)
80C TRIM COMBINATION, CLOTH, SAND (C)
80D TRIM COMBINATION, CLOTH, SAND (D)
80G TRIM COMBINATION, CLOTH, SAND (G)
80I INTERIOR TRIM, SAND (I)
80Q MOLDING COLOR, MED QUASAR BLUE MET (91)
80U PRIMARY COLOR, EXTERIOR, MED QUASAR BLUE MET (91)
81A STRIPE COLOR, ACCENT, TWO TONE, RED/BLACK (91)
81P WHEEL CDLOR, BRIGHT RED (91)
81Q MOLDIMG COLOR, BRIGHT RED (91)
81U PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
82A STRIPE COLOR, ACCENT, LT SAPPHIRE TITANIUM (91)
82B TRIM COMBINATION, CLOTH, MED DK GRAY (91)
82C TRIM COMBINATION, CLOTH, MED DK GRAY (C) (91)
82D TRIM COMBINATION, CLOTH, MED DK GRAY ( D) (91 )
82E TRIM COMBINATION, CLOTH, MED DK GRAY (E) (91)
82F COVERING COLOR, FLOOR MAT, MED DK GRAY (91)
82G TRIM COMBINATION, CLOTH, MED DK GRAY (G) (91)
82H TRIM COMBINATION, CLOTH MED DK GRAY (H) (91)
82I INTERIOR TRIM, MED DK GRAY (91)
82J TRIM COMBINATION, CLOTH, MED DK GRAY (J) (91)
82L SECONDARY COLOR, EXTERIOR, LT SAPPHIRE TITANIUM
82N TRIM COMBINATION, VINYL, DK MED GRAY (N)
82Q MOLDING COLOR, LT SAPPHIRE TITANIUM (91)
82R TRIM COMBINATION, VINYL , DK MED GRAY (R)
82T TOP COLOR, LT SAPPHIRE TITANIUM (91)
82U PRIMARY COLOR, EXTERIOR, LT SAPPHIRE TITANIUM (91)
82V TRIM COMBINATION, VINYL, DK MED GRAY (V)
82W TRIM COMBINATION, VINYL, DK MED GRAY (W)
82Y TRIM COMBINATION, VINYL, DK MED GRAY (Y)
82Z TRIM COMBINATION, VINYL, DK MED GRAY (Z)
822 TRIM COMBINATION, LEATHER, MED DK GRAY (2} (91)
823 TRIM COMBINATION, LEATHER, MED DK GRAY (3) (91)
826 TRIM COM8INATION, LEATHER, DK MED GRAY (6)
829 SEAT BELT COLOR, MED DK GRAY (91)
83A STRIPE COLOR, ACCENT, TWO TONE, GUNMETAL/GARNET RED
83L SECONDARY COLOR, EXTERIOR, MED SAPPHIRE BLUE FM
83Q MOLDING COLOR , MED SAPPHIRE BLUE FM (91)
83T TOP COLOR, MED SAPPHIRE BLUE FM (91)
83U PRIMARY COLOR, EXTERIOR, MED SAPPHIRE BLUE FM (91)
84L SECONDARY COLOR, EXTERIOR, HAWAIIAN ORCHID (92)
84P WHEEL COLOR GRAY (91)
84Q MOLDING COLOR, HAWAIIAN ORCHID (92)
84U PRIMARY COLOR, EXTERIOR HAWAIIAN ORCHID (92)
85A STRIPE COLOR, ACCENT, MED SLATE GRAY (91)
85L SECONDARY COLOR, EXTERIOR MED SLATE GRAY MET (91)
85P WHEEL COLOR, MED SLATE GRAY MET (91)
85Q MOLDING COLOR, MED SLATE GRAY MET (91)
85T TOP COLOR, MED SLATE GRAY MET (91)
85U PRIMARY COLOR, EXTERIOR, MED SLATE GRAY MET (91)
86A STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
86U PRIMARY COLOR, EXTERIOR, WHEATLAND YELLOW (91)
87A STRIPE COLOR, ACCENT, GUNMETAL MET (91)
87L SECONDARY COLOR, EXTERIOR GUNMETAL MET (91)
87Q MOLDING COLOR, GUNMETAL MET (92)
87T TOP COLOR, GUNMETAL MET (91)
87U PRIMARY COLOR, EXTERIOR, GUNMETAL MET (91)
88A STRIPE COLOR, ACCENT, TWO TONE, GOLD/BLACK (91)
88L SECONDARY COLOR, EXTERIOR, TANGIER ORANGE (91)
88T TOP COLOR, DK PLUM MET ( 92 )
88U PRIMARY COLOR , EXTERIOR, TANGIER ORANGE (91)
89A STRIPE COLOR, ACCENT, TWO TONE, RED/LT GRAY (91)
89U PRIMARY COLOR, EXTERIOR, AUTUMN MAPLE MET (91)
9A4 SALES PACKAGE, REC VEHICLE, MARK III
9A5 SALES PACKAGE, REC VEHICLE, DELETION
9A6 SALES PACKAGE, REC VEHICLE, STARCRAFT
9A7 SALES PACKAGE, RECREATIONAL VEHICLE
9B8 MODIFICATION, RYDER TRUCK VEHICLE
9C1 SEO VEHICLE, POLICE CAR
9C2 GOVERNOR, ELECTRONIC SPEED SENSOR - 85 MPH
9C6 SEO VEHICLE, TAXI CAB
9C7 MIRROR O/S, LH & RH, WEST COAST TYPE, LARGE,
9D2 RACK, SHELVES, ROLL OUT
9D9 MIRROR I/S, R/V, DELETION
9F2 MIRROR O/S, DELETION
9G4 TIRE REAR, DELETE 2 O/S (SPL ORDER)
9G6 SWITCH, DOME LAMP, RH RR DR JAMB
9G7 SWITCH, D0ME LAMP, FRT SIDE CARGO, RR DR JAMB
9H2 FUEL TANK, DELETION
9H5 LAMP, DELETION, ROOF MARKER
9H7 CARRIER SPARE TIRE, WITH HOIST, DELETION
9J4 BUMPER, RR DELETE
9J6 STEERING COLUMN, TILT TYPE (SEO)
9J7 MIRROR AUX O/S, 6.5" X 6" DUAL SPOT, CONVEX
9K3 AIR CLEANER 'OFF ROAD' PACKAGE
9K6 RADIO PROVISIONS, AM/FM STEREO RADIO, MISC MOUNTING
9K9 RUSTPROOFING, (OUTSIDE SOURCE) (TROPICAL) (MEETS
9L1 RUSTPROOFING, (OUTSIDE SOURCE) (MEETS FED STD 297)
9L5 FUEL SCREEN, ANTI-SYPHON
9L7 RADIO PROVISIONS, MISC. MOUNTING REQ.
9L8 RESTRAINT SYSTEM, FRT SEAT, W/DUAL MODE RETRACTOR
9L9 CYLINDER UNIT, DUAL KEY SYSTEM
9M2 CYLINDER UNIT, CURTIS BURNS - C0MM0N KEYS
9M3 COVERING, MAT, RUBBER, STEP WELL
9M6 SUSPENSION SYSTEM, STEERING UODIFICATION
9Q1 DECAL, ADSCO-SEARS
9Q3 CONVENIENCE PKG, SPECIAL
9Q4 SPRING REAR, LOWERED
9Q7 END GATE, DELETION, ASSEUBLY
9R7 INTERIOR PACKAGE SEAT RED
9S6 WIRING PROVISIONS, TAIL LIGHT, HEAVY GAGE
9T1 DOOR RR, 74 IN STRAP HINGES - UCB
9T2 DOOR RR, 66 IN OVERHEAD, SLIDING W/WINDOW - UCB
9T3 PARTITION, SLIDING, PLYWOOD W/CENTER SLIDING WOR -
9T4 PARTITION, EXPANDED METAL, W/CTR SLIDING WOR - UCB
9T5 DOOR, RR,60 IN, CTR SLIDING WOR
9T7 SALES PACKAGE, PLUMBING, HEATING, AND A/C
9T8 SALES PACKAGE, ELECTRICAL CONTRACTOR
9T9 SALES PACKAGE, GENERAL SERVICE CONTRACTOR
9U2 CYLINDER UNIT, CITY OF BOSTON/STATE OF TEXAS -
9U7 CYLINDER UNIT, HERTZ-PENSKE
9U9 CYLINDER UNIT, RYDER-COMMON KEYS
9V1 COLOR, BLACK
9V2 COLOR, ORANGE
9V4 COLOR, WHEATLAND YELLOW
9V5 COLOR, WOODLAND GREEN
9V9 COLOR, DOESKIN TAN
9W2 COLOR, POLAR WHITE
9W3 COLOR, WHEATLAND YELLOW, LEAD FREE
9W4 COLOR, TANGIER ORANGE, LEAD FREE
9W7 HEADLAMPS, ON-WARNING SYSTEM
9X5 TRIM OVERRIDE, CLOTH
90A STRIPE COLOR, ACCENT, TWO TONE, GOLD/DK AUBURN (91)
90C TRIM COMBINATION, CLOTH, MED SMOKE GRAY (C) (91)
90E TRIM COMBINATION, CLOTH, MED SMOKE GRAY (E) (91)
90I INTERIOR TRIM, MED SMOKE GRAY (91)
90L SECONDARY COLOR, EXTERIOR, GRAY MET (91)
90U PRIMARY COLOR, EXTERIOR, GRAY MET (91)
90V TRIM COMBINATION, VINYL , MED SMOKE GRAY (91)
903 TRIM COMBINATION, LEATHER, MED SMOKE GRAY (3) (91)
909 SEAT BELT COLOR, MED SMOKE GRAY (91)
91L SECONDARY COLOR, EXTERIOR, DK POLO GREEN MET (91)
91Q MOLDING COLOR, DK POLO GREEN MET (91)
91T TOP COLOR, DK POLO GREEN MET (91)
91U PRIMARY COLOR, EXTERIOR, DK POLO GREEN MET (91)
92U PRIMARY COLOR, EXTERIOR, DAWN GRAY MET (91)
93Q MOLDING COLOR, WHITE DIAMOND (91)
93U PRIMARY COLOR, EXTERIOR, WHITE DIAMOND (91)
94B TRIM COMBINATION, CLOTH, LT QUARTZ (B)
94C TRIM COMBINATION, CLOTH, LT QUARTZ (C)
94L SECONDARY COLOR, EXTERIOR, BLUE RED MET (91)
94U PRIMARY COLOR, EXTERIOR, BLUE RED MET (91)
942 TRIM COMBINATION, LEATHER, LT QUARTZ (2)
943 TRIM COMBINATION, LEATHER, LT QUARTZ (3)
95L SECONDARY COLOR, EXTERIOR, LT ANTELOPE FM (91)
95O MOLDING COLOR, LT ANTELOPE FM (91)
95T TOP COLOR, LT ANTELOPE FM (91)
95U PRIMARY COLOR EXTERIOR, LT ANTELOPE FM (91)
96L SECONDARY COLOR, EXTERIOR, DK SMOKE GRAY MET (91 )
96T TOP COLOR, DK DRIFTWOOD MET (92)
96U PRIMARY COLOR, EXTERIOR, ULTRA SILVER MET (91)
97A STRIPE COLOR, ACCENT, TWO TONE, WARM GRAY MET/DK
97K AUX TOP COLOR, DK GRAY (91)
97L SECONDARY COLOR, EXTERIOR, DK GRAY MET (91)
97U PRIMARY COLOR, EXTERIOR, DK GRAY MET (91)
98K AUX TOP COLOR, BLACK SAPPHIRE (91)
98L SECONDARY COLOR, EXTERIOR, VERY DK SAPPHIRE MET
98U PRIMARY COLOR, EXTERIOR, ULTRA BLUE MET (91)
99A STRIPE COLOR, ACCENT, DK SLATE GRAY (91)
99B TRIM COMBINATION, CLOTH, BLK CHERRY (B)
99C TRIM COMBINATION, CLOTH, BLK CHERRY (C)
99D TRIM COMBINATION, CLOTH, BLK CHERRY (D)
99E TRIM COMBINATION, CLOTH, BLK CHERRY (E)
99G TRIM COMBINATION, CLOTH, BLK CHERRY (G)
99H TRIM COMBINATIDN, CLOTH, BLK CHERRY (H)
99I INTERIOR TRIM, BLK CHERRY (I)
99L SECONDARY COLOR, EXTERIOR , DK SLATE MET (91 )
99Q MOLDING COLOR, DK SLATE GRAY MET (91)
99T TOP COLOR, DK SLATE GRAY MET (91)
99U PRIMARY COLOR, EXTERIOR, DK SLATE MET (91)
992 TRIM COMBINATION, LEATHER, BLK CHERRY (2)
993 TRIM COMBINATION, LEATHER, BLK CHERRY (3)Lightning Rods repair service:CLICK HERE
